2.6.31-rc introduced an architecture level set checker based on facility
bits. e.g. if the kernel is compiled to run only on z9, several facility
bits are checked very early and the kernel refuses to boot if a z9 specific
facility is missing.
Until now kvm on s390 did not implement the store facility extended (STFLE)
instruction. A 2.6.31-rc kernel that was compiled for z9 or higher did not
boot in kvm. This patch implements stfle.
This patch should go in before 2.6.31.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Adds more checking in case lockdep is turned on.
This check verifies that the guest we're trying to run in KVM_RUN
has some memory assigned to it. It enters an endless exception
loop if this is not the case.
Reported-by: Mijo Safradin <mijo@linux.vnet.ibm.com>
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Signed-off-by: Christian Ehrhardt <ehrhardt@de.ibm.com>
This patch makes sure we do unlink a vcpu's sie control block
from the system control area in kvm_arch_vcpu_destroy. This
prevents illegal accesses to the sie control block from other
virtual cpus after free.
The floating interrupt lock is only taken in process context. We can
replace all spin_lock_bh with standard spin_lock calls.
This patch reworks the s390 clock comparator wakeup to hrtimer. The clock
comparator is a per-cpu value that is compared against the TOD clock. If
ckc <= TOD an external interrupt 1004 is triggered. Since the clock comparator
and the TOD clock have a much higher resolution than jiffies we should use
hrtimers to trigger the wakeup. This speeds up guest nanosleep for small
values.
Since hrtimers callbacks run in hard-irq context, I added a tasklet to do
the actual work with enabled interrupts.
This patch fixes an incorrectness in the kvm backend for s390.
In case virtual cpus are being created before the corresponding
memory slot is being registered, we need to update the sie
control blocks for the virtual cpus.
*updates in v3*
In consideration of the s390 memslot constraints locking was changed
to trylock. These locks should never be held, as vcpu's can't run without
the single memslot we just assign when running this code. To ensure this
never deadlocks in case other code changes the code uses trylocks and bail
out if it can't get all locks.
Additionally most of the discussed special conditions for s390 like
only one memslot and no user_alloc are now checked for validity in
kvm_arch_set_memory_region.
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (81 commits)
[S390] remove duplicated #includes
[S390] cpumask: use mm_cpumask() wrapper
[S390] cpumask: Use accessors code.
[S390] cpumask: prepare for iterators to only go to nr_cpu_ids/nr_cpumask_bits.
[S390] cpumask: remove cpu_coregroup_map
[S390] fix clock comparator save area usage
[S390] Add hwcap flag for the etf3 enhancement facility
[S390] Ensure that ipl panic notifier is called late.
[S390] fix dfp elf hwcap/facility bit detection
[S390] smp: perform initial cpu reset before starting a cpu
[S390] smp: fix memory leak on __cpu_up
[S390] ipl: Improve checking logic and remove switch defaults.
[S390] s390dbf: Remove needless check for NULL pointer.
[S390] s390dbf: Remove redundant initilizations.
[S390] use kzfree()
[S390] BUG to BUG_ON changes
[S390] zfcpdump: Prevent zcore from beeing built as a kernel module.
[S390] Use csum_partial in checksum.h
[S390] cleanup lowcore.h
[S390] eliminate ipl_device from lowcore
Split machine check handler code and move it to cio and kernel code
where it belongs to. No functional change.
Currently we use the cpuid (via STIDP instruction) to recognize LPAR,
z/VM and KVM.
The architecture states, that bit 0-7 of STIDP returns all zero, and
if STIDP is executed in a virtual machine, the VM operating system
will replace bits 0-7 with FF.
KVM should not use FE to distinguish z/VM from KVM for interested
guests. The proper way to detect the hypervisor is the STSI (Store
System Information) instruction, which return information about the
hypervisors via function code 3, selector1=2, selector2=2.
This patch changes the detection routine of Linux to use STSI instead
of STIDP. This detection is earlier than bootmem, we have to use a
static buffer. Since STSI expects a 4kb block (4kb aligned) this
patch also changes the init.data alignment for s390. As this section
will be freed during boot, this should be no problem.
Patch is tested with LPAR, z/VM, KVM on LPAR, and KVM under z/VM.
This rips out the support for KVM_DEBUG_GUEST and introduces a new IOCTL
instead: KVM_SET_GUEST_DEBUG. The IOCTL payload consists of a generic
part, controlling the "main switch" and the single-step feature. The
arch specific part adds an x86 interface for intercepting both types of
debug exceptions separately and re-injecting them when the host was not
interested. Moveover, the foundation for guest debugging via debug
registers is layed.
To signal breakpoint events properly back to userland, an arch-specific
data block is now returned along KVM_EXIT_DEBUG. For x86, the arch block
contains the PC, the debug exception, and relevant debug registers to
tell debug events properly apart.
The availability of this new interface is signaled by
KVM_CAP_SET_GUEST_DEBUG. Empty stubs for not yet supported archs are
provided.
Note that both SVM and VTX are supported, but only the latter was tested
yet. Based on the experience with all those VTX corner case, I would be
fairly surprised if SVM will work out of the box.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
kvm_arch_sync_events is introduced to quiet down all other events may happen
contemporary with VM destroy process, like IRQ handler and work struct for
assigned device.
For kvm_arch_sync_events is called at the very beginning of kvm_destroy_vm(), so
the state of KVM here is legal and can provide a environment to quiet down other
events.
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
The s390 backend of kvm never calls kvm_vcpu_uninit. This causes
a memory leak of vcpu->run pages.
Lets call kvm_vcpu_uninit in kvm_arch_vcpu_destroy to free
the vcpu->run.
Acked-by: Carsten Otte <cotte@de.ibm.com>
Currently it is impossible to unload the kvm module on s390.
This patch fixes kvm_arch_destroy_vm to release all cpus.
This make it possible to unload the module.
In addition we stop messing with the module refcount in arch code.
Lets fix the name for the lctlg instruction...
Signed-off-by: Avi Kivity <avi@qumranet.com>
KVM_CAP_USER_MEMORY is used by s390, therefore, we should advertise it.
Flush the shadow mmu before removing regions to avoid stale entries.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
While doing some tests with our lcrash implementation I have seen a
naming conflict with prefix_info in kvm_host.h vs. addrconf.h
To avoid future conflicts lets rename private definitions in
asm/kvm_host.h by adding the kvm_s390 prefix.
Some machines do not accept 16EB as guest storage limit. Lets change the
default for the guest storage limit to a sane value. We also should set
the guest_origin to what userspace thinks it is. This allows guests
starting at an address != 0.
This patch fixes a memory leak, we want to free the physmem when destroying
the vm.
Obsoleted by the vmx-specific per-cpu list.
If the guest accesses non-existing memory, the sie64a function returns
-EFAULT. We must check the return value and send a program check to the
guest if the sie instruction faulted, otherwise the guest will loop at
the faulting code.
The current code delivers pending interrupts before it checks for
need_resched. On a busy host, this can lead to a longer interrupt
latency if the interrupt is injected while the process is scheduled
away. This patch moves delivering the interrupt _after_ schedule(),
which makes more sense.
The low-level interrupt handler on s390 checks for _TIF_WORK_INT and
exits the guest context, if work is pending.
TIF_WORK_INT is defined as_TIF_SIGPENDING | _TIF_NEED_RESCHED |
_TIF_MCCK_PENDING. Currently the sie loop checks for signals and
reschedule, but it does not check for machine checks. That means that
we exit the guest context if a machine check is pending, but we do not
handle the machine check.
CC: Heiko Carstens <heiko.carstens@de.ibm.com>
This patch fixes a bug with cpu bound guest on kvm-s390. Sometimes it
was impossible to deliver a signal to a spinning guest. We used
preemption as a circumvention. The preemption notifiers called
vcpu_load, which checked for pending signals and triggered a host
intercept. But even with preemption, a sigkill was not delivered
immediately.
This patch changes the low level host interrupt handler to check for the
SIE instruction, if TIF_WORK is set. In that case we change the
instruction pointer of the return PSW to rerun the vcpu_run loop. The kvm
code sees an intercept reason 0 if that happens. This patch adds accounting
for these types of intercept as well.
The advantages:
- works with and without preemption
- signals are delivered immediately
- much better host latencies without preemption
So userspace can save/restore the mpstate during migration.
[avi: export the #define constants describing the value]
[christian: add s390 stubs]
[avi: ditto for ia64]
kvm_arch_vcpu_ioctl_run currently incorrectly always returns 0.
This patch introduces interpretation of some diagnose instruction intercepts.
Diagnose is our classic architected way of doing a hypercall. This patch
features the following diagnose codes:
- vm storage size, that tells the guest about its memory layout
- time slice end, which is used by the guest to indicate that it waits
for a lock and thus cannot use up its time slice in a useful way
- ipl functions, which a guest can use to reset and reboot itself
In order to implement ipl functions, we also introduce an exit reason that
causes userspace to perform various resets on the virtual machine. All resets
are described in the principles of operation book, except KVM_S390_RESET_IPL
which causes a reboot of the machine.
Acked-by: Martin Schwidefsky <martin.schwidefsky@de.ibm.com>
This patch introduces in-kernel handling of _some_ sigp interprocessor
signals (similar to ipi).
kvm_s390_handle_sigp() decodes the sigp instruction and calls individual
handlers depending on the operation requested:
- sigp sense tries to retrieve information such as existence or running state
of the remote cpu
- sigp emergency sends an external interrupt to the remove cpu
- sigp stop stops a remove cpu
- sigp stop store status stops a remote cpu, and stores its entire internal
state to the cpus lowcore
- sigp set arch sets the architecture mode of the remote cpu. setting to
ESAME (s390x 64bit) is accepted, setting to ESA/S390 (s390, 31 or 24 bit) is
denied, all others are passed to userland
- sigp set prefix sets the prefix register of a remote cpu
For implementation of this, the stop intercept indication starts to get reused
on purpose: a set of action bits defines what to do once a cpu gets stopped:
ACTION_STOP_ON_STOP really stops the cpu when a stop intercept is recognized
ACTION_STORE_ON_STOP stores the cpu status to lowcore when a stop intercept is
recognized
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
This patch introduces in-kernel handling of some intercepts for privileged
instructions:
handle_set_prefix() sets the prefix register of the local cpu
handle_store_prefix() stores the content of the prefix register to memory
handle_store_cpu_address() stores the cpu number of the current cpu to memory
handle_skey() just decrements the instruction address and retries
handle_stsch() delivers condition code 3 "operation not supported"
handle_chsc() same here
handle_stfl() stores the facility list which contains the
capabilities of the cpu
handle_stidp() stores cpu type/model/revision and such
handle_stsi() stores information about the system topology
This patch contains the s390 interrupt subsystem (similar to in kernel apic)
including timer interrupts (similar to in-kernel-pit) and enabled wait
(similar to in kernel hlt).
In order to achieve that, this patch also introduces intercept handling
for instruction intercepts, and it implements load control instructions.
This patch introduces an ioctl KVM_S390_INTERRUPT which is valid for both
the vm file descriptors and the vcpu file descriptors. In case this ioctl is
issued against a vm file descriptor, the interrupt is considered floating.
Floating interrupts may be delivered to any virtual cpu in the configuration.
The following interrupts are supported:
SIGP STOP - interprocessor signal that stops a remote cpu
SIGP SET PREFIX - interprocessor signal that sets the prefix register of a
(stopped) remote cpu
INT EMERGENCY - interprocessor interrupt, usually used to signal need_reshed
and for smp_call_function() in the guest.
PROGRAM INT - exception during program execution such as page fault, illegal
instruction and friends
RESTART - interprocessor signal that starts a stopped cpu
INT VIRTIO - floating interrupt for virtio signalisation
INT SERVICE - floating interrupt for signalisations from the system
service processor
struct kvm_s390_interrupt, which is submitted as ioctl parameter when injecting
an interrupt, also carrys parameter data for interrupts along with the interrupt
type. Interrupts on s390 usually have a state that represents the current
operation, or identifies which device has caused the interruption on s390.
kvm_s390_handle_wait() does handle waitpsw in two flavors: in case of a
disabled wait (that is, disabled for interrupts), we exit to userspace. In case
of an enabled wait we set up a timer that equals the cpu clock comparator value
and sleep on a wait queue.
[christian: change virtio interrupt to 0x2603]
This path introduces handling of sie intercepts in three flavors: Intercepts
are either handled completely in-kernel by kvm_handle_sie_intercept(),
or passed to userspace with corresponding data in struct kvm_run in case
kvm_handle_sie_intercept() returns -ENOTSUPP.
In case of partial execution in kernel with the need of userspace support,
kvm_handle_sie_intercept() may choose to set up struct kvm_run and return
-EREMOTE.
The trivial intercept reasons are handled in this patch:
handle_noop() just does nothing for intercepts that don't require our support
at all
handle_stop() is called when a cpu enters stopped state, and it drops out to
userland after updating our vcpu state
handle_validity() faults in the cpu lowcore if needed, or passes the request
to userland
This patch contains the port of Qumranet's kvm kernel module to IBM zSeries
(aka s390x, mainframe) architecture. It uses the mainframe's virtualization
instruction SIE to run virtual machines with up to 64 virtual CPUs each.
This port is only usable on 64bit host kernels, and can only run 64bit guest
kernels. However, running 31bit applications in guest userspace is possible.
The following source files are introduced by this patch
arch/s390/kvm/kvm-s390.c similar to arch/x86/kvm/x86.c, this implements all
arch callbacks for kvm. __vcpu_run calls back into
sie64a to enter the guest machine context
arch/s390/kvm/sie64a.S assembler function sie64a, which enters guest
context via SIE, and switches world before and after that
include/asm-s390/kvm_host.h contains all vital data structures needed to run
virtual machines on the mainframe
include/asm-s390/kvm.h defines kvm_regs and friends for user access to
guest register content
arch/s390/kvm/gaccess.h functions similar to uaccess to access guest memory
arch/s390/kvm/kvm-s390.h header file for kvm-s390 internals, extended by
later patches
