path: root/arch/sparc/kernel/wof.S
2012-05-27sparc32: introduce support for run-time patching for all shared assembler codeSam Ravnborg
All users of MMUREGS ASI in kernel/ now uses run-time patching. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-11sparc32: drop sun4c window overflow stack checking routineSam Ravnborg
Also drop run-time patching for srmmu Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17sparc/kernel/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - apc.c: apc_swift_idle() - ebus.c: ebus_blacklist_irq() - ebus.c: fill_ebus_child() - ebus.c: fill_ebus_device() - entry.S: syscall_is_too_hard - etra: tsetup_sun4c_stackchk - head.S: cputyp - head.S: prom_vector_p - idprom.c: Sun_Machines[] - ioport.c: _sparc_find_resource() - ioport.c: create_proc_read_entry() - irq.c: struct sparc_irq[] - rtrap.S: sun4c_rett_stackchk - setup.c: prom_sync_me() - setup.c: boot_flags - sun4c_irq.c: sun4c_sbint_to_irq() - sun4d_irq.c: sbus_tid[] - sun4d_irq.c: struct sbus_actions - sun4d_irq.c: sun4d_sbint_to_irq() - sun4m_irq.c: sun4m_sbint_to_irq() - sun4m_irq.c: sun4m_get_irqmask() - sun4m_irq.c: sun4m_timers - sun4m_smp.c: smp4m_cross_call() - sun4m_smp.c: smp4m_blackbox_id() - sun4m_smp.c: smp4m_blackbox_current() - time.c: sp_clock_typ - time.c: sbus_time_init() - traps.c: instruction_dump() - wof.S: spwin_sun4c_stackchk - wuf.S: sun4c_fwin_stackchk - #if 0 the following unused code: - process.c: sparc_backtrace_lock - process.c: __show_backtrace() - process.c: show_backtrace() - process.c: smp_show_backtrace_all_cpus() - remove the following unused code: - entry.S: __handle_exception - smp.c: smp_num_cpus - smp.c: smp_activated - smp.c: __cpu_number_map[] - smp.c: __cpu_logical_map[] - smp.c: bitops_spinlock - traps.c: trap_curbuf - traps.c: trapbuf[] - traps.c: linux_smp_still_initting - traps.c: thiscpus_tbr - traps.c: thiscpus_mid Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
