path: root/arch/score
2014-01-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - a new jpeg codec driver for Samsung Exynos (jpeg-hw-exynos4) - a new dvb frontend for ds2103 chipset (m88ds2103) - a new sensor driver for Samsung S5K5BAF UXGA (s5k5baf) - new drivers for R-Car VSP1 - a new radio driver: radio-raremono - a new tuner driver for ts2022 chipset (m88ts2022) - the analog part of em28xx is now a separate module that only load/runs if the device is not a pure digital TV device - added a staging driver for bcm2048 radio devices - the omap 2 video driver (omap24xx) was moved to staging. This driver is for an old hardware and uses a deprecated Kernel internal API. If nobody cares enough to fix it, it would be removed on a couple Kernel releases - the sn9c102 driver was moved to staging. This driver was replaced by gspca, and disabled on some distros, as almost all devices are known to work properly with gspca. It should be removed from kernel on a couple Kernel releases - lots of driver fixes, improvements and cleanups * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (421 commits) [media] media: v4l2-dev: fix video device index assignment [media] rc-core: reuse device numbers [media] em28xx-cards: properly initialize the device bitmap [media] Staging: media: Fix line length exceeding 80 characters in as102_drv.c [media] Staging: media: Fix line length exceeding 80 characters in as102_fe.c [media] Staging: media: Fix quoted string split across line in as102_fe.c [media] media: st-rc: Add reset support [media] m2m-deinterlace: fix allocated struct type [media] radio-usb-si4713: fix sparse non static symbol warnings [media] em28xx-audio: remove needless check before usb_free_coherent() [media] au0828: Fix sparse non static symbol warning Revert "[media] go7007-usb: only use go->dev after allocated" [media] em28xx-audio: provide an error code when URB submit fails [media] em28xx: fix check for audio only usb interfaces when changing the usb alternate setting [media] em28xx: fix usb alternate setting for analog and digital video endpoints > 0 [media] em28xx: make 'em28xx_ctrl_ops' static em28xx-alsa: Fix error patch for init/fini [media] em28xx-audio: flush work at .fini [media] drxk: remove the option to load firmware asynchronously [media] em28xx: adjust period size at runtime ...
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-21score: remove "select HAVE_GENERIC_HARDIRQS" againGeert Uytterhoeven
Commit 5fbbf8a1a934 ("Score: The commit is for compiling successfully.") re-introduced "select HAVE_GENERIC_HARDIRQS" in v3.12-rc4, which had just been removed in v3.12-rc1 by 0244ad004a5 ("Remove GENERIC_HARDIRQ config option"). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-13arch: Re-sort some Kbuild files to hopefully help avoid some conflictsStephen Rothwell
Checkin: 93ea02bb8435 arch: Clean up asm/barrier.h implementations using asm-generic/barrier.h ... unfortunately left some Kbuild files out of order, which caused unnecessary merge conflicts, in particular with checkin: e3fec2f74f7f lib: Add missing arch generic-y entries for asm-generic/hash.h Put them back in order to make the upcoming merges cleaner. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Link: http://lkml.kernel.org/r/20140114164420.d296fbcc4be3a5f126c86069@canb.auug.org.au Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Miller <davem@davemloft.net>
2014-01-13net: resort some Kbuild files to hopefully help avoid some conflictsStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-12arch: Clean up asm/barrier.h implementations using asm-generic/barrier.hPeter Zijlstra
We're going to be adding a few new barrier primitives, and in order to avoid endless duplication make more agressive use of asm-generic/barrier.h. Change the asm-generic/barrier.h such that it allows partial barrier definitions and fills out the rest with defaults. There are a few architectures (m32r, m68k) that could probably do away with their barrier.h file entirely but are kept for now due to their unconventional nop() implementation. Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Michael Neuling <mikey@neuling.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Victor Kaplansky <VICTORK@il.ibm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20131213150640.846368594@infradead.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-12-17lib: Add missing arch generic-y entries for asm-generic/hash.hDavid S. Miller
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-10[media] doc: no singingKees Cook
Stop that, stop that! You're not going to do a song while I'm here. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-19Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq cleanups from Ingo Molnar: "This is a multi-arch cleanup series from Thomas Gleixner, which we kept to near the end of the merge window, to not interfere with architecture updates. This series (motivated by the -rt kernel) unifies more aspects of IRQ handling and generalizes PREEMPT_ACTIVE" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: preempt: Make PREEMPT_ACTIVE generic sparc: Use preempt_schedule_irq ia64: Use preempt_schedule_irq m32r: Use preempt_schedule_irq hardirq: Make hardirq bits generic m68k: Simplify low level interrupt handling code genirq: Prevent spurious detection for unconditionally polled interrupts
2013-11-15score: handle pgtable_page_ctor() failKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Acked-by: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13preempt: Make PREEMPT_ACTIVE genericThomas Gleixner
No point in having this bit defined by architecture. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20130917183629.090698799@linutronix.de
2013-10-09Merge tag 'v3.12-rc4' into sched/coreIngo Molnar
Merge Linux v3.12-rc4 to fix a conflict and also to refresh the tree before applying more scheduler patches. Conflicts: arch/avr32/include/asm/Kbuild Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-26Score: Modify the Makefile of Score, remove -mlong-calls for compilingLennox Wu
Signed-off-by: Lennox Wu <lennox.wu@gmail.com>
2013-09-26Score: Implement the function csum_ipv6_magicLennox Wu
2013-09-26Score: The commit is for compiling successfully.Lennox Wu
The modifications include: 1. Kconfig of Score: we don't support ioremap 2. Missed headfile including 3. There are some errors in other people's commit not checked by us, we fix it now 3.1 arch/score/kernel/entry.S: wrong instructions 3.2 arch/score/kernel/process.c : just some typos Signed-off-by: Lennox Wu <lennox.wu@gmail.com>
2013-09-25sched, arch: Create asm/preempt.hPeter Zijlstra
In order to prepare to per-arch implementations of preempt_count move the required bits into an asm-generic header and use this for all archs. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-12arch: mm: pass userspace fault flag to generic fault handlerJohannes Weiner
Unlike global OOM handling, memory cgroup code will invoke the OOM killer in any OOM situation because it has no way of telling faults occuring in kernel context - which could be handled more gracefully - from user-triggered faults. Pass a flag that identifies faults originating in user space from the architecture-specific fault handlers to generic code so that memcg OOM handling can be improved. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12arch: mm: remove obsolete init OOM protectionJohannes Weiner
The memcg code can trap tasks in the context of the failing allocation until an OOM situation is resolved. They can hold all kinds of locks (fs, mm) at this point, which makes it prone to deadlocking. This series converts memcg OOM handling into a two step process that is started in the charge context, but any waiting is done after the fault stack is fully unwound. Patches 1-4 prepare architecture handlers to support the new memcg requirements, but in doing so they also remove old cruft and unify out-of-memory behavior across architectures. Patch 5 disables the memcg OOM handling for syscalls, readahead, kernel faults, because they can gracefully unwind the stack with -ENOMEM. OOM handling is restricted to user triggered faults that have no other option. Patch 6 reworks memcg's hierarchical OOM locking to make it a little more obvious wth is going on in there: reduce locked regions, rename locking functions, reorder and document. Patch 7 implements the two-part OOM handling such that tasks are never trapped with the full charge stack in an OOM situation. This patch: Back before smart OOM killing, when faulting tasks were killed directly on allocation failures, the arch-specific fault handlers needed special protection for the init process. Now that all fault handlers call into the generic OOM killer (see commit 609838cfed97: "mm: invoke oom-killer from remaining unconverted page fault handlers"), which already provides init protection, the arch-specific leftovers can be removed. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13arch: *: Kconfig: add "kernel/Kconfig.freezer" to "arch/*/Kconfig"Chen Gang
All architectures include "kernel/Kconfig.freezer" except three left, so let them include it too, or 'allmodconfig' will report error. The related errors: (with allmodconfig for openrisc): CC kernel/cgroup_freezer.o kernel/cgroup_freezer.c: In function 'freezer_css_online': kernel/cgroup_freezer.c:133:15: error: 'system_freezing_cnt' undeclared (first use in this function) kernel/cgroup_freezer.c:133:15: note: each undeclared identifier is reported only once for each function it appears in kernel/cgroup_freezer.c: In function 'freezer_css_offline': kernel/cgroup_freezer.c:157:15: error: 'system_freezing_cnt' undeclared (first use in this function) kernel/cgroup_freezer.c: In function 'freezer_attach': kernel/cgroup_freezer.c:200:4: error: implicit declaration of function 'freeze_task' kernel/cgroup_freezer.c: In function 'freezer_apply_state': kernel/cgroup_freezer.c:371:16: error: 'system_freezing_cnt' undeclared (first use in this function) Signed-off-by: Chen Gang <gang.chen@asianux.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-14score: delete __cpuinit usage from all score filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) are flagged as __cpuinit -- so if we remove the __cpuinit from arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. This removes all the arch/score uses of the __cpuinit macros from all C files. Currently score does not have any __CPUINIT used in assembly files. [1] https://lkml.org/lkml/2013/5/20/589 Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-07-09mm: invoke oom-killer from remaining unconverted page fault handlersJohannes Weiner
A few remaining architectures directly kill the page faulting task in an out of memory situation. This is usually not a good idea since that task might not even use a significant amount of memory and so may not be the optimal victim to resolve the situation. Since 2.6.29's 1c0fe6e ("mm: invoke oom-killer from page fault") there is a hook that architecture page fault handlers are supposed to call to invoke the OOM killer and let it pick the right task to kill. Convert the remaining architectures over to this hook. To have the previous behavior of simply taking out the faulting task the vm.oom_kill_allocating_task sysctl can be set to 1. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc bits] Cc: James Hogan <james.hogan@imgtec.com> Cc: David Howells <dhowells@redhat.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - various misc bits - I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been distracted. There has been quite a bit of activity. - About half the MM queue - Some backlight bits - Various lib/ updates - checkpatch updates - zillions more little rtc patches - ptrace - signals - exec - procfs - rapidio - nbd - aoe - pps - memstick - tools/testing/selftests updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits) tools/testing/selftests: don't assume the x bit is set on scripts selftests: add .gitignore for kcmp selftests: fix clean target in kcmp Makefile selftests: add .gitignore for vm selftests: add hugetlbfstest self-test: fix make clean selftests: exit 1 on failure kernel/resource.c: remove the unneeded assignment in function __find_resource aio: fix wrong comment in aio_complete() drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode drivers/memstick/host/r592.c: convert to module_pci_driver drivers/memstick/host/jmb38x_ms: convert to module_pci_driver pps-gpio: add device-tree binding and support drivers/pps/clients/pps-gpio.c: convert to module_platform_driver drivers/pps/clients/pps-gpio.c: convert to devm_* helpers drivers/parport/share.c: use kzalloc Documentation/accounting/getdelays.c: avoid strncpy in accounting tool aoe: update internal version number to v83 aoe: update copyright date aoe: perform I/O completions in parallel ...
2013-07-03mm/score: prepare for removing num_physpages and simplify mem_init()Jiang Liu
Prepare for removing num_physpages and simplify mem_init(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03score: normalize global variables exported by vmlinux.ldsJiang Liu
Generate mandatory global variables _sdata in file vmlinux.lds. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: concentrate modification of totalram_pages into the mm coreJiang Liu
Concentrate code to modify totalram_pages into the mm core, so the arch memory initialized code doesn't need to take care of it. With these changes applied, only following functions from mm core modify global variable totalram_pages: free_bootmem_late(), free_all_bootmem(), free_all_bootmem_node(), adjust_managed_page_count(). With this patch applied, it will be much more easier for us to keep totalram_pages and zone->managed_pages in consistence. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: David Howells <dhowells@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: change signature of free_reserved_area() to fix building warningsJiang Liu
Change signature of free_reserved_area() according to Russell King's suggestion to fix following build warnings: arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default] free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL); ^ In file included from include/linux/mman.h:4:0, from arch/arm/mm/init.c:15: include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *' extern unsigned long free_reserved_area(unsigned long start, unsigned long end, mm/page_alloc.c: In function 'free_reserved_area': >> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default] In file included from arch/mips/include/asm/page.h:49:0, from include/linux/mmzone.h:20, from include/linux/gfp.h:4, from include/linux/mm.h:8, from mm/page_alloc.c:18: arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int' mm/page_alloc.c: In function 'free_area_init_nodes': mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds] Also address some minor code review comments. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reported-by: Arnd Bergmann <arnd@arndb.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03Merge branch 'exotic-arch-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull "exotic" arch fixes from Geert Uytterhoeven: "This is a collection of several exotic architecture fixes, and a few other fixes for issues that were detected while doing the former" * 'exotic-arch-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (35 commits) lib: Move fonts from drivers/video/console/ to lib/fonts/ console/font: Refactor font support code selection logic Revert "staging/solo6x10: depend on CONFIG_FONTS" input: cros_ec_keyb_clear_keyboard() depends on CONFIG_PM_SLEEP score: Wire up asm-generic/xor.h score: Remove unneeded <asm/dma-mapping.h> openrisc: Wire up asm-generic/xor.h h8300/boot: Use POSIX "$((..))" instead of bashism "$[...]" h8300: Mark H83002 and H83048 CPU support broken h8300: Switch h8300 to drivers/Kconfig h8300: Limit timer channel ranges in Kconfig h8300: Wire up asm-generic/xor.h h8300: Fill the system call table using a CALL() macro h8300: Fix <asm/tlb.h> h8300: Hardcode symbol prefixes in asm sources h8300: add missing definition for read_barries_depends() frv: head.S - Remove commented-out initialization code cris: Wire up asm-generic/vga.h parport: disable PC-style parallel port support on cris console: Disable VGA text console support on cris ...
2013-06-29consolidate io_remap_pfn_range definitionsAl Viro
2013-06-23score: Wire up asm-generic/xor.hGeert Uytterhoeven
2013-06-23score: Remove unneeded <asm/dma-mapping.h>Geert Uytterhoeven
It just includes <asm-generic/dma-mapping-broken.h>, which is already handled by <linux/dma-mapping.h> for the !CONFIG_HAS_DMA case (score sets CONFIG_NO_DMA=y). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com>
2013-05-25score: remove redundant kcore_list entriesKyle McMartin
kcore_vmalloc is in fs/proc/kcore.c and kcore_mem is unused across the tree. Noticed while grepping the tree for some other kcore stuff. (score looks pretty unmaintained to me.) Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-30dump_stack: unify debug information printed by show_regs()Tejun Heo
show_regs() is inherently arch-dependent but it does make sense to print generic debug information and some archs already do albeit in slightly different forms. This patch introduces a generic function to print debug information from show_regs() so that different archs print out the same information and it's much easier to modify what's printed. show_regs_print_info() prints out the same debug info as dump_stack() does plus task and thread_info pointers. * Archs which didn't print debug info now do. alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r, metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc, um, xtensa * Already prints debug info. Replaced with show_regs_print_info(). The printed information is superset of what used to be there. arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86 * s390 is special in that it used to print arch-specific information along with generic debug info. Heiko and Martin think that the arch-specific extra isn't worth keeping s390 specfic implementation. Converted to use the generic version. Note that now all archs print the debug info before actual register dumps. An example BUG() dump follows. kernel BUG at /work/os/work/kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... v2: Typo fix in x86-32. v3: CPU number dropped from show_regs_print_info() as dump_stack_print_info() has been updated to print it. s390 specific implementation dropped as requested by s390 maintainers. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: consolidate dump_stack() implementations and unify their behaviorsTejun Heo
Both dump_stack() and show_stack() are currently implemented by each architecture. show_stack(NULL, NULL) dumps the backtrace for the current task as does dump_stack(). On some archs, dump_stack() prints extra information - pid, utsname and so on - in addition to the backtrace while the two are identical on other archs. The usages in arch-independent code of the two functions indicate show_stack(NULL, NULL) should print out bare backtrace while dump_stack() is used for debugging purposes when something went wrong, so it does make sense to print additional information on the task which triggered dump_stack(). There's no reason to require archs to implement two separate but mostly identical functions. It leads to unnecessary subtle information. This patch expands the dummy fallback dump_stack() implementation in lib/dump_stack.c such that it prints out debug information (taken from x86) and invokes show_stack(NULL, NULL) and drops arch-specific dump_stack() implementations in all archs except blackfin. Blackfin's dump_stack() does something wonky that I don't understand. Debug information can be printed separately by calling dump_stack_print_info() so that arch-specific dump_stack() implementation can still emit the same debug information. This is used in blackfin. This patch brings the following behavior changes. * On some archs, an extra level in backtrace for show_stack() could be printed. This is because the top frame was determined in dump_stack() on those archs while generic dump_stack() can't do that reliably. It can be compensated by inlining dump_stack() but not sure whether that'd be necessary. * Most archs didn't use to print debug info on dump_stack(). They do now. An example WARN dump follows. WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505() Hardware name: empty Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9 0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48 ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c 0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58 Call Trace: [<ffffffff81c614dc>] dump_stack+0x19/0x1b [<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8234a071>] init_workqueues+0x35/0x505 ... v2: CPU number added to the generic debug info as requested by s390 folks and dropped the s390 specific dump_stack(). This loses %ksp from the debug message which the maintainers think isn't important enough to keep the s390-specific dump_stack() implementation. dump_stack_print_info() is moved to kernel/printk.c from lib/dump_stack.c. Because linkage is per objecct file, dump_stack_print_info() living in the same lib file as generic dump_stack() means that archs which implement custom dump_stack() - at this point, only blackfin - can't use dump_stack_print_info() as that will bring in the generic version of dump_stack() too. v1 The v1 patch broke build on blackfin due to this issue. The build breakage was reported by Fengguang Wu. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits] Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
2013-04-29mm/score: use common help functions to free reserved pagesJiang Liu
Use common help functions to free reserved pages. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29proc: Split kcore bits from linux/procfs.h into linux/kcore.hDavid Howells
Split kcore bits from linux/procfs.h into linux/kcore.h. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org cc: sparclinux@vger.kernel.org cc: x86@kernel.org cc: linux-mm@kvack.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-17idle: Remove GENERIC_IDLE_LOOP config switchThomas Gleixner
All archs are converted over. Remove the config switch and the fallback code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-08score: Use generic idle loopThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Link: http://lkml.kernel.org/r/20130321215235.147909863@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-03-12Select VIRT_TO_BUS directly where neededStephen Rothwell
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS") I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where needed. I am not sure what I was thinking. Instead, just directly select VIRT_TO_BUS where it is needed. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27arch Kconfig: centralise CONFIG_ARCH_NO_VIRT_TO_BUSStephen Rothwell
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures that already provide virt_to_bus(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: H Hartley Sweeten <hartleys@visionengravers.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26default SET_PERSONALITY() in linux/elf.hAl Viro
2013-02-14burying unused conditionalsAl Viro
__ARCH_WANT_SYS_RT_SIGACTION, __ARCH_WANT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} - can be assumed always set.
2013-02-03score: switch to generic sigaltstackAl Viro
2013-01-03ARCH: drivers remove __dev* attributes.Greg Kroah-Hartman
This fixes up all of the smaller arches that had __dev* markings for their platform-specific drivers. CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Bob Liu <lliubbo@gmail.com> Cc: Srinivas Kandagatla <srinivas.kandagatla@st.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Myron Stowe <myron.stowe@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Thierry Reding <thierry.reding@avionic-design.de> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Cc: Mark Salter <msalter@redhat.com> Cc: Yong Zhang <yong.zhang0@gmail.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Jan Glauber <jang@linux.vnet.ibm.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "sigaltstack infrastructure + conversion for x86, alpha and um, COMPAT_SYSCALL_DEFINE infrastructure. Note that there are several conflicts between "unify SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline; resolution is trivial - just remove definitions of SS_ONSTACK and SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and include/uapi/linux/signal.h contains the unified variant." Fixed up conflicts as per Al. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to generic sigaltstack new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those generic compat_sys_sigaltstack() introduce generic sys_sigaltstack(), switch x86 and um to it new helper: compat_user_stack_pointer() new helper: restore_altstack() unify SS_ONSTACK/SS_DISABLE definitions new helper: current_user_stack_pointer() missing user_stack_pointer() instances Bury the conditionals from kernel_thread/kernel_execve series COMPAT_SYSCALL_DEFINE: infrastructure
2012-12-20UAPI: (Scripted) Disintegrate arch/score/include/asmDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com> Acked-by: Lennox Wu <lennox.wu@gmail.com> Acked-by: Liqin Chen <liqin299@gmail.com>
2012-12-19missing user_stack_pointer() instancesAl Viro
for the architectures that have usp in pt_regs and do not have user_stack_pointer() already defined. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
