path: root/arch/s390/kvm/sie64a.S
2008-04-27KVM: s390: arch backend for the kvm kernel moduleHeiko Carstens
This patch contains the port of Qumranet's kvm kernel module to IBM zSeries (aka s390x, mainframe) architecture. It uses the mainframe's virtualization instruction SIE to run virtual machines with up to 64 virtual CPUs each. This port is only usable on 64bit host kernels, and can only run 64bit guest kernels. However, running 31bit applications in guest userspace is possible. The following source files are introduced by this patch arch/s390/kvm/kvm-s390.c similar to arch/x86/kvm/x86.c, this implements all arch callbacks for kvm. __vcpu_run calls back into sie64a to enter the guest machine context arch/s390/kvm/sie64a.S assembler function sie64a, which enters guest context via SIE, and switches world before and after that include/asm-s390/kvm_host.h contains all vital data structures needed to run virtual machines on the mainframe include/asm-s390/kvm.h defines kvm_regs and friends for user access to guest register content arch/s390/kvm/gaccess.h functions similar to uaccess to access guest memory arch/s390/kvm/kvm-s390.h header file for kvm-s390 internals, extended by later patches Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
