Add a node parameter to alloc_thread_info(), and change its name to
alloc_thread_info_node()
This change is needed to allow NUMA aware kthread_create_on_cpu()
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Tejun Heo <tj@kernel.org>
Cc: <linux-arch@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (308 commits)
ALSA: sound/pci/asihpi: check adapter index in hpi_ioctl
ALSA: aloop - Fix possible IRQ lock inversion
ALSA: sound/core: merge list_del()/list_add_tail() to list_move_tail()
ALSA: ctxfi - use list_move() instead of list_del()/list_add() combination
ALSA: firewire - msleep needs delay.h
ALSA: firewire-lib, firewire-speakers: handle packet queueing errors
ALSA: firewire-lib: allocate DMA buffer separately
ALSA: firewire-lib: use no-info SYT for packets without SYT sample
ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driver
ALSA: hda - Remove an unused variable in patch_realtek.c
ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecs
ALSA: hda - fix digital mic selection in mixer on 92HD8X codecs
ALSA: hda - Move default input-src selection to init part
ALSA: hda - Initialize special cases for input src in init phase
ALSA: ctxfi - Clear input settings before initialization
ALSA: ctxfi - Fix SPDIF status retrieval
ALSA: ctxfi - Fix incorrect SPDIF status bit mask
ALSA: ctxfi - Fix microphone boost codes/comments
ALSA: atiixp - Fix wrong time-out checks during ac-link reset
ALSA: intel8x0m: append 'm' to "r_intel8x0"
Trivial conversion, simply encapsulate the NMI stats in the arch code.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
A new parameter is added to sh_eth_plat_data. And the sh_eth driver
needs additional memory resource if a module has TSU.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
This patch also modifies for ETHER's platform_device.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-latest
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits)
bonding: enable netpoll without checking link status
xfrm: Refcount destination entry on xfrm_lookup
net: introduce rx_handler results and logic around that
bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag
bonding: wrap slave state work
net: get rid of multiple bond-related netdevice->priv_flags
bonding: register slave pointer for rx_handler
be2net: Bump up the version number
be2net: Copyright notice change. Update to Emulex instead of ServerEngines
e1000e: fix kconfig for crc32 dependency
netfilter ebtables: fix xt_AUDIT to work with ebtables
xen network backend driver
bonding: Improve syslog message at device creation time
bonding: Call netif_carrier_off after register_netdevice
bonding: Incorrect TX queue offset
net_sched: fix ip_tos2prio
xfrm: fix __xfrm_route_forward()
be2net: Fix UDP packet detected status in RX compl
Phonet: fix aligned-mode pipe socket buffer header reserve
netxen: support for GbE port settings
Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c
with the staging updates.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits)
pch_uart: reference clock on CM-iTC
pch_phub: add new device ML7213
n_gsm: fix UIH control byte : P bit should be 0
n_gsm: add a documentation
serial: msm_serial_hs: Add MSM high speed UART driver
tty_audit: fix tty_audit_add_data live lock on audit disabled
tty: move cd1865.h to drivers/staging/tty/
Staging: tty: fix build with epca.c driver
pcmcia: synclink_cs: fix prototype for mgslpc_ioctl()
Staging: generic_serial: fix double locking bug
nozomi: don't use flush_scheduled_work()
tty/serial: Relax the device_type restriction from of_serial
MAINTAINERS: Update HVC file patterns
tty: phase out of ioctl file pointer for tty3270 as well
tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile
pch_uart: Fix DMA channel miss-setting issue.
pch_uart: fix exclusive access issue
pch_uart: fix auto flow control miss-setting issue
pch_uart: fix uart clock setting issue
pch_uart : Use dev_xxx not pr_xxx
Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied
twice, then changes to the same area in one branch)
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu, x86: Add arch-specific this_cpu_cmpxchg_double() support
percpu: Generic support for this_cpu_cmpxchg_double()
alpha: use L1_CACHE_BYTES for cacheline size in the linker script
percpu: align percpu readmostly subsection to cacheline
Fix up trivial conflict in arch/x86/kernel/vmlinux.lds.S due to the
percpu alignment having changed ("x86: Reduce back the alignment of the
per-CPU data section")
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rtmutex: tester: Remove the remaining BKL leftovers
lockdep/timers: Explain in detail the locking problems del_timer_sync() may cause
rtmutex: Simplify PI algorithm and make highest prio task get lock
rwsem: Remove redundant asmregparm annotation
rwsem: Move duplicate function prototypes to linux/rwsem.h
rwsem: Unify the duplicate rwsem_is_locked() inlines
rwsem: Move duplicate init macros and functions to linux/rwsem.h
rwsem: Move duplicate struct rwsem declaration to linux/rwsem.h
x86: Cleanup rwsem_count_t typedef
rwsem: Cleanup includes
locking: Remove deprecated lock initializers
cred: Replace deprecated spinlock initialization
kthread: Replace deprecated spinlock initialization
xtensa: Replace deprecated spinlock initialization
um: Replace deprecated spinlock initialization
sparc: Replace deprecated spinlock initialization
mips: Replace deprecated spinlock initialization
cris: Replace deprecated spinlock initialization
alpha: Replace deprecated spinlock initialization
rtmutex-tester: Remove BKL tests
The SH7757's ETHER and GETHER use common MDIO pin. The MDIO pin is
selected by specific register. So this patch adds new interface in
bb_info, and when the sh_eth driver use the mdio, the register can
be changed by the function.
The previous code had hardcoded the PHY_INTERFACE_MODE_MII of phy_connect.
So some Gigabit PHYs will not behave correctly.
The patch adds the phy_interface in sh_eth_plat_data, so we can select
the phy interface.
The previous code cannot handle the ETHER and GETHER both as same time
because the definitions of register was hardcoded.
Change futex_atomic_op_inuser and futex_atomic_cmpxchg_inatomic
prototypes to use u32 types for the futex as this is the data type the
futex core code uses all over the place.
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: Darren Hart <darren@dvhart.com>
Cc: Matt Turner <mattst88@gmail.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
LKML-Reference: <20110311025058.GD26122@google.com>
The cmpxchg_futex_value_locked API was funny in that it returned either
the original, user-exposed futex value OR an error code such as -EFAULT.
This was confusing at best, and could be a source of livelocks in places
that retry the cmpxchg_futex_value_locked after trying to fix the issue
by running fault_in_user_writeable().
This change makes the cmpxchg_futex_value_locked API more similar to the
get_futex_value_locked one, returning an error code and updating the
original value through a reference argument.
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile]
Acked-by: Tony Luck <tony.luck@intel.com> [ia64]
Tested-by: Michal Simek <monstr@monstr.eu> [microblaze]
Acked-by: David Howells <dhowells@redhat.com> [frv]
LKML-Reference: <20110311024851.GC26122@google.com>
- enable SPI bus, MTD, MMCIF, SD, USB host, and USB storage.
C0 is known as "busy", "not idle" state.
X86 "busy polling" state also got renamed from C0
to "POLL" recently.
Let's stay consistent with naming to avoid confusions.
Signed-off-by: Thomas Renninger <trenn@suse.de>
Acked-by: Magnus Damm <damm@opensource.se>
This is useful for system management software so that it can kick
off things like gettys and everything that's started from a tty,
before we reuse it from/for something else or shut it down.
Without this ioctl it would have to temporarily become the owner of
the tty, then call vhangup() and then give it up again.
Cc: Lennart Poettering <lennart@poettering.net>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This patch enables gcov kernel profiling over the whole kernel for sh.
Profiling of specific files individually already worked. A handful of
files have to be explicitly excluded from the profiling to avoid
breaking things, notably pmb.c.
Signed-off-by: Chris Smith <chris.smith@st.com>
Signed-off-by: Stuart Menefy <stuart.menefy@st.com>
This patch changes the:
- __nosave_begin
- __nosave_end
symbols from 'void' to 'long' as required by the latest
Gcc (4.5.2) which raises the compilation error:
cc1: warnings being treated as errors
arch/sh/kernel/swsusp.c: In function 'pfn_is_nosave':
arch/sh/kernel/swsusp.c:24:28: error: taking address of expression of type 'void'
arch/sh/kernel/swsusp.c:25:26: error: taking address of expression of type 'void'
Signed-off-by: Francesco Virlinzi <francesco.virlinzi@st.com>
This resolves a problem seen when using the Android dynamic linker.
Sometimes the dynamic linker would seg-fault at start up and this
was eventually traced to the handling of a COW fault for a page which
was being modified by the linker. If there was no cache aliasing between
the kernel and the user page, the page was not flushed, leaving the
newly copied data in the D-cache. However when executing instructions
from that page, the I-cache is filled directly from external memory,
rather than the D-cache, and causing garbage to be executed.
A strange variation was seen in the BogoMIPS figure for the ST40-300.
This was eventually tracked down to sensitivity to the alignment of
the loop. So add an align directive to ensure this doesn't occur.
It is necessary to set array of struct platform_device in
early_platform_add_devices().
arch/sh/kernel/cpu/sh4/setup-sh7750.c: In function ‘plat_early_device_setup’:
arch/sh/kernel/cpu/sh4/setup-sh7750.c:260: warning: passing argument 1 of ‘early_platform_add_devices’ from incompatible pointer type
include/linux/platform_device.h:159: note: expected ‘struct platform_device **’ but argument is of type ‘struct platform_device *’
arch/sh/kernel/cpu/sh4/setup-sh7750.c:262: warning: passing argument 1 of ‘early_platform_add_devices’ from incompatible pointer type
arch/sh/kernel/cpu/sh4/setup-sh7750.c:263: warning: passing argument 1 of ‘early_platform_add_devices’ from incompatible pointer type
By commit 3252b11fc4790d046b93f300c898df2f7cd7c176,
machtypes.h moved to include/generated.
However, this forgot kernel/cpu/sh4/setup-sh7750.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into core/locking
*git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace tip/rtmutex:
For the SMP case we run in to a lockup without a full synchronization
prior to continuing with the boot.
All architecture specific rwsem headers carry the same function
prototypes. Just x86 adds asmregparm, which is an empty define on all
other architectures. S390 has a stale rwsem_downgrade_write()
prototype.
Remove the duplicates and add the prototypes to linux/rwsem.h
Cc: Richard Henderson <rth@twiddle.net>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Acked-by: David Miller <davem@davemloft.net>
Cc: Chris Zankel <chris@zankel.net>
LKML-Reference: <20110126195833.970840140@linutronix.de>
Instead of having the same implementation in each architecture, move
it to linux/rwsem.h and remove the duplicates. It's unlikely that an
arch will ever implement something different, but we can deal with
that when it happens.
LKML-Reference: <20110126195833.876773757@linutronix.de>
The rwsem initializers and related macros and functions are mostly the
same. Some of them lack the lockdep initializer, but having it in
place does not matter for architectures which do not support lockdep.
powerpc, sparc, x86: No functional change
sh, s390: Removes the duplicate init_rwsem (inline and #define)
alpha, ia64, xtensa: Use the lockdep capable init function in
lib/rwsem.c which is just uninlining the init
function for the LOCKDEP=n case
LKML-Reference: <20110126195833.771812729@linutronix.de>
The difference between these declarations is the data type of the
count member and the lack of lockdep in some architectures/
long is equivivalent to signed long and the #ifdef guarded dep_map
member does not hurt anyone.
LKML-Reference: <20110126195833.679641914@linutronix.de>
All rwsem implementations include the same headers. Include them from
include/linux/rwsem.h
LKML-Reference: <20110126195833.483520950@linutronix.de>
Current format selection of FSI-codecs depended on platform information for FSI,
and chip default settings for codecs. It is not understandable/formal method.
This patch modify FSI and FSI-codecs to use snd_soc_dai_set_fmt.
But FSI can use I2S/PCM and SPDIF format today.
It can be selected to I2S/PCM by snd_soc_dai_set_fmt, but can not select SPDIF.
So, this patch change FSI platform information to have DAI/SPDIF mode.
If platform selects DAI mode (default),
FSI-codecs can select I2S/PCM by snd_soc_dai_set_fmt,
and if it is SPDIF mode, FSI become SPDIF format.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
into sh-latest
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: Fix build of sh7750 base boards
sh: update INTC to clear IRQ sense valid flag
sh: Fix sh build failure when CONFIG_SFC=m
sh: fix MSIOF0 SPI on ecovec: it conflicts with VOU
sh: support XZ-compressed kernel.
sh: Fix up breakage from asm-generic/pgtable.h changes.
Currently percpu readmostly subsection may share cachelines with other
percpu subsections which may result in unnecessary cacheline bounce
and performance degradation.
This patch adds @cacheline parameter to PERCPU() and PERCPU_VADDR()
linker macros, makes each arch linker scripts specify its cacheline
size and use it to align percpu subsections.
This is based on Shaohua's x86 only patch.
Cc: Shaohua Li <shaohua.li@intel.com>
Renamed platform_register_device to platform_device_register.
This patch add snd_soc_dai_ops :: set_fmt to FSI driver and
select master/slave clock mode by snd_soc_dai_set_fmt on
fsi-xxx.c instead of platform infomation code.
This patch remove fsi_is_master function which is no longer needed.
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
CONFIG_SFC=m uses topology_core_cpumask() which, for sh, expects
cpu_core_map to be exported. It is not. This patch exports the needed
symbol.
Signed-off-by: Aurelien Jarno <aurelien@aurel32.net>
