path: root/arch/score
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25lib: consolidate DEBUG_STACK_USAGE optionStephen Boyd
Most arches define CONFIG_DEBUG_STACK_USAGE exactly the same way. Move it to lib/Kconfig.debug so each arch doesn't have to define it. This obviously makes the option generic, but that's fine because the config is already used in generic code. It's not obvious to me that sysrq-P actually does anything caution by keeping the most inclusive wording. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-30genirq: Remove the now obsolete config options and select statementsThomas Gleixner
2011-03-28score: Use generic show_interrupts()Thomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Chen Liqin <liqin.chen@sunplusct.com>
2011-03-28score: Convert to new irq function namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Chen Liqin <liqin.chen@sunplusct.com>
2011-03-28score: lost a semicolon in asm/irqflags.hChen Liqin
2011-03-28score: Select GENERIC_HARDIRQS_NO_DEPRECATEDThomas Gleixner
All chips converted and proper accessor functions used. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Chen Liqin <liqin.chen@sunplusct.com>
2011-03-28score: Convert irq_chip to new functionsThomas Gleixner
Use the proper accessor functions in show_interrupts() while at it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Chen Liqin <liqin.chen@sunplusct.com>
2011-03-22mm: NUMA aware alloc_thread_info_node()Eric Dumazet
Add a node parameter to alloc_thread_info(), and change its name to alloc_thread_info_node() This change is needed to allow NUMA aware kthread_create_on_cpu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-21score: Use generic irq KconfigThomas Gleixner
No functional change Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Chen Liqin <liqin.chen@sunplusct.com>
2011-01-21genirq: Remove __do_IRQThomas Gleixner
All architectures are finally converted. Remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Michal Simek <monstr@monstr.eu> Acked-by: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-27ptrace: cleanup arch_ptrace() on scoreNamhyung Kim
Remove unnecessary castings. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: remove pte_*map_nested()Peter Zijlstra
Since we no longer need to provide KM_type, the whole pte_*map_nested() API is now redundant, remove it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-12Merge branch 'kbuild/rc-fixes' into kbuild/kconfigMichal Marek
We need to revert the temporary hack in 71ebc01, hence the merge.
2010-10-07Fix IRQ flag handling namingDavid Howells
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration, it maps: local_irq_enable() -> raw_local_irq_enable() local_irq_disable() -> raw_local_irq_disable() local_irq_save() -> raw_local_irq_save() ... and under the other configuration, it maps: raw_local_irq_enable() -> local_irq_enable() raw_local_irq_disable() -> local_irq_disable() raw_local_irq_save() -> local_irq_save() ... This is quite confusing. There should be one set of names expected of the arch, and this should be wrapped to give another set of names that are expected by users of this facility. Change this to have the arch provide: flags = arch_local_save_flags() flags = arch_local_irq_save() arch_local_irq_restore(flags) arch_local_irq_disable() arch_local_irq_enable() arch_irqs_disabled_flags(flags) arch_irqs_disabled() arch_safe_halt() Then linux/irqflags.h wraps these to provide: raw_local_save_flags(flags) raw_local_irq_save(flags) raw_local_irq_restore(flags) raw_local_irq_disable() raw_local_irq_enable() raw_irqs_disabled_flags(flags) raw_irqs_disabled() raw_safe_halt() with type checking on the flags 'arguments', and then wraps those to provide: local_save_flags(flags) local_irq_save(flags) local_irq_restore(flags) local_irq_disable() local_irq_enable() irqs_disabled_flags(flags) irqs_disabled() safe_halt() with tracing included if enabled. The arch functions can now all be inline functions rather than some of them having to be macros. Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300] Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile] Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM] Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR] Acked-by: Tony Luck <tony.luck@intel.com> [IA-64] Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R] Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU] Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC] Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC] Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390] Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score] Acked-by: Matt Fleming <matt@console-pimps.org> [SH] Acked-by: David S. Miller <davem@davemloft.net> [Sparc] Acked-by: Chris Zankel <chris@zankel.net> [Xtensa] Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha] Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300] Cc: starvik@axis.com [CRIS] Cc: jesper.nilsson@axis.com [CRIS] Cc: linux-cris-kernel@axis.com
2010-09-19kbuild: migrate all arch to the kconfig mainmenu upgradeArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Reviewed-by: Michal Marek <mmarek@suse.cz>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-12score: fix dereference of NULL pointer in local_flush_tlb_page()Roel Kluin
Don't dereference vma if it's NULL. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-07remove needless ISA_DMA_THRESHOLDFUJITA Tomonori
Architectures don't need to define ISA_DMA_THRESHOLD anymore. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: James Bottomley <James.Bottomley@suse.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-06Merge branch 'timers-timekeeping-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: um: Fix read_persistent_clock fallout kgdb: Do not access xtime directly powerpc: Clean up obsolete code relating to decrementer and timebase powerpc: Rework VDSO gettimeofday to prevent time going backwards clocksource: Add __clocksource_updatefreq_hz/khz methods x86: Convert common clocksources to use clocksource_register_hz/khz timekeeping: Make xtime and wall_to_monotonic static hrtimer: Cleanup direct access to wall_to_monotonic um: Convert to use read_persistent_clock timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset powerpc: Cleanup xtime usage powerpc: Simplify update_vsyscall time: Kill off CONFIG_GENERIC_TIME time: Implement timespec_add x86: Fix vtime/file timestamp inconsistencies Trivial conflicts in Documentation/feature-removal-schedule.txt Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as per Thomas' earlier merge commit 47916be4e28c ("Merge branch 'powerpc.cherry-picks' into timers/clocksource")
2010-08-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits) tracing/kprobes: unregister_trace_probe needs to be called under mutex perf: expose event__process function perf events: Fix mmap offset determination perf, powerpc: fsl_emb: Restore setting perf_sample_data.period perf, powerpc: Convert the FSL driver to use local64_t perf tools: Don't keep unreferenced maps when unmaps are detected perf session: Invalidate last_match when removing threads from rb_tree perf session: Free the ref_reloc_sym memory at the right place x86,mmiotrace: Add support for tracing STOS instruction perf, sched migration: Librarize task states and event headers helpers perf, sched migration: Librarize the GUI class perf, sched migration: Make the GUI class client agnostic perf, sched migration: Make it vertically scrollable perf, sched migration: Parameterize cpu height and spacing perf, sched migration: Fix key bindings perf, sched migration: Ignore unhandled task states perf, sched migration: Handle ignored migrate out events perf: New migration tool overview tracing: Drop cpparg() macro perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call ... Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
2010-08-04Merge commit 'v2.6.35' into kbuild/kbuildMichal Marek
Conflicts: arch/powerpc/Makefile
2010-08-03kbuild: allow assignment to {A,C,LD}FLAGS_MODULE on the command lineSam Ravnborg
It is now possible to assign options to AS, CC and LD on the command line - which is only used when building modules. {A,C,LD}FLAGS_MODULE was all used both in the top-level Makefile in the arch makefiles, thus users had no way to specify additional options to AS, CC, LD when building modules without overriding the original value. Introduce a new set of variables KBUILD_{A,C,LD}FLAGS_MODULE that is used by arch specific files and free up {A,C,LD}FLAGS_MODULE so they can be assigned on the command line. All arch Makefiles that used the old variables has been updated. Note: Previously we had a MODFLAGS variable for both AS and CC. But in favour of consistency this was dropped. So in some cases arch Makefile has one assignmnet replaced by two assignmnets. Note2: MODFLAGS was not documented and is dropped without any notice. I do not expect much/any breakage from this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin] Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [avr32] Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-07-27time: Kill off CONFIG_GENERIC_TIMEJohn Stultz
Now that all arches have been converted over to use generic time via clocksources or arch_gettimeoffset(), we can remove the GENERIC_TIME config option and simplify the generic code. Signed-off-by: John Stultz <johnstul@us.ibm.com> LKML-Reference: <1279068988-21864-4-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-06-09arch: Implement local64_tPeter Zijlstra
On 64bit, local_t is of size long, and thus we make local64_t an alias. On 32bit, we fall back to atomic64_t. (architecture can provide optimized 32-bit version) (This new facility is to be used by perf events optimizations.) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-arch@vger.kernel.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-27asm-generic: remove ISA_DMA_THRESHOLD in scatterlist.hFUJITA Tomonori
This is the first half of the attempt to use asm-generic/scatterlist.h on every architecture. There are only two ways to define scatterlist structure. So it's easy to convert every architecture to use asm-generic/scatterlist.h. This patch: The trick for ISA_DMA_THRESHOLD in asm-generic/scatterlist.h doesn't work for powerpc. This lets architectures defin ISA_DMA_THRESHOLD. Hopefully, we can remove ISA_DMA_THRESHOLD in the future; we can do better to decide if the bouncing is necessary or not. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-14add descriptive comment for TIF_MEMDIE task flag declaration.Andreas Dilger
Signed-off-by: Andreas Dilger <adilger@dilger.ca> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12ptrace: move user_enable_single_step & co prototypes to linux/ptrace.hChristoph Hellwig
While in theory user_enable_single_step/user_disable_single_step/ user_enable_blockstep could also be provided as an inline or macro there's no good reason to do so, and having the prototype in one places keeps code size and confusion down. Roland said: The original thought there was that user_enable_single_step() et al might well be only an instruction or three on a sane machine (as if we have any of those!), and since there is only one call site inlining would be beneficial. But I agree that there is no strong reason to care about inlining it. As to the arch changes, there is only one thought I'd add to the record. It was always my thinking that for an arch where PTRACE_SINGLESTEP does text-modifying breakpoint insertion, user_enable_single_step() should not be provided. That is, arch_has_single_step()=>true means that there is an arch facility with "pure" semantics that does not have any unexpected side effects. Inserting a breakpoint might do very unexpected strange things in multi-threaded situations. Aside from that, it is a peculiar side effect that user_{enable,disable}_single_step() should cause COW de-sharing of text pages and so forth. For PTRACE_SINGLESTEP, all these peculiarities are the status quo ante for that arch, so having arch_ptrace() itself do those is one thing. But for building other things in the future, it is nicer to have a uniform "pure" semantics that arch-independent code can expect. OTOH, all such arch issues are really up to the arch maintainer. As of today, there is nothing but ptrace using user_enable_single_step() et al so it's a distinction without a practical difference. If/when there are other facilities that use user_enable_single_step() and might care, the affected arch's can revisit the question when someone cares about the quality of the arch support for said new facility. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-02-20MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itselfRussell King
On VIVT ARM, when we have multiple shared mappings of the same file in the same MM, we need to ensure that we have coherency across all copies. We do this via make_coherent() by making the pages uncacheable. This used to work fine, until we allowed highmem with highpte - we now have a page table which is mapped as required, and is not available for modification via update_mmu_cache(). Ralf Beache suggested getting rid of the PTE value passed to update_mmu_cache(): On MIPS update_mmu_cache() calls __update_tlb() which walks pagetables to construct a pointer to the pte again. Passing a pte_t * is much more elegant. Maybe we might even replace the pte argument with the pte_t? Ben Herrenschmidt would also like the pte pointer for PowerPC: Passing the ptep in there is exactly what I want. I want that -instead- of the PTE value, because I have issue on some ppc cases, for I$/D$ coherency, where set_pte_at() may decide to mask out the _PAGE_EXEC. So, pass in the mapped page table pointer into update_mmu_cache(), and remove the PTE value, updating all implementations and call sites to suit. Includes a fix from Stephen Rothwell: sparc: fix fallout from update_mmu_cache API change Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-17Merge branch 'linus' into x86/mmThomas Gleixner
x86/mm is on 32-rc4 and missing the spinlock namespace changes which are needed for further commits into this topic. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-02-01resources: introduce generic page_is_ram()Wu Fengguang
It's based on walk_system_ram_range(), for archs that don't have their own page_is_ram(). The static verions in MIPS and SCORE are also made global. v4: prefer plain 1 instead of PAGE_IS_RAM (H. Peter Anvin) v3: add comment (KAMEZAWA Hiroyuki) "AFAIK, this "System RAM" information has been used for kdump to grab valid memory area and seems good for the kernel itself." v2: add PAGE_IS_RAM macro (Américo Wang) Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Américo Wang <xiyou.wangcong@gmail.com> Cc: linux-mips@linux-mips.org Cc: Yinghai Lu <yinghai@kernel.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> LKML-Reference: <20100122081619.GA6431@localhost> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-01-11mm: make totalhigh_pages unsigned longAndreas Fenkart
Makes it consistent with the extern declaration, used when CONFIG_HIGHMEM is set Removes redundant casts in printout messages Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17Merge branch 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-scoreLinus Torvalds
* 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-score: score: include asm-generic/param.h in asm/delay.h. score: fixed pfn_valid define. score: add flush_dcahce_page and PG_dcache_dirty define
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-17score: include asm-generic/param.h in asm/delay.h.Chen Liqin
Signed-off-by: Cui Bixiong <bixiong@sunnorth.com.cn> Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com>
2009-12-17score: fixed pfn_valid define.Chen Liqin
Signed-off-by: Cui Bixiong <bixiong@sunnorth.com.cn> Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com> modified: arch/score/include/asm/page.h modified: arch/score/kernel/setup.c modified: arch/score/mm/init.c
2009-12-17score: add flush_dcahce_page and PG_dcache_dirty defineChen Liqin
Signed-off-by: Cui Bixiong <bixiong@sunnorth.com.cn> Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com> modified: arch/score/include/asm/cacheflush.h modified: arch/score/mm/cache.c
2009-12-16elf: kill USE_ELF_CORE_DUMPChristoph Hellwig
Currently all architectures but microblaze unconditionally define USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so let's kill this ifdef and make sure we are the same everywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <linux-arch@vger.kernel.org> Cc: Michal Simek <michal.simek@petalogix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-12score: add asm/asm-offsets.h wrapperMichal Marek
A recent kbuild patch moved asm-offsets.h to include/generated. Provide a wrapper header as for other architectures. Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-11Add missing alignment check in arch/score sys_mmap()Al Viro
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
