path: root/arch/sh/kernel/cpu/sh4a/setup-sh7722.c
2012-08-02sh: explicitly include sh_dma.h in setup-sh7722.cGuennadi Liakhovetski
setup-sh7722.c defines several objects, whose types are defined in sh_dma.h, so, it has to be included explicitly. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-07-20sh: remove unused DMA device pointer from SIU platform dataGuennadi Liakhovetski
The SIU ALSA driver is not using the DMA device pointer for DMA channel filtering any more, it can be now removed. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2012-05-18sh: sh7722 evt2irq migration.Paul Mundt
Migrate SH7722 to evt2irq() backed hwirq lookups. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-01-12Merge branch 'sh/hwblk' into sh-latestPaul Mundt
2012-01-12sh: add a resource name for shdmaShimoda, Yoshihiro
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-11-18sh: hwblk: Kill off hwblk_id from pdev archdata.Paul Mundt
Now that nothing is using this anymore, kill off the assignments across the board. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-20sh: Fix up build fallout from serial merge.Paul Mundt
This fixes up build issues for SH7720/SH7722/SH7750 that crept in with the serial rework. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-14serial: sh-sci: Abstract register maps.Paul Mundt
This takes a bit of a sledgehammer to the horribly CPU subtype ifdef-ridden header and abstracts all of the different register layouts in to distinct types which in turn can be overriden on a per-port basis, or permitted to default to the map matching the port type at probe time. In the process this ultimately fixes up inumerable bugs with mismatches on various CPU types (particularly the legacy ones that were obviously broken years ago and no one noticed) and provides a more tightly coupled and consolidated platform for extending and implementing generic features. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-13Merge branch 'common/serial-rework' into sh-latestPaul Mundt
2011-01-13Merge branch 'master' of ↵Paul Mundt
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 into common/serial-rework Conflicts: arch/sh/kernel/cpu/sh2/setup-sh7619.c arch/sh/kernel/cpu/sh2a/setup-mxg.c arch/sh/kernel/cpu/sh2a/setup-sh7201.c arch/sh/kernel/cpu/sh2a/setup-sh7203.c arch/sh/kernel/cpu/sh2a/setup-sh7206.c arch/sh/kernel/cpu/sh3/setup-sh7705.c arch/sh/kernel/cpu/sh3/setup-sh770x.c arch/sh/kernel/cpu/sh3/setup-sh7710.c arch/sh/kernel/cpu/sh3/setup-sh7720.c arch/sh/kernel/cpu/sh4/setup-sh4-202.c arch/sh/kernel/cpu/sh4/setup-sh7750.c arch/sh/kernel/cpu/sh4/setup-sh7760.c arch/sh/kernel/cpu/sh4a/setup-sh7343.c arch/sh/kernel/cpu/sh4a/setup-sh7366.c arch/sh/kernel/cpu/sh4a/setup-sh7722.c arch/sh/kernel/cpu/sh4a/setup-sh7723.c arch/sh/kernel/cpu/sh4a/setup-sh7724.c arch/sh/kernel/cpu/sh4a/setup-sh7763.c arch/sh/kernel/cpu/sh4a/setup-sh7770.c arch/sh/kernel/cpu/sh4a/setup-sh7780.c arch/sh/kernel/cpu/sh4a/setup-sh7785.c arch/sh/kernel/cpu/sh4a/setup-sh7786.c arch/sh/kernel/cpu/sh4a/setup-shx3.c arch/sh/kernel/cpu/sh5/setup-sh5.c drivers/serial/sh-sci.c drivers/serial/sh-sci.h include/linux/serial_sci.h
2011-01-12sh: sh7722 Enable SDIO IRQsArnd Hannemann
This patch enables the interrupt generation for SDIO IRQs of the sdhi controllers of the SoC. To make sure SDIO IRQs are used, announce the MMC_CAP_SDIO_IRQ capability on migor. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-19sh: fix an SIU device name mismatchGuennadi Liakhovetski
Recent ASoC changes unified all PCM names, fix the platform code to match. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-22sh: add DMA slaves for two SDHI controllers to sh7722Guennadi Liakhovetski
SuperH SDHI controllers can use DMA, add slave definitions to sh7722. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: define DMA slaves per CPU type, remove now redundant headerGuennadi Liakhovetski
Now that DMA slave IDs are only used used in platform specific code and have become opaque cookies for the rest of the code, we can make the, CPU specific too. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-04-26SH: constify multiple DMA related objects and references to themGuennadi Liakhovetski
Lists of DMA channels and slaves are not changed, make them constant. Besides, SH7724 channel and slave configuration of both DMA controllers is identical, remove the extra copy of the configuration data. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-29sh: sh7722 clock string death.Paul Mundt
Kills off clock string usage, using the new function clock definition instead. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-10serial: sh-sci: clkdev updates for MSTP gating.Paul Mundt
This fixes up some of the I/D/F clock ambiguity in the sh-sci driver. The interface clock in most cases just wraps back to the peripheral clock, while the function clock wraps in to the MSTP bits. As the logic was somewhat inverted, this cleans that up, and also enables all CPUs with SCI MSTP bits to match function clocks through clkdev lookup. As a result, this gets rid of the clk string abuse on the sh side, and the clock string will be killed off once the ARM code has had a chance to sync up. This also enables MSTP gating on CPUs like 7786 which had never wired it up before. Impacted CPUs are primarily all SH-Mobiles, SH7785, and SH7786. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-10sh: Kill off all timer name clobbering.Paul Mundt
Now that dev_name() can be used early, we no longer require a static string. Kill off all of the superfluous timer names. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-02sh: activate runtime PM for dmaengine on sh7722 and sh7724Guennadi Liakhovetski
2010-03-02dmaengine: shdma: separate DMA headers.Guennadi Liakhovetski
Separate SH DMA headers into ones, commonly used by both drivers, and ones, specific to each of them. This will make the future development of the dmaengine driver easier. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-02dmaengine: shdma: convert to platform device resourcesGuennadi Liakhovetski
The shdma dmaengine driver currently uses numerous macros to support various platforms, selected by ifdef's. Convert it to use platform device resources and lists of channel descriptors to specify register locations, interrupt numbers and other system-specific configuration variants. Unavoidably, we have to simultaneously convert all shdma users to provide those resources. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-02sh: add DMA slave definitions and SIU platform data to sh7722 setupGuennadi Liakhovetski
This patch is required to use the SIU ASoC driver on sh7722 systems. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-02-17sh: fix sh7722 SDHI support using INTC force_disableMagnus Damm
Update the sh7722 INTC tables with force_enable support to mask out pending unsupported SDHI interrupt sources. Without this patch the kernel locks up due to a pending SDHI interrupt that the tmio_mmc driver cannot handle. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-02-09sh: sh7722/Migo-R SDHI vector mergeMagnus Damm
Merge the SDHI vectors in the sh7722 INTC table and update the SDHI platform data for Migo-R. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-12-15sh: sh4a scif pdata (sh7343/sh7366/sh7722/sh7723/sh7724)Magnus Damm
This patch breaks out the sh4a scif serial port platform data from a shared platform device to one platform device per port. Also, add serial ports to the list of early platform devices. Only sh4a SuperH Mobile processors are modified by this patch. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-25sh: Add support DMA Engine to SH7722Nobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-08-04sh: Runtime PM pdev hwblk - sh7722Magnus Damm
Add hwblk_id to on-chip sh7722 platform devices. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-07-23sh: convert processor device setup functions to arch_initcall()Magnus Damm
Convert the processor platform device setup functions from __initcall() and sometimes device_initcall() to arch_initcall(). This makes sure that the platform devices are registered a bit earlier so the devices are available when drivers register using initcall levels earlier than device_initcall(). A good example is platform devices needed by i2c-sh_mobile.c which registers a bit earlier using subsys_initcall(). Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-07-23usb: m66592-udc platform data on_chip supportMagnus Damm
Convert the m66592-udc driver to use the on_chip flag from platform data to enable on chip behaviour instead of relying on CONFIG_SUPERH_BUILT_IN_M66592 ugliness. This makes the code cleaner and also allows us to support both external and internal m66592 with the same kernel. It also makes the Kconfig part more future proof since we with this patch can add support for new processors with on-chip m66592 without modifying the Kconfig. The patch adds a m66592 header file for platform data and ties in platform data to the existing m66592 devices. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-06-24serial: sh-sci: Move SCBRR calculation algo in to platform data.Paul Mundt
This permits each port to select its own SCBRR calculation algorithm, rather than having it all ifdef'ed in the header. There are presently only 5 different variations that all parts fall under. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-06-24serial: sh-sci: Move SCSCR_INIT in to platform data.Paul Mundt
This moves all of the SCSCR_INIT definitions in to the platform data, for future consolidation. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-12sh: clkfwk: Convert SH-Mobile CPUs to use CLK_ENABLE_ON_INIT.Paul Mundt
Kill off all of the clk_always_enabled leftovers and use the new flag directly. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-08sh: Add clock id to sh-sci platform data on SH-Mobile CPUs.Paul Mundt
This adds the clock specifier to all of the SH-Mobile sh-sci ports. Impacted CPUs are SH7343/SH7366/SH7722/SH7723/SH7724. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-08sh: enable TMU clocksource on sh7722Magnus Damm
This patch enables the TMU clocksource on sh7722. To prioritize TMU over CMT we also adjust the CMT clock source rating. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-03sh: Consolidate MTU2/CMT/TMU timer platform data.Paul Mundt
All of the SH timers use a roughly identical structure for platform data, which presently is broken out for each block. Consolidate all of these definitions, as there is no reason for them to be broken out in the first place. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-03sh: TMU platform data for sh7722Magnus Damm
This patch adds TMU platform data for sh7722. Only clockevent mode is enabled for now, clocksource requires this patch: "clocksource: setup mult_orig in clocksource_enable()" Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-04-19Merge branches 'sh/earlytimer' and 'sh/shmobile-r2r-staging'Paul Mundt
2009-04-19sh: Early Platform Data for SuperH MobileMagnus Damm
Use plat_early_device_setup() to register Early Platform Data for SuperH Mobile processors. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-04-16sh: sh7722: Don't default enable the RTC clock.Paul Mundt
rtc-sh takes care of this now, so no need to have this always enabled. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-01-29sh: CMT platform data for sh7723/sh7722/sh7366/sh7343Magnus Damm
CMT platform data for SuperH Mobile sh7723/sh7722/sh7343/sh7366. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-01-21sh: export the sh7343 JPU to user spaceMagnus Damm
This patch exports the sh7343 JPU to user space using uio_pdrv_genirq, very similar to the sh7722 JPU patch by Hayama-san. While at it fix up the end of the sh7722 JPU iomem resource. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-12-22sh: add UIO support for JPU on SH7722.Takanari Hayama
Add JPU support on Migo-R via UIO. This make use of Magnus's generic UIO platform driver. Chunk of contiguous memory to hold intermediate image and compressed data during encode and decode. Signed-off-by: Takanari Hayama <taki@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-12-22sh: remove old sh_mobile mstpc clocksMagnus Damm
Remove the old sh_mobile mstpcr clocks. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-12-22sh: sh_mobile usbf clock framework supportMagnus Damm
Add clock framework support to the usbf/m66592 driver and adjust the cpu specific code accordingly. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-12-22sh: sh_mobile i2c clock framework supportMagnus Damm
Add clock framework support to the sh_mobile i2c driver and adjust the processor specific code accordingly. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-10-28sh: Add on-chip RTC support for SH7722.Paul Mundt
2008-07-28sh: Use clk_always_enable() on sh7722 / Migo-R / SE7722Magnus Damm
Use clk_always_enable() on the sh7722 processor and in the board code for Migo-R and Solution Engine 7722. Remove duplicate MSTPCR register definitions. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add memory chunks to SH-Mobile UIO devicesMagnus Damm
This patch adds physically contiguous memory chunks to the UIO devices. The same strategy can be used in the future for the CEU as well. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Export sh7722 VPU and VEU using uio_pdrv_genirqMagnus Damm
This patch exports the VPU and VEU blocks of the sh7722 to user space using the uio_pdrv_genirq platform driver. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: add interrupt ack code to sh4aYoshihiro Shimoda
This patch is based on interrupt acknowledge code for external interrupt sources on sh3 processors and adds on sh4a processors. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
