[ Upstream commit 178a29600340bef5b13cd4157053679debe35351 ]
Config option GENERIC_HARDIRQS_NO_DEPRECATED was removed in commit
78c89825649a9a5ed526c507603196f467d781a5 ("genirq: Remove the now obsolete
config options and select statements"), but the select was accidentally
reintroduced in commit 6baa9b20a68a88c2fd751cbe8d7652009379351b
("sparc32: genirq support")
The DMA region must be accessible in order for PCI peripheral
drivers to work, the sparc32 has DMA in the normal memory
zone which requires the GRPCI2 to PCI target BARs so that all
kernel low mem (192MB) can be mapped 1:1 to PCI address
space. The GRPCI2 has resizeable target BARs, by default the
first is made 256MB and all other BARs are disabled.
I/O space are always located on 0x1000-0x10000, but accessed
through the GRPCI2 PCI I/O Window memory mapped to virtual
address space.
Configuration space is accessed through the 64KB GRPCI2 PCI
CFG Window using LDA bypassing the MMU.
The GRPCI2 has a single PCI Window for prefetchable and non-
prefetchable address space, it is up to the AHB master
requesting PCI data to determine access type. Memory space
is mapped 1:1.
The GRPCI2 core can be configured in 4 different IRQ modes,
where PCI Interrupt, Error Interrupt and DMA Interrupt are
shared on a single IRQ line or at most 5 IRQs are used. The
GRPCI2 can mask/unmask PCI interrupts, Err and DMA in the control
and check status bits which tells us which IRQ really happended.
The GENIRQ layer is used to unmask/mask each individual IRQ
source by creating virtual IRQs and implementing a IRQ chip.
The optional DMA functionality of the GRPCI2 is not supported
by this patch.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
The LEON architecture does not have a BIOS or bootloader that
initializes PCI for us, instead Linux generic PCI layer is used
to set up resources and IRQ.
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT,
CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used
to test for existence of find bitops anymore.
Acked-by: Greg Ungerer <gerg@uclinux.org>
The current sparc32 SMP IPI generation is implemented the
cross call function. The cross call function uses IRQ15 the
NMI, this is has the effect that IPIs will interrupt IRQ
critical areas and hang the system. Typically on/after
spin_lock_irqsave calls can be aborted.
The cross call functionality must still exist to flush
cache/TLBS.
This patch provides CPU models a custom way to implement
generation of IPIs on the generic code's request. The
typical approach is to generate an IRQ for each IPI case.
After this patch each sparc32 SMP CPU model needs to
implement IPIs in order to function properly.
The conversion of sparc32 to genirq is based on original work done
by David S. Miller.
Daniel Hellstrom has helped in the conversion and implemented
the shutdowm functionality.
Marcel van Nies <morcles@gmail.com> has tested this on Sparc Station 20
Test status:
sun4c - not tested
sun4m,pci - not tested
sun4m,sbus - tested (Sparc Classic, Sparc Station 5, Sparc Station 20)
sun4d - not tested
leon - tested on various combinations of leon boards,
including SMP variants
generic
Introduce use of GENERIC_HARDIRQS and GENERIC_IRQ_SHOW
Allocate 64 IRQs - which is enough even for SS2000
Use a table of irq_bucket to maintain uses IRQs
irq_bucket is also used to chain several irq's that
must be called when the same intrrupt is asserted
Use irq_link to link a interrupt source to the irq
All plafforms must now supply their own build_device_irq method
handler_irq rewriten to use generic irq support
floppy
Read FLOPPY_IRQ from platform device
Use generic request_irq to register the floppy interrupt
Rewrote sparc_floppy_irq to use the generic irq support
pcic:
Introduce irq_chip
Store mask in chip_data for use in mask/unmask functions
Add build_device_irq for pcic
Use pcic_build_device_irq in pci_time_init
allocate virtual irqs in pcic_fill_irq
sun4c:
Introduce irq_chip
Add build_device_irq for sun4c
Use sun4c_build_device_irq in sun4c_init_timers
sun4m:
Introduce irq_chip
Introduce dedicated mask/unmask methods
Introduce sun4m_handler_data that allow easy access to necessary
data in the mask/unmask functions
Add a helper method to enable profile_timer (used from smp)
Added sun4m_build_device_irq
Use sun4m_build_device_irq in sun4m_init_timers
TODO:
There is no replacement for smp_rotate that always scheduled
next CPU as interrupt target upon an interrupt
sun4d:
Introduce irq_chip
Introduce sun4d_handler_data that allow easy access to
necessary data in mask/unmask fuctions
Rewrote sun4d_handler_irq to use generic irq support
TODO:
The original implmentation of enable/disable had:
if (irq < NR_IRQS)
return;
The new implmentation does not distingush between SBUS and cpu
interrupts.
I am no sure what is right here. I assume we need to do
something for the cpu interrupts.
I have not succeeded booting my sun4d box (with or without this patch)
and my understanding of this platfrom is limited.
So I would be a bit suprised if this works.
leon:
Introduce irq_chip
Add build_device_irq for leon
Use leon_build_device_irq in leon_init_timers
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Daniel Hellstrom <daniel@gaisler.com>
Tested-by: Daniel Hellstrom <daniel@gaisler.com>
Tested-by: Marcel van Nies <morcles@gmail.com>
Cc: sparclinux@vger.kernel.org
Make use of the new features in genirq:
1) Set the chip flag IRCHIP_EOI_IF_HANDLED, which ensures in the
core code that irq_eoi() is only called when the interrupt was
handled. That removes the extra status check in the callback.
2) Use the preflow handler, which is called from the fasteoi core code
before the device handler. That avoids another status check and the
open coded handler redirection.
This introduces CONFIG_GENERIC_FIND_BIT_LE to tell whether to use generic
implementation of find_*_bit_le() in lib/find_next_bit.c or not.
For now we select CONFIG_GENERIC_FIND_BIT_LE for all architectures which
enable CONFIG_GENERIC_FIND_NEXT_BIT.
But m68knommu wants to define own faster find_next_zero_bit_le() and
continues using generic find_next_{,zero_}bit().
(CONFIG_GENERIC_FIND_NEXT_BIT and !CONFIG_GENERIC_FIND_BIT_LE)
Cc: Greg Ungerer <gerg@uclinux.org>
This is only for LEON as u-boot for SPARC only supports LEON.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Drop all uses of deprecated genirq features.
The irq_set_affinity() call got a third paramter 'force'
which is unused.
For now genirq does not use this paramter and it is
ignored by sparc.
Cc: Josip Rodin <joy@entuzijast.net>
No functional change.
Acked-by: "David S. Miller" <davem@davemloft.net>
All architectures are finally converted. Remove the cruft.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jeff Dike <jdike@addtoit.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
kbuild: add ARCH=sparc32 target
sparc32: fix build failure on CONFIG_SPARC_LEON
sparc: Fixed random SPARC/LEON SMP CPU Stuck problem.
sparc32: remove CONFIG_HAVE_PERF_EVENTS option
sparc: don't #include asm/system.h in asm/jump_label.h
sparc32: Fix unaligned stack handling on trap return.
sparc: keep calling do_signal() as long as pending signals remain
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits)
kbuild: convert `arch/tile' to the kconfig mainmenu upgrade
README: cite nconfig
Revert "kconfig: Temporarily disable dependency warnings"
kconfig: Use PATH_MAX instead of 128 for path buffer sizes.
kconfig: Fix realloc usage()
kconfig: Propagate const
kconfig: Don't go out from read config loop when you read new symbol
kconfig: fix menuconfig on debian lenny
kbuild: migrate all arch to the kconfig mainmenu upgrade
kconfig: expand file names
kconfig: use the file's name of sourced file
kconfig: constify file name
kconfig: don't emit warning upon rootmenu's prompt redefinition
kconfig: replace KERNELVERSION usage by the mainmenu's prompt
kconfig: delay gconf window initialization
kconfig: expand by default the rootmenu's prompt
kconfig: add a symbol string expansion helper
kconfig: regen parser
kconfig: implement the `mainmenu' directive
kconfig: allow PACKAGE to be defined on the compiler's command-line
Fix up trivial conflict in arch/mn10300/Kconfig
Remove HAVE_PERF_EVENTS and PERF_USE_VMALLOC under config
SPARC because they're under SPARC64 too. Supporting
perf_event needs atomic64 operations but AFAIK sparc32
doesn't provide them, CMIIW. ;-) Also removes redundant
HAVE_IRQ_WORK line.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mtd/m25p80: add support to parse the partitions by OF node
of/irq: of_irq.c needs to include linux/irq.h
of/mips: Cleanup some include directives/files.
of/mips: Add device tree support to MIPS
of/flattree: Eliminate need to provide early_init_dt_scan_chosen_arch
of/device: Rework to use common platform_device_alloc() for allocating devices
of/xsysace: Fix OF probing on little-endian systems
of: use __be32 types for big-endian device tree data
of/irq: remove references to NO_IRQ in drivers/of/platform.c
of/promtree: add package-to-path support to pdt
of/promtree: add of_pdt namespace to pdt code
of/promtree: no longer call prom_ functions directly; use an ops structure
of/promtree: make drivers/of/pdt.c no longer sparc-only
sparc: break out some PROM device-tree building code out into drivers/of
of/sparc: convert various prom_* functions to use phandle
sparc: stop exporting openprom.h header
powerpc, of_serial: Endianness issues setting up the serial ports
of: MTD: Fix OF probing on little-endian systems
of: GPIO: Fix OF probing on little-endian systems
Provide a mechanism that allows running code in IRQ context. It is
most useful for NMI code that needs to interact with the rest of the
system -- like wakeup a task to drain buffers.
Perf currently has such a mechanism, so extract that and provide it as
a generic feature, independent of perf so that others may also
benefit.
The IRQ context callback is generated through self-IPIs where
possible, or on architectures like powerpc the decrementer (the
built-in timer facility) is set to generate an interrupt immediately.
Architectures that don't have anything like this get to do with a
callback from the timer tick. These architectures can call
irq_work_run() at the tail of any IRQ handlers that might enqueue such
work (like the perf IRQ handler) to avoid undue latencies in
processing the work.
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
[ various fixes ]
Signed-off-by: Huang Ying <ying.huang@intel.com>
LKML-Reference: <1287036094.7768.291.camel@yhuang-dev>
We need to revert the temporary hack in 71ebc01, hence the merge.
Clean up pdt.c:
- make build dependent upon config OF_PROMTREE
- #ifdef out the sparc-specific stuff
- create pdt-specific header
Signed-off-by: Andres Salomon <dilinger@queued.net>
The !CC_OPTIMIZE_FOR_SIZE was added to enable the jump label functionality
because Jason noticed that the gcc option would not optimize the labels
and may even hurt performance.
But this is a gcc problem not a kernel one. Removing this condition should
add motivation to the gcc developers to actually fix it.
Cc: Jason Baron <jbaron@redhat.com>
Add jump label support for sparc64.
LKML-Reference: <3b5b071fcdb2afb7f67cacecfa78b14c740278a7.1284733808.git.jbaron@redhat.com>
Signed-off-by: Jason Baron <jbaron@redhat.com>
[ cleaned up some formatting ]
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
Reviewed-by: Michal Marek <mmarek@suse.cz>
* 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
um: Fix read_persistent_clock fallout
kgdb: Do not access xtime directly
powerpc: Clean up obsolete code relating to decrementer and timebase
powerpc: Rework VDSO gettimeofday to prevent time going backwards
clocksource: Add __clocksource_updatefreq_hz/khz methods
x86: Convert common clocksources to use clocksource_register_hz/khz
timekeeping: Make xtime and wall_to_monotonic static
hrtimer: Cleanup direct access to wall_to_monotonic
um: Convert to use read_persistent_clock
timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset
powerpc: Cleanup xtime usage
powerpc: Simplify update_vsyscall
time: Kill off CONFIG_GENERIC_TIME
time: Implement timespec_add
x86: Fix vtime/file timestamp inconsistencies
Trivial conflicts in Documentation/feature-removal-schedule.txt
Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as
per Thomas' earlier merge commit 47916be4e28c ("Merge branch
'powerpc.cherry-picks' into timers/clocksource")
Now that all arches have been converted over to use generic time via
clocksources or arch_gettimeoffset(), we can remove the GENERIC_TIME
config option and simplify the generic code.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
LKML-Reference: <1279068988-21864-4-git-send-email-johnstul@us.ibm.com>
arch/sparc/kernel/prom_64.c
via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
now that CONFIG_OF is defined globally
Acked-by: Michal Simek <monstr@monstr.eu>
so that we can make CONFIG_OF global and remove it from
the architecture Kconfig files later.
There are only two ways to define sg_dma_len(); use sg->dma_length or
sg->length. This patch introduces NEED_SG_DMA_LENGTH that enables
architectures to choose sg->dma_length or sg->length.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
* 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
avr32: Fix typo in read_persistent_clock()
sparc: Convert sparc to use read/update_persistent_clock
cris: Convert cris to use read/update_persistent_clock
m68k: Convert m68k to use read/update_persistent_clock
m32r: Convert m32r to use read/update_peristent_clock
blackfin: Convert blackfin to use read/update_persistent_clock
ia64: Convert ia64 to use read/update_persistent_clock
avr32: Convert avr32 to use read/update_persistent_clock
h8300: Convert h8300 to use read/update_persistent_clock
frv: Convert frv to use read/update_persistent_clock
mn10300: Convert mn10300 to use read/update_persistent_clock
alpha: Convert alpha to use read/update_persistent_clock
xtensa: Fix unnecessary setting of xtime
time: Clean up direct xtime usage in xen
Check function_trace_stop at ftrace_caller
Toss mcount_call and dummy call of ftrace_stub, unnecessary.
Document problems we'll have if the final kernel image link
ever turns on relaxation.
Properly size 'ftrace_call' so it looks right when inspecting
instructions under gdb et al.
This patch converts the sparc architecture to use the generic
read_persistent_clock and update_persistent_clock interfaces, reducing
the amount of arch specific code we have to maintain, and allowing for
further cleanups in the future.
[ davem: compile fix: Here's a version that compiles, you have to get
rid of the now unused variably last_rtc_update since we build with
-Werror ]
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
This patch converts sparc (specifically sparc32) to use GENERIC_TIME via
the arch_getoffset() infrastructure, reducing the amount of arch
specific code we need to maintain.
The sparc architecture is one of the last 3 arches that need to be
converted.
This patch applies on top of Linus' current -git tree
I've taken my best swing at converting this, but I'm not 100% confident
I got it right. My cross-compiler is now out of date (gcc4.2) so I
wasn't able to check if it compiled. Any assistance from arch
maintainers or testers to get this merged would be great.
Borrow the powerpc bootx text console driver.
* 'sparc-perf-events-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
mm, perf_event: Make vmalloc_user() align base kernel virtual address to SHMLBA
perf_event: Provide vmalloc() based mmap() backing
Some architectures such as Sparc, ARM and MIPS (basically
everything with flush_dcache_page()) need to deal with dcache
aliases by carefully placing pages in both kernel and user maps.
These architectures typically have to use vmalloc_user() for this.
However, on other architectures, vmalloc() is not needed and has
the downsides of being more restricted and slower than regular
allocations.
Acked-by: David Miller <davem@davemloft.net>
Cc: Jens Axboe <jens.axboe@oracle.com>
LKML-Reference: <1254830228.21044.272.camel@laptop>
Implement page mapping percpu first chunk allocator as a fallback to
the embedding allocator. The next patch will make the embedding
allocator check distances between units to determine whether it fits
within the vmalloc area so that this fallback can be used on such
cases.
sparc64 currently has relatively small vmalloc area which makes it
impossible to create any dynamic chunks on certain configurations
leading to percpu allocation failures. This and the next patch should
allow those configurations to keep working until proper solution is
found.
While at it, mark pcpu_cpu_distance() with __init.
Bye-bye Performance Counters, welcome Performance Events!
In the past few months the perfcounters subsystem has grown out its
initial role of counting hardware events, and has become (and is
becoming) a much broader generic event enumeration, reporting, logging,
monitoring, analysis facility.
Naming its core object 'perf_counter' and naming the subsystem
'perfcounters' has become more and more of a misnomer. With pending
code like hw-breakpoints support the 'counter' name is less and
less appropriate.
All in one, we've decided to rename the subsystem to 'performance
events' and to propagate this rename through all fields, variables
and API names. (in an ABI compatible fashion)
The word 'event' is also a bit shorter than 'counter' - which makes
it slightly more convenient to write/handle as well.
Thanks goes to Stephane Eranian who first observed this misnomer and
suggested a rename.
User-space tooling and ABI compatibility is not affected - this patch
should be function-invariant. (Also, defconfigs were not touched to
keep the size down.)
This patch has been generated via the following script:
sed -i \
-e 's/PERF_EVENT_/PERF_RECORD_/g' \
-e 's/PERF_COUNTER/PERF_EVENT/g' \
-e 's/perf_counter/perf_event/g' \
-e 's/nb_counters/nb_events/g' \
-e 's/swcounter/swevent/g' \
-e 's/tpcounter_event/tp_event/g' \
$FILES
for N in $(find . -name perf_counter.[ch]); do
M=$(echo $N | sed 's/perf_counter/perf_event/g')
mv $N $M
done
FILES=$(find . -name perf_event.*)
sed -i \
-e 's/COUNTER_MASK/REG_MASK/g' \
-e 's/COUNTER/EVENT/g' \
-e 's/\<event\>/event_id/g' \
-e 's/counter/event/g' \
-e 's/Counter/Event/g' \
$FILES
... to keep it as correct as possible. This script can also be
used by anyone who has pending perfcounters patches - it converts
a Linux kernel tree over to the new naming. We tried to time this
change to the point in time where the amount of pending patches
is the smallest: the end of the merge window.
Namespace clashes were fixed up in a preparatory patch - and some
stylistic fallout will be fixed up in a subsequent patch.
( NOTE: 'counters' are still the proper terminology when we deal
with hardware registers - and these sed scripts are a bit
over-eager in renaming them. I've undone some of that, but
in case there's something left where 'counter' would be
better than 'event' we can undo that on an individual basis
instead of touching an otherwise nicely automated patch. )
Suggested-by: Stephane Eranian <eranian@google.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Paul Mackerras <paulus@samba.org>
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: <linux-arch@vger.kernel.org>
LKML-Reference: <new-submission>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits)
powerpc64: convert to dynamic percpu allocator
sparc64: use embedding percpu first chunk allocator
percpu: kill lpage first chunk allocator
x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA
percpu: update embedding first chunk allocator to handle sparse units
percpu: use group information to allocate vmap areas sparsely
vmalloc: implement pcpu_get_vm_areas()
vmalloc: separate out insert_vmalloc_vm()
percpu: add chunk->base_addr
percpu: add pcpu_unit_offsets[]
percpu: introduce pcpu_alloc_info and pcpu_group_info
percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward
percpu: add @align to pcpu_fc_alloc_fn_t
percpu: make @dyn_size mandatory for pcpu_setup_first_chunk()
percpu: drop @static_size from first chunk allocators
percpu: generalize first chunk allocator selection
percpu: build first chunk allocators selectively
percpu: rename 4k first chunk allocator to page
percpu: improve boot messages
percpu: fix pcpu_reclaim() locking
Fix trivial conflict as by Tejun Heo in kernel/sched.c
arch/sparc/Kconfig
This wires up the perf_counter_open() syscall so that basic
software support for perf is working.
The macro CONFIG_SPARC_LEON will shield, if undefined, the sun-sparc
code from LEON specific code. In
particular include/asm/leon.h will get empty through #ifdef and
leon_kernel.c and leon_mm.c will not be compiled.
Signed-off-by: Konrad Eisele <konrad@gaisler.com>
