path: root/arch/s390/kvm/diag.c
2010-02-26[S390] Replace ENOTSUPP usage with EOPNOTSUPPHeiko Carstens
ENOTSUPP is not supposed to leak to userspace so lets just use EOPNOTSUPP everywhere. Doesn't fix a bug, but makes future reviews easier. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-01-09[S390] Use unsigned long long for u64 on 64bit.Heiko Carstens
As requested by Andrew. Same as what sparc did. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-06-06KVM: s390: use yield instead of schedule to implement diag 0x44Christian Borntraeger
diag 0x44 is the common way on s390 to yield the cpu to the hypervisor. It is called by the guest in cpu_relax and in the spinlock code to yield to other guest cpus. This semantic is similar to yield. Lets replace the call to schedule with yield to make sure that current is really yielding. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: s390: intercepts for diagnose instructionsChristian Borntraeger
This patch introduces interpretation of some diagnose instruction intercepts. Diagnose is our classic architected way of doing a hypercall. This patch features the following diagnose codes: - vm storage size, that tells the guest about its memory layout - time slice end, which is used by the guest to indicate that it waits for a lock and thus cannot use up its time slice in a useful way - ipl functions, which a guest can use to reset and reboot itself In order to implement ipl functions, we also introduce an exit reason that causes userspace to perform various resets on the virtual machine. All resets are described in the principles of operation book, except KVM_S390_RESET_IPL which causes a reboot of the machine. Acked-by: Martin Schwidefsky <martin.schwidefsky@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
