path: root/arch/sparc/prom/Makefile
2012-05-11sparc32: drop sun4c supportSam Ravnborg
Machines with sun4c support are very rare these days, and noone is using them for any practical purposes. The sun4c support has been know broken for quite some time too. So rather than trying to keep it up-to-date, lets get rid of it. This allows us to do some very welcome cleanup of sparc32 support. Updated the former sun4c specifc nmi (which was also used for sun4m UP) to be a generic UP NMI. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-02sparc: drop prom/palloc.cSam Ravnborg
None of the functions was used. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-02sparc: drop prom/devmap.cSam Ravnborg
2010-11-16sparc: Kill prom devops_{32,64}.cDavid S. Miller
Completely unused. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-08sparc: Use sparc64 version of prom/printf.cRobert Reif
Use sparc64 version of prom/printf.c. The only differences for sparc32 is that prom_printf is no longer exported for modules which should be OK. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc,sparc64: unify prom/Sam Ravnborg
- all files with identical names copied and renamed to *_64.c - the remaning files copied as is - added sparc64 specific files to sparc/prom/Makefile - teach sparc64 Makefile to look into sparc/prom/ - delete unused Makefile from sparc64/prom/ linking order was not kept for sparc64 with this change. It was not possible to keep linking order for both sparc and sparc64 and as sparc64 see more testing than sparc it was natural to break linking order on sparc64. Should it have any effect it would be detected sooner this way. printf_32.c and printf_64.c are obvious candidates to be merged but they are not 100% equal so that was left for later Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc: prepare prom/ for unificationSam Ravnborg
- rename files where sparc64 uses identical names to *_32.c - refactor Makefile (but keep linking order) Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-31sparc: remove CONFIG_SUN4Adrian Bunk
While doing some easy cleanups on the sparc code I noticed that the CONFIG_SUN4 code seems to be worse than the rest - there were some "I don't know how it should work, but the current code definitely cannot work." places. And while I have seen people running Linux on machines like a SPARCstation 5 a few years ago I don't recall having seen sun4 machines, even less ones running Linux. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
