[ Upstream commit 3e37fd3153ac95088a74f5e7c569f7567e9f993a ]
To handle the large physical addresses, just make a simple wrapper
around remap_pfn_range() like MIPS does.
Change-Id: I6817a588d5422f96a100466db56d11c33aa39ec4
Reviewed-on: http://git-master/r/74207
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
[ Upstream commit b1f44e13a525d2ffb7d5afe2273b7169d6f2222e ]
The "(insn & 0x01800000) != 0x01800000" test matches 'restore'
but that is a legitimate place to see the %lo() part of a 32-bit
symbol relocation, particularly in tail calls.
Tested-by: Sergei Trofimovich <slyfox@gentoo.org>
Change-Id: I588195deba991fe368241abdc4f270d6d3792e7d
Reviewed-on: http://git-master/r/74205
commit b35a35b556f5e6b7993ad0baf20173e75c09ce8c upstream.
This avoids duplicating the function in every arch gup_fast.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
commit e0d85a366c2300efd230ef82a9b22110b0658331 upstream.
Up to this point the code assumed old refcounting for hugepages (pre-thp).
This updates the code directly to the thp mapcount tail page refcounting.
Acked-by: David Miller <davem@davemloft.net>
The LEON MMU Model (SRMMU) does not implement MMu Table probing
in hardware, instead it is implemented in software. However the
software implementation does not return the PTE as it should which
always results in INVALID entires and the PROM mappings are not
inherited as they should during startup. The following patch
removes the masking of the PTE.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
In the OF 'translations' property, the template TTEs in the mappings
never specify the executable bit. This is the case even though some
of these mappings are for OF's code segment.
Therefore, we need to force the execute bit on in every mapping.
This problem can only really trigger on Niagara/sun4v machines and the
history behind this is a little complicated.
Previous to sun4v, the sun4u TTE entries lacked a hardware execute
permission bit. So OF didn't have to ever worry about setting
anything to handle executable pages. Any valid TTE loaded into the
I-TLB would be respected by the chip.
But sun4v Niagara chips have a real hardware enforced executable bit
in their TTEs. So it has to be set or else the I-TLB throws an
instruction access exception with type code 6 (protection violation).
We've been extremely fortunate to not get bitten by this in the past.
The best I can tell is that the OF's mappings for it's executable code
were mapped using permanent locked mappings on sun4v in the past.
Therefore, the fact that we didn't have the exec bit set in the OF
translations we would use did not matter in practice.
Thanks to Greg Onufer for helping me track this down.
arch/sparc/mm/init_64.c:1622:22: error: unused variable '__swapper_4m_tsb_phys_patch_end' [-Werror=unused-variable]
arch/sparc/mm/init_64.c:1621:22: error: unused variable '__swapper_4m_tsb_phys_patch' [-Werror=unused-variable]
On sun4v this is basically required since we point the hypervisor and
the TSB walking hardware at these tables using physical addressing
too.
With the recent mmu_gather changes that included generic RCU freeing of
page-tables, it is now quite straightforward to implement gup_fast() on
sparc64.
This patch:
Remove the page table quicklists. They are pointless and make it harder
to use RCU page table freeing and share code with other architectures.
BTW, this is the second time this has happened, see commit 3c936465249f
("[SPARC64]: Kill pgtable quicklists and use SLAB.")
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (123 commits)
perf: Remove the nmi parameter from the oprofile_perf backend
x86, perf: Make copy_from_user_nmi() a library function
perf: Remove perf_event_attr::type check
x86, perf: P4 PMU - Fix typos in comments and style cleanup
perf tools: Make test use the preset debugfs path
perf tools: Add automated tests for events parsing
perf tools: De-opt the parse_events function
perf script: Fix display of IP address for non-callchain path
perf tools: Fix endian conversion reading event attr from file header
perf tools: Add missing 'node' alias to the hw_cache[] array
perf probe: Support adding probes on offline kernel modules
perf probe: Add probed module in front of function
perf probe: Introduce debuginfo to encapsulate dwarf information
perf-probe: Move dwarf library routines to dwarf-aux.{c, h}
perf probe: Remove redundant dwarf functions
perf probe: Move strtailcmp to string.c
perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_END
tracing/kprobe: Update symbol reference when loading module
tracing/kprobes: Support module init function probing
kprobes: Return -ENOENT if probe point doesn't exist
The function leon_flush_needed() is called only during bootup from another
__init function. Therefore, we can also add __init to leon_flush_needed().
Signed-off-by: Matthias Rosenfelder <rosenfelder.lkml@googlemail.com>
Acked-by: Daniel Hellstrom <daniel@gaisler.com>
The nmi parameter indicated if we could do wakeups from the current
context, if not, we would set some state and self-IPI and let the
resulting interrupt do the wakeup.
For the various event classes:
- hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from
the PMI-tail (ARM etc.)
- tracepoint: nmi=0; since tracepoint could be from NMI context.
- software: nmi=[0,1]; some, like the schedule thing cannot
perform wakeups, and hence need 0.
As one can see, there is very little nmi=1 usage, and the down-side of
not using it is that on some platforms some software events can have a
jiffy delay in wakeup (when arch_irq_work_raise isn't implemented).
The up-side however is that we can remove the nmi parameter and save a
bunch of conditionals in fast paths.
Cc: Michael Cree <mcree@orcon.net.nz>
Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org
Semicolons are not necessary after switch/while/for/if braces
so remove them.
Fold all the mmu_gather rework patches into one for submission
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
Rework the sparc mmu_gather usage to conform to the new world order :-)
Sparc mmu_gather does two things:
- tracks vaddrs to unhash
- tracks pages to free
Split these two things like powerpc has done and keep the vaddrs
in per-cpu data structures and flush them on context switch.
The remaining bits can then use the generic mmu_gather.
Architectures that implement their own show_mem() function did not pass
the filter argument to show_free_areas() to appropriately avoid emitting
the state of nodes that are disallowed in the current context. This patch
now passes the filter argument to show_free_areas() so those nodes are now
avoided.
This patch also removes the show_free_areas() wrapper around
__show_free_areas() and converts existing callers to pass an empty filter.
ia64 emits additional information for each node, so skip_free_areas_zone()
must be made global to filter disallowed nodes and it is converted to use
a nid argument rather than a zone for this use case.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Helge Deller <deller@gmx.de>
Cc: James Bottomley <jejb@parisc-linux.org>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Adapt new API. Almost change is trivial, most important change are to
remove following like =operator.
cpumask_t cpu_mask = *mm_cpumask(mm);
cpus_allowed = current->cpus_allowed;
Because cpumask_var_t is =operator unsafe. These usage might prevent
kernel core improvement.
No functional change.
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from
meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which
resulted in build warnings on all architectures that implement their own
versions of show_mem():
lib/lib.a(show_mem.o): In function `show_mem':
show_mem.c:(.text+0x1f4): multiple definition of `show_mem'
arch/sparc/mm/built-in.o:(.text+0xd70): first defined here
The fix is to remove __show_mem() and add its argument to show_mem() in
all implementations to prevent this breakage.
Architectures that implement their own show_mem() actually don't do
anything with the argument yet, but they could be made to filter nodes
that aren't allowed in the current context in the future just like the
generic implementation.
Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Add a node parameter to alloc_thread_info(), and change its name to
alloc_thread_info_node()
This change is needed to allow NUMA aware kthread_create_on_cpu()
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Tejun Heo <tj@kernel.org>
Cc: <linux-arch@vger.kernel.org>
When we try to handle vmalloc faults, we can take a code
path which uses "code" before we actually set it.
Amusingly gcc-3.3 notices this yet gcc-4.x does not.
Reported-by: Bob Breuer <breuerr@mc.net>
pte alloc routines must wait for split_huge_page if the pmd is not present
and not null (i.e. pmd_trans_splitting). The additional branches are
optimized away at compile time by pmd_trans_splitting if the config option
is off. However we must pass the vma down in order to know the anon_vma
lock to wait for.
Acked-by: Mel Gorman <mel@csn.ul.ie>
We use "_start" in 64 bit - do the same in 32 bit.
It is always good to be consistent.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
kbuild: add ARCH=sparc32 target
sparc32: fix build failure on CONFIG_SPARC_LEON
sparc: Fixed random SPARC/LEON SMP CPU Stuck problem.
sparc32: remove CONFIG_HAVE_PERF_EVENTS option
sparc: don't #include asm/system.h in asm/jump_label.h
sparc32: Fix unaligned stack handling on trap return.
sparc: keep calling do_signal() as long as pending signals remain
Christoph reported a nice splat which illustrated a race in the new stack
based kmap_atomic implementation.
The problem is that we pop our stack slot before we're completely done
resetting its state -- in particular clearing the PTE (sometimes that's
CONFIG_DEBUG_HIGHMEM). If an interrupt happens before we actually clear
the PTE used for the last slot, that interrupt can reuse the slot in a
dirty state, which triggers a BUG in kmap_atomic().
Fix this by introducing kmap_atomic_idx() which reports the current slot
index without actually releasing it and use that to find the PTE and delay
the _pop() until after we're completely done.
Reported-by: Christoph Hellwig <hch@infradead.org>
Keep the current interface but ignore the KM_type and use a stack based
approach.
The advantage is that we get rid of crappy code like:
#define __KM_PTE \
(in_nmi() ? KM_NMI_PTE : \
in_irq() ? KM_IRQ_PTE : \
KM_PTE0)
and in general can stop worrying about what context we're in and what kmap
slots might be appropriate for that.
The downside is that FRV kmap_atomic() gets more expensive.
For now we use a CPP trick suggested by Andrew:
#define kmap_atomic(page, args...) __kmap_atomic(page)
to avoid having to touch all kmap_atomic() users in a single patch.
[ not compiled on:
- mn10300: the arch doesn't actually build with highmem to begin with ]
[akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c]
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Li Zefan <lizf@cn.fujitsu.com>
When the rett stack checking code sees the stack is unaligned (in both
the sun4c and srmmu cases) it jumps to the window fault-in path.
But that just tries to page the stack pages in, it doesn't do anything
special if the stack is misaligned.
Therefore we essentially just loop forever in the trap return path.
Fix this by emitting a SIGILL in the stack fault-in code if the stack
is mis-aligned.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mtd/m25p80: add support to parse the partitions by OF node
of/irq: of_irq.c needs to include linux/irq.h
of/mips: Cleanup some include directives/files.
of/mips: Add device tree support to MIPS
of/flattree: Eliminate need to provide early_init_dt_scan_chosen_arch
of/device: Rework to use common platform_device_alloc() for allocating devices
of/xsysace: Fix OF probing on little-endian systems
of: use __be32 types for big-endian device tree data
of/irq: remove references to NO_IRQ in drivers/of/platform.c
of/promtree: add package-to-path support to pdt
of/promtree: add of_pdt namespace to pdt code
of/promtree: no longer call prom_ functions directly; use an ops structure
of/promtree: make drivers/of/pdt.c no longer sparc-only
sparc: break out some PROM device-tree building code out into drivers/of
of/sparc: convert various prom_* functions to use phandle
sparc: stop exporting openprom.h header
powerpc, of_serial: Endianness issues setting up the serial ports
of: MTD: Fix OF probing on little-endian systems
of: GPIO: Fix OF probing on little-endian systems
We need to round memory regions correctly -- specifically, we need to
round reserved region in the more expansive direction (lower limit
down, upper limit up) whereas usable memory regions need to be rounded
in the more restrictive direction (lower limit up, upper limit down).
This introduces two set of inlines:
memblock_region_memory_base_pfn()
memblock_region_memory_end_pfn()
memblock_region_reserved_base_pfn()
memblock_region_reserved_end_pfn()
Although they are antisymmetric (and therefore are technically
duplicates) the use of the different inlines explicitly documents the
programmer's intention.
The lack of proper rounding caused a bug on ARM, which was then found
to also affect other architectures.
Reported-by: Russell King <rmk@arm.linux.org.uk>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <4CB4CDFD.4020105@kernel.org>
Rather than passing around ints everywhere, use the
phandle type where appropriate for the various functions
that talk to the PROM.
Signed-off-by: Andres Salomon <dilinger@queued.net>
arch/x86/kernel/trampoline.c
mm/memblock.c
Merge reason: Resolve the conflicts, update to latest upstream.
kunmap_atomic() is currently at level -4 on Rusty's "Hard To Misuse"
list[1] ("Follow common convention and you'll get it wrong"), except in
some architectures when CONFIG_DEBUG_HIGHMEM is set[2][3].
kunmap() takes a pointer to a struct page; kunmap_atomic(), however, takes
takes a pointer to within the page itself. This seems to once in a while
trip people up (the convention they are following is the one from
kunmap()).
Make it much harder to misuse, by moving it to level 9 on Rusty's list[4]
("The compiler/linker won't let you get it wrong"). This is done by
refusing to build if the type of its first argument is a pointer to a
struct page.
The real kunmap_atomic() is renamed to kunmap_atomic_notypecheck()
(which is what you would call in case for some strange reason calling it
with a pointer to a struct page is not incorrect in your code).
The previous version of this patch was compile tested on x86-64.
[1] http://ozlabs.org/~rusty/index.cgi/tech/2008-04-01.html
[2] In these cases, it is at level 5, "Do it right or it will always
break at runtime."
[3] At least mips and powerpc look very similar, and sparc also seems to
share a common ancestor with both; there seems to be quite some
degree of copy-and-paste coding here. The include/asm/highmem.h file
for these three archs mention x86 CPUs at its top.
[4] http://ozlabs.org/~rusty/index.cgi/tech/2008-03-30.html
[5] As an aside, could someone tell me why mn10300 uses unsigned long as
the first parameter of kunmap_atomic() instead of void *?
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net>
Cc: Russell King <linux@arm.linux.org.uk> (arch/arm)
Cc: Ralf Baechle <ralf@linux-mips.org> (arch/mips)
Cc: David Howells <dhowells@redhat.com> (arch/frv, arch/mn10300)
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> (arch/mn10300)
Cc: Kyle McMartin <kyle@mcmartin.ca> (arch/parisc)
Cc: Helge Deller <deller@gmx.de> (arch/parisc)
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> (arch/parisc)
Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> (arch/powerpc)
Cc: Paul Mackerras <paulus@samba.org> (arch/powerpc)
Cc: "David S. Miller" <davem@davemloft.net> (arch/sparc)
Cc: Thomas Gleixner <tglx@linutronix.de> (arch/x86)
Cc: Ingo Molnar <mingo@redhat.com> (arch/x86)
Cc: "H. Peter Anvin" <hpa@zytor.com> (arch/x86)
Cc: Arnd Bergmann <arnd@arndb.de> (include/asm-generic)
Cc: Rusty Russell <rusty@rustcorp.com.au> ("Hard To Misuse" list)
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (63 commits)
of/platform: Register of_platform_drivers with an "of:" prefix
of/address: Clean up function declarations
of/spi: call of_register_spi_devices() from spi core code
of: Provide default of_node_to_nid() implementation.
of/device: Make of_device_make_bus_id() usable by other code.
of/irq: Fix endian issues in parsing interrupt specifiers
of: Fix phandle endian issues
of/flattree: fix of_flat_dt_is_compatible() to match the full compatible string
of: remove of_default_bus_ids
of: make of_find_device_by_node generic
microblaze: remove references to of_device and to_of_device
sparc: remove references to of_device and to_of_device
powerpc: remove references to of_device and to_of_device
of/device: Replace of_device with platform_device in includes and core code
of/device: Protect against binding of_platform_drivers to non-OF devices
of: remove asm/of_device.h
of: remove asm/of_platform.h
of/platform: remove all of_bus_type and of_platform_bus_type references
of: Merge of_platform_bus_type with platform_bus_type
drivercore/of: Add OF style matching to platform bus
Fix up trivial conflicts in arch/microblaze/kernel/Makefile due to just
some obj-y removals by the devicetree branch, while the microblaze
updates added a new file.
arch/sparc/mm: Use GFP_KERNEL
MAINTAINERS: Add trailing slash to SBUS path.
sbus: autoconvert trivial BKL users to private mutex
The former is now strict, it will fail if it cannot honor the allocation
within the node, while the later implements the previous semantic which
falls back to allocating anywhere.
CC: David S. Miller <davem@davemloft.net>
memblock_region
GFP_ATOMIC is not needed here, as evidenced by the other two uses of
GFP_KERNEL in the same function.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@@ identifier f; @@
*f(...,GFP_ATOMIC,...)
... when != spin_unlock(...)
when != read_unlock(...)
when != write_unlock(...)
when != read_unlock_irq(...)
when != write_unlock_irq(...)
when != read_unlock_irqrestore(...)
when != write_unlock_irqrestore(...)
when != spin_unlock_irq(...)
when != spin_unlock_irqrestore(...)
*f(...,GFP_KERNEL,...)
// </smpl>
of_device is just a #define alias to platform_device. This patch
replaces all references to it with platform_device.
math-emu: correct test for downshifting fraction in _FP_FROM_INT()
perf: Add DWARF register lookup for sparc
MAINTAINERS: Add SBUS driver path to sparc entry.
drivers/sbus: Remove unnecessary casts of private_data
sparc: remove homegrown L1_CACHE_ALIGN macro
sparc64: fix the build error due to smp_kgdb_capture_client()
sparc64: Fix maybe_change_configuration() PCR setting.
arch/sparc/kernel: Eliminate what looks like a NULL pointer dereference
sparc64: Update defconfig.
sunsu: Fix use after free in su_remove().
sunserial: Don't call add_preferred_console() when console= is specified.
sparc32: Kill none_mask, it's bogus.
via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
For some reason, the pte_none() calculation for srmmu sparc32
chips was masking out the top 4 bits. That doesn't make any
sense, as those are just some of the physical bits of the PTE
encoding.
Furthermore, this mistake breaks things when the offset of of a swap
entry has a large enough offset as reported by Тхай Кирилл.
Sun4c always set it to zero, so it's really completely useless,
kill it.
Reported-by: Тхай Кирилл <tkhai@yandex.ru>
vmemmap_populate() attempts to report the used index and total size of
vmemmap_table, but it wrongly shifts the total size so that it is
always shown as 0.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6:
sparc: Support show_unhandled_signals.
sparc: use __ratelimit
sunxvr500: Additional PCI id for sunxvr500 driver
sparc: use asm-generic/scatterlist.h
sparc64: If 'slot-names' property exist, create sysfs PCI slot information.
sparc: remove trailing space in messages
sparc: remove redundant return statements
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits)
ARM: Eliminate decompressor -Dstatic= PIC hack
ARM: 5958/1: ARM: U300: fix inverted clk round rate
ARM: 5956/1: misplaced parentheses
ARM: 5955/1: ep93xx: move timer defines into core.c and document
ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c
ARM: 5953/1: ep93xx: fix broken build of clock.c
ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig
ARM: 5949/1: NUC900 add gpio virtual memory map
ARM: 5948/1: Enable timer0 to time4 clock support for nuc910
ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk
ARM: make_coherent(): fix problems with highpte, part 2
MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself
ARM: 5945/1: ep93xx: include correct irq.h in core.c
ARM: 5933/1: amba-pl011: support hardware flow control
ARM: 5930/1: Add PKMAP area description to memory.txt.
ARM: 5929/1: Add checks to detect overlap of memory regions.
ARM: 5928/1: Change type of VMALLOC_END to unsigned long.
ARM: 5927/1: Make delimiters of DMA area globally visibly.
ARM: 5926/1: Add "Virtual kernel memory..." printout.
ARM: 5920/1: OMAP4: Enable L2 Cache
Fix up trivial conflict in arch/arm/mach-mx25/clock.c
Just faults right now, will add other traps later.
On VIVT ARM, when we have multiple shared mappings of the same file
in the same MM, we need to ensure that we have coherency across all
copies. We do this via make_coherent() by making the pages
uncacheable.
This used to work fine, until we allowed highmem with highpte - we
now have a page table which is mapped as required, and is not available
for modification via update_mmu_cache().
Ralf Beache suggested getting rid of the PTE value passed to
update_mmu_cache():
On MIPS update_mmu_cache() calls __update_tlb() which walks pagetables
to construct a pointer to the pte again. Passing a pte_t * is much
more elegant. Maybe we might even replace the pte argument with the
pte_t?
Ben Herrenschmidt would also like the pte pointer for PowerPC:
Passing the ptep in there is exactly what I want. I want that
-instead- of the PTE value, because I have issue on some ppc cases,
for I$/D$ coherency, where set_pte_at() may decide to mask out the
_PAGE_EXEC.
So, pass in the mapped page table pointer into update_mmu_cache(), and
remove the PTE value, updating all implementations and call sites to
suit.
Includes a fix from Stephen Rothwell:
sparc: fix fallout from update_mmu_cache API change
