path: root/arch/sparc/kernel/irq.c
2008-12-04sparc: prepare kernel/ for unificationSam Ravnborg
o sparc32 files with identical names to sparc64 renamed to <name>_32.S o introduced a few Kconfig helpers to simplify Makefile logic o refactored Makefile to prepare for unification - use obj-$(CONFIG_SPARC32) for sparc32 specific files - use <name>_$(BITS) for files where sparc64 has a _64 variant - sparc64 directly include a few files where sparc32 builds them, refer to these files directly (no BITS) - sneaked in -Werror as used by sparc64 o modified sparc/Makefile to use the new names for head/init_task Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17sparc/kernel/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - apc.c: apc_swift_idle() - ebus.c: ebus_blacklist_irq() - ebus.c: fill_ebus_child() - ebus.c: fill_ebus_device() - entry.S: syscall_is_too_hard - etra: tsetup_sun4c_stackchk - head.S: cputyp - head.S: prom_vector_p - idprom.c: Sun_Machines[] - ioport.c: _sparc_find_resource() - ioport.c: create_proc_read_entry() - irq.c: struct sparc_irq[] - rtrap.S: sun4c_rett_stackchk - setup.c: prom_sync_me() - setup.c: boot_flags - sun4c_irq.c: sun4c_sbint_to_irq() - sun4d_irq.c: sbus_tid[] - sun4d_irq.c: struct sbus_actions - sun4d_irq.c: sun4d_sbint_to_irq() - sun4m_irq.c: sun4m_sbint_to_irq() - sun4m_irq.c: sun4m_get_irqmask() - sun4m_irq.c: sun4m_timers - sun4m_smp.c: smp4m_cross_call() - sun4m_smp.c: smp4m_blackbox_id() - sun4m_smp.c: smp4m_blackbox_current() - time.c: sp_clock_typ - time.c: sbus_time_init() - traps.c: instruction_dump() - wof.S: spwin_sun4c_stackchk - wuf.S: sun4c_fwin_stackchk - #if 0 the following unused code: - process.c: sparc_backtrace_lock - process.c: __show_backtrace() - process.c: show_backtrace() - process.c: smp_show_backtrace_all_cpus() - remove the following unused code: - entry.S: __handle_exception - smp.c: smp_num_cpus - smp.c: smp_activated - smp.c: __cpu_number_map[] - smp.c: __cpu_logical_map[] - smp.c: bitops_spinlock - traps.c: trap_curbuf - traps.c: trapbuf[] - traps.c: linux_smp_still_initting - traps.c: thiscpus_tbr - traps.c: thiscpus_mid Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-06[SPARC]: Remove duplicate includes.Lucas Woods
Signed-off-by: Lucas Woods <woodzy@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-23[SPARC, XEN, NET/CXGB3] use irq_handler_t where appropriateJeff Garzik
Rather than hand-rolling our own prototype, make the code more future-proof by using the standard irq_handler_t typedef. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-13[SPARC32]: Add irqflags.h to sparc32 and use it from generic code.Robert Reif
Added asm-sparc/irqflags.h and moved irq related code from system.h to it. Renamed local_irq functions to raw_local_irq in irq.c. Modified system.h to include linux/irqflags.h which includes asm/irqflags.h. Added TRACE_IRQFLAGS_SUPPORT to Kconfig.debug. This is the first step in adding IRQ-flags state tracing as outlined in Documentation/irqflags-tracing.txt. These changes should be harmless because they just move things around and rename them. The next step is making the lowlevel entry code modifications which to be honest are beyond my capabilities at this point. Boot tested on an ss20 running an SMP kernel. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-03[SPARC32]: Fix modular build of floppy driver.David S. Miller
2007-07-21[SPARC32]: Take enable_irq/disable_irq out of line.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-21[SPARC32]: clean include/asm-sparc/irq.hAl Viro
Move stuff used only by arch/sparc/kernel/* into arch/sparc/kernel/irq.h and into individual files in there (e.g. macros internal to sun4m_irq.c, etc.) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-11[SPARC]: Spelling fixes.Simon Arlott
Spelling fixes in arch/sparc/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[SPARC]: Sparc compilation fix with floppy enabledKrzysztof Helt
This patch fixes a typo to make kernel compilable when floppy driver for Sparc is build. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-08[PATCH] sparc32 pt_regs fixesAl Viro
2006-07-21[SPARC]: Do not call sun4m_irq_rotate on sun4d.Raymond Burns
2006-07-02[PATCH] irq-flags: SPARC: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[SPARC]: Try to start getting SMP back into shape.Bob Breuer
Todo items: - IRQ_INPROGRESS flag - use sparc64 irq buckets, or generic irq_desc? - sun4d - re-indent large chunks of sun4m_smp.c - some places assume sequential cpu numbering (i.e. 0,1 instead of 0,2) Last I checked (with 2.6.14), random programs segfault with dual HyperSPARC. And with SuperSPARC II's, it seems stable but will eventually die from a write lock error (wrong lock owner or something). I haven't tried the HyperSPARC + highmem combination recently, so that may still be a problem. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-23[PATCH] more for_each_cpu() conversionsAndrew Morton
When we stop allocating percpu memory for not-possible CPUs we must not touch the percpu data for not-possible CPUs at all. The correct way of doing this is to test cpu_possible() or to use for_each_cpu(). This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very few instances of this bug, if any. But the patch converts lots of open-coded test to use the preferred helper macros. Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Cc: Christian Zankel <chris@zankel.net> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: Nathan Scott <nathans@sgi.com> Cc: Jens Axboe <axboe@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
