o sparc32 files with identical names to sparc64 renamed to <name>_32.S
o introduced a few Kconfig helpers to simplify Makefile logic
o refactored Makefile to prepare for unification
- use obj-$(CONFIG_SPARC32) for sparc32 specific files
- use <name>_$(BITS) for files where sparc64 has a _64 variant
- sparc64 directly include a few files where sparc32 builds them,
refer to these files directly (no BITS)
- sneaked in -Werror as used by sparc64
o modified sparc/Makefile to use the new names for head/init_task
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
While doing some easy cleanups on the sparc code I noticed that the
CONFIG_SUN4 code seems to be worse than the rest - there were some
"I don't know how it should work, but the current code definitely cannot
work." places.
And while I have seen people running Linux on machines like a
SPARCstation 5 a few years ago I don't recall having seen sun4
machines, even less ones running Linux.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch introduces the new syscall pipe2 which is like pipe but it also
takes an additional parameter which takes a flag value. This patch implements
the handling of O_CLOEXEC for the flag. I did not add support for the new
syscall for the architectures which have a special sys_pipe implementation. I
think the maintainers of those archs have the chance to go with the unified
implementation but that's up to them.
The implementation introduces do_pipe_flags. I did that instead of changing
all callers of do_pipe because some of the callers are written in assembler.
I would probably screw up changing the assembly code. To avoid breaking code
do_pipe is now a small wrapper around do_pipe_flags. Once all callers are
changed over to do_pipe_flags the old do_pipe function can be removed.
The following test must be adjusted for architectures other than x86 and
x86-64 and in case the syscall numbers changed.
#include <fcntl.h>
#include <stdio.h>
#include <unistd.h>
#include <sys/syscall.h>
#ifndef __NR_pipe2
# ifdef __x86_64__
# define __NR_pipe2 293
# elif defined __i386__
# define __NR_pipe2 331
# else
# error "need __NR_pipe2"
# endif
#endif
int
main (void)
int fd[2];
if (syscall (__NR_pipe2, fd, 0) != 0)
puts ("pipe2(0) failed");
return 1;
for (int i = 0; i < 2; ++i)
int coe = fcntl (fd[i], F_GETFD);
if (coe == -1)
puts ("fcntl failed");
return 1;
if (coe & FD_CLOEXEC)
printf ("pipe2(0) set close-on-exit for fd[%d]\n", i);
return 1;
close (fd[0]);
close (fd[1]);
if (syscall (__NR_pipe2, fd, O_CLOEXEC) != 0)
puts ("pipe2(O_CLOEXEC) failed");
return 1;
if (coe == -1)
return 1;
if ((coe & FD_CLOEXEC) == 0)
printf ("pipe2(O_CLOEXEC) does not set close-on-exit for fd[%d]\n", i);
return 1;
close (fd[0]);
close (fd[1]);
puts ("OK");
return 0;
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Acked-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: <linux-arch@vger.kernel.org>
Just like mmap, we need to validate address ranges regardless
of MAP_FIXED.
sparc{,64}_mmap_check()'s flag argument is unused, remove.
Based upon a report and preliminary patch by
Jan Lieskovsky <jlieskov@redhat.com>
We should not conditionalize VA range checks on MAP_FIXED.
Back around the same time we were bootstrapping the first 32-bit sparc
Linux kernel with a SunOS userland, we made the signal frame match
that of SunOS.
By the time we even started putting together a native Linux userland
for 32-bit Sparc we realized this layout wasn't sufficient for Linux's
needs.
Therefore we changed the layout, yet kept support for the old style
signal frame layout in there. The detection mechanism is that we had
sys_sigaction() start passing in a negative signal number to indicate
"new style signal frames please".
Anyways, no binaries exist in the world that use the old stuff. In
fact, I bet Jakub Jelinek and myself are the only two people who ever
had such binaries to be honest.
So let's get rid of this stuff.
I added an assertion using WARN_ON_ONCE() that makes sure 32-bit
applications are passing in that negative signal number still.
One of the easiest things to isolate is the pid printed in kernel log.
There was a patch, that made this for arch-independent code, this one makes
so for arch/xxx files.
It took some time to cross-compile it, but hopefully these are all the
printks in arch code.
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
All asm/ipc.h files do only #include <asm-generic/ipc.h>.
This patch therefore removes all include/asm-*/ipc.h files and moves the
contents of include/asm-generic/ipc.h to include/linux/ipc.h.
This adds the new kernel_execve function on all architectures that were using
_syscall3() to implement execve.
The implementation uses code from the _syscall3 macros provided in the
unistd.h header file. I don't have cross-compilers for any of these
architectures, so the patch is untested with the exception of i386.
Most architectures can probably implement this in a nicer way in assembly or
by combining it with the sys_execve implementation itself, but this should do
it for now.
[bunk@stusta.de: m68knommu build fix]
[markh@osdl.org: build fix]
[bero@arklinux.org: build fix]
[ralf@linux-mips.org: mips fix]
[schwidefsky@de.ibm.com: s390 fix]
Cc: Andi Kleen <ak@muc.de>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata.hirokazu@renesas.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Cc: Richard Curnow <rc@rc0.org.uk>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
Cc: Chris Zankel <chris@zankel.net>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Signed-off-by: Bernhard Rosenkraenzer <bero@arklinux.org>
Signed-off-by: Mark Haverkamp <markh@osdl.org>
Replace references to system_utsname to the per-process uts namespace
where appropriate. This includes things like uname.
Changes: Per Eric Biederman's comments, use the per-process uts namespace
for ELF_PLATFORM, sunrpc, and parts of net/ipv4/ipconfig.c
[jdike@addtoit.com: UML fix]
[clg@fr.ibm.com: cleanup]
[akpm@osdl.org: build fix]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Andrey Savochkin <saw@sw.ru>
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
This patch corrects the buffer length checking in the
sys_getdomainname() implementation for sparc/sparc64.
Signed-off-by: Andy Walker <andy@puszczka.com>
This prevents cross-region mappings on IA64 and SPARC which could lead
to system crash. They were correctly trapped for normal mmap() calls,
but not for the kernel internal calls generated by executable loading.
This code just moves the architecture-specific cross-region checks into
an arch-specific "arch_mmap_check()" macro, and defines that for the
architectures that needed it (ia64, sparc and sparc64).
Architectures that don't have any special requirements can just ignore
the new cross-region check, since the mmap() code will just notice on
its own when the macro isn't defined.
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
Acked-by: David Miller <davem@davemloft.net>
[ Cleaned up to not affect architectures that don't need it ]
Found by scrashme.
infrastructure for it.
Let it rip!
