The cpu measurement alerts that are used for instance by oprofile
for hardware sampling are not turned off on a cpu that is going
offline. Add the appropriate control register bit that should be
disabled to the list.
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
The bit shift operation in smp_ctl_set_bit does not specify the type
of the shifted bit so integer is used as default. Therefore it is not
possible to set bits in the upper 32 bit of the control register if
the kernel runs in 64 bit mode. Fix this by specifying the type as
unsigned long.
Merge irq.c and s390_ext.c into irq.c. That way all external interrupt
related functions are together.
When disabling a cpu all external interrupt subclass masks in control
register 0 get cleared. However instead of the service signal subclass
mask bit an unused bit got cleared.
Accidently (or luckily) the service subclass mask gets cleared with the
pfault_fini() call that happens just before the rest of the subclass
mask bits get cleared.
Adapt new API.
Add missing __noreturn attribute to cpu_die():
arch/s390/kernel/smp.c:691:6: error: symbol 'cpu_die' redeclared with different type
For future rework of try_to_wake_up() we'd like to push part of that
function onto the CPU the task is actually going to run on.
In order to do so we need a generic callback from the existing scheduler IPI.
This patch introduces such a generic callback: scheduler_ipi() and
implements it as a NOP.
BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions!
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Reviewed-by: Frank Rowand <frank.rowand@am.sony.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
Get rid of messages that indicate if a cpu went online or offline.
There is nothing special about this anymore and these messages might
flood the kernel log buffer which makes debugging harder since more
important messages might be overwritten.
Call init_idle() which (re-)initializes the idle task structure before
it gets used on a new cpu.
That way we can also get rid of the odd preempt_enable_no_resched()
call we have in the cpu offline path within cpu_idle(). That call
prevented preempt count imbalances between cpu hotplug operations.
Delay idle task creation until a cpu gets set online instead of
creating them for all possible cpus at system startup.
For one cpu system this should safe more than 1 MB.
On my debug system with lots of debug stuff enabled this saves 2 MB.
Same as on x86.
Up to now /proc/interrupts only has statistics for external and i/o
interrupts but doesn't split up them any further.
This patch adds a line for every single interrupt source so that it
is possible to easier tell what the machine is/was doing.
Part of the output now looks like this;
CPU0 CPU2 CPU4
EXT: 3898 4232 2305
I/O: 782 315 245
CLK: 1029 1964 727 [EXT] Clock Comparator
IPI: 2868 2267 1577 [EXT] Signal Processor
TMR: 0 0 0 [EXT] CPU Timer
TAL: 0 0 0 [EXT] Timing Alert
PFL: 0 0 0 [EXT] Pseudo Page Fault
NMI: 0 1 1 [NMI] Machine Checks
Store the facility list once at system startup with stfl/stfle and
reuse the result for all facility tests.
Read external interrupts parameters from the lowcore in the first
level interrupt handler in entry[64].S.
The tlb flushing code uses the mm_users field of the mm_struct to
decide if each page table entry needs to be flushed individually with
IPTE or if a global flush for the mm_struct is sufficient after all page
table updates have been done. The comment for mm_users says "How many
users with user space?" but the /proc code increases mm_users after it
found the process structure by pid without creating a new user process.
Which makes mm_users useless for the decision between the two tlb
flusing methods. The current code can be confused to not flush tlb
entries by a concurrent access to /proc files if e.g. a fork is in
progres. The solution for this problem is to make the tlb flushing
logic independent from the mm_users field.
By the previous modification, the cpu notifier can return encapsulate
errno value. This converts the cpu notifiers for s390.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
To save the registers for all CPUs a sigp "store status" is done that
stores the registers to address absolute zero. To access storage at
absolute zero, normally the address of the prefix register of the
accessing CPU has to be used. This does not work when large pages are
active (currently only under LPAR). In order to fix that problem,
instead of memcpy memcpy_real is used, which switches to real mode
where prefixing works.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
In linux-next "sysdev: Pass attribute in sysdev_class attributes show/store"
forgot to convert one place in s390 code. Here is the missing part.
Passing the attribute to the low level IO functions allows all kinds
of cleanups, by sharing low level IO code without requiring
an own function for every piece of data.
Also drivers can extend the attributes with own data fields
and use that in the low level function.
Similar to sysdev_attributes and normal attributes.
This is a tree-wide sweep, converting everything in one go.
No functional changes in this patch other than passing the new
argument everywhere.
Tested on x86, the non x86 parts are uncompiled.
Use asm offsets to make sure the offset defines to struct _lowcore and
its layout don't get out of sync.
Also add a BUILD_BUG_ON() which checks that the size of the structure
is sane.
And while being at it change those sites which use odd casts to access
the current lowcore. These should use S390_lowcore instead.
Rename signal_processor* functions to sigp*.
Add raw variants of each version, so we can get rid of the hacks played
in smp code which establish temporary cpu logical mappings so they could
call the sigp functions.
Always reboot on logical cpu 0. This makes sure that the IPL cpu is
always the same and usually avoids strange numbering schemes between
physical and logical cpus.
Remove support to be able to dump 31 bit systems with a 64 bit dumper.
This is mostly useless since no distro ships 31 bit kernels together
We also get rid of a bit of hacky code.
Finally move it to the place where it belongs to and make get rid of
it for !CONFIG_SMP.
smp_processor_id() is supposed to work before setup_arch() gets called.
Before that smp_processor_id() may return just an arbitrary value that
is contained in the uninitialized boot lowcore.
So provide the arch function which will override the weak function in
init/main.c.
sigp sense only returns the status of a cpu if it is non zero. If the
status of the sensed cpu is all zeros condition code 0 (accpeted) is
set and no status bits are returned.
The current code however assumes that a status was returned and tests
bits in it. This means uninitalized data is accessed with random
results.
Worst case is that the code that checks if cpu is offline on cpu
hotplug assumes that the target cpu is offline while it is still
running. This leads potentially to memory corruption since resources
that are still needed by the target cpu will be freed and could be
resused while still in use.
According to the architecture a cpu must not necessarily enter stopped
state after completion of a sigp instruction with "stop" order code.
So remove the BUG() statement after self sending sigp stop to avoid
that it ever gets reached.
Also add a sigp busy check to make sure that the order gets delivered.
Offlined cpus still have valid prefix register contents. Dumpers
will store the register contents of a cpu to the location where its
prefix register points to.
For offlined cpus the area (lowcore) has been freed and the dumper
would write the uninteresting contents of the offline cpu to a memory
location which might be in use by some other component and destroy
valueable information.
To fix this set the prefix register of offline cpus to absolute
address zero again. This prevents the current dumpers to write to
random memory locations.
We're weaning the core code off handing cpumask's around on-stack.
This introduces arch_send_call_function_ipi_mask().
Currently, when the physical resume CPU is not equal to the physical suspend
CPU, we swap the CPUs logically, by modifying the logical/physical CPU mapping.
This has two major drawbacks: First the change is visible from user space (e.g.
CPU sysfs files) and second it is hard to ensure that nowhere in the kernel
the physical CPU ID is stored before suspend.
To fix this, we now really swap the physical CPUs, if the resume CPU is not
the pysical suspend CPU. We restart the suspend CPU and stop the resume CPU
using SIGP restart and SIGP stop. If the suspend CPU is no longer available,
we write a message and load a disabled wait PSW.
Signed-off-by: Michael Holzheu <michael.holzheu@linux.vnet.ibm.com>
Removes a couple of simple code duplications. But before I have to do
this again, just simplify it.
smp_cpu_not_running() and cpu_stopped() are doing the same.
Remove one and also get rid of the last hard_smp_processor_id() leftover.
Saves us more than 65k pointless IPIs.
vdso per cpu area allocation in smp_prepare_cpus() happens with GFP_KERNEL
but irqs disabled. Triggers this one:
Badness at kernel/lockdep.c:2280
Modules linked in:
CPU: 0 Not tainted 2.6.30 #2
Process swapper (pid: 1, task: 000000003fe88000, ksp: 000000003fe87eb8)
Krnl PSW : 0400c00180000000 0000000000083360 (lockdep_trace_alloc+0xec/0xf8)
Call Trace:
([<00000000000832b6>] lockdep_trace_alloc+0x42/0xf8)
[<00000000000b1880>] __alloc_pages_internal+0x3e8/0x5c4
[<00000000000b1b4a>] __get_free_pages+0x3a/0xb0
[<0000000000026546>] vdso_alloc_per_cpu+0x6a/0x18c
[<00000000005eff82>] smp_prepare_cpus+0x322/0x594
[<00000000005e8232>] kernel_init+0x76/0x398
[<000000000001bb1e>] kernel_thread_starter+0x6/0xc
[<000000000001bb18>] kernel_thread_starter+0x0/0xc
Fix this by moving the allocation out of the irqs disabled section.
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Replace the spinlock used in the idle time accounting with a sequence
counter mechanism analog to seqlock.
This patch introduces the hibernation backend support to the
s390 architecture. Now it is possible to suspend a mainframe Linux
guest using the following command:
echo disk > /sys/power/state
Signed-off-by: Hans-Joachim Picht <hans@linux.vnet.ibm.com>
Dynamic ftrace support for s390.
All definition in cpu.h have to do with cputime accounting. Move
them to cputime.h and remove the header file.
The cpu_possible_map by default is initialized with all ones in s390.
If the kernel paramert possible_cpus=<x> is passed the cpu_possible_map
is supposed to have x bits set.
However the current code just sets the x bits without clearing the NR_CPUS
bits that were already set. So we end up with an unchanged map that has
all bits set.
To fix this just clear the map before setting any new bits.
This broke with def6cfb70bab83c0094bc0cedd27c4eda563043e
"[S390] cpumask: Use accessors code."
Currently the storage of the machine flags is a globally exported unsigned
long long variable. By moving the storage location into the lowcore struct we
allow assembler code to check machine_flags directly even without needing a
register. Addtionally the lowcore and therefore the machine flags too will be
in cache most of the time.
Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
Impact: use new API
Use the accessors rather than frobbing bits directly. Most of this is
in arch code I haven't even compiled, but is straightforward.
Signed-off-by: Mike Travis <travis@sgi.com>
Impact: cleanup, futureproof
In fact, all cpumask ops will only be valid (in general) for bit
numbers < nr_cpu_ids. So use that instead of NR_CPUS in various
places (I also updated the immediate sites to use the new cpumask_
operators).
This is always safe: no cpu number can be >= nr_cpu_ids, and
nr_cpu_ids is initialized to NR_CPUS at boot.
Performing an initial cpu reset makes sure all registers and tlbs of
the targeted cpu are initialized and flushed.
If sigp_set_prefix fails on __cpu_up we leak the lowcore structures
and async+panic stacks for the failed cpu.
The zcore code switches to real addressing mode when creating a kernel dump.
This is not possible, if it is built as a kernel module. With this patch
zcore (zfcpdump) can't be built as a kernel module any more.
With lockdep we got the following trace after a panic:
Badness at /home/autobuild/BUILD/linux-2.6.28-20090204/kernel/lockdep.c:2878
Call Trace:
[<0000000000176334>] lock_acquire+0x54/0xbc
[<000000000050b4fe>] __atomic_notifier_call_chain+0x6e/0xdc
[<000000000050b59c>] atomic_notifier_call_chain+0x30/0x44
[<0000000000504274>] panic+0xd0/0x1e8
INFO: lockdep is turned off.
Last Breaking-Event-Address:
[<0000000000170e62>] check_flags+0xae/0x15c
possible reason: unannotated irqs-off.
lockdep is right. We missed a trace_hardirq_off in our smp_send_stop
function and smp_send_stop is called before the panic call chain.
Reported-by: Mijo <Safradin mijo@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Provide new shutdown action "dump_reipl" for automatic ipl after dump.
Signed-off-by: Frank Munzert <munzert@de.ibm.com>
!CONFIG_SMP:
arch/s390/kernel/vdso.c: In function 'vdso_init':
arch/s390/kernel/vdso.c:325: error: incompatible type for argument 2 of 'vdso_alloc_per_cpu'
Also move the code out of the BUG_ON statement since it won't be
executed on !CONFIG_BUG. And that would be a bug.
