path: root/arch/score
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-11-26block: add helpers to run flush_dcache_page() against a bio and a request's ↵Ilya Loginov
pages Mtdblock driver doesn't call flush_dcache_page for pages in request. So, this causes problems on architectures where the icache doesn't fill from the dcache or with dcache aliases. The patch fixes this. The ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE symbol was introduced to avoid pointless empty cache-thrashing loops on architectures for which flush_dcache_page() is a no-op. Every architecture was provided with this flush pages on architectires where ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE is equal 1 or do nothing otherwise. See "fix mtd_blkdevs problem with caches on some architectures" discussion on LKML for more information. Signed-off-by: Ilya Loginov <isloginov@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Peter Horton <phorton@bitbox.co.uk> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-23score: Cleanup linker script using new macros.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com>
2009-09-23score: Make THREAD_SIZE available to assembly files.Tim Abbott
2009-09-23score: Make PAGE_SIZE available to assembly.Tim Abbott
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-17score: add TIF_NOTIFY_RESUME define in asm/thread_info.hChen Liqin
2009-08-30score: make init_thread_union align to THREAD_SIZEChen Liqin
2009-08-30score: update files according to review comments.Chen Liqin
2009-08-30score: add old syscall supportChen Liqin
2009-08-30score: add MEMORY_START and MEMORY_SIZE define, to make the code clearChen Liqin
2009-08-30score: update inconsistent declare after .c was changedChen Liqin
2009-08-30score: remove unused code, add include files in .cChen Liqin
2009-06-27score: clean up mm/init.cArnd Bergmann
score does not need multiple zero pages, because it does not suffer from cache aliasing problems, so simplify that code. Also make some functions static and include the appropriate header files. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-27score: make irq.h definitions localArnd Bergmann
Some internal definitions of the interrupt controller are only needed in irq.c, so move them out of the global irq.h header. Also add proper __iomem annotations for sparse. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-27score: cleanups: dead code, 0 as pointer, shadowed variablesArnd Bergmann
A few smaller issues found by sparse, some code that was never used, two instances of '0' instead of 'NULL' and local variables shadowing another one. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-27score: fix function prototypesArnd Bergmann
Syscalls should return 'long' and be marked as 'asmlinkage'. Functions that are only used in a single file should be 'static'. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-27score: add address space annotationsArnd Bergmann
Annotate the address space for pointers that are used correctly with __user and __iomem, so that sparse can better warn about incorrect casts. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-27score: add missing #includesArnd Bergmann
Files that define a global function should #include the header with its declaration to make sure that the prototypes do not diverge. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-22score: move save arg5 and arg6 instruction in front of enable_irqChen Liqin
Because enable_irq clobber r8 before arg5 was saved. modified: arch/score/kernel/entry.S Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-19score: add prototypes for wrapped syscallsArnd Bergmann
Every system call should be declared, so this adds missing declarations for the ones we were missing so far. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-19score: remove init_mmArnd Bergmann
init_mm is now part of the common code and not provided by the architecture any more. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-19score: add generic sys_call_tableArnd Bergmann
This adds back a sys_call_table to the score architecture, which got lost in the conversion to the generic unistd.h file. It's rather worrying that the code got submitted without a system call table, which evidently means that it got zero testing. Since the system call table has a different layout from the old one (which was modeled after the mips-o32 one), I also try to fix the entry.S path to use it. In the modified calling conventions, all system call arguments are passed as registers r4 through r9, instead of r4 through r7 plus stack for the fifth and sixth argument. This matches what other architectures to when they normally pass arguments on the stack. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-19score: remove __{put,get}_user_unknownArnd Bergmann
The point of these extern declarations is to provoke a link error, so an architecture must not provide a symbol for them. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-19score: unset __ARCH_WANT_IPC_PARSE_VERSIONArnd Bergmann
This really should not be needed. The change for not changing the IPC code for every new architecture just went into 2.6.31, so we can skip it now. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-19score: update files according to review commentsChen Liqin
modified: arch/score/include/asm/cacheflush.h modified: arch/score/include/asm/delay.h modified: arch/score/include/asm/errno.h modified: arch/score/include/asm/pgtable-bits.h modified: arch/score/include/asm/pgtable.h modified: arch/score/include/asm/ptrace.h modified: arch/score/include/asm/unistd.h modified: arch/score/kernel/entry.S modified: arch/score/kernel/process.c modified: arch/score/kernel/ptrace.c modified: arch/score/kernel/signal.c modified: arch/score/kernel/sys_score.c modified: arch/score/kernel/traps.c modified: arch/score/mm/cache.c Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-19score: Add support for Sunplus S+core architectureChen Liqin
This is the complete set of new arch Score's files for linux. Score instruction set support 16bits, 32bits and 64bits instruction, Score SOC had been used in game machine and LCD TV. Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
