path: root/arch/sparc/crypto
2015-10-08crypto: sparc - initialize blkcipher.ivsizeDave Kleikamp
Some of the crypto algorithms write to the initialization vector, but no space has been allocated for it. This clobbers adjacent memory. Cc: stable@vger.kernel.org Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-18crypto: sparc/md5 - use md5 IV MD5_HX instead of their raw valueLABBE Corentin
Since MD5 IV are now available in crypto/md5.h, use them. Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-01-13crypto: sparc64/md5 - fix module descriptionMathias Krause
MD5 is not SHA1. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-01-13crypto: sparc64/des - add "des3_ede" module aliasMathias Krause
This module provides implementations for "des3_ede", too. Announce those via an appropriate crypto module alias so it can be used in favour to the generic C implementation. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-01-13crypto: sparc64/camellia - fix module aliasMathias Krause
The module alias should be "camellia", not "aes". Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-01-13crypto: sparc64/aes - fix module descriptionMathias Krause
AES is a block cipher, not a hash. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-12-02crypto: sparc - replace memset by memzero_explicitJulia Lawall
Memset on a local variable may be removed when it is called just before the variable goes out of scope. Using memzero_explicit defeats this optimization. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier x; type T; @@ { ... when any T x[...]; ... when any when exists - memset + memzero_explicit (x, -0, ...) ... when != x when strict } // </smpl> This change was suggested by Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-11-24crypto: prefix module autoloading with "crypto-"Kees Cook
This prefixes all crypto module loading with "crypto-" so we never run the risk of exposing module auto-loading to userspace via a crypto API, as demonstrated by Mathias Krause: https://lkml.org/lkml/2013/3/4/70 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-05-18sparc64: fix sparse warnings in aes_glue.cSam Ravnborg
Fix following warnings: aes_glue.c:127:16: warning: symbol 'aes128_ops' was not declared. Should it be static? aes_glue.c:139:16: warning: symbol 'aes192_ops' was not declared. Should it be static? aes_glue.c:151:16: warning: symbol 'aes256_ops' was not declared. Should it be static? Fix by defining the variables static as they are not used outside this file Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19sparc64: Set CRYPTO_TFM_REQ_MAY_SLEEP consistently in CAMELLIA code.David S. Miller
We use the FPU and therefore cannot sleep during the crypto loops. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19sparc64: Set CRYPTO_TFM_REQ_MAY_SLEEP consistently in DES code.David S. Miller
2012-12-19sparc64: Fix ECB looping constructs in AES code.David S. Miller
Things works better when you increment the source buffer pointer properly. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19sparc64: Set CRYPTO_TFM_REQ_MAY_SLEEP consistently in AES code.David S. Miller
2012-12-19sparc64: Fix AES ctr mode block size.David S. Miller
Like the generic versions, we need to support a block size of '1' for CTR mode AES. This was discovered thanks to all of the new test cases added by Jussi Kivilinna. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19sparc64: Fix unrolled AES 256-bit key loops.David S. Miller
The basic scheme of the block mode assembler is that we start by enabling the FPU, loading the key into the floating point registers, then iterate calling the encrypt/decrypt routine for each block. For the 256-bit key cases, we run short on registers in the unrolled loops. So the {ENCRYPT,DECRYPT}_256_2() macros reload the key registers that get clobbered. The unrolled macros, {ENCRYPT,DECRYPT}_256(), are not mindful of this. So if we have a mix of multi-block and single-block calls, the single-block unrolled 256-bit encrypt/decrypt can run with some of the key registers clobbered. Handle this by always explicitly loading those registers before using the non-unrolled 256-bit macro. This was discovered thanks to all of the new test cases added by Jussi Kivilinna. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09sparc64: Fix build with mix of modular vs. non-modular crypto drivers.David S. Miller
We tried linking in a single built object to hold the device table, but only works if all of the sparc64 crypto modules get built the same way (modular vs. non-modular). Just include the device ID stub into each driver source file so that the table gets compiled into the correct result in all cases. Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-21sparc64: Fix function argument comment in camellia_sparc64_key_expand asm.David S. Miller
2012-09-17sparc64: Fix IV handling bug in des_sparc64_cbc_decryptDavid S. Miller
The IV wasn't being propagated properly past the first loop iteration. This bug lived only because the crypto layer tests for cbc(des) do not have any cases that go more than one loop. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-15sparc64: Add auto-loading mechanism to crypto-opcode drivers.David S. Miller
Just simply provide a device table containing an entry for sun4v cpus, the capability mask checks in the drivers themselves will take care of the rest. This makes the bootup logs on pre-T4 cpus slightly more verbose, with each driver indicating lack of support for the associated opcode(s). But this isn't too much of a real problem. I toyed with the idea of using explicit entries with compatability fields of "SPARC-T4", "SPARC-T5", etc. but all future cpus will have some subset of these opcodes available and this would just be one more pointless thing to do as each new cpu is released with a new string. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-15sparc64: Add missing pr_fmt define to crypto opcode drivers.David S. Miller
The hashes and crc32c had it, only the AES/DES/CAMELLIA drivers were missing it. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-15sparc64: Adjust crypto priorities.David S. Miller
Make the crypto opcode implementations have a higher priority than those provides by the ring buffer based Niagara crypto device. Also, several crypto opcode hashes were not setting the priority value at all. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-01sparc64: Fix bugs in unrolled 256-bit loops.David S. Miller
Some dm-crypt testing revealed several bugs in the 256-bit unrolled loops. The DECRYPT_256_2() macro had two errors: 1) Missing reload of KEY registers %f60 and %f62 2) Missing "\" in penultimate line of definition. In aes_sparc64_ecb_decrypt_256, we were storing the second half of the encryption result from the wrong source registers. In aes_sparc64_ctr_crypt_256 we have to be careful when we fall out of the 32-byte-at-a-time loop and handle a trailing 16-byte chunk. In that case we've clobbered the final key holding registers and have to restore them before executing the ENCRYPT_256() macro. Inside of the 32-byte-at-a-time loop things are OK, because we do this key register restoring during the first few rounds of the ENCRYPT_256_2() macro. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31sparc64: Avoid code duplication in crypto assembler.David S. Miller
Put the opcode macros in a common header Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30sparc64: Unroll CTR crypt loops in AES driver.David S. Miller
Before: testing speed of ctr(aes) encryption test 0 (128 bit key, 16 byte blocks): 1 operation in 206 cycles (16 bytes) test 1 (128 bit key, 64 byte blocks): 1 operation in 244 cycles (64 bytes) test 2 (128 bit key, 256 byte blocks): 1 operation in 360 cycles (256 bytes) test 3 (128 bit key, 1024 byte blocks): 1 operation in 814 cycles (1024 bytes) test 4 (128 bit key, 8192 byte blocks): 1 operation in 5021 cycles (8192 bytes) test 5 (192 bit key, 16 byte blocks): 1 operation in 206 cycles (16 bytes) test 6 (192 bit key, 64 byte blocks): 1 operation in 240 cycles (64 bytes) test 7 (192 bit key, 256 byte blocks): 1 operation in 378 cycles (256 bytes) test 8 (192 bit key, 1024 byte blocks): 1 operation in 939 cycles (1024 bytes) test 9 (192 bit key, 8192 byte blocks): 1 operation in 6395 cycles (8192 bytes) test 10 (256 bit key, 16 byte blocks): 1 operation in 209 cycles (16 bytes) test 11 (256 bit key, 64 byte blocks): 1 operation in 249 cycles (64 bytes) test 12 (256 bit key, 256 byte blocks): 1 operation in 414 cycles (256 bytes) test 13 (256 bit key, 1024 byte blocks): 1 operation in 1073 cycles (1024 bytes) test 14 (256 bit key, 8192 byte blocks): 1 operation in 7110 cycles (8192 bytes) testing speed of ctr(aes) decryption test 0 (128 bit key, 16 byte blocks): 1 operation in 225 cycles (16 bytes) test 1 (128 bit key, 64 byte blocks): 1 operation in 233 cycles (64 bytes) test 2 (128 bit key, 256 byte blocks): 1 operation in 344 cycles (256 bytes) test 3 (128 bit key, 1024 byte blocks): 1 operation in 810 cycles (1024 bytes) test 4 (128 bit key, 8192 byte blocks): 1 operation in 5021 cycles (8192 bytes) test 5 (192 bit key, 16 byte blocks): 1 operation in 206 cycles (16 bytes) test 6 (192 bit key, 64 byte blocks): 1 operation in 240 cycles (64 bytes) test 7 (192 bit key, 256 byte blocks): 1 operation in 376 cycles (256 bytes) test 8 (192 bit key, 1024 byte blocks): 1 operation in 938 cycles (1024 bytes) test 9 (192 bit key, 8192 byte blocks): 1 operation in 6380 cycles (8192 bytes) test 10 (256 bit key, 16 byte blocks): 1 operation in 214 cycles (16 bytes) test 11 (256 bit key, 64 byte blocks): 1 operation in 251 cycles (64 bytes) test 12 (256 bit key, 256 byte blocks): 1 operation in 411 cycles (256 bytes) test 13 (256 bit key, 1024 byte blocks): 1 operation in 1070 cycles (1024 bytes) test 14 (256 bit key, 8192 byte blocks): 1 operation in 7114 cycles (8192 bytes) After: testing speed of ctr(aes) encryption test 0 (128 bit key, 16 byte blocks): 1 operation in 211 cycles (16 bytes) test 1 (128 bit key, 64 byte blocks): 1 operation in 246 cycles (64 bytes) test 2 (128 bit key, 256 byte blocks): 1 operation in 344 cycles (256 bytes) test 3 (128 bit key, 1024 byte blocks): 1 operation in 799 cycles (1024 bytes) test 4 (128 bit key, 8192 byte blocks): 1 operation in 4975 cycles (8192 bytes) test 5 (192 bit key, 16 byte blocks): 1 operation in 210 cycles (16 bytes) test 6 (192 bit key, 64 byte blocks): 1 operation in 236 cycles (64 bytes) test 7 (192 bit key, 256 byte blocks): 1 operation in 365 cycles (256 bytes) test 8 (192 bit key, 1024 byte blocks): 1 operation in 888 cycles (1024 bytes) test 9 (192 bit key, 8192 byte blocks): 1 operation in 6055 cycles (8192 bytes) test 10 (256 bit key, 16 byte blocks): 1 operation in 209 cycles (16 bytes) test 11 (256 bit key, 64 byte blocks): 1 operation in 255 cycles (64 bytes) test 12 (256 bit key, 256 byte blocks): 1 operation in 404 cycles (256 bytes) test 13 (256 bit key, 1024 byte blocks): 1 operation in 1010 cycles (1024 bytes) test 14 (256 bit key, 8192 byte blocks): 1 operation in 6669 cycles (8192 bytes) testing speed of ctr(aes) decryption test 0 (128 bit key, 16 byte blocks): 1 operation in 210 cycles (16 bytes) test 1 (128 bit key, 64 byte blocks): 1 operation in 233 cycles (64 bytes) test 2 (128 bit key, 256 byte blocks): 1 operation in 340 cycles (256 bytes) test 3 (128 bit key, 1024 byte blocks): 1 operation in 818 cycles (1024 bytes) test 4 (128 bit key, 8192 byte blocks): 1 operation in 4956 cycles (8192 bytes) test 5 (192 bit key, 16 byte blocks): 1 operation in 206 cycles (16 bytes) test 6 (192 bit key, 64 byte blocks): 1 operation in 239 cycles (64 bytes) test 7 (192 bit key, 256 byte blocks): 1 operation in 361 cycles (256 bytes) test 8 (192 bit key, 1024 byte blocks): 1 operation in 888 cycles (1024 bytes) test 9 (192 bit key, 8192 byte blocks): 1 operation in 5996 cycles (8192 bytes) test 10 (256 bit key, 16 byte blocks): 1 operation in 214 cycles (16 bytes) test 11 (256 bit key, 64 byte blocks): 1 operation in 248 cycles (64 bytes) test 12 (256 bit key, 256 byte blocks): 1 operation in 395 cycles (256 bytes) test 13 (256 bit key, 1024 byte blocks): 1 operation in 1010 cycles (1024 bytes) test 14 (256 bit key, 8192 byte blocks): 1 operation in 6664 cycles (8192 bytes) Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30sparc64: Unroll ECB decryption loops in AES driver.David S. Miller
Before: testing speed of ecb(aes) decryption test 0 (128 bit key, 16 byte blocks): 1 operation in 223 cycles (16 bytes) test 1 (128 bit key, 64 byte blocks): 1 operation in 230 cycles (64 bytes) test 2 (128 bit key, 256 byte blocks): 1 operation in 325 cycles (256 bytes) test 3 (128 bit key, 1024 byte blocks): 1 operation in 719 cycles (1024 bytes) test 4 (128 bit key, 8192 byte blocks): 1 operation in 4266 cycles (8192 bytes) test 5 (192 bit key, 16 byte blocks): 1 operation in 211 cycles (16 bytes) test 6 (192 bit key, 64 byte blocks): 1 operation in 234 cycles (64 bytes) test 7 (192 bit key, 256 byte blocks): 1 operation in 353 cycles (256 bytes) test 8 (192 bit key, 1024 byte blocks): 1 operation in 808 cycles (1024 bytes) test 9 (192 bit key, 8192 byte blocks): 1 operation in 5344 cycles (8192 bytes) test 10 (256 bit key, 16 byte blocks): 1 operation in 214 cycles (16 bytes) test 11 (256 bit key, 64 byte blocks): 1 operation in 243 cycles (64 bytes) test 12 (256 bit key, 256 byte blocks): 1 operation in 393 cycles (256 bytes) test 13 (256 bit key, 1024 byte blocks): 1 operation in 939 cycles (1024 bytes) test 14 (256 bit key, 8192 byte blocks): 1 operation in 6039 cycles (8192 bytes) After: testing speed of ecb(aes) decryption test 0 (128 bit key, 16 byte blocks): 1 operation in 226 cycles (16 bytes) test 1 (128 bit key, 64 byte blocks): 1 operation in 231 cycles (64 bytes) test 2 (128 bit key, 256 byte blocks): 1 operation in 313 cycles (256 bytes) test 3 (128 bit key, 1024 byte blocks): 1 operation in 681 cycles (1024 bytes) test 4 (128 bit key, 8192 byte blocks): 1 operation in 3964 cycles (8192 bytes) test 5 (192 bit key, 16 byte blocks): 1 operation in 205 cycles (16 bytes) test 6 (192 bit key, 64 byte blocks): 1 operation in 240 cycles (64 bytes) test 7 (192 bit key, 256 byte blocks): 1 operation in 341 cycles (256 bytes) test 8 (192 bit key, 1024 byte blocks): 1 operation in 770 cycles (1024 bytes) test 9 (192 bit key, 8192 byte blocks): 1 operation in 5050 cycles (8192 bytes) test 10 (256 bit key, 16 byte blocks): 1 operation in 216 cycles (16 bytes) test 11 (256 bit key, 64 byte blocks): 1 operation in 250 cycles (64 bytes) test 12 (256 bit key, 256 byte blocks): 1 operation in 371 cycles (256 bytes) test 13 (256 bit key, 1024 byte blocks): 1 operation in 869 cycles (1024 bytes) test 14 (256 bit key, 8192 byte blocks): 1 operation in 5494 cycles (8192 bytes) Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30sparc64: Unroll ECB encryption loops in AES driver.David S. Miller
The AES opcodes have a 3 cycle latency, so by doing 32-bytes at a time we avoid a pipeline bubble in between every round. For the 256-bit key case, it looks like we're doing more work in order to reload the KEY registers during the loop to make space for scarce temporaries. But the load dual issues with the AES operations so we get the KEY reloads essentially for free. Before: testing speed of ecb(aes) encryption test 0 (128 bit key, 16 byte blocks): 1 operation in 264 cycles (16 bytes) test 1 (128 bit key, 64 byte blocks): 1 operation in 231 cycles (64 bytes) test 2 (128 bit key, 256 byte blocks): 1 operation in 329 cycles (256 bytes) test 3 (128 bit key, 1024 byte blocks): 1 operation in 715 cycles (1024 bytes) test 4 (128 bit key, 8192 byte blocks): 1 operation in 4248 cycles (8192 bytes) test 5 (192 bit key, 16 byte blocks): 1 operation in 221 cycles (16 bytes) test 6 (192 bit key, 64 byte blocks): 1 operation in 234 cycles (64 bytes) test 7 (192 bit key, 256 byte blocks): 1 operation in 359 cycles (256 bytes) test 8 (192 bit key, 1024 byte blocks): 1 operation in 803 cycles (1024 bytes) test 9 (192 bit key, 8192 byte blocks): 1 operation in 5366 cycles (8192 bytes) test 10 (256 bit key, 16 byte blocks): 1 operation in 209 cycles (16 bytes) test 11 (256 bit key, 64 byte blocks): 1 operation in 255 cycles (64 bytes) test 12 (256 bit key, 256 byte blocks): 1 operation in 379 cycles (256 bytes) test 13 (256 bit key, 1024 byte blocks): 1 operation in 938 cycles (1024 bytes) test 14 (256 bit key, 8192 byte blocks): 1 operation in 6041 cycles (8192 bytes) After: testing speed of ecb(aes) encryption test 0 (128 bit key, 16 byte blocks): 1 operation in 266 cycles (16 bytes) test 1 (128 bit key, 64 byte blocks): 1 operation in 256 cycles (64 bytes) test 2 (128 bit key, 256 byte blocks): 1 operation in 305 cycles (256 bytes) test 3 (128 bit key, 1024 byte blocks): 1 operation in 676 cycles (1024 bytes) test 4 (128 bit key, 8192 byte blocks): 1 operation in 3981 cycles (8192 bytes) test 5 (192 bit key, 16 byte blocks): 1 operation in 210 cycles (16 bytes) test 6 (192 bit key, 64 byte blocks): 1 operation in 233 cycles (64 bytes) test 7 (192 bit key, 256 byte blocks): 1 operation in 340 cycles (256 bytes) test 8 (192 bit key, 1024 byte blocks): 1 operation in 766 cycles (1024 bytes) test 9 (192 bit key, 8192 byte blocks): 1 operation in 5136 cycles (8192 bytes) test 10 (256 bit key, 16 byte blocks): 1 operation in 206 cycles (16 bytes) test 11 (256 bit key, 64 byte blocks): 1 operation in 268 cycles (64 bytes) test 12 (256 bit key, 256 byte blocks): 1 operation in 368 cycles (256 bytes) test 13 (256 bit key, 1024 byte blocks): 1 operation in 890 cycles (1024 bytes) test 14 (256 bit key, 8192 byte blocks): 1 operation in 5718 cycles (8192 bytes) Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-29sparc64: Add ctr mode support to AES driver.David S. Miller
2012-08-29sparc64: Move AES driver over to a methods based implementation.David S. Miller
Instead of testing and branching off of the key size on every encrypt/decrypt call, use method ops assigned at key set time. Reverse the order of float registers used for decryption to make future changes easier. Align all assembler routines on a 32-byte boundary. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-28sparc64: Use fsrc2 instead of fsrc1 in sparc64 hash crypto drivers.David S. Miller
On SPARC-T4 fsrc2 has 1 cycle of latency, whereas fsrc1 has 11 cycles. True story. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-28sparc64: Add CAMELLIA driver making use of the new camellia opcodes.David S. Miller
2012-08-25sparc64: Add DES driver making use of the new des opcodes.David S. Miller
2012-08-22sparc64: Add CRC32C driver making use of the new crc32c opcode.David S. Miller
2012-08-22sparc64: Add AES driver making use of the new aes opcodes.David S. Miller
Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-20sparc64: Add MD5 driver making use of the 'md5' instruction.David S. Miller
2012-08-20sparc64: Add SHA384/SHA512 driver making use of the 'sha512' instruction.David S. Miller
2012-08-20sparc64: Add SHA224/SHA256 driver making use of the 'sha256' instruction.David S. Miller
2012-08-20sparc64: Add SHA1 driver making use of the 'sha1' instruction.David S. Miller
