commit 2b29a9fdcb92bfc6b6f4c412d71505869de61a56 upstream.
Any uaccess between guest_enter and guest_exit could trigger a page fault,
the page fault handler would handle it as a guest fault and translate a
user address as guest address.
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Return KVM_USER_MEM_SLOTS in kvm_dev_ioctl_check_extension().
Signed-off-by: Nick Wang <jfwang@us.ibm.com>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
To model the standby memory with memory_region_add_subregion
and friends, the guest would have one or more regions of ram.
Remove the check allowing only one memory slot and the check
requiring the real address of memory slot starts at zero.
kvm_s390_inject_program_int() and friends may fail if no memory is available.
This must be reported to the calling functions, so that this gets passed
down to user space which should fix the situation.
Alternatively we end up with guest state corruption.
So fix this and enforce return value checking by adding a __must_check
annotation to all of these function prototypes.
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Some memslot updates dont affect the gmap implementation,
e.g. setting/unsetting dirty tracking. Since a gmap update
will cause tlb flushes and segment table invalidations we
want to avoid that.
Enable ioeventfd support on s390 and hook up diagnose 500 virtio-ccw
notifications.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
This patch makes the parameter old a const pointer to the old memory
slot and adds a new parameter named change to know the change being
requested: the former is for removing extra copying and the latter is
for cleaning up the code.
Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp>
This patch drops the parameter old, a copy of the old memory slot, and
adds a new parameter named change to know the change being requested.
This not only cleans up the code but also removes extra copying of the
memory slot structure.
X86 does not use this any more. The remaining user, s390's !user_alloc
check, can be simply removed since KVM_SET_MEMORY_REGION ioctl is no
longer supported.
Note: fixed powerpc's indentations with spaces to suppress checkpatch
errors.
Pull KVM updates from Marcelo Tosatti:
"KVM updates for the 3.9 merge window, including x86 real mode
emulation fixes, stronger memory slot interface restrictions, mmu_lock
spinlock hold time reduction, improved handling of large page faults
on shadow, initial APICv HW acceleration support, s390 channel IO
based virtio, amongst others"
* tag 'kvm-3.9-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (143 commits)
Revert "KVM: MMU: lazily drop large spte"
x86: pvclock kvm: align allocation size to page size
KVM: nVMX: Remove redundant get_vmcs12 from nested_vmx_exit_handled_msr
x86 emulator: fix parity calculation for AAD instruction
KVM: PPC: BookE: Handle alignment interrupts
booke: Added DBCR4 SPR number
KVM: PPC: booke: Allow multiple exception types
KVM: PPC: booke: use vcpu reference from thread_struct
KVM: Remove user_alloc from struct kvm_memory_slot
KVM: VMX: disable apicv by default
KVM: s390: Fix handling of iscs.
KVM: MMU: cleanup __direct_map
KVM: MMU: remove pt_access in mmu_set_spte
KVM: MMU: cleanup mapping-level
KVM: VMX: cleanup vmx_set_cr0().
KVM: VMX: add missing exit names to VMX_EXIT_REASONS array
KVM: VMX: disable SMEP feature when guest is in non-paging mode
KVM: Remove duplicate text in api.txt
Revert "KVM: MMU: split kvm_mmu_free_page"
The s390 architecture is unique in respect to dirty page detection,
it uses the change bit in the per-page storage key to track page
modifications. All other architectures track dirty bits by means
of page table entries. This property of s390 has caused numerous
problems in the past, e.g. see git commit ef5d437f71afdf4a
"mm: fix XFS oops due to dirty pages without buffers on s390".
To avoid future issues in regard to per-page dirty bits convert
s390 to a fault based software dirty bit detection mechanism. All
user page table entries which are marked as clean will be hardware
read-only, even if the pte is supposed to be writable. A write by
the user process will trigger a protection fault which will cause
the user pte to be marked as dirty and the hardware read-only bit
is removed.
With this change the dirty bit in the storage key is irrelevant
for Linux as a host, but the storage key is still required for
KVM guests. The effect is that page_test_and_clear_dirty and the
related code can be removed. The referenced bit in the storage
key is still used by the page_test_and_clear_young primitive to
provide page age information.
For page cache pages of mappings with mapping_cap_account_dirty
there will not be any change in behavior as the dirty bit tracking
already uses read-only ptes to control the amount of dirty pages.
Only for swap cache pages and pages of mappings without
mapping_cap_account_dirty there can be additional protection faults.
To avoid an excessive number of additional faults the mk_pte
primitive checks for PageDirty if the pgprot value allows for writes
and pre-dirties the pte. That avoids all additional faults for
tmpfs and shmem pages until these pages are added to the swap cache.
On store status we need to copy the current state of registers
into a save area. Currently we might save stale versions:
The sie state descriptor doesnt have fields for guest ACRS,FPRS,
those registers are simply stored in the host registers. The host
program must copy these away if needed. We do that in vcpu_put/load.
If we now do a store status in KVM code between vcpu_put/load, the
saved values are not up-to-date. Lets collect the ACRS/FPRS before
saving them.
This also fixes some strange problems with hotplug and virtio-ccw,
since the low level machine check handler (on hotplug a machine check
will happen) will revalidate all registers with the content of the
save area.
CC: stable@vger.kernel.org
commit b080935c8638e08134629d0a9ebdf35669bec14d
kvm: Directly account vtime to system on guest switch
also removed the irq_disable/enable around kvm guest switch, which
is correct in itself. Unfortunately, there is a BUG ON that (correctly)
checks for preemptible to cover the call to rcu later on.
(Introduced with commit 8fa2206821953a50a3a02ea33fcfb3ced2fd9997
KVM: make guest mode entry to be rcu quiescent state)
This check might trigger depending on the kernel config.
Lets make sure that no preemption happens during kvm_guest_enter.
We can enable preemption again after the call to
rcu_virt_note_context_switch returns.
Please note that we continue to run s390 guests with interrupts
enabled.
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
CC: Gleb Natapov <gleb@redhat.com>
Add a new capability, KVM_CAP_S390_CSS_SUPPORT, which will pass
intercepts for channel I/O instructions to userspace. Only I/O
instructions interacting with I/O interrupts need to be handled
in-kernel:
- TEST PENDING INTERRUPTION (tpi) dequeues and stores pending
interrupts entirely in-kernel.
- TEST SUBCHANNEL (tsch) dequeues pending interrupts in-kernel
and exits via KVM_EXIT_S390_TSCH to userspace for subchannel-
related processing.
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Reviewed-by: Alexander Graf <agraf@suse.de>
Make s390 support KVM_ENABLE_CAP.
Acked-by: Alexander Graf <agraf@suse.de>
There's no need for this to be an int, it holds a boolean.
Move to the end of the struct for alignment.
Reviewed-by: Gleb Natapov <gleb@redhat.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
"Considerable KVM/PPC work, x86 kvmclock vsyscall support,
IA32_TSC_ADJUST MSR emulation, amongst others."
Fix up trivial conflict in kernel/sched/core.c due to cross-cpu
migration notifier added next to rq migration call-back.
* tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (156 commits)
KVM: emulator: fix real mode segment checks in address linearization
VMX: remove unneeded enable_unrestricted_guest check
KVM: VMX: fix DPL during entry to protected mode
x86/kexec: crash_vmclear_local_vmcss needs __rcu
kvm: Fix irqfd resampler list walk
KVM: VMX: provide the vmclear function and a bitmap to support VMCLEAR in kdump
x86/kexec: VMCLEAR VMCSs loaded on all cpus if necessary
KVM: MMU: optimize for set_spte
KVM: PPC: booke: Get/set guest EPCR register using ONE_REG interface
KVM: PPC: bookehv: Add EPCR support in mtspr/mfspr emulation
KVM: PPC: bookehv: Add guest computation mode for irq delivery
KVM: PPC: Make EPCR a valid field for booke64 and bookehv
KVM: PPC: booke: Extend MAS2 EPN mask for 64-bit
KVM: PPC: e500: Mask MAS2 EPN high 32-bits in 32/64 tlbwe emulation
KVM: PPC: Mask ea's high 32-bits in 32/64 instr emulation
KVM: PPC: e500: Add emulation helper for getting instruction ea
KVM: PPC: bookehv64: Add support for interrupt handling
KVM: PPC: bookehv: Remove GET_VCPU macro from exception handler
KVM: PPC: booke: Fix get_tb() compile error on 64-bit
KVM: PPC: e500: Silence bogus GCC warning in tlb code
TSC initialization will soon make use of online_vcpus.
Switching to or from guest context is done on ioctl context.
So by the time we call kvm_guest_enter() or kvm_guest_exit()
we know we are not running the idle task.
As a result, we can directly account the cputime using
vtime_account_system().
There are two good reasons to do this:
* We avoid some useless checks on guest switch. It optimizes
a bit this fast path.
* In the case of CONFIG_IRQ_TIME_ACCOUNTING, calling vtime_account()
checks for irq time to account. This is pointless since we know
we are not in an irq on guest switch. This is wasting cpu cycles
for no good reason. vtime_account_system() OTOH is a no-op in
this config option.
* We can remove the irq disable/enable around kvm guest switch in s390.
A further optimization may consist in introducing a vtime_account_guest()
that directly calls account_guest_time().
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Joerg Roedel <joerg.roedel@amd.com>
Cc: Alexander Graf <agraf@suse.de>
Cc: Xiantao Zhang <xiantao.zhang@intel.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Newer kernels (linux-next with the transparent huge page patches)
use rrbm if the feature is announced via feature bit 66.
RRBM will cause intercepts, so KVM does not handle it right now,
causing an illegal instruction in the guest.
The easy solution is to disable the feature bit for the guest.
This fixes bugs like:
Kernel BUG at 0000000000124c2a [verbose debug info unavailable]
illegal operation: 0001 [#1] SMP
Modules linked in: virtio_balloon virtio_net ipv6 autofs4
CPU: 0 Not tainted 3.5.4 #1
Process fmempig (pid: 659, task: 000000007b712fd0, ksp: 000000007bed3670)
Krnl PSW : 0704d00180000000 0000000000124c2a (pmdp_clear_flush_young+0x5e/0x80)
R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:3 CC:1 PM:0 EA:3
00000000003cc000 0000000000000004 0000000000000000 0000000079800000
0000000000040000 0000000000000000 000000007bed3918 000000007cf40000
0000000000000001 000003fff7f00000 000003d281a94000 000000007bed383c
000000007bed3918 00000000005ecbf8 00000000002314a6 000000007bed36e0
Krnl Code:>0000000000124c2a: b9810025 ogr %r2,%r5
0000000000124c2e: 41343000 la %r3,0(%r4,%r3)
0000000000124c32: a716fffa brct %r1,124c26
0000000000124c36: b9010022 lngr %r2,%r2
0000000000124c3a: e3d0f0800004 lg %r13,128(%r15)
0000000000124c40: eb22003f000c srlg %r2,%r2,63
[ 2150.713198] Call Trace:
[ 2150.713223] ([<00000000002312c4>] page_referenced_one+0x6c/0x27c)
[ 2150.713749] [<0000000000233812>] page_referenced+0x32a/0x410
CC: Alex Graf <agraf@suse.de>
Introducing kvm_arch_flush_shadow_memslot, to invalidate the
translations of a single memory slot.
Signed-off-by: Avi Kivity <avi@redhat.com>
Introduce a new trace system, kvm-s390, for some kvm/s390 specific
trace points:
- injection of interrupts
- delivery of interrupts to the guest
- creation/destruction of kvm machines and vcpus
- stop actions for vcpus
- reset requests for userspace
Add trace events for several s390 architecture specifics:
- SIE entry/exit
- common intercepts
- common instructions (sigp/diagnose)
Pull KVM updates from Avi Kivity:
"Highlights include
- full big real mode emulation on pre-Westmere Intel hosts (can be
disabled with emulate_invalid_guest_state=0)
- relatively small ppc and s390 updates
- PCID/INVPCID support in guests
- EOI avoidance; 3.6 guests should perform better on 3.6 hosts on
interrupt intensive workloads)
- Lockless write faults during live migration
- EPT accessed/dirty bits support for new Intel processors"
Fix up conflicts in:
- Documentation/virtual/kvm/api.txt:
Stupid subchapter numbering, added next to each other.
- arch/powerpc/kvm/booke_interrupts.S:
PPC asm changes clashing with the KVM fixes
- arch/s390/include/asm/sigp.h, arch/s390/kvm/sigp.c:
Duplicated commits through the kvm tree and the s390 tree, with
subsequent edits in the KVM tree.
* tag 'kvm-3.6-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (93 commits)
KVM: fix race with level interrupts
x86, hyper: fix build with !CONFIG_KVM_GUEST
Revert "apic: fix kvm build on UP without IOAPIC"
KVM guest: switch to apic_set_eoi_write, apic_write
apic: add apic_set_eoi_write for PV use
KVM: VMX: Implement PCID/INVPCID for guests with EPT
KVM: Add x86_hyper_kvm to complete detect_hypervisor_platform check
KVM: PPC: Critical interrupt emulation support
KVM: PPC: e500mc: Fix tlbilx emulation for 64-bit guests
KVM: PPC64: booke: Set interrupt computation mode for 64-bit host
KVM: PPC: bookehv: Add ESR flag to Data Storage Interrupt
KVM: PPC: bookehv64: Add support for std/ld emulation.
booke: Added crit/mc exception handler for e500v2
booke/bookehv: Add host crit-watchdog exception support
KVM: MMU: document mmu-lock and fast page fault
KVM: MMU: fix kvm_mmu_pagetable_walk tracepoint
KVM: MMU: trace fast page fault
KVM: MMU: fast path of handling guest page fault
KVM: MMU: introduce SPTE_MMU_WRITEABLE bit
KVM: MMU: fold tlb flush judgement into mmu_spte_update
Remove the file name from the comment at top of many files. In most
cases the file name was wrong anyway, so it's rather pointless.
Also unify the IBM copyright statement. We did have a lot of sightly
different statements and wanted to change them one after another
whenever a file gets touched. However that never happened. Instead
people start to take the old/"wrong" statements to use as a template
for new files.
So unify all of them in one go.
The initial cpu reset sets the cpu in the stopped state.
Several places check for the cpu state (e.g. sigp set prefix) and
not setting the STOPPED state triggered errors with newer guest
kernels after reboot.
Enhance the KVM ONE_REG capability within S390 to allow
getting/setting the following special cpu registers: clock comparator
and the cpu timer. These are needed for migration.
Signed-off-by: Jason J. herne <jjherne@us.ibm.com>
This patch makes vcpu epoch difference and the TOD programmable
field accessible from userspace. This is needed in order to
implement a couple of instructions that deal with the time of
day clock on s390, such as SET CLOCK and for migration.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
This patch enables KVM_CAP_ONE_REG for s390 and implements stubs
for KVM_GET/SET_ONE_REG. This is based on the ppc implementation.
Currently qemu/kvm on s390 uses a guest mapping that does not
allow the guest backing page table to be write-protected to
support older systems. On those older systems a host write
protection fault will be delivered to the guest.
Newer systems allow to write-protect the guest backing memory
and let the fault be delivered to the host, thus allowing COW.
Use a capability bit to tell qemu if that is possible.
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Let userspace know the number of max and supported cpus for kvm on s390.
Return KVM_MAX_VCPUS (currently 64) for both values.
This patch implements the directed yield hypercall found on other
System z hypervisors. It delegates execution time to the virtual cpu
specified in the instruction's parameter.
Useful to avoid long spinlock waits in the guest.
Christian Borntraeger: moved common code in virt/kvm/
Signed-off-by: Konstantin Weitz <WEITZKON@de.ibm.com>
The kvm_vcpu_kick function performs roughly the same funcitonality on
most all architectures, so we shouldn't have separate copies.
PowerPC keeps a pointer to interchanging waitqueues on the vcpu_arch
structure and to accomodate this special need a
__KVM_HAVE_ARCH_VCPU_GET_WQ define and accompanying function
kvm_arch_vcpu_wq have been defined. For all other architectures this
is a generic inline that just returns &vcpu->wq;
Acked-by: Scott Wood <scottwood@freescale.com>
Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Disintegrate asm/system.h for S390.
cc: linux-s390@vger.kernel.org
Some members of kvm_memory_slot are not used by every architecture.
This patch is the first step to make this difference clear by
introducing kvm_memory_slot::arch; lpage_info is moved into it.
Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
There are several cases were we need the control registers for
userspace. Lets also provide those in kvm_run.
commit 7eef87dc99e419b1cc051e4417c37e4744d7b661 (KVM: s390: fix
register setting) added a load of the floating point control register
to the KVM_SET_FPU path. Lets make sure that the fpc is valid.
This patch adds the access registers to the kvm_run structure.
This patch adds the general purpose registers to the kvm_run structure.
Add the prefix register to the synced register field in kvm_run.
While we need the prefix register most of the time read-only, this
patch also adds handling for guest dirtying of the prefix register.
There are several places in the kvm module, which set the prefix register.
Since we need to flush the cpu, lets combine this operation into a helper
function. This helper will also explicitely mask out the unused bits.
This patch fixes the return code of kvm_arch_vcpu_ioctl in case
of an unkown ioctl number.
This patch announces a new capability KVM_CAP_S390_UCONTROL that
indicates that kvm can now support virtual machines that are
controlled by userspace.
This patch makes sure user controlled virtual machines do not use a
system control area (sca). This is needed in order to create
virtual machines with more cpus than the size of the sca [64].
This patch allows the user to fault in pages on a virtual cpus
address space for user controlled virtual machines. Typically this
is superfluous because userspace can just create a mapping and
let the kernel's page fault logic take are of it. There is one
exception: SIE won't start if the lowcore is not present. Normally
the kernel takes care of this [handle_validity() in
arch/s390/kvm/intercept.c] but since the kernel does not handle
intercepts for user controlled virtual machines, userspace needs to
be able to handle this condition.
This patch disables the in-kernel interrupt stack for KVM virtual
machines that are controlled by user. Userspace has to take care
of handling interrupts on its own.
This patch disables in-kernel handling of SIE intercepts for user
controlled virtual machines. All intercepts are passed to userspace
via KVM_EXIT_SIE exit reason just like SIE intercepts that cannot be
handled in-kernel for regular KVM guests.
This patch exports the s390 SIE hardware control block to userspace
via the mapping of the vcpu file descriptor. In order to do so,
a new arch callback named kvm_arch_vcpu_fault is introduced for all
architectures. It allows to map architecture specific pages.
This patch introduces a new exit reason in the kvm_run structure
named KVM_EXIT_S390_UCONTROL. This exit indicates, that a virtual cpu
has regognized a fault on the host page table. The idea is that
userspace can handle this fault by mapping memory at the fault
location into the cpu's address space and then continue to run the
virtual cpu.
