path: root/arch/sh
2013-01-21sh: Fix FDPIC binary loaderThomas Schwinge
commit 4a71997a3279a339e7336ea5d0cd27282e2dea44 upstream. Ensure that the aux table is properly initialized, even when optional features are missing. Without this, the FDPIC loader did not work. This was meant to be included in commit d5ab780305bb6d60a7b5a74f18cf84eb6ad153b1. Signed-off-by: Thomas Schwinge <thomas@codesourcery.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27sh: Fix up tracepoint build fallout from static key introduction.Nobuhiro Iwamatsu
With the introduction of static keys, anything using tracepoints blows up in the following manner: include/trace/events/oom.h:8:13: error: initializer element is not constant include/trace/events/oom.h:8:13: error: (near initialization for '__tracepoint_oom_score_adj_update') include/trace/events/oom.h:8:13: error: initializer element is not constant include/trace/events/oom.h:8:13: error: (near initialization for '__tracepoint_oom_score_adj_update.key') This is a result of the STATIC_KEY_INIT_xxx defs wrapping ATOMIC_INIT() which on sh includes an atomic_t typecast. Given that we don't really need the typecast for anything anymore, the simplest solution is simply to kill off the cast. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-04-19sh: Fix error synchronising kernel page tablesStuart Menefy
The problem is caused by the interaction of two features in the Linux memory management code. A processes address space is described by a struct mm_struct, and every thread has a pointer to the mm it should run in. The exception to this are kernel threads, which don't have an mm, and so borrow the mm from the last thread which ran. The system is bootstrapped by the initial kernel thread using init's mm (even though init hasn't been created yet, its mm is the static init_mm). The other feature is how the kernel handles the page table which describes the portion of the address space which is only visible when executing inside the kernel, and which is shared by all threads. On the SH4 the only portion of the kernel's address space which described using the page table is called P3, from 0xc0000000 to 0xdfffffff. This portion of the address space is divided into three: - mappings for dma_alloc_coherent() - mappings for vmalloc() and ioremap() - fixmap mappings, primarily used in copy_user_pages() to create kernel mappings of user pages with the correct cache colour. To optimise the TLB miss handler we don't want to add an additional condition which checks whether the faulting address is in the user or the kernel portion of the address space, and so all page tables have a common portion which describes the kernel part of the address space. As the SH4 uses a two level page table, only the kernel portion of first level page table (the pgd entries) is duplicated. These all point to the same second level entries (the pte's), and so no memory is wasted. The reference page table for the kernel is called the swapper_pg_dir, and when a new page table is created for a new process the kernel portion of the page table is copied from swapper_pg_dir. This works fine when changes only occur in the second level of the kernel's page table, or the first level entries are created before any new user processes. However if a change occurs to the first level of the page table, and there are existing processes which don't have this entry in their page table, this new entry needs to be added. This is done on demand, when the kernel accesses a P3 address which isn't mapped using the current page table, the code in vmalloc_fault() copies the entry from the reference page table (swapper_pg_dir) into the current processes page table. The bug which this patch addresses is that the code in vmalloc_fault() was not copying addresses which fell in the dma_alloc_coherent() portion of the address space, and it should have been copying any P3 address. Why we hadn't seen this before, and what made this hard to reproduce, is that normally the kernel will have called dma_alloc_coherent(), and accessed the memory mapping created, before any user process runs. Typically drivers such as USB or SATA will have created and used mappings of this type during the kernel initialisation, when probing for the attached devices, before init runs. Ethernet is slightly different, as it normally only creates and accesses dma_alloc_coherent() mappings when the network is brought up, but if kernel level IP configuration is used this will also occur before any user space process runs. So the first reproduction of this problem which we saw was occurred when USB and SATA were removed from the kernel, and then bring up Ethernet from user space using ifconfig. I'd like to thank Joseph Bormolini who did the hard work reducing the problem to this simple to reproduce criteria. In your case the situation is slightly different, and turns out to depends on the exact kernel configuration (which we had) and your ramdisk contents (which we didn't - hence the need for some assumptions). In this case the problem is a side effect of kernel level module loading. Kernel subsystems sometimes trigger the load of kernel modules directly, for example the crypto subsystem tries to load the cryptomgr and MTD tries to load modules for Flash partitioning if these are not built into the kernel. This is done by the kernel creating a user process which runs insmod to try and load the appropriate module. In order for this to cause problems the system must be running with a initrd or initramfs, which contains an insmod executable - if the kernel can't find an insmod to run, no user process is created, and the problem doesn't occur. If an insmod is found, a process is created to run it, which will inherit the kernel portion of the swapper_pg_dir first level page table. It doesn't matter whether the inmod is successful or not, but when the the kernel scheduler context switches back to the kernel initialisation thread, the insmod's mm is 'borrowed' by the kernel thread, as it doesn't have an address space of its own. (Reference counting is used to ensure this mm is not destroyed, even though the user process which caused its creation may no longer exist.) If this address space doesn't have a first level page table entry for the consistent mappings, and a driver tries to access such a mapping, we are in the same situation as described above, except this time in a kernel thread rather than a user thread executing inside the kernel. See bugzilla: 15425, 15836, 15862, 16106, 16793 Signed-off-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-04-07Merge tag 'sh-for-linus' of git://github.com/pmundt/linux-shLinus Torvalds
Pull SuperH fixes from Paul Mundt. * tag 'sh-for-linus' of git://github.com/pmundt/linux-sh: sh: fix clock-sh7757 for the latest sh_mobile_sdhi driver serial: sh-sci: use serial_port_in/out vs sci_in/out. sh: vsyscall: Fix up .eh_frame generation. sh: dma: Fix up device attribute mismatch from sysdev fallout. sh: dwarf unwinder depends on SHcompact. sh: fix up fallout from system.h disintegration.
2012-04-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull DMA mapping branch from Marek Szyprowski: "Short summary for the whole series: A few limitations have been identified in the current dma-mapping design and its implementations for various architectures. There exist more than one function for allocating and freeing the buffers: currently these 3 are used dma_{alloc, free}_coherent, dma_{alloc,free}_writecombine, dma_{alloc,free}_noncoherent. For most of the systems these calls are almost equivalent and can be interchanged. For others, especially the truly non-coherent ones (like ARM), the difference can be easily noticed in overall driver performance. Sadly not all architectures provide implementations for all of them, so the drivers might need to be adapted and cannot be easily shared between different architectures. The provided patches unify all these functions and hide the differences under the already existing dma attributes concept. The thread with more references is available here: http://www.spinics.net/lists/linux-sh/msg09777.html These patches are also a prerequisite for unifying DMA-mapping implementation on ARM architecture with the common one provided by dma_map_ops structure and extending it with IOMMU support. More information is available in the following thread: http://thread.gmane.org/gmane.linux.kernel.cross-arch/12819 More works on dma-mapping framework are planned, especially in the area of buffer sharing and managing the shared mappings (together with the recently introduced dma_buf interface: commit d15bd7ee445d "dma-buf: Introduce dma buffer sharing mechanism"). The patches in the current set introduce a new alloc/free methods (with support for memory attributes) in dma_map_ops structure, which will later replace dma_alloc_coherent and dma_alloc_writecombine functions." People finally started piping up with support for merging this, so I'm merging it as the last of the pending stuff from the merge window. Looks like pohmelfs is going to wait for 3.5 and more external support for merging. * 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: common: DMA-mapping: add NON-CONSISTENT attribute common: DMA-mapping: add WRITE_COMBINE attribute common: dma-mapping: introduce mmap method common: dma-mapping: remove old alloc_coherent and free_coherent methods Hexagon: adapt for dma_map_ops changes Unicore32: adapt for dma_map_ops changes Microblaze: adapt for dma_map_ops changes SH: adapt for dma_map_ops changes Alpha: adapt for dma_map_ops changes SPARC: adapt for dma_map_ops changes PowerPC: adapt for dma_map_ops changes MIPS: adapt for dma_map_ops changes X86 & IA64: adapt for dma_map_ops changes common: dma-mapping: introduce generic alloc() and free() methods
2012-04-05sh: fix clock-sh7757 for the latest sh_mobile_sdhi driverShimoda, Yoshihiro
The commit 996bc8aebd2cd5b6d4c5d85085f171fa2447f364 (mmc: sh_mobile_sdhi: do not manage PM clocks manually) modified the sh_mobile_sdhi driver to remove the clk_enable/clk_disable. So, we need to change the "CLKDEV_CON_ID" to "CLKDEV_DEV_ID". If we don't change this, we will see the following error from the driver: sh_mobile_sdhi sh_mobile_sdhi.0: timeout waiting for hardware interrupt (CMD52) Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-30Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - Unification of cmd_uimage among archs that use it - make headers_check tries harder before reporting a missing <linux/types.h> include - kbuild portability fix for shells that do not support echo -e - make clean descends into samples/ - setlocalversion grep fix - modpost typo fix - dtc warnings fix * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: setlocalversion: Use "grep -q" instead of piping output to "read dummy" modpost: fix ALL_INIT_DATA_SECTIONS Kbuild: centralize MKIMAGE and cmd_uimage definitions headers_check: recursively search for linux/types.h inclusion scripts/Kbuild.include: Fix portability problem of "echo -e" scripts: dtc: fix compile warnings kbuild: clean up samples directory kbuild: disable -Wmissing-field-initializers for W=1
2012-03-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull ACPI & Power Management changes from Len Brown: - ACPI 5.0 after-ripples, ACPICA/Linux divergence cleanup - cpuidle evolving, more ARM use - thermal sub-system evolving, ditto - assorted other PM bits Fix up conflicts in various cpuidle implementations due to ARM cpuidle cleanups (ARM at91 self-refresh and cpu idle code rewritten into "standby" in asm conflicting with the consolidation of cpuidle time keeping), trivial SH include file context conflict and RCU tracing fixes in generic code. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (77 commits) ACPI throttling: fix endian bug in acpi_read_throttling_status() Disable MCP limit exceeded messages from Intel IPS driver ACPI video: Don't start video device until its associated input device has been allocated ACPI video: Harden video bus adding. ACPI: Add support for exposing BGRT data ACPI: export acpi_kobj ACPI: Fix logic for removing mappings in 'acpi_unmap' CPER failed to handle generic error records with multiple sections ACPI: Clean redundant codes in scan.c ACPI: Fix unprotected smp_processor_id() in acpi_processor_cst_has_changed() ACPI: consistently use should_use_kmap() PNPACPI: Fix device ref leaking in acpi_pnp_match ACPI: Fix use-after-free in acpi_map_lsapic ACPI: processor_driver: add missing kfree ACPI, APEI: Fix incorrect APEI register bit width check and usage Update documentation for parameter *notrigger* in einj.txt ACPI, APEI, EINJ, new parameter to control trigger action ACPI, APEI, EINJ, limit the range of einj_param ACPI, APEI, Fix ERST header length check cpuidle: power_usage should be declared signed integer ...
2012-03-30Merge branches 'sh/urgent', 'sh/vsyscall' and 'common/serial-rework' into ↵Paul Mundt
sh-latest
2012-03-30sh: vsyscall: Fix up .eh_frame generation.Paul Mundt
Some improper formatting caused the .eh_frame generation to fail, resulting in gcc/g++ testsuite failures with regards to unwinding through the vDSO. Now that someone is actually working on this on the gcc side it's time to fix up the kernel side, too. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-30sh: dma: Fix up device attribute mismatch from sysdev fallout.Paul Mundt
This fixes up an attribute mismatch that was introduced in the sysdev->struct device migration. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-30sh: dwarf unwinder depends on SHcompact.Paul Mundt
Presently there's no SHmedia support plugged in for the dwarf unwinder. While it's trivial to provide an SHmedia version of dwarf_read_arch_reg(), the general sh64 case is more complicated in that the TLB miss handler uses a locked down set of registers for optimization (including the frame pointer) which we need for the unwind table generation. While freeing up the frame pointer for use in the TLB miss handler is reasonably straightforward, it's still more trouble than it's worth, so we simply restrict the unwinder to 32-bit for now. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-30sh: fix up fallout from system.h disintegration.Paul Mundt
Quite a bit of fallout all over the place, nothing terribly exciting. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-30Merge tag 'sh-for-linus' of git://github.com/pmundt/linux-shLinus Torvalds
Pull SuperH updates from Paul Mundt. * tag 'sh-for-linus' of git://github.com/pmundt/linux-sh: (25 commits) sh: Support I/O space swapping where needed. sh: use set_current_blocked() and block_sigmask() sh: no need to reset handler if SA_ONESHOT sh: intc: Fix up section mismatch for intc_ack_data sh: select ARCH_DISCARD_MEMBLOCK. sh: Consolidate duplicate _32/_64 unistd definitions. sh: ecovec: switch SDHI controllers to card polling sh: Avoid exporting unimplemented syscalls. sh: add platform_device for RSPI in setup-sh7757 SH: pci-sh7780: enable big-endian operation. serial: sh-sci: fix a race of DMA submit_tx on transfer sh: dma: Collect up CHCR of SH7763, SH7764, SH7780 and SH7785 sh: dma: Collect up CHCR of SH7723 and SH7730 sh/next: Fix build fail by asm/system.h in asm/bitops.h arch/sh/drivers/dma/{dma-g2,dmabrg}.c: ensure arguments to request_irq and free_irq are compatible sh: cpufreq: Wire up scaling_available_freqs support. sh: cpufreq: notify about rate rounding fallback. sh: cpufreq: Support CPU clock frequency table. sh: cpufreq: struct device lookup from CPU topology. sh: cpufreq: percpu struct clk accounting. ...
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-29Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull more ARM updates from Russell King. This got a fair number of conflicts with the <asm/system.h> split, but also with some other sparse-irq and header file include cleanups. They all looked pretty trivial, though. * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (59 commits) ARM: fix Kconfig warning for HAVE_BPF_JIT ARM: 7361/1: provide XIP_VIRT_ADDR for no-MMU builds ARM: 7349/1: integrator: convert to sparse irqs ARM: 7259/3: net: JIT compiler for packet filters ARM: 7334/1: add jump label support ARM: 7333/2: jump label: detect %c support for ARM ARM: 7338/1: add support for early console output via semihosting ARM: use set_current_blocked() and block_sigmask() ARM: exec: remove redundant set_fs(USER_DS) ARM: 7332/1: extract out code patch function from kprobes ARM: 7331/1: extract out insn generation code from ftrace ARM: 7330/1: ftrace: use canonical Thumb-2 wide instruction format ARM: 7351/1: ftrace: remove useless memory checks ARM: 7316/1: kexec: EOI active and mask all interrupts in kexec crash path ARM: Versatile Express: add NO_IOPORT ARM: get rid of asm/irq.h in asm/prom.h ARM: 7319/1: Print debug info for SIGBUS in user faults ARM: 7318/1: gic: refactor irq_start assignment ARM: 7317/1: irq: avoid NULL check in for_each_irq_desc loop ARM: 7315/1: perf: add support for the Cortex-A7 PMU ...
2012-03-29sh: Support I/O space swapping where needed.Paul Mundt
This adopts a trimmed down version of the MIPS port mangling interface limited to the I/O swabbing for platforms that can't use little endian accessors. For platforms with mixed I/O spaces involving PCI it will still be necessary to enable byte swapping at the host controller level. Attention needs to be paid to all of host controller endianness, CPU endianness, and whether I/O accesses are explicitly swapped or not via SWAP_IO_SPACE. Fortunately the platforms that need this are in the minority. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-29sh: use set_current_blocked() and block_sigmask()Matt Fleming
As described in e6fa16ab ("signal: sigprocmask() should do retarget_shared_pending()") the modification of current->blocked is incorrect as we need to check whether the signal we're about to block is pending in the shared queue. Also, use the new helper function introduced in commit 5e6292c0f28f ("signal: add block_sigmask() for adding sigmask to current->blocked") which centralises the code for updating current->blocked after successfully delivering a signal and reduces the amount of duplicate code across architectures. In the past some architectures got this code wrong, so using this helper function should stop that from happening again. Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-29sh: no need to reset handler if SA_ONESHOTMatt Fleming
get_signal_to_deliver() already resets the signal handler if SA_ONESHOT is set in ka->sa.sa_flags, there's no need to do it again in handle_signal(). Furthermore, because we were modifying ka->sa.sa_handler (which is a copy of sighand->action[]) instead of sighand->action[] the original code had no effect on signal delivery. Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Delete all instances of asm/system.hDavid Howells
Delete all instances of asm/system.h as they should be redundant by this point. Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28Move all declarations of free_initmem() to linux/mm.hDavid Howells
Move all declarations of free_initmem() to linux/mm.h so that there's only one and it's used by everything. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-c6x-dev@linux-c6x.org cc: microblaze-uclinux@itee.uq.edu.au cc: linux-sh@vger.kernel.org cc: sparclinux@vger.kernel.org cc: x86@kernel.org cc: linux-mm@kvack.org
2012-03-28Disintegrate asm/system.h for SHDavid Howells
Disintegrate asm/system.h for SH. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-sh@vger.kernel.org
2012-03-28SH: adapt for dma_map_ops changesAndrzej Pietrasiewicz
Adapt core SH architecture code for dma_map_ops changes: replace alloc/free_coherent with generic alloc/free methods. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Paul Mundt <lethal@linux-sh.org>
2012-03-28sh: select ARCH_DISCARD_MEMBLOCK.Paul Mundt
We don't require it outside of the __init context, so discard it. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-28sh: Consolidate duplicate _32/_64 unistd definitions.Paul Mundt
This does some more tidying and converging of the header split, following the x86 example. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-28sh: ecovec: switch SDHI controllers to card pollingGuennadi Liakhovetski
Polling for card hotplug events is a better option than using SDHI native hotplug interrupt, because the latter option forces the controller to stay permanently powered up and enabled. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-28sh: Avoid exporting unimplemented syscalls.Paul Mundt
Now that userspace is making use of kernel-provided sanitized headers for working out supported interfaces, we need to be a bit more diligent with matching the syscall definitions with their actual wiring/support state. In theory it shouldn't hurt anything since sys_ni_syscall will ultimately do the right thing, but there's also not much need to lie about legacy x86 syscalls that we've never supported. This tightens things up a bit for uClibc at least. Suggested-by: Carmelo Amoroso <carmelo.amoroso@st.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-28sh: add platform_device for RSPI in setup-sh7757Shimoda, Yoshihiro
2012-03-28SH: pci-sh7780: enable big-endian operation.Thomas Schwinge
If in big-endian mode, switch the PCI bus, too. Tested on both litte-endian and big-endian sh7785lcr. Signed-off-by: Thomas Schwinge <thomas@codesourcery.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: linux-sh@vger.kernel.org Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-28sh: dma: Collect up CHCR of SH7763, SH7764, SH7780 and SH7785Nobuhiro Iwamatsu
CHCR of SH7763, SH7764, SH7780 and SH7785 is constitution same as SH7757. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Reviewed-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-28sh: dma: Collect up CHCR of SH7723 and SH7730Nobuhiro Iwamatsu
CHCR of SH7723 and SH7730 is constitution same as SH7724. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Reviewed-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-28Merge branch 'sh/cpufreq' into sh-latestPaul Mundt
2012-03-28sh/next: Fix build fail by asm/system.h in asm/bitops.hNobuhiro Iwamatsu
Other files are not done include definitely by asm/system.h made include in asm/bitops.h. This patch remove asm/system.h from asm/bitops.h. ----- LANG=C make ARCH=sh CROSS_COMPILE=sh4-linux-gnu- CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/machtypes.h' is up to date. CC arch/sh/kernel/asm-offsets.s In file included from include/asm-generic/getorder.h:7, from /home/iwamatsu/work/kernel/sh-2.6-devel/arch/sh/include/asm/page.h:187, from /home/iwamatsu/work/kernel/sh-2.6-devel/arch/sh/include/asm/mmu.h:38, from /home/iwamatsu/work/kernel/sh-2.6-devel/arch/sh/include/asm/system_32.h:5, from /home/iwamatsu/work/kernel/sh-2.6-devel/arch/sh/include/asm/system.h:179, from /home/iwamatsu/work/kernel/sh-2.6-devel/arch/sh/include/asm/bitops.h:10, from include/linux/bitops.h:22, from include/linux/thread_info.h:52, from include/linux/preempt.h:9, from include/linux/spinlock.h:50, from include/linux/mmzone.h:7, from include/linux/gfp.h:4, from include/linux/mm.h:8, from arch/sh/kernel/asm-offsets.c:13: include/linux/log2.h: In function '__ilog2_u32': include/linux/log2.h:34: error: implicit declaration of function 'fls' include/linux/log2.h: In function '__ilog2_u64': include/linux/log2.h:42: error: implicit declaration of function 'fls64' include/linux/log2.h: In function '__roundup_pow_of_two': include/linux/log2.h:63: error: implicit declaration of function 'fls_long' ----- Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-28Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux into sh-latest
2012-03-27Merge tag 'timer' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: timer cleanup work" from Arnd Bergmann: "These are split out from the generic soc and driver updates because there was a lot of conflicting work by multiple people. Marc Zyngier worked on simplifying the "localtimer" interfaces, and some of the platforms are touching the same code as they move to device tree based booting. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" * tag 'timer' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (61 commits) ARM: tegra: select USB_ULPI if USB is selected arm/tegra: pcie: fix return value of function ARM: ux500: fix compilation after local timer rework ARM: shmobile: remove additional __io() macro use ARM: local timers: make the runtime registration interface mandatory ARM: local timers: convert MSM to runtime registration interface ARM: local timers: convert exynos to runtime registration interface ARM: smp_twd: remove old local timer interface ARM: imx6q: convert to twd_local_timer_register() interface ARM: highbank: convert to twd_local_timer_register() interface ARM: ux500: convert to twd_local_timer_register() interface ARM: shmobile: convert to twd_local_timer_register() interface ARM: tegra: convert to twd_local_timer_register() interface ARM: plat-versatile: convert to twd_local_timer_register() interface ARM: OMAP4: convert to twd_local_timer_register() interface ARM: smp_twd: add device tree support ARM: smp_twd: add runtime registration support ARM: local timers: introduce a new registration interface ARM: smp_twd: make local_timer_stop a symbol instead of a #define ARM: mach-shmobile: default to no earlytimer ...
2012-03-26Kbuild: centralize MKIMAGE and cmd_uimage definitionsStephen Warren
All ARCHs have the same definition of MKIMAGE. Move it to Makefile.lib to avoid duplication. All ARCHs have similar definitions of cmd_uimage. Place a sufficiently parameterized version in Makefile.lib to avoid duplication. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Nicolas Pitre <nico@linaro.org> Tested-by: Mike Frysinger <vapier@gentoo.org> [Blackfin] Tested-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Guan Xuetao <gxt@mprc.pku.edu.cn> [unicore32] Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-23Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge second batch of patches from Andrew Morton: - various misc things - core kernel changes to prctl, exit, exec, init, etc. - kernel/watchdog.c updates - get_maintainer - MAINTAINERS - the backlight driver queue - core bitops code cleanups - the led driver queue - some core prio_tree work - checkpatch udpates - largeish crc32 update - a new poll() feature for the v4l guys - the rtc driver queue - fatfs - ptrace - signals - kmod/usermodehelper updates - coredump - procfs updates * emailed from Andrew Morton <akpm@linux-foundation.org>: (141 commits) seq_file: add seq_set_overflow(), seq_overflow() proc-ns: use d_set_d_op() API to set dentry ops in proc_ns_instantiate(). procfs: speed up /proc/pid/stat, statm procfs: add num_to_str() to speed up /proc/stat proc: speed up /proc/stat handling fs/proc/kcore.c: make get_sparsemem_vmemmap_info() static coredump: add VM_NODUMP, MADV_NODUMP, MADV_CLEAR_NODUMP coredump: remove VM_ALWAYSDUMP flag kmod: make __request_module() killable kmod: introduce call_modprobe() helper usermodehelper: ____call_usermodehelper() doesn't need do_exit() usermodehelper: kill umh_wait, renumber UMH_* constants usermodehelper: implement UMH_KILLABLE usermodehelper: introduce umh_complete(sub_info) usermodehelper: use UMH_WAIT_PROC consistently signal: zap_pid_ns_processes: s/SEND_SIG_NOINFO/SEND_SIG_FORCED/ signal: oom_kill_task: use SEND_SIG_FORCED instead of force_sig() signal: cosmetic, s/from_ancestor_ns/force/ in prepare_signal() paths signal: give SEND_SIG_FORCED more power to beat SIGNAL_UNKILLABLE Hexagon: use set_current_blocked() and block_sigmask() ...
2012-03-23coredump: remove VM_ALWAYSDUMP flagJason Baron
The motivation for this patchset was that I was looking at a way for a qemu-kvm process, to exclude the guest memory from its core dump, which can be quite large. There are already a number of filter flags in /proc/<pid>/coredump_filter, however, these allow one to specify 'types' of kernel memory, not specific address ranges (which is needed in this case). Since there are no more vma flags available, the first patch eliminates the need for the 'VM_ALWAYSDUMP' flag. The flag is used internally by the kernel to mark vdso and vsyscall pages. However, it is simple enough to check if a vma covers a vdso or vsyscall page without the need for this flag. The second patch then replaces the 'VM_ALWAYSDUMP' flag with a new 'VM_NODUMP' flag, which can be set by userspace using new madvise flags: 'MADV_DONTDUMP', and unset via 'MADV_DODUMP'. The core dump filters continue to work the same as before unless 'MADV_DONTDUMP' is set on the region. The qemu code which implements this features is at: http://people.redhat.com/~jbaron/qemu-dump/qemu-dump.patch In my testing the qemu core dump shrunk from 383MB -> 13MB with this patch. I also believe that the 'MADV_DONTDUMP' flag might be useful for security sensitive apps, which might want to select which areas are dumped. This patch: The VM_ALWAYSDUMP flag is currently used by the coredump code to indicate that a vma is part of a vsyscall or vdso section. However, we can determine if a vma is in one these sections by checking it against the gate_vma and checking for a non-NULL return value from arch_vma_name(). Thus, freeing a valuable vma bit. Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Roland McGrath <roland@hack.frob.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Avi Kivity <avi@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci Pull PCI changes (including maintainer change) from Jesse Barnes: "This pull has some good cleanups from Bjorn and Yinghai, as well as some more code from Yinghai to better handle resource re-allocation when enabled. There's also a new initcall_debug feature from Arjan which will print out quirk timing information to help identify slow quirks for fixing or refinement (Yinghai sent in a few patches to do just that once the new debug code landed). Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas. He's been a core PCI and Linux contributor for some time now, and has kindly volunteered to take over. I just don't feel I have the time for PCI review and work that it deserves lately (I've taken on some other projects), and haven't been as responsive lately as I'd like, so I approached Bjorn asking if he'd like to manage things. He's going to give it a try, and I'm confident he'll do at least as well as I have in keeping the tree managed, patches flowing, and keeping things stable." Fix up some fairly trivial conflicts due to other cleanups (mips device resource fixup cleanups clashing with list handling cleanup, ppc iseries removal clashing with pci_probe_only cleanup etc) * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits) PCI: Bjorn gets PCI hotplug too PCI: hand PCI maintenance over to Bjorn Helgaas unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h sparc/PCI: convert devtree and arch-probed bus addresses to resource powerpc/PCI: allow reallocation on PA Semi powerpc/PCI: convert devtree bus addresses to resource powerpc/PCI: compute I/O space bus-to-resource offset consistently arm/PCI: don't export pci_flags PCI: fix bridge I/O window bus-to-resource conversion x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()' PCI / PCIe: Introduce command line option to disable ARI PCI: make acpihp use __pci_remove_bus_device instead PCI: export __pci_remove_bus_device PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device PCI: print out PCI device info along with duration PCI: Move "pci reassigndev resource alignment" out of quirks.c PCI: Use class for quirk for usb host controller fixup PCI: Use class for quirk for ti816x class fixup PCI: Use class for quirk for intel e100 interrupt fixup ...
2012-03-22Merge tag 'fbdev-updates-for-3.4' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev updates for 3.4 from Florian Tobias Schandinat: - drivers for Samsung Exynos MIPI DSI and display port - i740fb to support those old Intel chips - large updates to OMAP, viafb and sh_mobile_lcdcfb - some updates to s3c-fb and udlfb, few patches to others Fix up conflicts in drivers/video/udlfb.c due to Key Sievers' fix making it in twice. * tag 'fbdev-updates-for-3.4' of git://github.com/schandinat/linux-2.6: (156 commits) Revert "video:uvesafb: Fix oops that uvesafb try to execute NX-protected page" OMAPDSS: register dss drivers in module init video: pxafb: add clk_prepare/clk_unprepare calls fbdev: bfin_adv7393fb: Drop needless include fbdev: sh_mipi_dsi: add extra phyctrl for sh_mipi_dsi_info fbdev: remove dependency of FB_SH_MOBILE_MERAM from FB_SH_MOBILE_LCDC Revert "MAINTAINERS: add entry for exynos mipi display drivers" fbdev: da8xx: add support for SP10Q010 display fbdev: da8xx:: fix reporting of the display timing info drivers/video/pvr2fb.c: ensure arguments to request_irq and free_irq are compatible OMAPDSS: APPLY: fix clearing shadow dirty flag with manual update fbdev: sh_mobile_meram: Implement system suspend/resume fbdev: sh_mobile_meram: Remove unneeded sanity checks fbdev: sh_mobile_meram: Don't perform update in register operation arm: mach-shmobile: Constify sh_mobile_meram_cfg structures fbdev: sh_mobile_lcdc: Don't store copy of platform data fbdev: sh_mobile_meram: Remove unused sh_mobile_meram_icb_cfg fields arm: mach-shmobile: Don't set MERAM ICB numbers in platform data fbdev: sh_mobile_meram: Allocate ICBs automatically fbdev: sh_mobile_meram: Use genalloc to manage MERAM allocation ...
2012-03-22Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull updates of sound stuff from Takashi Iwai: "Here is the first big update chunk of sound stuff for 3.4-rc1. In the common sound infrastructure, there are a few changes for dynamic PCM support (used in ASoC) and a few clean-ups. Majority of changes are found, as usual, in HD-audio and ASoC. Some highlights of HD-audio changes: - All the long-standing static quirk codes for Realtek codec were finally removed by fixing and extending the Realtek auto-parser. - The mute-LED control is standardized over all HD-audio codec drivers using the extended vmaster hook. - The vmaster slave mixer elements are initialized to 0dB as default so that the user won't be annoyed by the silent output after updates, e.g. due to the additions of new elements. - Other many fix-ups for the misc HD-audio devices. In the ASoC side, this is a very active release, including a quite a few framework enhancements. Some highlights: - Support for widgets not associated with a CODEC, an important part of the dynamic PCM framework. - A library factoring out the common code shared by dmaengine based DMA drivers contributed by Lars-Peter Clausen. This will save a lot of code and make it much easier to deploy enhancements to dmaengine. - Support for binary controls, used for providing runtime configuration of algorithm coefficients. - A new DAPM widget type for regulator supplies allowing drivers for devices that can power down unused supplies while active to do without any per-driver code. - DAPM widgets for DAIs, initially giving a speed boost for playback startup and shutdown and also the basis for CODEC<->CODEC DAI link support. - Support for specifying the number of significant bits on audio interfaces, useful for allowing applications to know how much effort to put into generating data for a larger sample format. - Conversion of the FSI driver used on some SH processors to DMAEngine. - Conversion of EP93xx drivers to DMAEngine. - New CODEC drivers for Maxim MAX9768 and Wolfson Microelectronics WM2200. - Move audmux driver from arc/arm to sound/soc - McBSP move from arch/ to sound/ and updates Also, a few small updates and fixes for other drivers like au88x0, ymfpci, USB 6fire, USB usx2yaudio are included." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (446 commits) ASoC: wm8994: Provide VMID mode control and fix default sequence ASoC: wm8994: Add missing break in resume ASoC: wm_hubs: Don't actively manage LINEOUT_VMID_BUF ASoC: pxa-ssp: atomically set stream active masks ASoC: fsl: p1022ds: tell the WM8776 codec driver that it's the master ASoC: Samsung: Added to support mono recording ALSA: hda - Fix build with CONFIG_PM=n ALSA: au88x0 - Avoid possible Oops at unbinding ALSA: usb-audio - Fix build error by consitification of rate list ASoC: core: Fix obscure leak of runtime array ALSA: pcm - Avoid GFP_ATOMIC in snd_pcm_link() ALSA: pcm: Constify the list in snd_pcm_hw_constraint_list ASoC: wm8996: Add 44.1kHz support ALSA: hda - Fix build of patch_sigmatel.c without CONFIG_SND_HDA_POWER_SAVE ASoC: mx27vis-aic32x4: Convert it to platform driver ALSA: hda - fix printing of high HDMI sample rates ALSA: ymfpci - Fix legacy registers on S3/S4 resume ALSA: control - Fixe a trailing white space error ALSA: hda - Add expose_enum_ctl flag to snd_hda_add_vmaster_hook() ALSA: hda - Add "Mute-LED Mode" enum control ...
2012-03-21Merge branch 'kmap_atomic' of git://github.com/congwang/linuxLinus Torvalds
Pull kmap_atomic cleanup from Cong Wang. It's been in -next for a long time, and it gets rid of the (no longer used) second argument to k[un]map_atomic(). Fix up a few trivial conflicts in various drivers, and do an "evil merge" to catch some new uses that have come in since Cong's tree. * 'kmap_atomic' of git://github.com/congwang/linux: (59 commits) feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] drbd: remove the second argument of k[un]map_atomic() zcache: remove the second argument of k[un]map_atomic() gma500: remove the second argument of k[un]map_atomic() dm: remove the second argument of k[un]map_atomic() tomoyo: remove the second argument of k[un]map_atomic() sunrpc: remove the second argument of k[un]map_atomic() rds: remove the second argument of k[un]map_atomic() net: remove the second argument of k[un]map_atomic() mm: remove the second argument of k[un]map_atomic() lib: remove the second argument of k[un]map_atomic() power: remove the second argument of k[un]map_atomic() kdb: remove the second argument of k[un]map_atomic() udf: remove the second argument of k[un]map_atomic() ubifs: remove the second argument of k[un]map_atomic() squashfs: remove the second argument of k[un]map_atomic() reiserfs: remove the second argument of k[un]map_atomic() ocfs2: remove the second argument of k[un]map_atomic() ntfs: remove the second argument of k[un]map_atomic() ...
2012-03-21SH: shmobile: Consolidate time keeping and irq enableRobert Lee
Enable core cpuidle timekeeping and irq enabling and remove that handling from this code. Signed-off-by: Robert Lee <rob.lee@linaro.org> Reviewed-by: Kevin Hilman <khilman@ti.com> Reviewed-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Jean Pihet <j-pihet@ti.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-20Merge commit 'v3.3' into fbdev-nextFlorian Tobias Schandinat
2012-03-20Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes for v3.4 from Ingo Molnar * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) printk: Make it compile with !CONFIG_PRINTK sched/x86: Fix overflow in cyc2ns_offset sched: Fix nohz load accounting -- again! sched: Update yield() docs printk/sched: Introduce special printk_sched() for those awkward moments sched/nohz: Correctly initialize 'next_balance' in 'nohz' idle balancer sched: Cleanup cpu_active madness sched: Fix load-balance wreckage sched: Clean up parameter passing of proc_sched_autogroup_set_nice() sched: Ditch per cgroup task lists for load-balancing sched: Rename load-balancing fields sched: Move load-balancing arguments into helper struct sched/rt: Do not submit new work when PI-blocked sched/rt: Prevent idle task boosting sched/wait: Add __wake_up_all_locked() API sched/rt: Document scheduler related skip-resched-check sites sched/rt: Use schedule_preempt_disabled() sched/rt: Add schedule_preempt_disabled() sched/rt: Do not throttle when PI boosting sched/rt: Keep period timer ticking when rt throttling is active ...
2012-03-20Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf events changes for v3.4 from Ingo Molnar: - New "hardware based branch profiling" feature both on the kernel and the tooling side, on CPUs that support it. (modern x86 Intel CPUs with the 'LBR' hardware feature currently.) This new feature is basically a sophisticated 'magnifying glass' for branch execution - something that is pretty difficult to extract from regular, function histogram centric profiles. The simplest mode is activated via 'perf record -b', and the result looks like this in perf report: $ perf record -b any_call,u -e cycles:u branchy $ perf report -b --sort=symbol 52.34% [.] main [.] f1 24.04% [.] f1 [.] f3 23.60% [.] f1 [.] f2 0.01% [k] _IO_new_file_xsputn [k] _IO_file_overflow 0.01% [k] _IO_vfprintf_internal [k] _IO_new_file_xsputn 0.01% [k] _IO_vfprintf_internal [k] strchrnul 0.01% [k] __printf [k] _IO_vfprintf_internal 0.01% [k] main [k] __printf This output shows from/to branch columns and shows the highest percentage (from,to) jump combinations - i.e. the most likely taken branches in the system. "branches" can also include function calls and any other synchronous and asynchronous transitions of the instruction pointer that are not 'next instruction' - such as system calls, traps, interrupts, etc. This feature comes with (hopefully intuitive) flat ascii and TUI support in perf report. - Various 'perf annotate' visual improvements for us assembly junkies. It will now recognize function calls in the TUI and by hitting enter you can follow the call (recursively) and back, amongst other improvements. - Multiple threads/processes recording support in perf record, perf stat, perf top - which is activated via a comma-list of PIDs: perf top -p 21483,21485 perf stat -p 21483,21485 -ddd perf record -p 21483,21485 - Support for per UID views, via the --uid paramter to perf top, perf report, etc. For example 'perf top --uid mingo' will only show the tasks that I am running, excluding other users, root, etc. - Jump label restructurings and improvements - this includes the factoring out of the (hopefully much clearer) include/linux/static_key.h generic facility: struct static_key key = STATIC_KEY_INIT_FALSE; ... if (static_key_false(&key)) do unlikely code else do likely code ... static_key_slow_inc(); ... static_key_slow_inc(); ... The static_key_false() branch will be generated into the code with as little impact to the likely code path as possible. the static_key_slow_*() APIs flip the branch via live kernel code patching. This facility can now be used more widely within the kernel to micro-optimize hot branches whose likelihood matches the static-key usage and fast/slow cost patterns. - SW function tracer improvements: perf support and filtering support. - Various hardenings of the perf.data ABI, to make older perf.data's smoother on newer tool versions, to make new features integrate more smoothly, to support cross-endian recording/analyzing workflows better, etc. - Restructuring of the kprobes code, the splitting out of 'optprobes', and a corner case bugfix. - Allow the tracing of kernel console output (printk). - Improvements/fixes to user-space RDPMC support, allowing user-space self-profiling code to extract PMU counts without performing any system calls, while playing nice with the kernel side. - 'perf bench' improvements - ... and lots of internal restructurings, cleanups and fixes that made these features possible. And, as usual this list is incomplete as there were also lots of other improvements * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (120 commits) perf report: Fix annotate double quit issue in branch view mode perf report: Remove duplicate annotate choice in branch view mode perf/x86: Prettify pmu config literals perf report: Enable TUI in branch view mode perf report: Auto-detect branch stack sampling mode perf record: Add HEADER_BRANCH_STACK tag perf record: Provide default branch stack sampling mode option perf tools: Make perf able to read files from older ABIs perf tools: Fix ABI compatibility bug in print_event_desc() perf tools: Enable reading of perf.data files from different ABI rev perf: Add ABI reference sizes perf report: Add support for taken branch sampling perf record: Add support for sampling taken branch perf tools: Add code to support PERF_SAMPLE_BRANCH_STACK x86/kprobes: Split out optprobe related code to kprobes-opt.c x86/kprobes: Fix a bug which can modify kernel code permanently x86/kprobes: Fix instruction recovery on optimized path perf: Add callback to flush branch_stack on context switch perf: Disable PERF_SAMPLE_BRANCH_* when not supported perf/x86: Add LBR software filter support for Intel CPUs ...
2012-03-20sh: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-15arch/sh/drivers/dma/{dma-g2,dmabrg}.c: ensure arguments to request_irq and ↵Julia Lawall
free_irq are compatible Convert calls to free_irq so that the second argument is the same as the last argument of the corresponding call to request_irq. Without this property, free_irq does nothing. In the case of dmabrg.c the change is merely cosmetic - changing 0 to NULL. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-03-12fbdev: sh_mobile_lcdc: Rename (lcd|num)_cfg (lcd|num)_modesLaurent Pinchart
The struct sh_mobile_lcdc_chan_cfg platform data contains a list of video modes. Name the lcd_cfg and num_cfg fields to reflect that they describe video modes. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
