path: root/arch/sparc/kernel/iommu.c
2009-06-16sparc: use dma_map_page instead of dma_map_singleFUJITA Tomonori
This patch converts dma_map_single and dma_unmap_single to use map_page and unmap_page respectively and removes unnecessary map_single and unmap_single. map_page can be used to implement map_single but the opposite is impossible. Having only dma_map_page in struct dma_ops is enough. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-06sparc64: Use unsigned long long for u64.Sam Ravnborg
Andrew Morton wrote: People keep on doing printk("%llu", some_u64); testing it only on x86_64 and this generates a warning storm on powerpc, sparc64, etc. Because they use `long', not `long long'. Quite a few 64-bit architectures are using `long' for their s64/u64 types. We should convert them all to `long long'. Update types.h so we use unsigned long long for u64 and fix all warnings in sparc64 code. Tested with an allnoconfig, defconfig and allmodconfig builds. This patch introduces additional warnings in several drivers. These will be dealt with in separate patches. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc,sparc64: unify kernel/Sam Ravnborg
o Move all files from sparc64/kernel/ to sparc/kernel - rename as appropriate o Update sparc/Makefile to the changes o Update sparc/kernel/Makefile to include the sparc64 files NOTE: This commit changes link order on sparc64! Link order had to change for either of sparc32 and sparc64. And assuming sparc64 see more testing than sparc32 change link order on sparc64 where issues will be caught faster. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
