path: root/arch/score/kernel
2014-10-05score: remove deprecated IRQF_DISABLEDMichael Opdenacker
This patch removes the use of the IRQF_DISABLED flag from arch/score/kernel/time.c It's a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Acked-by: Lennox Wu <lennox.wu@gmail.com>
2014-08-06score: Use get_signal() signal_setup_done()Richard Weinberger
Use the more generic functions get_signal() signal_setup_done() for signal delivery. Acked-by: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at>
2013-09-26Score: The commit is for compiling successfully.Lennox Wu
The modifications include: 1. Kconfig of Score: we don't support ioremap 2. Missed headfile including 3. There are some errors in other people's commit not checked by us, we fix it now 3.1 arch/score/kernel/entry.S: wrong instructions 3.2 arch/score/kernel/process.c : just some typos Signed-off-by: Lennox Wu <lennox.wu@gmail.com>
2013-07-03score: normalize global variables exported by vmlinux.ldsJiang Liu
Generate mandatory global variables _sdata in file vmlinux.lds. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: unify debug information printed by show_regs()Tejun Heo
show_regs() is inherently arch-dependent but it does make sense to print generic debug information and some archs already do albeit in slightly different forms. This patch introduces a generic function to print debug information from show_regs() so that different archs print out the same information and it's much easier to modify what's printed. show_regs_print_info() prints out the same debug info as dump_stack() does plus task and thread_info pointers. * Archs which didn't print debug info now do. alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r, metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc, um, xtensa * Already prints debug info. Replaced with show_regs_print_info(). The printed information is superset of what used to be there. arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86 * s390 is special in that it used to print arch-specific information along with generic debug info. Heiko and Martin think that the arch-specific extra isn't worth keeping s390 specfic implementation. Converted to use the generic version. Note that now all archs print the debug info before actual register dumps. An example BUG() dump follows. kernel BUG at /work/os/work/kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... v2: Typo fix in x86-32. v3: CPU number dropped from show_regs_print_info() as dump_stack_print_info() has been updated to print it. s390 specific implementation dropped as requested by s390 maintainers. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: consolidate dump_stack() implementations and unify their behaviorsTejun Heo
Both dump_stack() and show_stack() are currently implemented by each architecture. show_stack(NULL, NULL) dumps the backtrace for the current task as does dump_stack(). On some archs, dump_stack() prints extra information - pid, utsname and so on - in addition to the backtrace while the two are identical on other archs. The usages in arch-independent code of the two functions indicate show_stack(NULL, NULL) should print out bare backtrace while dump_stack() is used for debugging purposes when something went wrong, so it does make sense to print additional information on the task which triggered dump_stack(). There's no reason to require archs to implement two separate but mostly identical functions. It leads to unnecessary subtle information. This patch expands the dummy fallback dump_stack() implementation in lib/dump_stack.c such that it prints out debug information (taken from x86) and invokes show_stack(NULL, NULL) and drops arch-specific dump_stack() implementations in all archs except blackfin. Blackfin's dump_stack() does something wonky that I don't understand. Debug information can be printed separately by calling dump_stack_print_info() so that arch-specific dump_stack() implementation can still emit the same debug information. This is used in blackfin. This patch brings the following behavior changes. * On some archs, an extra level in backtrace for show_stack() could be printed. This is because the top frame was determined in dump_stack() on those archs while generic dump_stack() can't do that reliably. It can be compensated by inlining dump_stack() but not sure whether that'd be necessary. * Most archs didn't use to print debug info on dump_stack(). They do now. An example WARN dump follows. WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505() Hardware name: empty Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9 0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48 ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c 0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58 Call Trace: [<ffffffff81c614dc>] dump_stack+0x19/0x1b [<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8234a071>] init_workqueues+0x35/0x505 ... v2: CPU number added to the generic debug info as requested by s390 folks and dropped the s390 specific dump_stack(). This loses %ksp from the debug message which the maintainers think isn't important enough to keep the s390-specific dump_stack() implementation. dump_stack_print_info() is moved to kernel/printk.c from lib/dump_stack.c. Because linkage is per objecct file, dump_stack_print_info() living in the same lib file as generic dump_stack() means that archs which implement custom dump_stack() - at this point, only blackfin - can't use dump_stack_print_info() as that will bring in the generic version of dump_stack() too. v1 The v1 patch broke build on blackfin due to this issue. The build breakage was reported by Fengguang Wu. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits] Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-08score: Use generic idle loopThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Link: http://lkml.kernel.org/r/20130321215235.147909863@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-02-03score: switch to generic sigaltstackAl Viro
2012-11-28flagday: don't pass regs to copy_thread()Al Viro
2012-11-28score: switch to generic fork/vfork/cloneAl Viro
2012-11-28Merge branches 'no-rebases', 'arch-avr32', 'arch-blackfin', 'arch-cris', ↵Al Viro
'arch-h8300', 'arch-m32r', 'arch-mn10300', 'arch-score', 'arch-sh' and 'arch-powerpc' into for-next
2012-11-28score: do_sigaltstack() expects a userland pointer...Al Viro
2012-10-15score: switch to generic sys_execve()Al Viro
2012-10-15score: switch to generic kernel_thread()/kernel_execve()Al Viro
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-12vfs: define struct filename and have getname() return itJeff Layton
getname() is intended to copy pathname strings from userspace into a kernel buffer. The result is just a string in kernel space. It would however be quite helpful to be able to attach some ancillary info to the string. For instance, we could attach some audit-related info to reduce the amount of audit-related processing needed. When auditing is enabled, we could also call getname() on the string more than once and not need to recopy it from userspace. This patchset converts the getname()/putname() interfaces to return a struct instead of a string. For now, the struct just tracks the string in kernel space and the original userland pointer for it. Later, we'll add other information to the struct as it becomes convenient. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull pile 2 of execve and kernel_thread unification work from Al Viro: "Stuff in there: kernel_thread/kernel_execve/sys_execve conversions for several more architectures plus assorted signal fixes and cleanups. There'll be more (in particular, real fixes for the alpha do_notify_resume() irq mess)..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (43 commits) alpha: don't open-code trace_report_syscall_{enter,exit} Uninclude linux/freezer.h m32r: trim masks avr32: trim masks tile: don't bother with SIGTRAP in setup_frame microblaze: don't bother with SIGTRAP in setup_rt_frame() mn10300: don't bother with SIGTRAP in setup_frame() frv: no need to raise SIGTRAP in setup_frame() x86: get rid of duplicate code in case of CONFIG_VM86 unicore32: remove pointless test h8300: trim _TIF_WORK_MASK parisc: decide whether to go to slow path (tracesys) based on thread flags parisc: don't bother looping in do_signal() parisc: fix double restarts bury the rest of TIF_IRET sanitize tsk_is_polling() bury _TIF_RESTORE_SIGMASK unicore32: unobfuscate _TIF_WORK_MASK mips: NOTIFY_RESUME is not needed in TIF masks mips: merge the identical "return from syscall" per-ABI code ... Conflicts: arch/arm/include/asm/thread_info.h
2012-10-06sections: fix section conflicts in arch/scoreAndi Kleen
Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-01score: fix bogus restarts on sigreturn()Al Viro
we *really* don't want to have restart logics hit when we are returning from sigreturn() - random replacement of %r4 with -4 just because a signal had been noticed from timer interrupt that came when %r4 happened to contain -514 is not nice at all. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-28Make most arch asm/module.h files use asm-generic/module.hDavid Howells
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela, ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version into asm-generic/module.h for all arches bar MIPS. Also, use the generic definition mod_arch_specific where possible. To this end, I've defined three new config bools: (*) HAVE_MOD_ARCH_SPECIFIC Arches define this if they don't want to use the empty generic mod_arch_specific struct. (*) MODULES_USE_ELF_RELA Arches define this if their modules can contain RELA records. This causes the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be defined by the arch rather than have the core emit an error message. (*) MODULES_USE_ELF_REL Arches define this if their modules can contain REL records. This causes the Elf_Rel mapping to be emitted and allows apply_relocate() to be defined by the arch rather than have the core emit an error message. Note that it is possible to allow both REL and RELA records: m68k and mips are two arches that do this. With this, some arch asm/module.h files can be deleted entirely and replaced with a generic-y marker in the arch Kbuild file. Additionally, I have removed the bits from m32r and score that handle the unsupported type of relocation record as that's now handled centrally. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-23score: Add missing RCU idle APIs on idle loopFrederic Weisbecker
In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in scores's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: <stable@vger.kernel.org> # 3.3+ Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2012-06-01new helper: signal_delivered()Al Viro
Does block_sigmask() + tracehook_signal_handler(); called when sigframe has been successfully built. All architectures converted to it; block_sigmask() itself is gone now (merged into this one). I'm still not too happy with the signature, but that's a separate story (IMO we need a structure that would contain signal number + siginfo + k_sigaction, so that get_signal_to_deliver() would fill one, signal_delivered(), handle_signal() and probably setup...frame() - take one). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01most of set_current_blocked() callers want SIGKILL/SIGSTOP removed from setAl Viro
Only 3 out of 63 do not. Renamed the current variant to __set_current_blocked(), added set_current_blocked() that will exclude unblockable signals, switched open-coded instances to it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01pull clearing RESTORE_SIGMASK into block_sigmask()Al Viro
2012-06-01new helper: sigmask_to_save()Al Viro
replace boilerplate "should we use ->saved_sigmask or ->blocked?" with calls of obvious inlined helper... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01new helper: restore_saved_sigmask()Al Viro
first fruits of ..._restore_sigmask() helpers: now we can take boilerplate "signal didn't have a handler, clear RESTORE_SIGMASK and restore the blocked mask from ->saved_mask" into a common helper. Open-coded instances switched... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-23move key_repace_session_keyring() into tracehook_notify_resume()Al Viro
2012-05-21score: add handling of NOTIFY_RESUME to do_notify_resume()Al Viro
It's already called if TIF_NOTIFY_RESUME is set, so we only need to add the actual work. Note that checking for RESTORE_SIGMASK was not needed - set_restore_sigmask() also sets SIGPENDING, so we never RESTORE_SIGMASK without SIGPENDING. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-21score: don't open-code force_sigsegv()Al Viro
2012-05-21score: ->restart_block.fn needs to be reset on rt_sigreturnAl Viro
2012-05-21score: use set_current_blocked() and block_sigmask()Matt Fleming
As described in e6fa16ab ("signal: sigprocmask() should do retarget_shared_pending()") the modification of current->blocked is incorrect as we need to check whether the signal we're about to block is pending in the shared queue. Also, use the new helper function introduced in commit 5e6292c0f28f ("signal: add block_sigmask() for adding sigmask to current->blocked") which centralises the code for updating current->blocked after successfully delivering a signal and reduces the amount of duplicate code across architectures. In the past some architectures got this code wrong, so using this helper function should stop that from happening again. Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-21score: don't mask signals if we fail to setup signal stackMatt Fleming
If setup_rt_frame() returns -EFAULT then we must not block any signals in the current process. Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-05score: Use generic init_taskThomas Gleixner
Same code. Use the generic version. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chen Liqin <liqin.chen@sunplusct.com> Link: http://lkml.kernel.org/r/20120503085035.332320547@linutronix.de
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-23score: fix off-by-one index into syscall tableDan Rosenberg
If the provided system call number is equal to __NR_syscalls, the current check will pass and a function pointer just after the system call table may be called, since sys_call_table is an array with total size __NR_syscalls. Whether or not this is a security bug depends on what the compiler puts immediately after the system call table. It's likely that this won't do anything bad because there is an additional NULL check on the syscall entry, but if there happens to be a non-NULL value immediately after the system call table, this may result in local privilege escalation. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: <stable@vger.kernel.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Eugene Teo <eugeneteo@kernel.sg> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-08score: Use HAVE_MEMBLOCK_NODE_MAPTejun Heo
score used early_node_map[] just to prime free_area_init_nodes(). Now memblock can be used for the same purpose and early_node_map[] is scheduled to be dropped. Use memblock instead. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com>
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-03-28score: Use generic show_interrupts()Thomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Chen Liqin <liqin.chen@sunplusct.com>
2011-03-28score: Convert to new irq function namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Chen Liqin <liqin.chen@sunplusct.com>
2011-03-28score: Convert irq_chip to new functionsThomas Gleixner
Use the proper accessor functions in show_interrupts() while at it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Chen Liqin <liqin.chen@sunplusct.com>
2010-10-27ptrace: cleanup arch_ptrace() on scoreNamhyung Kim
Remove unnecessary castings. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-17score: fixed pfn_valid define.Chen Liqin
Signed-off-by: Cui Bixiong <bixiong@sunnorth.com.cn> Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com> modified: arch/score/include/asm/page.h modified: arch/score/kernel/setup.c modified: arch/score/mm/init.c
2009-12-11Add missing alignment check in arch/score sys_mmap()Al Viro
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-23score: Cleanup linker script using new macros.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
