path: root/arch/sparc/kernel/module.c
2009-06-12module: cleanup FIXME comments about trimming exception table entries.Rusty Russell
Everyone cut and paste this comment from my original one. We now do it generically, so cut the comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Amerigo Wang <amwang@redhat.com>
2008-12-26sparc: unify module.cSam Ravnborg
o Copy module_64.c to module.c o Add all sparc specific bits to module.c o delete module_32.c o update Makefile Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc: prepare kernel/ for unificationSam Ravnborg
o sparc32 files with identical names to sparc64 renamed to <name>_32.S o introduced a few Kconfig helpers to simplify Makefile logic o refactored Makefile to prepare for unification - use obj-$(CONFIG_SPARC32) for sparc32 specific files - use <name>_$(BITS) for files where sparc64 has a _64 variant - sparc64 directly include a few files where sparc32 builds them, refer to these files directly (no BITS) - sneaked in -Werror as used by sparc64 o modified sparc/Makefile to use the new names for head/init_task Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-12[SPARC]: Handle UNWIND_INFO properly.David S. Miller
For sparc32 we need R_SPARC_UA32 relocation support, for sparc64 we need the handle R_SPARC_DISP32 relocations. Based upon reports and initial patch by Martin Habets. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-11[SPARC]: Fix dot-symbol exporting for good.Al Viro
From: Al Viro <viro@ZenIV.linux.org.uk> Instead of playing all of these hand-coded assembler aliasing games, just translate symbol names in the name space ".sym" to "_Sym" at module load time. Signed-off-by: David S. Miller <davem@davemloft.net>
