This takes a bit of a sledgehammer to the horribly CPU subtype
ifdef-ridden header and abstracts all of the different register layouts
in to distinct types which in turn can be overriden on a per-port basis,
or permitted to default to the map matching the port type at probe time.
In the process this ultimately fixes up inumerable bugs with mismatches
on various CPU types (particularly the legacy ones that were obviously
broken years ago and no one noticed) and provides a more tightly coupled
and consolidated platform for extending and implementing generic
features.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 into common/serial-rework
arch/sh/kernel/cpu/sh2/setup-sh7619.c
arch/sh/kernel/cpu/sh2a/setup-mxg.c
arch/sh/kernel/cpu/sh2a/setup-sh7201.c
arch/sh/kernel/cpu/sh2a/setup-sh7203.c
arch/sh/kernel/cpu/sh2a/setup-sh7206.c
arch/sh/kernel/cpu/sh3/setup-sh7705.c
arch/sh/kernel/cpu/sh3/setup-sh770x.c
arch/sh/kernel/cpu/sh3/setup-sh7710.c
arch/sh/kernel/cpu/sh3/setup-sh7720.c
arch/sh/kernel/cpu/sh4/setup-sh4-202.c
arch/sh/kernel/cpu/sh4/setup-sh7750.c
arch/sh/kernel/cpu/sh4/setup-sh7760.c
arch/sh/kernel/cpu/sh4a/setup-sh7343.c
arch/sh/kernel/cpu/sh4a/setup-sh7366.c
arch/sh/kernel/cpu/sh4a/setup-sh7722.c
arch/sh/kernel/cpu/sh4a/setup-sh7723.c
arch/sh/kernel/cpu/sh4a/setup-sh7724.c
arch/sh/kernel/cpu/sh4a/setup-sh7763.c
arch/sh/kernel/cpu/sh4a/setup-sh7770.c
arch/sh/kernel/cpu/sh4a/setup-sh7780.c
arch/sh/kernel/cpu/sh4a/setup-sh7785.c
arch/sh/kernel/cpu/sh4a/setup-sh7786.c
arch/sh/kernel/cpu/sh4a/setup-shx3.c
arch/sh/kernel/cpu/sh5/setup-sh5.c
drivers/serial/sh-sci.c
drivers/serial/sh-sci.h
include/linux/serial_sci.h
Now with the lookup aliases in place there is no longer any need to
provide the clock string, kill it off for all legacy CPG CPUs.
Now that dev_name() can be used early, we no longer require a static
string. Kill off all of the superfluous timer names.
The old ctrl in/out routines are non-portable and unsuitable for
cross-platform use. While drivers/sh has already been sanitized, there
is still quite a lot of code that is not. This converts the arch/sh/ bits
over, which permits us to flag the routines as deprecated whilst still
building with -Werror for the architecture code, and to ensure that
future users are not added.
This patch breaks out the sh4a scif serial port platform
data from a shared platform device to one platform
device per port. Also, add serial ports to the list of
early platform devices.
All sh4a except SuperH Mobile processors are modified by
this patch.
While at it, sh7757 gets early platform device support.
Signed-off-by: Magnus Damm <damm@opensource.se>
Convert the processor platform device setup
functions from __initcall() and sometimes
device_initcall() to arch_initcall().
This makes sure that the platform devices are
registered a bit earlier so the devices are
available when drivers register using initcall
levels earlier than device_initcall().
A good example is platform devices needed by
i2c-sh_mobile.c which registers a bit earlier
using subsys_initcall().
Signed-off-by: Magnus Damm <damm@igel.co.jp>
This permits each port to select its own SCBRR calculation algorithm,
rather than having it all ifdef'ed in the header. There are presently
only 5 different variations that all parts fall under.
This moves all of the SCSCR_INIT definitions in to the platform data,
for future consolidation.
For consistenct naming, and to allow us to fix up some confusion in the
SH-Mobile clock framework, amongst other places.
This patch adds TMU platform data for sh7763. Both clockevent
and clocksource support is enabled.
This was accidentally dropped in the multiple vectors per irq conversion.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Update intc tables and platform data to use one linux irq
per maskable interrupt source instead of keeping the one-to-one
mapping between vectors and linux irqs.
This fixes potential irq masking issues for sh7763 hardware
blocks such as RTC/SCIF/DMAC/GETHER/PCIC5/MMCIF/SIM/GPIO/USBF.
This patch is based on interrupt acknowledge code for external
interrupt sources on sh3 processors and adds on sh4a processors.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
SH7763 has 3 SCIF device. Current code supports SCIF0 and 1.
SCIF0 and 1 are same register constitution, but only SCIF2 is different.
I added support of SCIF2.
SH7763's setup code use old DECLARE_INTC_DESC.
There was a compile error because of this.
This header is needed on other architectures as well (namely h8300),
which currently fails to build without this in place. Rather than
duplicating the port definition completely there, just move this to a
common location instead.
This should get h8300 working again for 2.6.25, in addition to the
changes already pushed by Sato-san in -rc2.
