path: root/arch/sh/kernel
2011-08-29Merge branch 'sh-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x: sh: fix the compile error in setup-sh7757.c serial: sh-sci: report CTS as active for get_mctrl sh: Add unaligned memory access for PC relative intructions sh: Fix unaligned memory access for branches without delay slots sh: Fix up fallout from cpuidle changes. serial: sh-sci: console Runtime PM support sh: Fix conflicting definitions of ptrace_triggered serial: sh-sci: fix DMA build by including dma-mapping.h serial: sh-sci: Fix up default regtype probing. sh: intc: enable both edges GPIO interrupts on sh7372 shwdt: fix usage of mod_timer clocksource: sh_cmt: wait for CMCNT on init V2
2011-08-29sh: fix the compile error in setup-sh7757.cYoshihiro Shimoda
Fix the following build errors: CC arch/sh/kernel/cpu/sh4a/setup-sh7757.o arch/sh/kernel/cpu/sh4a/setup-sh7757.c:681: error: implicit declaration of function ‘DMA_BIT_MASK’ arch/sh/kernel/cpu/sh4a/setup-sh7757.c:681: error: initializer element is not constant arch/sh/kernel/cpu/sh4a/setup-sh7757.c:681: error: (near initialization for ‘usb_ehci_device.dev.coherent_dma_mask’) arch/sh/kernel/cpu/sh4a/setup-sh7757.c:705: error: initializer element is not constant arch/sh/kernel/cpu/sh4a/setup-sh7757.c:705: error: (near initialization for ‘usb_ohci_device.dev.coherent_dma_mask’) make[3]: *** [arch/sh/kernel/cpu/sh4a/setup-sh7757.o] Error 1 Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29sh: Add unaligned memory access for PC relative intructionsPhil Edworthy
This adds unaligned memory access support for the following instructions: mov.w @(disp,PC),Rn mov.l @(disp,PC),Rn These instructions are often used on SH2A toolchains. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29sh: Fix unaligned memory access for branches without delay slotsPhil Edworthy
This patch just clears the return code for those cases where an unaligned memory access occurs on branch instructions without a delay slot. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-08sh: Fix up fallout from cpuidle changes.Paul Mundt
Fixes up the pm_idle redefinition that was introduced with the earlier cpuidle changes. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-04cpuidle: Consistent spelling of cpuidle_idle_call()David Brown
Commit a0bfa1373859e9d11dc92561a8667588803e42d8 mispells cpuidle_idle_call() on ARM and SH code. Fix this to be consistent. Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: x86@kernel.org Cc: Len Brown <len.brown@intel.com> Signed-off-by: David Brown <davidb@codeaurora.org> [ Also done by Mark Brown - th ebug has been around forever, and was noticed in -next, but the idle tree never picked it up. Bad bad bad ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: cpuidle: stop depending on pm_idle x86 idle: move mwait_idle_with_hints() to where it is used cpuidle: replace xen access to x86 pm_idle and default_idle cpuidle: create bootparam "cpuidle.off=1" mrst_pmu: driver for Intel Moorestown Power Management Unit
2011-08-03cpuidle: stop depending on pm_idleLen Brown
cpuidle users should call cpuidle_call_idle() directly rather than via (pm_idle)() function pointer. Architecture may choose to continue using (pm_idle)(), but cpuidle need not depend on it: my_arch_cpu_idle() ... if(cpuidle_call_idle()) pm_idle(); cc: Kevin Hilman <khilman@deeprootsystems.com> cc: Paul Mundt <lethal@linux-sh.org> cc: x86@kernel.org Acked-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-01Merge branch 'sh-latest' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x * 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x: (39 commits) SH: static should be at beginning of declaration sh: move CLKDEV_xxx_ID macro to sh_clk.h sh: clock-shx3: add CLKDEV_ICK_ID for cleanup sh: clock-sh7786: add CLKDEV_ICK_ID for cleanup sh: clock-sh7785: add CLKDEV_ICK_ID for cleanup sh: clock-sh7757: add CLKDEV_ICK_ID for cleanup sh: clock-sh7366: add CLKDEV_ICK_ID for cleanup sh: clock-sh7343: add CLKDEV_ICK_ID for cleanup sh: clock-sh7722: add CLKDEV_ICK_ID for cleanup sh: clock-sh7724: add CLKDEV_ICK_ID for cleanup sh: clock-sh7366: modify I2C clock settings sh: clock-sh7343: modify I2C clock settings sh: clock-sh7723: modify I2C clock settings sh: clock-sh7722: modify I2C clock settings sh: clock-sh7724: modify I2C clock settings serial: sh-sci: Fix up pretty name printing for port IRQs. serial: sh-sci: Kill off per-port enable/disable callbacks. serial: sh-sci: Add missing module description/author bits. serial: sh-sci: Regtype probing doesn't need to be fatal. sh: Tidy up pre-clkdev clk_get() error handling. ...
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (123 commits) perf: Remove the nmi parameter from the oprofile_perf backend x86, perf: Make copy_from_user_nmi() a library function perf: Remove perf_event_attr::type check x86, perf: P4 PMU - Fix typos in comments and style cleanup perf tools: Make test use the preset debugfs path perf tools: Add automated tests for events parsing perf tools: De-opt the parse_events function perf script: Fix display of IP address for non-callchain path perf tools: Fix endian conversion reading event attr from file header perf tools: Add missing 'node' alias to the hw_cache[] array perf probe: Support adding probes on offline kernel modules perf probe: Add probed module in front of function perf probe: Introduce debuginfo to encapsulate dwarf information perf-probe: Move dwarf library routines to dwarf-aux.{c, h} perf probe: Remove redundant dwarf functions perf probe: Move strtailcmp to string.c perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_END tracing/kprobe: Update symbol reference when loading module tracing/kprobes: Support module init function probing kprobes: Return -ENOENT if probe point doesn't exist ...
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-07-11sh: move CLKDEV_xxx_ID macro to sh_clk.hKuninori Morimoto
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-07-11sh: clock-shx3: add CLKDEV_ICK_ID for cleanupKuninori Morimoto
2011-07-11sh: clock-sh7786: add CLKDEV_ICK_ID for cleanupKuninori Morimoto
2011-07-11sh: clock-sh7785: add CLKDEV_ICK_ID for cleanupKuninori Morimoto
2011-07-11sh: clock-sh7757: add CLKDEV_ICK_ID for cleanupKuninori Morimoto
2011-07-11sh: clock-sh7366: add CLKDEV_ICK_ID for cleanupKuninori Morimoto
2011-07-11sh: clock-sh7343: add CLKDEV_ICK_ID for cleanupKuninori Morimoto
2011-07-11sh: clock-sh7722: add CLKDEV_ICK_ID for cleanupKuninori Morimoto
2011-07-11sh: clock-sh7724: add CLKDEV_ICK_ID for cleanupKuninori Morimoto
2011-07-11sh: clock-sh7366: modify I2C clock settingsKuninori Morimoto
I2C doesn't work without this patch on SH7366 Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-07-11sh: clock-sh7343: modify I2C clock settingsKuninori Morimoto
I2C doesn't work without this patch on SH7343 Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-07-11sh: clock-sh7723: modify I2C clock settingsKuninori Morimoto
I2C doesn't work without this patch on SH7723 Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-07-11sh: clock-sh7722: modify I2C clock settingsKuninori Morimoto
I2C doesn't work without this patch on SH7722 Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-07-11sh: clock-sh7724: modify I2C clock settingsKuninori Morimoto
I2C doesn't work without this patch on SH7724 Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-07-02PM / Domains: Rename struct dev_power_domain to struct dev_pm_domainRafael J. Wysocki
The naming convention used by commit 7538e3db6e015e890825fbd9f86599b (PM: Add support for device power domains), which introduced the struct dev_power_domain type for representing device power domains, evidently confuses some developers who tend to think that objects of this type must correspond to "power domains" as defined by hardware, which is not the case. Namely, at the kernel level, a struct dev_power_domain object can represent arbitrary set of devices that are mutually dependent power management-wise and need not belong to one hardware power domain. To avoid that confusion, rename struct dev_power_domain to struct dev_pm_domain and rename the related pointers in struct device and struct pm_clk_notifier_block from pwr_domain to pm_domain. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Kevin Hilman <khilman@ti.com>
2011-07-01perf: Add context field to perf_eventAvi Kivity
The perf_event overflow handler does not receive any caller-derived argument, so many callers need to resort to looking up the perf_event in their local data structure. This is ugly and doesn't scale if a single callback services many perf_events. Fix by adding a context parameter to perf_event_create_kernel_counter() (and derived hardware breakpoints APIs) and storing it in the perf_event. The field can be accessed from the callback as event->overflow_handler_context. All callers are updated. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1309362157-6596-2-git-send-email-avi@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf, arch: Add generic NODE cache eventsPeter Zijlstra
Add a NODE level to the generic cache events which is used to measure local vs remote memory accesses. Like all other cache events, an ACCESS is HIT+MISS, if there is no way to distinguish between reads and writes do reads only etc.. The below needs filling out for !x86 (which I filled out with unsupported events). I'm fairly sure ARM can leave it like that since it doesn't strike me as an architecture that even has NUMA support. SH might have something since it does appear to have some NUMA bits. Sparc64, PowerPC and MIPS certainly want a good look there since they clearly are NUMA capable. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Miller <davem@davemloft.net> Cc: Anton Blanchard <anton@samba.org> Cc: David Daney <ddaney@caviumnetworks.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1303508226.4865.8.camel@laptop Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf: Remove the nmi parameter from the swevent and overflow interfacePeter Zijlstra
The nmi parameter indicated if we could do wakeups from the current context, if not, we would set some state and self-IPI and let the resulting interrupt do the wakeup. For the various event classes: - hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from the PMI-tail (ARM etc.) - tracepoint: nmi=0; since tracepoint could be from NMI context. - software: nmi=[0,1]; some, like the schedule thing cannot perform wakeups, and hence need 0. As one can see, there is very little nmi=1 usage, and the down-side of not using it is that on some platforms some software events can have a jiffy delay in wakeup (when arch_irq_work_raise isn't implemented). The up-side however is that we can remove the nmi parameter and save a bunch of conditionals in fast paths. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Michael Cree <mcree@orcon.net.nz> Cc: Will Deacon <will.deacon@arm.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Don Zickus <dzickus@redhat.com> Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-30sh: use printk_ratelimited instead of printk_ratelimitPaul Mundt
Follows the powerpc change, for much the same rationale. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-29Merge branches 'common/serial-rework' and 'sh/stable-updates' into sh-latestPaul Mundt
2011-06-29sh: fix the value of sh_dmae_slave_config in setup-sh7757Yoshihiro Shimoda
Fix the value of chcr for SCIF[2-4]_RX and RIIC[0-9]_RX and the value of mid_rid for some RIIC. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-29sh: fix the INTC vector for IRQ and IRL in setup-sh7757Yoshihiro Shimoda
2011-06-21Merge branch 'sh/stable-updates' into sh-latestPaul Mundt
2011-06-21sh: add platform_device of EHCI/OHCI to setup-sh7757Yoshihiro Shimoda
2011-06-20sh: Fix up build fallout from serial merge.Paul Mundt
This fixes up build issues for SH7720/SH7722/SH7750 that crept in with the serial rework. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-16Merge branches 'common/dma' and 'sh/stable-updates' into sh-latestPaul Mundt
2011-06-16sh: sh7724: Add USBHS DMAEngine supportKuninori Morimoto
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-15Merge branch 'common/serial-rework' into sh-latestPaul Mundt
2011-06-14sh, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so those calls to set_fs(USER_DS) are redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-14serial: sh-sci: Abstract register maps.Paul Mundt
This takes a bit of a sledgehammer to the horribly CPU subtype ifdef-ridden header and abstracts all of the different register layouts in to distinct types which in turn can be overriden on a per-port basis, or permitted to default to the map matching the port type at probe time. In the process this ultimately fixes up inumerable bugs with mismatches on various CPU types (particularly the legacy ones that were obviously broken years ago and no one noticed) and provides a more tightly coupled and consolidated platform for extending and implementing generic features. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-08serial: sh-sci: Consolidate RXD pin handling.Paul Mundt
Non-SCI parts do not have the special port reg necessary for cases where the RX and SCI pins are muxed and need to be manually polled, so these like always fall back on the normal FIFO processing paths. SH7760 is in a class in and of itself with regards to mapping its SIM card interface via the SCI port class despite not having any of the RXD lines wired up and so implicitly behaving more like a SCIF in this regard. Out of the other CPUs, some support the port check via the same block while others do it through an external SuperI/O, so it's not even possible to perform the check relative to the ioremapped cookie offset, so the separate read semantics are preserved here, too. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-31Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-fixes-for-linus
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
