path: root/arch/sh
2010-07-14lmb: rename to memblockYinghai Lu
via following scripts FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/lmb/memblock/g' \ -e 's/LMB/MEMBLOCK/g' \ $FILES for N in $(find . -name lmb.[ch]); do M=$(echo $N | sed 's/lmb/memblock/g') mv $N $M done and remove some wrong change like lmbench and dlmb etc. also move memblock.c from lib/ to mm/ Suggested-by: Ingo Molnar <mingo@elte.hu> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-06-21arch/sh/mm: Eliminate a double lockJulia Lawall
The function begins and ends with a read_lock. The latter is changed to a read_unlock. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @locked@ expression E1; position p; @@ read_lock(E1@p,...); @r exists@ expression x <= locked.E1; expression locked.E1; expression E2; identifier lock; position locked.p,p1,p2; @@ *lock@p1 (E1@p,...); ... when != E1 when != \(x = E2\|&x\) *lock@p2 (E1,...); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Matt Fleming <matt@console-pimps.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-06-07sh: Fix up IORESOURCE_PCI_FIXED usage in pcibios_fixup_device_resources().Paul Mundt
pcibios_fixup_device_resources() presently skips over resources flagged with IORESOURCE_PCI_FIXED, which is a remnant of the old PCI-auto code. The only user for this at present is the Dreamast GAPSPCI code which can't tolerate any adjustments to the BARs, but a combination of the IORESOURCE_PCI_FIXED and zeroed out hose offsets does the right thing for this case already, so we simply kill off the special casing. Reported-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-06-07sh: remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in arch/sh/boards/mach-ecovec24/setup.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-06-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (23 commits) sh: Make intc messages consistent via pr_fmt. sh: make sure static declaration on ms7724se sh: make sure static declaration on mach-migor sh: make sure static declaration on mach-ecovec24 sh: make sure static declaration on mach-ap325rxa clocksource: sh_cmt: compute mult and shift before registration clocksource: sh_tmu: compute mult and shift before registration sh: PIO disabling for x3proto and urquell. sh: mach-sdk7786: conditionally disable PIO support. sh: support for platforms without PIO. usb: r8a66597-hcd pio to mmio accessor conversion. usb: gadget: r8a66597-udc pio to mmio accessor conversion. usb: gadget: m66592-udc pio to mmio accessor conversion. sh: add romImage MMCIF boot for sh7724 and Ecovec V2 sh: add boot code to MMCIF driver header sh: prepare MMCIF driver header file sh: allow romImage data between head.S and the zero page sh: Add support MMCIF for ecovec sh: remove duplicated #include input: serio: disable i8042 for non-cayman sh platforms. ...
2010-06-02sh: make sure static declaration on ms7724seKuninori Morimoto
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-06-02sh: make sure static declaration on mach-migorKuninori Morimoto
2010-06-02sh: make sure static declaration on mach-ecovec24Kuninori Morimoto
2010-06-02sh: make sure static declaration on mach-ap325rxaKuninori Morimoto
2010-06-02Merge branch 'sh/iomap'Paul Mundt
2010-06-02sh: PIO disabling for x3proto and urquell.Paul Mundt
urquell only provides PIO in the PCI case, while the x3proto board never had a working PCIe controller, so it can simply disable it outright. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-06-02sh: mach-sdk7786: conditionally disable PIO support.Paul Mundt
SDK7786 only supports PIO via the PCI I/O space, so we disable PIO completely for the non-PCI case. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-06-02sh: support for platforms without PIO.Paul Mundt
This extends some of the existing special casing for HAS_IOPORT platforms and gets it to the point where platforms can begin to conditionally select it. The major changes here are that the PIO routines themselves go away completely, including all of the machvec port mapping wrappers. With this in place it's possible for any non-machvec abusing platform to disable PIO completely. At present this is left as an opt-in until the abusers are the odd ones out instead of the majority. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-05-31sh: add romImage MMCIF boot for sh7724 and Ecovec V2Magnus Damm
This patch is V2 of the MMCIF romImage boot support for sh7724 and the Ecovec board. With this patch applied and CONFIG_ROMIMAGE_MMCIF selected the romImage kernel image can be written to a MMC card and booted directly by the sh7724 cpu. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-31sh: allow romImage data between head.S and the zero pageMagnus Damm
Extend the romImage code to allow putting data between the head.S file and the empty_zero_page. Needed in the case of more advanced loader code in a separate C file. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-31sh: Add support MMCIF for ecovecYusuke Goda
This patch adds MMCIF platform data for the Ecovec board. Signed-off-by: Yusuke Goda <yusuke.goda.sx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-31Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2010-05-27asm-generic: add NEED_SG_DMA_LENGTH to define sg_dma_len()FUJITA Tomonori
There are only two ways to define sg_dma_len(); use sg->dma_length or sg->length. This patch introduces NEED_SG_DMA_LENGTH that enables architectures to choose sg->dma_length or sg->length. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27ptrace: unify FDPIC implementationsMike Frysinger
The Blackfin/FRV/SuperH guys all have the same exact FDPIC ptrace code in their arch handlers (since they were probably copied & pasted). Since these ptrace interfaces are an arch independent aspect of the FDPIC code, unify them in the common ptrace code so new FDPIC ports don't need to copy and paste this fundamental stuff yet again. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26Revert "endian: #define __BYTE_ORDER"Linus Torvalds
This reverts commit b3b77c8caef1750ebeea1054e39e358550ea9f55, which was also totally broken (see commit 0d2daf5cc858 that reverted the crc32 version of it). As reported by Stephen Rothwell, it causes problems on big-endian machines: > In file included from fs/jfs/jfs_types.h:33, > from fs/jfs/jfs_incore.h:26, > from fs/jfs/file.c:22: > fs/jfs/endian24.h:36:101: warning: "__LITTLE_ENDIAN" is not defined The kernel has never had that crazy "__BYTE_ORDER == __LITTLE_ENDIAN" model. It's not how we do things, and it isn't how we _should_ do things. So don't go there. Requested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26sh: remove duplicated #includeHuang Weiyi
2010-05-25endian: #define __BYTE_ORDERJoakim Tjernlund
Linux does not define __BYTE_ORDER in its endian header files which makes some header files bend backwards to get at the current endian. Lets #define __BYTE_ORDER in big_endian.h/litte_endian.h to make it easier for header files that are used in user space too. In userspace the convention is that 1. _both_ __LITTLE_ENDIAN and __BIG_ENDIAN are defined, 2. you have to test for e.g. __BYTE_ORDER == __BIG_ENDIAN. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25sh: handle early calls to return_address() when using dwarf unwinder.Paul Mundt
The dwarf unwinder ties in to an early initcall, but it's possible that return_address() calls will be made prior to that. This implements some additional error handling in to the dwarf unwinder as well as an exit path in the return_address() case to bail out if the unwinder hasn't come up yet. This fixes a NULL pointer deref in early boot when mempool_alloc() blows up on the not-yet-ready mempool via dwarf_unwind_stack(). Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-24sh: fix up sh7785lcr_32bit_defconfig.Paul Mundt
The build scripts inadvertently dropped this down to 29-bit, fix it back up. Reported-by: Raul Porcel <armin76@gentoo.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-24arch/sh/lib/strlen.S: Checkpatch cleanupAndrea Gelmini
arch/sh/lib/strlen.S:38: ERROR: trailing whitespace Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: fix up sh7786 dmaengine build.Paul Mundt
The asm/dmaengine.h header is gone now, update accordingly. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: disable SD-card write-protection detection on kfr2r09Guennadi Liakhovetski
kfr2r09 board has a micro-SD card slot, therefore card write-protection detection cannot work there, disable it. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: Add SDHI DMA support to migorGuennadi Liakhovetski
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: Add SDHI DMA support to kfr2r09Guennadi Liakhovetski
2010-05-22sh: Add SDHI DMA support to ms7724seGuennadi Liakhovetski
2010-05-22sh: Add SDHI DMA support to ecovecGuennadi Liakhovetski
2010-05-22sh: add DMA slave definitions to sh7724Guennadi Liakhovetski
Add a list of SCIF and SDHI DMA slave definitions to sh7724. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: add DMA slaves for two SDHI controllers to sh7722Guennadi Liakhovetski
SuperH SDHI controllers can use DMA, add slave definitions to sh7722. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: define DMA slaves per CPU type, remove now redundant headerGuennadi Liakhovetski
Now that DMA slave IDs are only used used in platform specific code and have become opaque cookies for the rest of the code, we can make the, CPU specific too. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: add Video Output Unit (VOU) and AK8813 TV-encoder support to ms7724seGuennadi Liakhovetski
Add platform bindings, GPIO initialisation and allocation and AK8813 reset code to ms7724se. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: add Video Output Unit and AK8813 video encoder support on ecovecGuennadi Liakhovetski
Ecovec uses the AK8813 video envoder similarly to the ms7724se platform with the only difference, that on ecovec GPIOs are used for resetting and powering up and down the chip. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: fix up the dwarf unwinder build for MODULES=n.Paul Mundt
Presently the dwarf unwinder build blows up if modules are disabled, fix it up. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in arch/sh/kernel/cpu/sh4a/clock-sh7786.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-21Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: Set a more specific taint flag for invalid BIOS DMAR tables intel-iommu: Combine the BIOS DMAR table warning messages panic: Add taint flag TAINT_FIRMWARE_WORKAROUND ('I') panic: Allow warnings to set different taint flags intel-iommu: intel_iommu_map_range failed at very end of address space intel-iommu: errors with smaller iommu widths intel-iommu: Fix boot inside 64bit virtualbox with io-apic disabled intel-iommu: use physfn to search drhd for VF intel-iommu: Print out iommu seq_id intel-iommu: Don't complain that ACPI_DMAR_SCOPE_TYPE_IOAPIC is not supported intel-iommu: Avoid global flushes with caching mode. intel-iommu: Use correct domain ID when caching mode is enabled intel-iommu mistakenly uses offset_pfn when caching mode is enabled intel-iommu: use for_each_set_bit() intel-iommu: Fix section mismatch dmar_ir_support() uses dmar_tbl.
2010-05-20kgdb,sh: update superh kgdb exception handlingJason Wessel
Implement kgdb_arch_pc() which adjusts the pc if it needs to be adjusted after a software breakpoint trap. Implement kgdb_arch_set_pc() which is a new required function in the kgdb debug core. When processing a single step return zero in the error exception field so that the debug core can distinguish between a single step trap and a breakpoint trap generically. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Paul Mundt <lethal@linux-sh.org>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (127 commits) sh: update defconfigs. sh: Fix up the NUMA build for recent LMB changes. sh64: provide a stub per_cpu_trap_init() definition. sh: fix up CONFIG_KEXEC=n build. sh: fixup the docbook paths for clock framework shuffling. driver core: Early dev_name() depends on slab_is_available(). sh: simplify WARN usage in SH clock driver sh: Check return value of clk_get on ms7724 sh: Check return value of clk_get on ecovec24 sh: move sh clock-cpg.c contents to drivers/sh/clk-cpg.c sh: move sh clock.c contents to drivers/sh/clk. sh: move sh asm/clock.h contents to linux/sh_clk.h V2 sh: remove unused clock lookup sh: switch boards to clkdev sh: switch sh4-202 to clkdev sh: switch shx3 to clkdev sh: switch sh7757 to clkdev sh: switch sh7763 to clkdev sh: switch sh7780 to clkdev sh: switch sh7786 to clkdev ...
2010-05-19panic: Allow warnings to set different taint flagsBen Hutchings
WARN() is used in some places to report firmware or hardware bugs that are then worked-around. These bugs do not affect the stability of the kernel and should not set the flag for TAINT_WARN. To allow for this, add WARN_TAINT() and WARN_TAINT_ONCE() macros that take a taint number as argument. Architectures that implement warnings using trap instructions instead of calls to warn_slowpath_*() now implement __WARN_TAINT(taint) instead of __WARN(). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Helge Deller <deller@gmx.de> Tested-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-05-18Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (311 commits) perf tools: Add mode to build without newt support perf symbols: symbol inconsistency message should be done only at verbose=1 perf tui: Add explicit -lslang option perf options: Type check all the remaining OPT_ variants perf options: Type check OPT_BOOLEAN and fix the offenders perf options: Check v type in OPT_U?INTEGER perf options: Introduce OPT_UINTEGER perf tui: Add workaround for slang < 2.1.4 perf record: Fix bug mismatch with -c option definition perf options: Introduce OPT_U64 perf tui: Add help window to show key associations perf tui: Make <- exit menus too perf newt: Add single key shortcuts for zoom into DSO and threads perf newt: Exit browser unconditionally when CTRL+C, q or Q is pressed perf newt: Fix the 'A'/'a' shortcut for annotate perf newt: Make <- exit the ui_browser x86, perf: P4 PMU - fix counters management logic perf newt: Make <- zoom out filters perf report: Report number of events, not samples perf hist: Clarify events_stats fields usage ... Fix up trivial conflicts in kernel/fork.c and tools/perf/builtin-record.c
2010-05-18sh: update defconfigs.Paul Mundt
2010-05-18sh: Fix up the NUMA build for recent LMB changes.Paul Mundt
Now that the node 0 initialization code has been overhauled, kill off the now obsolete setup_memory() bits. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-18sh64: provide a stub per_cpu_trap_init() definition.Paul Mundt
This is needed to fix up the build at the moment. Gradually this will be reworked to follow the 32-bit initialization path and deal with delayed VBR initialization. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-18sh: fix up CONFIG_KEXEC=n build.Paul Mundt
The reserve_crashkernel() definition is in asm/kexec.h which is only dragged in via linux/kexec.h if CONFIG_KEXEC is set. Just switch over to asm/kexec.h unconditionally to fix up the build. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-17atomic_t: Cast to volatile when accessing atomic variablesAnton Blanchard
In preparation for removing volatile from the atomic_t definition, this patch adds a volatile cast to all the atomic read functions. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
