path: root/arch/sparc/kernel/sun4m_smp.c
2009-08-18sparc32: Kill trap table freeing code.David S. Miller
Normally, srmmu uses different trap table register values to allow determination of the cpu we're on. All of the trap tables have identical content, they just sit at different offsets from the first trap table, and the offset shifted down and masked out determines the cpu we are on. The code tries to free them up when they aren't actually used (don't have all 4 cpus, we're on sun4d, etc.) but that causes problems. For one thing it triggers false positives in the DMA debugging code. And fixing that up while preserving this relative offset thing isn't trivial. So just kill the freeing code, it costs us at most 3 pages, big deal... Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-16cpumask: prepare for iterators to only go to nr_cpu_ids/nr_cpumask_bits.: sparcRusty Russell
Impact: cleanup, futureproof In fact, all cpumask ops will only be valid (in general) for bit numbers < nr_cpu_ids. So use that instead of NR_CPUS in various places. This is always safe: no cpu number can be >= nr_cpu_ids, and nr_cpu_ids is initialized to NR_CPUS at boot. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-03-16cpumask: Use accessors code: sparcRusty Russell
Impact: use new API Use the accessors rather than frobbing bits directly. Most of this is in arch code I haven't even compiled, but it is mostly straightforward. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com>
2009-01-08generic swap(): sparc: rename swap() to swap_ulong()Wu Fengguang
In preparation for the introduction of a generic swap() macro. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-30sparc32 cpuinit flase positivesAl Viro
All noise since we don't have CPU hotplug there. However, they did expose something very odd-looking in there - poke_viking() does a bunch of identical btfixup each time it's called (i.e. for each CPU). That one is left alone for now; just the trivial misannotation fixes. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-12sparc32: fix build errorsRobert Reif
arch/sparc/kernel/sun4d_smp.c: In function ‘smp4d_callin’: arch/sparc/kernel/sun4d_smp.c:101: error: implicit declaration of function ‘notify_cpu_starting’ arch/sparc/kernel/sun4m_smp.c: In function ‘smp4m_callin’: arch/sparc/kernel/sun4m_smp.c:74: error: implicit declaration of function ‘notify_cpu_starting’ Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: sound/core/memalloc.c
2008-09-19sparc32: Call sun4m_clear_profile_irq() directly from sun4m_smp.cDavid S. Miller
This is the only use of the clear_profile_irq() btfixup entry, which just eats up lots of dead space on other platform types. A subsequent commit will delete the other implementations and the btfixup entry as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-08kernel/cpu.c: create a CPU_STARTING cpu_chain notifierManfred Spraul
Right now, there is no notifier that is called on a new cpu, before the new cpu begins processing interrupts/softirqs. Various kernel function would need that notification, e.g. kvm works around by calling smp_call_function_single(), rcu polls cpu_online_map. The patch adds a CPU_STARTING notification. It also adds a helper function that sends the message to all cpu_chain handlers. Tested on x86-64. All other archs are untested. Especially on sparc, I'm not sure if I got it right. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-27sparc32: Implement smp_call_function_single().David S. Miller
Reported by Stephen Rothwell. Needed to fix the build when CONFIG_RELAY is enabled. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17sparc/kernel/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - apc.c: apc_swift_idle() - ebus.c: ebus_blacklist_irq() - ebus.c: fill_ebus_child() - ebus.c: fill_ebus_device() - entry.S: syscall_is_too_hard - etra: tsetup_sun4c_stackchk - head.S: cputyp - head.S: prom_vector_p - idprom.c: Sun_Machines[] - ioport.c: _sparc_find_resource() - ioport.c: create_proc_read_entry() - irq.c: struct sparc_irq[] - rtrap.S: sun4c_rett_stackchk - setup.c: prom_sync_me() - setup.c: boot_flags - sun4c_irq.c: sun4c_sbint_to_irq() - sun4d_irq.c: sbus_tid[] - sun4d_irq.c: struct sbus_actions - sun4d_irq.c: sun4d_sbint_to_irq() - sun4m_irq.c: sun4m_sbint_to_irq() - sun4m_irq.c: sun4m_get_irqmask() - sun4m_irq.c: sun4m_timers - sun4m_smp.c: smp4m_cross_call() - sun4m_smp.c: smp4m_blackbox_id() - sun4m_smp.c: smp4m_blackbox_current() - time.c: sp_clock_typ - time.c: sbus_time_init() - traps.c: instruction_dump() - wof.S: spwin_sun4c_stackchk - wuf.S: sun4c_fwin_stackchk - #if 0 the following unused code: - process.c: sparc_backtrace_lock - process.c: __show_backtrace() - process.c: show_backtrace() - process.c: smp_show_backtrace_all_cpus() - remove the following unused code: - entry.S: __handle_exception - smp.c: smp_num_cpus - smp.c: smp_activated - smp.c: __cpu_number_map[] - smp.c: __cpu_logical_map[] - smp.c: bitops_spinlock - traps.c: trap_curbuf - traps.c: trapbuf[] - traps.c: linux_smp_still_initting - traps.c: thiscpus_tbr - traps.c: thiscpus_mid Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29sparc32: Kill smp_message_pass() and related code.David S. Miller
Completely unused, and it just makes the SMP message passing code on 32-bit sparc look more complex than it is. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-06calibrate_delay() must be __cpuinitAdrian Bunk
calibrate_delay() must be __cpuinit, not __{dev,}init. I've verified that this is correct for all users. While doing the latter, I also did the following cleanups: - remove pointless additional prototypes in C files - ensure all users #include <linux/delay.h> This fixes the following section mismatches with CONFIG_HOTPLUG=n, CONFIG_HOTPLUG_CPU=y: WARNING: vmlinux.o(.text+0x1128d): Section mismatch: reference to .init.text.1:calibrate_delay (between 'check_cx686_slop' and 'set_cx86_reorder') WARNING: vmlinux.o(.text+0x25102): Section mismatch: reference to .init.text.1:calibrate_delay (between 'smp_callin' and 'cpu_coregroup_map') Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christian Zankel <chris@zankel.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21[SPARC32]: clean include/asm-sparc/irq.hAl Viro
Move stuff used only by arch/sparc/kernel/* into arch/sparc/kernel/irq.h and into individual files in there (e.g. macros internal to sun4m_irq.c, etc.) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-06[SPARC]: Fix comment typo in smp4m_blackbox_current().David S. Miller
2006-10-08[PATCH] sparc32 pt_regs fixesAl Viro
2006-08-26[SPARC]: Small smp cleanup.Krzysztof Helt
It moves the smp_procesors_ready variable to sun4d_smp.c only. Signed-off-by: Krzysztof Helt (krzysztof.h1@wp.pl) Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-20[SPARC]: Mark smp init functions as cpuinitBob Breuer
Fix the smp related section mismatch warnings by marking the smp init functions as cpuinit. Signed-off-by: Bob Breuer <breuerr@mc.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-23[SPARC]: Try to start getting SMP back into shape.Bob Breuer
Todo items: - IRQ_INPROGRESS flag - use sparc64 irq buckets, or generic irq_desc? - sun4d - re-indent large chunks of sun4m_smp.c - some places assume sequential cpu numbering (i.e. 0,1 instead of 0,2) Last I checked (with 2.6.14), random programs segfault with dual HyperSPARC. And with SuperSPARC II's, it seems stable but will eventually die from a write lock error (wrong lock owner or something). I haven't tried the HyperSPARC + highmem combination recently, so that may still be a problem. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-23[PATCH] more for_each_cpu() conversionsAndrew Morton
When we stop allocating percpu memory for not-possible CPUs we must not touch the percpu data for not-possible CPUs at all. The correct way of doing this is to test cpu_possible() or to use for_each_cpu(). This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very few instances of this bug, if any. But the patch converts lots of open-coded test to use the preferred helper macros. Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Cc: Christian Zankel <chris@zankel.net> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: Nathan Scott <nathans@sgi.com> Cc: Jens Axboe <axboe@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] remove set_page_count() outside mm/Nick Piggin
set_page_count usage outside mm/ is limited to setting the refcount to 1. Remove set_page_count from outside mm/, and replace those users with init_page_count() and set_page_refcounted(). This allows more debug checking, and tighter control on how code is allowed to play around with page->_count. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] sparc: task_thread_info()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
