Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The generic cputime_to_nsecs function first converts the cputime
to micro-seconds and then multiplies the result with 1000. This
looses some bits of accuracy, provide our own version of
cputime_to_nsecs that does not loose precision.
The cputime_t type is a thing of the past, replace the last occurences
of the type in the s390 code with a simple u64.
Since the core doesn't deal with cputime_t anymore, most of these APIs
have been left unused. Lets remove these.
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Wanpeng Li <wanpeng.li@hotmail.com>
Link: http://lkml.kernel.org/r/1485832191-26889-34-git-send-email-fweisbec@gmail.com
This way we don't need to deal with cputime_t details from the core code.
Link: http://lkml.kernel.org/r/1485832191-26889-32-git-send-email-fweisbec@gmail.com
Remove the 31 bit support in order to reduce maintenance cost and
effectively remove dead code. Since a couple of years there is no
distribution left that comes with a 31 bit kernel.
The 31 bit kernel also has been broken since more than a year before
anybody noticed. In addition I added a removal warning to the kernel
shown at ipl for 5 minutes: a960062e5826 ("s390: add 31 bit warning
message") which let everybody know about the plan to remove 31 bit
code. We didn't get any response.
Given that the last 31 bit only machine was introduced in 1999 let's
remove the code.
Anybody with 31 bit user space code can still use the compat mode.
git commit 8461b63ca01d125a245a0d0fb4821ea0656e5053
"s390: translate cputime magic constants to macros"
introduce a built error for 31-bit:
kernel/built-in.o: In function `posix_cpu_timer_set':
posix-cpu-timers.c:(.text+0x2a8cc): undefined reference to `__udivdi3'
The original code is actually broken for 31-bit and has been
corrected by the above commit by forcing the compiler to use
64-bit arithmetic through the CPUTIME_PER_USEC define.
To fix the compile error replace the 64-bit division with
a call to __div().
Make the code more self-explanatory by naming magic constants.
Cc: Wu Fengguang <fengguang.wu@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"This patch set contains the main portion of the changes for 3.18 in
regard to the s390 architecture. It is a bit bigger than usual,
mainly because of a new driver and the vector extension patches.
The interesting bits are:
- Quite a bit of work on the tracing front. Uprobes is enabled and
the ftrace code is reworked to get some of the lost performance
back if CONFIG_FTRACE is enabled.
- To improve boot time with CONFIG_DEBIG_PAGEALLOC, support for the
IPTE range facility is added.
- The rwlock code is re-factored to improve writer fairness and to be
able to use the interlocked-access instructions.
- The kernel part for the support of the vector extension is added.
- The device driver to access the CD/DVD on the HMC is added, this
will hopefully come in handy to improve the installation process.
- Add support for control-unit initiated reconfiguration.
- The crypto device driver is enhanced to enable the additional AP
domains and to allow the new crypto hardware to be used.
- Bug fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (39 commits)
s390/ftrace: simplify enabling/disabling of ftrace_graph_caller
s390/ftrace: remove 31 bit ftrace support
s390/kdump: add support for vector extension
s390/disassembler: add vector instructions
s390: add support for vector extension
s390/zcrypt: Toleration of new crypto hardware
s390/idle: consolidate idle functions and definitions
s390/nohz: use a per-cpu flag for arch_needs_cpu
s390/vtime: do not reset idle data on CPU hotplug
s390/dasd: add support for control unit initiated reconfiguration
s390/dasd: fix infinite loop during format
s390/mm: make use of ipte range facility
s390/setup: correct 4-level kernel page table detection
s390/topology: call set_sched_topology early
s390/uprobes: architecture backend for uprobes
s390/uprobes: common library for kprobes and uprobes
s390/rwlock: use the interlocked-access facility 1 instructions
s390/rwlock: improve writer fairness
s390/rwlock: remove interrupt-enabling rwlock variant.
s390/mm: remove change bit override support
Move the C functions and definitions related to the idle state handling
to arch/s390/include/asm/idle.h and arch/s390/kernel/idle.c. The function
s390_get_idle_time is renamed to arch_cpu_idle_time and vtime_stop_cpu to
enabled_wait.
Move the nohz_delay bit from the s390_idle data structure to the
per-cpu flags. Clear the nohz delay flag in __cpu_disable and
remove the cpu hotplug notifier that used to do this.
On 32 bit systems cmpxchg cannot handle 64 bit values, so
some additional magic is required to allow a 32 bit system
with CONFIG_VIRT_CPU_ACCOUNTING_GEN=y enabled to build.
Make sure the correct cmpxchg function is used when doing
an atomic swap of a cputime_t.
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: umgwanakikbuti@gmail.com
Cc: fweisbec@gmail.com
Cc: srao@redhat.com
Cc: lwoodman@redhat.com
Cc: atheurer@redhat.com
Cc: oleg@redhat.com
Cc: linux390@de.ibm.com
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-s390@vger.kernel.org
Link: http://lkml.kernel.org/r/20140930155947.070cdb1f@annuminas.surriel.com
If the arch overrides some generic vtime APIs, let it describe
these on a dedicated and standalone header. This way it becomes
convenient to include it in vtime generic headers without irrelevant
stuff in such a low level header.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Li Zhong <zhong@linux.vnet.ibm.com>
Cc: Kevin Hilman <khilman@linaro.org>
On ia64 and powerpc, vtime context switch only consists
in flushing system and user pending time, plus a few
arch housekeeping.
Consolidate that into a generic implementation. s390 is
a special case because pending user and system time accounting
there is hard to dissociate. So it's keeping its own implementation.
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Move the code that finds out to which context we account the
cputime into generic layer.
Archs that consider the whole time spent in the idle task as idle
time (ia64, powerpc) can rely on the generic vtime_account()
and implement vtime_account_system() and vtime_account_idle(),
letting the generic code to decide when to call which API.
Archs that have their own meaning of idle time, such as s390
that only considers the time spent in CPU low power mode as idle
time, can just override vtime_account().
The current virtual timer interface is inherently per-cpu and hard to
use. The sole user of the interface is appldata which uses it to execute
a function after a specific amount of cputime has been used over all cpus.
Rework the virtual timer interface to hook into the cputime accounting.
This makes the interface independent from the CPU timer interrupts, and
makes the virtual timers global as opposed to per-cpu.
Overall the code is greatly simplified. The downside is that the accuracy
is not as good as the original implementation, but it is still good enough
for appldata.
Reviewed-by: Jan Glauber <jang@linux.vnet.ibm.com>
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Remove the file name from the comment at top of many files. In most
cases the file name was wrong anyway, so it's rather pointless.
Also unify the IBM copyright statement. We did have a lot of sightly
different statements and wanted to change them one after another
whenever a file gets touched. However that never happened. Instead
people start to take the old/"wrong" statements to use as a template
for new files.
So unify all of them in one go.
Avoid padding in the middle and the end of the data structure by
moving nohz_delay member to the beginning.
Saves eight byte per cpu.
Replace __s390x__ with CONFIG_64BIT in all places that are not exported
to userspace or guarded with #ifdef __KERNEL__.
Whenever the cpu loads an enabled wait PSW it will appear as idle to the
underlying host system. The code in default_idle calls vtime_stop_cpu
which does the necessary voodoo to get the cpu time accounting right.
The udelay code just loads an enabled wait PSW. To correct this rework
the vtime_stop_cpu/vtime_start_cpu logic and move the difficult parts
to entry[64].S, vtime_stop_cpu can now be called from anywhere and
vtime_start_cpu is gone. The correction of the cpu time during wakeup
from an enabled wait PSW is done with a critical section in entry[64].S.
As vtime_start_cpu is gone, s390_idle_check can be removed as well.
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits)
sched/tracing: Add a new tracepoint for sleeptime
sched: Disable scheduler warnings during oopses
sched: Fix cgroup movement of waking process
sched: Fix cgroup movement of newly created process
sched: Fix cgroup movement of forking process
sched: Remove cfs bandwidth period check in tg_set_cfs_period()
sched: Fix load-balance lock-breaking
sched: Replace all_pinned with a generic flags field
sched: Only queue remote wakeups when crossing cache boundaries
sched: Add missing rcu_dereference() around ->real_parent usage
[S390] fix cputime overflow in uptime_proc_show
[S390] cputime: add sparse checking and cleanup
sched: Mark parent and real_parent as __rcu
sched, nohz: Fix missing RCU read lock
sched, nohz: Set the NOHZ_BALANCE_KICK flag for idle load balancer
sched, nohz: Fix the idle cpu check in nohz_idle_balance
sched: Use jump_labels for sched_feat
sched/accounting: Fix parameter passing in task_group_account_field
sched/accounting: Fix user/system tick double accounting
sched/accounting: Re-use scheduler statistics for the root cgroup
Fix up conflicts in
- arch/ia64/include/asm/cputime.h, include/asm-generic/cputime.h
usecs_to_cputime64() vs the sparse cleanups
- kernel/sched/fair.c, kernel/time/tick-sched.c
scheduler changes in multiple branches
Commit 2a95ea6c0d129b4 ("procfs: do not overflow get_{idle,iowait}_time
for nohz") did not take into account that one some architectures jiffies
and cputime use different units.
This causes get_idle_time() to return numbers in the wrong units, making
the idle time fields in /proc/stat wrong.
Instead of converting the usec value returned by
get_cpu_{idle,iowait}_time_us to units of jiffies, use the new function
usecs_to_cputime64 to convert it to the correct unit of cputime64_t.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: "Artem S. Tashkinov" <t.artem@mailcity.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Make cputime_t and cputime64_t nocast to enable sparse checking to
detect incorrect use of cputime. Drop the cputime macros for simple
scalar operations. The conversion macros are still needed.
arch_needs_cpu() gets always executed on the current cpu. Therefore
the cpu parameter can be ignored it is possible to use __get_cpu_var()
instead of per_cpu() to access the per_cpu variable, which will
generate better code.
The taskstats interface uses microsecond granularity for the user and
system time values. The conversion from cputime to the taskstats values
uses the cputime_to_msecs primitive which effectively limits the
granularity to milliseconds. Add the cputime_to_usecs primitive for
architectures that have better, more precise CPU time values. Remove
cputime_to_msecs primitive because there are no more users left.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Luck Tony <tony.luck@intel.com>
Cc: Shailabh Nagar <nagar1234@in.ibm.com>
Cc: Shailabh Nagar <nagar@us.ibm.com>
A machine check can interrupt the i/o and external interrupt handler
anytime. If the machine check occurs while the interrupt handler is
waking up from idle vtime_start_cpu can get executed a second time
and the int_clock / async_enter_timer values in the lowcore get
clobbered. This can confuse the cpu time accounting.
To fix this problem two changes are needed. First the machine check
handler has to use its own copies of int_clock and async_enter_timer,
named mcck_clock and mcck_enter_timer. Second the nested execution
of vtime_start_cpu has to be prevented. This is done in s390_idle_check
by checking the wait bit in the program status word.
* 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
timers, init: Limit the number of per cpu calibration bootup messages
posix-cpu-timers: optimize and document timer_create callback
clockevents: Add missing include to pacify sparse
x86: vmiclock: Fix printk format
x86: Fix printk format due to variable type change
sparc: fix printk for change of variable type
clocksource/events: Fix fallout of generic code changes
nohz: Allow 32-bit machines to sleep for more than 2.15 seconds
nohz: Track last do_timer() cpu
nohz: Prevent clocksource wrapping during idle
nohz: Type cast printk argument
mips: Use generic mult/shift factor calculation for clocks
clocksource: Provide a generic mult/shift factor calculation
clockevents: Use u32 for mult and shift factors
nohz: Introduce arch_needs_cpu
nohz: Reuse ktime in sub-functions of tick_check_idle.
time: Remove xtime_cache
time: Implement logarithmic time accumulation
Allow the architecture to request a normal jiffy tick when the system
goes idle and tick_nohz_stop_sched_tick is called . On s390 the hook is
used to prevent the system going fully idle if there has been an
interrupt other than a clock comparator interrupt since the last wakeup.
On s390 the HiperSockets response time for 1 connection ping-pong goes
down from 42 to 34 microseconds. The CPU cost decreases by 27%.
LKML-Reference: <20090929122533.402715150@de.ibm.com>
The cputime_to_msecs / cputime_to_clock_t and cputime64_to_clock_t
cause fixpoint divide exceptions if the cputime is too large.
On a machine that collected 49.7 days worth of idle time reading
from /proc/stat will generate oopses like this:
Kernel BUG at 001b0c92 [verbose debug info unavailable]
fixpoint divide exception: 0009 [#13] SMP
Modules linked in: ipv6
CPU: 1 Tainted: G D 2.6.27.10 #5
Process cat (pid: 21352, task: 1fb34138, ksp: 1d2a3d98)
Krnl PSW : 070c2000 801b0c92 (show_stat+0x2ca/0x68c)
R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:0 CC:2 PM:0
Krnl GPRS: 00000001 00001388 00000bb8 0015d2a1
00000000 00000000 000003e8 0001fd91
00000000 00000000 0000129d eecd2ff0
1cc533b9 0036f780 801b0bce 1d2a3cc0
Krnl Code: 801b0c86: f18890abf198 mvo 171(9,%r9),408(9,%r15)
801b0c8c: 98abf170 lm %r10,%r11,368(%r15)
801b0c90: 1da1 dr %r10,%r1
>801b0c92: 90abf170 stm %r10,%r11,368(%r15)
801b0c96: 98abf190 lm %r10,%r11,400(%r15)
801b0c9a: 1da1 dr %r10,%r1
801b0c9c: 90abf190 stm %r10,%r11,400(%r15)
801b0ca0: 18a3 lr %r10,%r3
Call Trace:
([<00000000001b09f4>] show_stat+0x2c/0x68c)
[<000000000018dcee>] seq_read+0xb2/0x364
[<00000000001a9980>] proc_reg_read+0x68/0x98
[<00000000001705ee>] vfs_read+0x6e/0xe8
[<0000000000170732>] sys_read+0x36/0x78
[<000000000010f750>] sysc_do_restart+0x12/0x16
[<0000000077f3ad6a>] 0x77f3ad6a
<4>---[ end trace 1436ea9559d3de9e ]---
Reported-by: Mike Frysinger <vapier@gentoo.org>
For powerpc with CONFIG_VIRT_CPU_ACCOUNTING
jiffies_to_cputime(1) is not compile time constant and run time
calculations are quite expensive. To optimize we use
precomputed value. For all other architectures is is
preprocessor definition.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <1248862529-6063-5-git-send-email-sgruszka@redhat.com>
Replace the spinlock used in the idle time accounting with a sequence
counter mechanism analog to seqlock.
All definition in cpu.h have to do with cputime accounting. Move
them to cputime.h and remove the header file.
The cpu idle field in the output of /proc/stat is too small for cpus
that have been idle for more than a tick. Add the architecture hook
arch_idle_time that allows to add the not accounted idle time of a
sleeping cpu without waking the cpu.
The s390 implementation of arch_idle_time uses the already existing
s390_idle_data per_cpu variable to find the sleep time of a neighboring
idle cpu.
commit aa5e97ce4bbc9d5daeec16b1d15bb3f6b7b4f4d4
[PATCH] improve precision of process accounting.
Introduced a timing regression:
-bash-3.2# time ls
real 0m0.006s
user 0m1.754s
sys 0m1.094s
The problem was introduced by an error in cputime_to_timeval.
Cputime is now 1/4096 microsecond, therefore, we have to divide
the remainder with 4096 to get the microseconds.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
The unit of the cputime accouting values that are stored per process is
currently a microsecond. The CPU timer has a maximum granularity of
2**-12 microseconds. There is no benefit in storing the per process values
in the lesser precision and there is the disadvantage that the backend
has to do the rounding to microseconds. The better solution is to use
the maximum granularity of the CPU timer as cputime unit.
