commit 2253e8d79237c69086ded391e6767afe16972527 upstream.
ccw consoles are in use before they can be properly registered with
the driver core. For devices which are in use by a device driver we
rely on the ccw_device's pointer to the driver callbacks to be valid.
For ccw consoles this pointer is NULL until they are registered later
during boot and we dereferenced this pointer. This worked by
chance on 64 bit builds (cdev->drv was NULL but the optional callback
cdev->drv->path_event was also NULL by coincidence) and was unnoticed
until we received reports about boot failures on 31 bit systems.
Fix it by initializing the driver pointer for ccw consoles.
Reported-by: Mike Frysinger <vapier@gentoo.org>
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
commit 03b8c7b623c80af264c4c8d6111e5c6289933666 upstream.
If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there
is no runtime check necessary, allow to skip the test within futex_init().
This allows to get rid of some code which would always give the same result,
and also allows the compiler to optimize a couple of if statements away.
Cc: Finn Thain <fthain@telegraphics.com.au>
Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris
[geert: Backported to v3.10..v3.13]
commit 8d7f6690cedb83456edd41c9bd583783f0703bf0 upstream.
The kernel currently crashes with a low-address-protection exception
if a user space process executes an instruction that tries to use the
linkage stack. Set the base-ASTE origin and the subspace-ASTE origin
of the dispatchable-unit-control-table to point to a dummy ASTE.
Set up control register 15 to point to an empty linkage stack with no
room left.
A user space process with a linkage stack instruction will still crash
but with a different exception which is correctly translated to a
segmentation fault instead of a kernel oops.
commit d7736ff5be31edaa4fe5ab62810c64529a24b149 upstream.
Dumps created by kdump or zfcpdump can contain invalid memory holes when
dumping z/VM systems that have memory pressure.
For example:
# zgetdump -i /proc/vmcore.
Memory map:
0000000000000000 - 0000000000bfffff (12 MB)
0000000000e00000 - 00000000014fffff (7 MB)
000000000bd00000 - 00000000f3bfffff (3711 MB)
The memory detection function find_memory_chunks() issues tprot to
find valid memory chunks. In case of CMM it can happen that pages are
marked as unstable via set_page_unstable() in arch_free_page().
If z/VM has released that pages, tprot returns -EFAULT and indicates
a memory hole.
So fix this and switch off CMM in case of kdump or zfcpdump.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
commit ee97dc7db4cbda33e4241c2d85b42d1835bc8a35 upstream.
In s390 des and 3des ctr mode there is one preallocated page
used to speed up the en/decryption. This page is not protected
against concurrent usage and thus there is a potential of data
corruption with multiple threads.
The fix introduces locking/unlocking the ctr page and a slower
fallback solution at concurrency situations.
Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com>
commit adc3fcf1552b6e406d172fd9690bbd1395053d13 upstream.
In s390 des and des3_ede cbc mode the iv value is not protected
against concurrency access and modifications from another running
en/decrypt operation which is using the very same tfm struct
instance. This fix copies the iv to the local stack before
the crypto operation and stores the value back when done.
commit 0519e9ad89e5cd6e6b08398f57c6a71d9580564c upstream.
The aes-ctr mode uses one preallocated page without any concurrency
protection. When multiple threads run aes-ctr encryption or decryption
this can lead to data corruption.
The patch introduces locking for the page and a fallback solution with
slower en/decryption performance in concurrency situations.
[ Upstream commit 3af57f78c38131b7a66e2b01e06fdacae01992a3 ]
The s390 bpf jit compiler emits the signed divide instructions "dr" and "d"
for unsigned divisions.
This can cause problems: the dividend will be zero extended to a 64 bit value
and the divisor is the 32 bit signed value as specified A or X accumulator,
even though A and X are supposed to be treated as unsigned values.
The divide instrunctions will generate an exception if the result cannot be
expressed with a 32 bit signed value.
This is the case if e.g. the dividend is 0xffffffff and the divisor either 1
or also 0xffffffff (signed: -1).
To avoid all these issues simply use unsigned divide instructions.
[ Upstream commit aee636c4809fa54848ff07a899b326eb1f9987a2 ]
At first Jakub Zawadzki noticed that some divisions by reciprocal_divide
were not correct. (off by one in some cases)
http://www.wireshark.org/~darkjames/reciprocal-buggy.c
He could also show this with BPF:
http://www.wireshark.org/~darkjames/set-and-dump-filter-k-bug.c
The reciprocal divide in linux kernel is not generic enough,
lets remove its use in BPF, as it is not worth the pain with
current cpus.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Cc: Mircea Gherzan <mgherzan@gmail.com>
Cc: Daniel Borkmann <dxchgb@gmail.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Matt Evans <matt@ozlabs.org>
commit 4e078146dff728f4865270a47710d57797e81eb6 upstream.
With b8668fd0a7e1b59f "s390/uapi: change struct statfs[64] member types
to unsigned values" the size of a couple of struct statfs64 member got
incorrectly changed from 64 to 32 bit for 32 bit builds.
Fix this by changing the type of couple of struct statfs64 members from
unsigned long to unsigned long long.
The definition of struct compat_statfs64 was correct however.
commit 743db27c526e0f31cc507959d662e97e2048a86f upstream.
The diagnose code to be used is the contents of the base register (if not
zero), plus the displacement. The current code ignores the base register
contents. So let's fix that...
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Cc: stable@vger.kernel.org
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
commit 9dda2769af4f3f3093434648c409bb351120d9e8 upstream.
Some s390 crypto algorithms incorrectly use the crypto_tfm structure to
store private data. As the tfm can be shared among multiple threads, this
can result in data corruption.
This patch fixes aes-xts by moving the xts and pcc parameter blocks from
the tfm onto the stack (48 + 96 bytes).
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
commit 71a86ef055f569b93bc6901f007bdf447dbf515f upstream.
When translating a user space address, the address must be checked against
the ASCE limit of the process. If the address is larger than the maximum
address that is reachable with the ASCE, an ASCE type exception must be
generated.
The current code simply ignored the higher order bits. This resulted in an
address wrap around in user space instead of an exception in user space.
Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
commit 4560e7c3317c7a2b370e36dadd3a3bac2ed70818 upstream.
Use the ACCESS_ONCE macro for both accesses to idle->sequence in the
loops to calculate the idle time. If only one access uses the macro,
the compiler is free to cache the value for the second access which
can cause endless loops.
commit f262f0f5cad0c9eca61d1d383e3b67b57dcbe5ea upstream.
The cbc-aes-s390 algorithm incorrectly places the IV in the tfm
data structure. As the tfm is shared between multiple threads,
this introduces a possibility of data corruption.
This patch fixes this by moving the parameter block containing
the IV and key onto the stack (the block is 48 bytes long).
The same bug exists elsewhere in the s390 crypto system and they
will be fixed in subsequent patches.
commit 3f0116c3238a96bc18ad4b4acefe4e7be32fa861 upstream.
Fengguang Wu, Oleg Nesterov and Peter Zijlstra tracked down
a kernel crash to a GCC bug: GCC miscompiles certain 'asm goto'
constructs, as outlined here:
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670
Implement a workaround suggested by Jakub Jelinek.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Suggested-by: Jakub Jelinek <jakub@redhat.com>
Reviewed-by: Richard Henderson <rth@twiddle.net>
Link: http://lkml.kernel.org/r/20131015062351.GA4666@gmail.com
commit dbbfe487e5f3fc00c9fe5207d63309859704d12f upstream.
Git commit 616498813b11ffef "s390: system call path micro optimization"
introduced a regression in regard to system call restarting and inferior
function calls via the ptrace interface. The pointer to the system call
table needs to be loaded in sysc_sigpending if do_signal returns with
TIF_SYSCALl set after it restored a system call context.
commit 2b29a9fdcb92bfc6b6f4c412d71505869de61a56 upstream.
Any uaccess between guest_enter and guest_exit could trigger a page fault,
the page fault handler would handle it as a guest fault and translate a
user address as guest address.
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit 215b28a5308f3d332df2ee09ef11fda45d7e4a92 upstream.
Fix this build error:
In file included from fs/exec.c:61:0:
arch/s390/include/asm/tlb.h:35:23: error: expected identifier or '(' before 'unsigned'
arch/s390/include/asm/tlb.h:36:1: warning: no semicolon at end of struct or union [enabled by default]
arch/s390/include/asm/tlb.h: In function 'tlb_gather_mmu':
arch/s390/include/asm/tlb.h:57:5: error: 'struct mmu_gather' has no member named 'end'
Broken due to commit 2b047252d0 ("Fix TLB gather virtual address range
invalidation corner cases").
[ Oh well. We had build testing for ppc amd um, but no s390 - Linus ]
commit 2b047252d087be7f2ba088b4933cd904f92e6fce upstream.
Ben Tebulin reported:
"Since v3.7.2 on two independent machines a very specific Git
repository fails in 9/10 cases on git-fsck due to an SHA1/memory
failures. This only occurs on a very specific repository and can be
reproduced stably on two independent laptops. Git mailing list ran
out of ideas and for me this looks like some very exotic kernel issue"
and bisected the failure to the backport of commit 53a59fc67f97 ("mm:
limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPT").
That commit itself is not actually buggy, but what it does is to make it
much more likely to hit the partial TLB invalidation case, since it
introduces a new case in tlb_next_batch() that previously only ever
happened when running out of memory.
The real bug is that the TLB gather virtual memory range setup is subtly
buggered. It was introduced in commit 597e1c3580b7 ("mm/mmu_gather:
enable tlb flush range in generic mmu_gather"), and the range handling
was already fixed at least once in commit e6c495a96ce0 ("mm: fix the TLB
range flushed when __tlb_remove_page() runs out of slots"), but that fix
was not complete.
The problem with the TLB gather virtual address range is that it isn't
set up by the initial tlb_gather_mmu() initialization (which didn't get
the TLB range information), but it is set up ad-hoc later by the
functions that actually flush the TLB. And so any such case that forgot
to update the TLB range entries would potentially miss TLB invalidates.
Rather than try to figure out exactly which particular ad-hoc range
setup was missing (I personally suspect it's the hugetlb case in
zap_huge_pmd(), which didn't have the same logic as zap_pte_range()
did), this patch just gets rid of the problem at the source: make the
TLB range information available to tlb_gather_mmu(), and initialize it
when initializing all the other tlb gather fields.
This makes the patch larger, but conceptually much simpler. And the end
result is much more understandable; even if you want to play games with
partial ranges when invalidating the TLB contents in chunks, now the
range information is always there, and anybody who doesn't want to
bother with it won't introduce subtle bugs.
Ben verified that this fixes his problem.
Reported-bisected-and-tested-by: Ben Tebulin <tebulin@googlemail.com>
Build-testing-by: Stephen Rothwell <sfr@canb.auug.org.au>
Build-testing-by: Richard Weinberger <richard.weinberger@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit 3b0040a47ad63f7147e9e7d2febb61a3b564bb90 upstream.
The find_next_bit_left function is broken if used with an offset which
is not a multiple of 64. The shift to mask the bits of a 64-bit word
not to search is in the wrong direction, the result can be either a
bit found smaller than the offset or failure to find a set bit.
commit 594712276e737961d30e11eae80d403b2b3815df upstream.
Just add the new model number where appropiate.
The following git commit changed the behavior of sscanf:
commit 53809751ac230a3611b5cdd375f3389f3207d471
Author: Jan Beulich <JBeulich@suse.com>
Date: Mon Dec 17 16:01:31 2012 -0800
sscanf: don't ignore field widths for numeric conversions
This broke the WWPN and LUN sysfs attributes for s390 reipl and dump
on panic.
Example:
$ echo 0x0123456701234567 > /sys/firmware/reipl/fcp/wwpn
$ cat /sys/firmware/reipl/fcp/wwpn
0x0001234567012345
So fix this and use format strings that work also with the
new sscanf implementation:
$ echo 0x012345670123456789 > /sys/firmware/reipl/fcp/wwpn
0x0123456701234567
Cc: stable@vger.kernel.org # 3.8+
Reviewed-by: Steffen Maier <maier@linux.vnet.ibm.com>
With git commit 996b4a7d "s390/mem_detect: remove artificial kdump
memory types" the memory detection code got simplified.
As a side effect the array that describes memory chunks may now
contain empty (zeroed) entries.
All call sites can handle this except for
drivers/s390/char/zcore.c::zcore_memmap_open
which has a really odd user space interface. The easiest fix is to
change the memory hole handling code, so that no empty entries exist
before the last valid entry is reached.
Without this patch drivers will get blamed (CONFIG_DMA_API_DEBUG=y)
for not calling dma_mapping_error (even if they do).
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
The map_page implementation of s390 returns DMA_ERROR_CODE in an error
situation. Correctly test if a mapping was erroneous (DMA_ERROR_CODE is
defined as ~0).
In uniprocessor configurations, synchronize_irq() is defined in
<linux/hardirq.h> as a macro, and this function definition fails to
compile.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Cc: stable@vger.kernel.org # 3.9
All architectures must implement IRQ functions. Since various
dependencies on !S390 were removed, there are various drivers that can
be selected but will fail to link. Provide a dummy implementation of
these functions for the !PCI case.
When printing multi-line text using sclp_print, line endings are not
correctly handled. The routine is expecting an EBCDIC new line character
as line terminator while the input text is encoded in ASCII format.
Fix this problem by modifying sclp_print to scan for ASCII new line
characters.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Getting and Releasing the pgste lock has lock semantics. Make the
code an explicit barrier.
In modify_prot_start we update the pgste value but never store it back
into the original location. Lets save the calculated result, since
modify_prot_commit will use the value of the pgste.
git commit dc7ee00d4771b321 "s390: lowcore stack pointer offsets"
introduced a regression in regard to show_stack(). The stack pointer
for the asynchronous and the panic stack in the lowcore now have an
additional offset applied to them. This offset needs to be taken into
account in the calculation for the low and high address for the stacks.
When doing the transition invalid->valid in the host page table for
a guest, then the guest view of C/R is in the pgste. After validation
the view is pgste OR real key. We must zero out the real key C/R to
avoid guest over-indication for change (and reference).
Touching the real key is ok also for the host: The change bit is
tracked via write protection and the reference bit is also ok
because set_pte_at was called and the page will be touched anyway
soon. Furthermore architecture defines reference as "substantially
accurate", over- and underindication are ok.
The address of the gmap notifier was broken, resulting in
unhandled validity intercepts in KVM. Fix the rmap->vmaddr
to be on a segment boundary.
pte_present might return true on PAGE_TYPE_NONE, even if
the invalid bit is on. Modify the existing check of the
pgste functions to avoid crashes.
[ Martin Schwidefsky: added ptep_modify_prot_[start|commit] bits ]
Reported-by: Martin Schwidefky <schwidefsky@de.ibm.com>
CC: stable@vger.kernel.org
'buf[2]' is 2 bytes length, and sprintf() will append '\0' at the end
of string "?\n", so original implementation is memory overflow.
Need use strncpy() and strnlen() instead of sprintf().
Signed-off-by: Chen Gang <gang.chen@asianux.com>
IPIs might be lost when a cpu gets brought offline:
When stop_machine executes its state machine there is a race window
for the state STOPMACHINE_DISABLE_IRQ where the to be brought offline
cpu might already have irqs disabled but a different cpu still may
have irqs enabled.
If the enabled cpu receives an interrupt and as a result sends an IPI
to the to be offlined cpu in its bottom halve context, the IPI won't
be noticed before the cpu is offline.
In fact the race window is much larger since there is no guarantee
when an IPI will be received.
To fix this check for enqueued but not yet received IPIs in the
cpu_disable() path and call the respective handlers before the cpu
is marked offline.
Reported-by: Juergen Doelle <juergen.doelle@de.ibm.com>
On s390 the prefix page and absolute zero pages are not correctly
returned when reading /dev/mem. The reason is that the s390 asm/io.h
file includes the asm-generic/io.h file which then defines
xlate_dev_mem_ptr() and therefore overwrites the s390 specific
version that does the correct swap operation for prefix and absolute
zero pages. The problem is a regression that was introduced with git
commit cd248341 (s390/pci: base support).
To fix the problem add "#ifndef xlate_dev_mem_ptr" in asm-generic/io.h
and "#define xlate_dev_mem_ptr" in asm/io.h. This ensures that the
s390 version is used. For completeness also add the "#ifndef"
construct for xlate_dev_kmem_ptr().
In dma_free_coherent call debug_dma_free_coherent before deallocating
the memory to avoid a possible use after free.
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 update from Martin Schwidefsky:
"An additional sysfs attribute for channel paths and a couple of bux
fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/pgtable: fix ipte notify bit
s390/xpram: mark xpram as non-rotational
s390/smp: fix cpu re-scan vs. cpu state
s390/cio: add channel ID sysfs attribute
s390/ftrace: fix mcount adjustment
s390: fix gmap_ipte_notifier vs. software dirty pages
s390: disable pfmf for clear page instruction
s390/disassembler: prevent endless loop in print_fn_code()
s390: remove non existent reference to GENERIC_KERNEL_THREAD
Dont use the same bit as user referenced.
The cpu-info array starts with a list of cpus in configured state,
followed by the cpus in standby state. The comparison to decide which
state a cpu has is incorrect, this causes configured cpus appear as
standby cpus. The correct comparison is the index of the new cpu in
the cpu-info array vs. the number of configured cpus.
Tony Jones reported that the ftrace self tests on s390 do not work:
<6>Testing dynamic ftrace ops #1: (0 0 0 0 0) FAILED!
<6>Testing tracer irqsoff:
<3>failed to start irqsoff tracer
<4>.. no entries found ..FAILED!
<6>Testing tracer wakeup:
<3>failed to start wakeup tracer
<6>Testing tracer function_graph:
<4>Failed to init function_graph tracer, init returned -19
<4>FAILED!
This happens because we forgot to adjust the instruction pointer that gets
passed to the ftrace trace function by MCOUNT_INSN_SIZE.
In addition change MCOUNT_INSN_SIZE to the correct value on 31 bit.
It only worked so far because the to be patched instruction was identical.
Reported-by: Tony Jones <tonyj@suse.com>
On heavy paging load some guest cpus started to loop in gmap_ipte_notify.
This was visible as stalled cpus inside the guest. The gmap_ipte_notifier
tries to map a user page and then made sure that the pte is valid and
writable. Turns out that with the software change bit tracking the pte
can become read-only (and only software writable) if the page is clean.
Since we loop in this code, the page would stay clean and, therefore,
be never writable again.
Let us just use fixup_user_fault, that guarantees to call handle_mm_fault.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull stray syscall bits from Al Viro:
"Several syscall-related commits that were missing from the original"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
switch compat_sys_sysctl to COMPAT_SYSCALL_DEFINE
unicore32: just use mmap_pgoff()...
unify compat fanotify_mark(2), switch to COMPAT_SYSCALL_DEFINE
x86, vm86: fix VM86 syscalls: use SYSCALL_DEFINEx(...)
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
Wit the introduction of large pages Linux also used pfmf for page
clearing. The current implementation is not ideal, though:
- currently we set usage intent=0, but cleared pages are often used
directly after the clearing
- z/VM does not yet provide EDAT
- KVM does have to intercept PFMF even for resident pages
Lets just the mvcl loop in all cases until we have a well defined
pattern were pfmf is besser.
If the size of the opcode to be printed is larger than "len" we'll
see an overflow of an unsigned long value, which means that the
while loop within print_fn_code() will loop quite a long time until
there is the next chance for an exit.
So add an early exit check.
Reported-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
