path: root/arch/sh/kernel/entry-common.S
2008-10-31sh: FTRACE renamed to FUNCTION_TRACER.Paul Mundt
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-09-21sh: ftrace support.Paul Mundt
This adds support for ftrace to SH. This only includes CONFIG_FTRACE, and does not handle dynamic ftrace presently. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-09-05sh: resume_kernel fix for kernel oops built with CONFIG_BKL_PREEMPT=y.Carmelo Amoroso
This patch fixes a problem within the SH implementation of resume_kernel code, that implements in assembly the bulk of preempt_schedule_irq function without taking care of the extra code needed to handle the BKL preemptible. The patch basically consists of removing this asm code and calling the common C implementation (see kernel/sched.c) as other archs do. Another change is the missing 'cli' macro invocation at the beginning of the resume_kernel. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: Carmelo Amoroso <carmelo.amoroso@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-08-02sh: Make syscall tracer use tracehook notifiers, add TIF_NOTIFY_RESUME.Paul Mundt
This follows the changes in commits: 7d6d637dac2050f30a1b57b0a3dc5de4a10616ba 4f72c4279eab1e5f3ed1ac4e55d4527617582392 on powerpc. Adding in TIF_NOTIFY_RESUME, and cleaning up the syscall tracing to be more generic. This is an incremental step to turning on tracehook, as well as unifying more of the ptrace and signal code across the 32/64 split. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-08-02sh: Tidy up the _TIF work masks, and fix syscall trace bug on singlestep.Paul Mundt
2008-07-28sh: Don't miss pending signals returning to user mode after signal processingStuart MENEFY
Without this patch, signals sent during architecture specific signal handling (typically as a result of the user's stack being inaccessible) are ignored. This is the SH version of commit c3ff8ec31c1249d268cd11390649768a12bec1b9 which was for the i386. Signed-off-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-19sh: Fix up restorer in debug_trap exception return path.Paul Mundt
There are a few different types of debug trap exceptions, though now that they are all going through a special jump table, the restorer needs to be unified as well. Presently this is falling through the ret_from_fork path, which more or less does the right thing on SH-3/4 whilst being completely unsuitable on MMU-less targets. Ultimately what we want here is a branch through the platform's restore_all directly, without worrying about the retval being clobbered. We can accomplish that through a branch to __restore_all directly, so switch it so we come back from the jump table and branch to the restorer. This fixes up a recursion in the nommu WARN_ON() path, as well as some other userspace nastiness where said recursion caused serious stack corruption. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-16sh: Fix up thread info pointer in syscall_badsys resume path.Hideo Saito
Entry to resume_userspace expects r8 to contain current_thread_info, which happens in all paths except for syscall_badsys, where r8 was being inadvertently trampled. Reload it before the branch. Signed-off-by: Hideo Saito <saito@densan.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: GUSA atomic rollback support.Stuart Menefy
This implements kernel-level atomic rollback built on top of gUSA, as an alternative non-IRQ based atomicity method. This is generally a faster method for platforms that are lacking the LL/SC pairs that SH-4A and later use, and is only supportable on legacy cores. Signed-off-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: syscall audit support.Yuichi Nakamura
Support syscall auditing.. Signed-off-by: Yuichi Nakamura <ynakam@hitachisoft.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-28sh: Conditionalize gUSA support.Paul Mundt
This conditionalizes gUSA support. gUSA is not supported on SMP configurations, and it's not necessary there anyways due to having other atomicity options (ie, movli.l/movco.l). Anything implementing the LL/SC semantics (all SH-4A CPUs) can switch to userspace atomicity implementations without requiring gUSA. This is left default-enabled on all UP so that glibc doesn't break. Those that know what they are doing can disable this explicitly. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-03-05sh: Clear UBC when not in use.Stuart Menefy
This takes care of tearing down the UBC so it's not inadvertently left configured at the next context switch time. Failure to do this results in spurious SIGTRAPs in certain debug sequences. Signed-off-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-02-13sh: Use a jump call table for debug trap handlers.Paul Mundt
This rips out most of the needlessly complicated sh_bios and kgdb trap handling, and forces it all through a common fast dispatch path. As more debug traps are inserted, it's important to keep them in sync for all of the parts, not just SH-3/4. As the SH-2 parts are unable to do traps in the >= 0x40 range, we restrict the debug traps to the 0x30-0x3f range on all parts, and also bump the kgdb breakpoint trap down in to this range (from 0xff to 0x3c) so it's possible to use for nommu. Optionally, this table can be padded out to catch spurious traps for SH-3/4, but we don't do that yet.. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-12sh: Fixup sh_bios() trap handling.Paul Mundt
This was inadvertently broken when the entry.S code split up, restore the missing branch and get subsequent traps working under debug again. This manifested itself as a lockup when attempting to reload the VBR base. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: stacktrace/lockdep/irqflags tracing support.Paul Mundt
Wire up all of the essentials for lockdep.. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: Fix syscall tracing ordering.Stuart Menefy
The implementation of system call tracing in the kernel has a couple of ordering problems: - the validity of the system call number is checked before calling out to system call tracing code, and should be done after - the system call number used when tracing is the one the system call was invoked with, while the system call tracing code can legitimatly change the call number (for example strace permutes fork into clone) This patch fixes both of these problems, and also reoders the code slightly to make the direct path through the code the common case. Signed-off-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: Exception vector rework and SH-2/SH-2A support.Yoshinori Sato
This splits out common bits from the existing exception handler for use between SH-2/SH-2A and SH-3/4, and adds support for the SH-2/2A exceptions. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
