The diagnose 500 subcode 3 contains the 32 bit subchannel id in bits 32-63
(counting from the left). As for other I/O instructions, bits 0-31 should be
ignored and thus not be passed to kvm_io_bus_write_cookie().
This fixes a bug where the guest passed non-zero bits 0-31 which the
host tried to interpret, leading to ioeventfd notification failures.
Cc: stable@vger.kernel.org
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
The diagnose code to be used is the contents of the base register (if not
zero), plus the displacement. The current code ignores the base register
contents. So let's fix that...
The kvm->srcu lock has to be held while accessing the memory of
guests and during certain other actions. This patch now adds
the locks to the __vcpu_run function so that all affected code
is protected now (and additionally to the KVM_S390_STORE_STATUS
ioctl, which can be called out-of-band and needs a separate lock).
Signed-off-by: Thomas Huth <thuth@linux.vnet.ibm.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Make use of cookies for the virtio ccw notification hypercall to speed up
lookup of devices on the io bus.
[Small fix to a comment. - Paolo]
DIAGNOSE is a privileged instruction and thus we must make sure that we are
in supervisor mode before taking any other actions.
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Enable ioeventfd support on s390 and hook up diagnose 500 virtio-ccw
notifications.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Introduce a new trace system, kvm-s390, for some kvm/s390 specific
trace points:
- injection of interrupts
- delivery of interrupts to the guest
- creation/destruction of kvm machines and vcpus
- stop actions for vcpus
- reset requests for userspace
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Add trace events for several s390 architecture specifics:
- SIE entry/exit
- common intercepts
- common instructions (sigp/diagnose)
Remove the file name from the comment at top of many files. In most
cases the file name was wrong anyway, so it's rather pointless.
Also unify the IBM copyright statement. We did have a lot of sightly
different statements and wanted to change them one after another
whenever a file gets touched. However that never happened. Instead
people start to take the old/"wrong" statements to use as a template
for new files.
So unify all of them in one go.
Lets replace the old open coded version of diag 0x44 (which relied on
compat_sched_yield) with kvm_vcpu_on_spin.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
This patch implements the directed yield hypercall found on other
System z hypervisors. It delegates execution time to the virtual cpu
specified in the instruction's parameter.
Useful to avoid long spinlock waits in the guest.
Christian Borntraeger: moved common code in virt/kvm/
Signed-off-by: Konstantin Weitz <WEITZKON@de.ibm.com>
This patch adds the general purpose registers to the kvm_run structure.
CPUSTAT_RUNNING was implemented signifying that a vcpu is not stopped.
This is not, however, what the architecture says: RUNNING should be
set when the host is acting on the behalf of the guest operating
system.
CPUSTAT_RUNNING has been changed to be set in kvm_arch_vcpu_load()
and to be unset in kvm_arch_vcpu_put().
For signifying stopped state of a vcpu, a host-controlled bit has
been used and is set/unset basically on the reverse as the old
CPUSTAT_RUNNING bit (including pushing it down into stop handling
proper in handle_stop()).
Cc: stable@kernel.org
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Linux on System z uses a ballooner based on diagnose 0x10. (aka as
collaborative memory management). This patch implements diagnose
0x10 on the guest address space.
ENOTSUPP is not supposed to leak to userspace so lets just use
EOPNOTSUPP everywhere.
Doesn't fix a bug, but makes future reviews easier.
As requested by Andrew. Same as what sparc did.
diag 0x44 is the common way on s390 to yield the cpu to the hypervisor.
It is called by the guest in cpu_relax and in the spinlock code to
yield to other guest cpus.
This semantic is similar to yield. Lets replace the call to schedule with
yield to make sure that current is really yielding.
Signed-off-by: Avi Kivity <avi@qumranet.com>
This patch introduces interpretation of some diagnose instruction intercepts.
Diagnose is our classic architected way of doing a hypercall. This patch
features the following diagnose codes:
- vm storage size, that tells the guest about its memory layout
- time slice end, which is used by the guest to indicate that it waits
for a lock and thus cannot use up its time slice in a useful way
- ipl functions, which a guest can use to reset and reboot itself
In order to implement ipl functions, we also introduce an exit reason that
causes userspace to perform various resets on the virtual machine. All resets
are described in the principles of operation book, except KVM_S390_RESET_IPL
which causes a reboot of the machine.
Acked-by: Martin Schwidefsky <martin.schwidefsky@de.ibm.com>
