path: root/arch/sparc/kernel/ebus.c
2008-12-04sparc,sparc64: unify kernel/Sam Ravnborg
o Move all files from sparc64/kernel/ to sparc/kernel - rename as appropriate o Update sparc/Makefile to the changes o Update sparc/kernel/Makefile to include the sparc64 files NOTE: This commit changes link order on sparc64! Link order had to change for either of sparc32 and sparc64. And assuming sparc64 see more testing than sparc32 change link order on sparc64 where issues will be caught faster. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-30sparc: Kill EBUS driver layer.David S. Miller
All that remains is the EBUS DMA programming library for sparc64. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Delete bare sbus char bpp driver, obsoleted by parport_sunbppDavid S. Miller
2008-07-17sparc/kernel/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - apc.c: apc_swift_idle() - ebus.c: ebus_blacklist_irq() - ebus.c: fill_ebus_child() - ebus.c: fill_ebus_device() - entry.S: syscall_is_too_hard - etra: tsetup_sun4c_stackchk - head.S: cputyp - head.S: prom_vector_p - idprom.c: Sun_Machines[] - ioport.c: _sparc_find_resource() - ioport.c: create_proc_read_entry() - irq.c: struct sparc_irq[] - rtrap.S: sun4c_rett_stackchk - setup.c: prom_sync_me() - setup.c: boot_flags - sun4c_irq.c: sun4c_sbint_to_irq() - sun4d_irq.c: sbus_tid[] - sun4d_irq.c: struct sbus_actions - sun4d_irq.c: sun4d_sbint_to_irq() - sun4m_irq.c: sun4m_sbint_to_irq() - sun4m_irq.c: sun4m_get_irqmask() - sun4m_irq.c: sun4m_timers - sun4m_smp.c: smp4m_cross_call() - sun4m_smp.c: smp4m_blackbox_id() - sun4m_smp.c: smp4m_blackbox_current() - time.c: sp_clock_typ - time.c: sbus_time_init() - traps.c: instruction_dump() - wof.S: spwin_sun4c_stackchk - wuf.S: sun4c_fwin_stackchk - #if 0 the following unused code: - process.c: sparc_backtrace_lock - process.c: __show_backtrace() - process.c: show_backtrace() - process.c: smp_show_backtrace_all_cpus() - remove the following unused code: - entry.S: __handle_exception - smp.c: smp_num_cpus - smp.c: smp_activated - smp.c: __cpu_number_map[] - smp.c: __cpu_logical_map[] - smp.c: bitops_spinlock - traps.c: trap_curbuf - traps.c: trapbuf[] - traps.c: linux_smp_still_initting - traps.c: thiscpus_tbr - traps.c: thiscpus_mid Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-03sparc: replace remaining __FUNCTION__ occurancesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-27[SPARC]: Fix EBUS use of uninitialized variable.David S. Miller
If of_get_property() fails, it returns NULL and the 'len' parameter is undefined. So we need to explicitly set len to zero in such cases. Noticed by Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-10[SPARC32]: Remove iommu from struct sbus_bus and use archdata like sparc64.Robert Reif
Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-20[SPARC]: Make sure dev_archdata is filled in for all devices.David S. Miller
2007-04-26[SPARC]: device_node name constification falloutStephen Rothwell
A couple of routines need their arguments to be const. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[SPARC]: constify of_get_property return: arch/sparcStephen Rothwell
2006-10-27[SPARC]: Fix bus_id[] string overflow.David S. Miller
dp->path_component_name can be larger than ->bus_id[] so use a different naming scheme for this stuff. Noticed by Jurij Smakov. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[PATCH] fix ancient breakage in ebus_init()Al Viro
Back when pci_dev had base_address[], loop of form base = &...->base_address[0]; for (.....) { ... *base++ = addr; } was fine, but when that array got spread in ->resource[...].start replacing the initialization with base = &...->resource[0].start; was not a sufficient modification. IOW this code got broken for cases when there had been more than one resource to fill. All way back in 2.3.41-pre3... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[SPARC]: Port of_device layer and make ebus use it.David S. Miller
2006-06-23[SPARC]: Port sparc64 in-kernel device tree code to sparc32.David S. Miller
2005-12-15[PATCH] sparc: NULL noise removal (ebus.c)Al Viro
