Convert cpu_sibling_map from a static array sized by NR_CPUS to a per_cpu
variable. This saves sizeof(cpumask_t) * NR unused cpus. Access is mostly
from startup and CPU HOTPLUG functions.
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Andi Kleen <ak@suse.de>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Check the return value of fork_idle() to catch error.
Every time a cpu is added via hotplug, we allocate the per-cpu MONDO
queues but we never free them up. Freeing isn't easy since the first
cpu gets this memory from bootmem.
Therefore, the simplest thing to do to fix this bug is to allocate the
queues for all possible cpus at boot time.
When we hot-plug in new cpus, the core_id and proc_id of existing
cpus can change. So in order to set the cpu groups correctly we
need to clear the maps out completely first.
Take a page from the powerpc folks and just calculate the
delay factor directly.
Since frequency scaling chips use a system-tick register,
the value is going to be the same system-wide.
With the move of ldom_startcpu_cpuid() into smp.c some other
things need to follow along:
1) smp.c is not a driver so we can't use "PFX" macro in the
printk calls.
2) smp.c now needs asm/io.h and asm/hvtramp.h, ds.c no longer
does
3) kimage_addr_to_ra() also needs to move into smp.c
While we're here, update copyright info and my email address
in smp.c
Do not select HOTPLUG_CPU from SUN_LDOMS, that causes
HOTPLUG_CPU to be selected even on non-SMP which is
illegal.
Only build hvtramp.o when SMP, just like trampoline.o
Protect dr-cpu code in ds.c with HOTPLUG_CPU.
Likewise move ldom_startcpu_cpuid() to smp.c and protect
it and the call site with SUN_LDOMS && HOTPLUG_CPU.
Only adding cpus is supports at the moment, removal
will come next.
When new cpus are configured, the machine description is
updated. When we get the configure request we pass in a
cpu mask of to-be-added cpus to the mdesc CPU node parser
so it only fetches information for those cpus. That code
also proceeds to update the SMT/multi-core scheduling bitmaps.
cpu_up() does all the work and we return the status back
over the DS channel.
CPUs via dr-cpu need to be booted straight out of the
hypervisor, and this requires:
1) A new trampoline mechanism. CPUs are booted straight
out of the hypervisor with MMU disabled and running in
physical addresses with no mappings installed in the TLB.
The new hvtramp.S code sets up the critical cpu state,
installs the locked TLB mappings for the kernel, and
turns the MMU on. It then proceeds to follow the logic
of the existing trampoline.S SMP cpu bringup code.
2) All calls into OBP have to be disallowed when domaining
is enabled. Since cpus boot straight into the kernel from
the hypervisor, OBP has no state about that cpu and therefore
cannot handle being invoked on that cpu.
Luckily it's only a handful of interfaces which can be called
after the OBP device tree is obtained. For example, rebooting,
halting, powering-off, and setting options node variables.
CPU removal support will require some infrastructure changes
here. Namely we'll have to process the requests via a true
kernel thread instead of in a workqueue. workqueues run on
a per-cpu thread, but when unconfiguring we might need to
force the thread to execute on another cpu if the current cpu
is the one being removed. Removal of a cpu also causes the kernel
to destroy that cpu's workqueue running thread.
Another issue on removal is that we may have interrupts still
pointing to the cpu-to-be-removed. So new code will be needed
to walk the active INO list and retarget those cpus as-needed.
the SMP load-balancer uses the boot-time migration-cost estimation
code to attempt to improve the quality of balancing. The reason for
this code is that the discrete priority queues do not preserve
the order of scheduling accurately, so the load-balancer skips
tasks that were running on a CPU 'recently'.
this code is fundamental fragile: the boot-time migration cost detector
doesnt really work on systems that had large L3 caches, it caused boot
delays on large systems and the whole cache-hot concept made the
balancing code pretty undeterministic as well.
(and hey, i wrote most of it, so i can say it out loud that it sucks ;-)
under CFS the same purpose of cache affinity can be achieved without
any special cache-hot special-case: tasks are sorted in the 'timeline'
tree and the SMP balancer picks tasks from the left side of the
tree, thus the most cache-cold task is balanced automatically.
It's not just sun4v hypervisor platforms that should return true
for this, sun4u with UltraSPARC-IV should return true too.
The scheduling domain hierarchy is:
all cpus -->
cpus that share an instruction cache -->
cpus that share an integer execution unit
Cheetah systems can have cpuids as large as 1023, although physical
systems don't have that many cpus.
Only three limitations existed in the kernel preventing arbitrary
NR_CPUS values:
1) dcache dirty cpu state stored in page->flags on
D-cache aliasing platforms. With some build time
calculations and some build-time BUG checks on
page->flags layout, this one was easily solved.
2) The cheetah XCALL delivery code could only handle
a cpumask with up to 32 cpus set. Some simple looping
logic clears that up too.
3) thread_info->cpu was a u8, easily changed to a u16.
There are a few spots in the kernel that still put NR_CPUS
sized arrays on the kernel stack, but that's not a sparc64
specific problem.
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Let's allow page-alignment in general for per-cpu data (wanted by Xen, and
Ingo suggested KVM as well).
Because larger alignments can use more room, we increase the max per-cpu
memory to 64k rather than 32k: it's getting a little tight.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Signed-off-by: Andi Kleen <ak@suse.de>
I'd like to thank John Stul and others for helping
me along the way.
A lot of cleanups fell out of this. For example, the get_compare()
tick_op was totally unused, so was deleted. And the most often used
tick_op members were grouped together for cache-friendlyness.
The sparc64 TSC is given to the kernel as a one-shot timer.
tick_ops->init_timer() simply turns off the privileged bit in
the tick register (when possible), and disables the interrupt
by setting bit 63 in the compare register. The ->disable_irq()
op also sets this bit.
tick_ops->add_compare() is changed to:
1) Add the given delta to "tick" not to "compare"
2) Return a boolean which, if true, means that the tick
value read after writing the compare value was found
to have incremented past the initial tick value. This
mirrors logic used in the HPET driver's ->next_event()
method.
Each tick_ops implementation also now provides a name string.
And we feed this into the clocksource and clockevents layers.
Things were scattered all over the place, split between
SMP and non-SMP.
Unify it all so that dyntick support is easier to add.
Compiling the kernel with CONFIG_HOTPLUG = y and CONFIG_HOTPLUG_CPU = n
with CONFIG_RELOCATABLE = y generates the following modpost warnings
WARNING: vmlinux - Section mismatch: reference to .init.data: from
.text between '_cpu_up' (at offset 0xc0141b7d) and 'cpu_up'
.text between '_cpu_up' (at offset 0xc0141b9c) and 'cpu_up'
WARNING: vmlinux - Section mismatch: reference to .init.text:__cpu_up
from .text between '_cpu_up' (at offset 0xc0141bd8) and 'cpu_up'
.text between '_cpu_up' (at offset 0xc0141c05) and 'cpu_up'
.text between '_cpu_up' (at offset 0xc0141c26) and 'cpu_up'
.text between '_cpu_up' (at offset 0xc0141c37) and 'cpu_up'
This is because cpu_up, _cpu_up and __cpu_up (in some architectures) are
defined as __devinit
AND
__cpu_up calls some __cpuinit functions.
Since __cpuinit would map to __init with this kind of a configuration,
we get a .text refering .init.data warning.
This patch solves the problem by converting all of __cpu_up, _cpu_up
and cpu_up from __devinit to __cpuinit. The approach is justified since
the callers of cpu_up are either dependent on CONFIG_HOTPLUG_CPU or
are of __init type.
Thus when CONFIG_HOTPLUG_CPU=y, all these cpu up functions would land up
in .text section, and when CONFIG_HOTPLUG_CPU=n, all these functions would
land up in .init section.
Tested on a i386 SMP machine running linux-2.6.20-rc3-mm1.
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Uses of smp_processor_id() get pushed earlier and earlier in
the start_kernel() sequence. So just get it working before
we call start_kernel() to avoid all possible problems.
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes
in the past where people were using for_each_cpu() where they should have been
iterating across only online or present CPUs. This is inefficient and
possibly buggy.
We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the
future.
This patch replaces for_each_cpu with for_each_possible_cpu.
for sparc64.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: "David S. Miller" <davem@davemloft.net>
1) Take doc-book function comment from i386 implementation.
2) cacheline align call_lock, taken from powerpc
3) Need memory barrier after setting call_data
4) Remove timeout
switch_mm() changes the mm state and does a tsb_context_switch()
first, then we do the cpu register state switch which changes
current_thread_info() and current().
So it's safer to check the PGD physical address stored in the
trap block (which will be updated by the tsb_context_switch() in
switch_mm()) than current->active_mm.
Technically we should never run here in between those two
updates, because interrupts are disabled during the entire
context switch operation. But some day we might like to leave
interrupts enabled during the context switch and this change
allows that to happen without any surprises.
Don't rely on fixup_cpu_present_map() to do this as that function
is about to be removed.
When we stop allocating percpu memory for not-possible CPUs we must not touch
the percpu data for not-possible CPUs at all. The correct way of doing this
is to test cpu_possible() or to use for_each_cpu().
This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very
few instances of this bug, if any. But the patch converts lots of open-coded
test to use the preferred helper macros.
Acked-by: Kyle McMartin <kyle@parisc-linux.org>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Christian Zankel <chris@zankel.net>
Cc: Philippe Elie <phil.el@wanadoo.fr>
Cc: Nathan Scott <nathans@sgi.com>
Cc: Jens Axboe <axboe@suse.de>
Cc: Eric Dumazet <dada1@cosmosbay.com>
The mapping is a simple "(cpuid >> 2) == core" for now.
Later we'll add more sophisticated code that will walk
the sun4v machine description and figure this out from
there.
We should also add core mappings for jaguar and panther
processors.
Don't piggy back the SMP receive signal code to do the
context version change handling.
Instead allocate another fixed PIL number for this
asynchronous cross-call. We can't use smp_call_function()
because this thing is invoked with interrupts disabled
and a few spinlocks held.
Also, fix smp_call_function_mask() to count "cpus" correctly.
There is no guarentee that the local cpu is in the mask
yet that is exactly what this code was assuming.
This cpu mondo sending interface isn't all that easy to
use correctly...
We were clearing out the wrong bits from the "mask" after getting
something other than EOK from the hypervisor.
It turns out the hypervisor can just be resent the same cpu_list[]
array, with the 0xffff "done" entries still in there, and it will do
the right thing.
So don't update or try to rebuild the cpu_list[] array to condense it.
This requires the "forward_progress" check to be done slightly
differently, but this new scheme is less bug prone than what we were
doing before.
There were several bugs in the SUN4V cpu mondo dispatch code.
In fact, if we ever got a EWOULDBLOCK or other error from
the hypervisor call, we'd potentially send a cpu mondo multiple
times to the same cpu and even worse we could loop until the
timeout resending the same mondo over and over to such cpus.
So let's bulletproof this thing as follows:
1) Implement cpu_mondo_send() and cpu_state() hypervisor calls
in arch/sparc64/kernel/entry.S, add prototypes to asm/hypervisor.h
2) Don't build and update the cpulist using inline functions, this
was causing the cpu mask to not get updated in the caller.
3) Disable interrupts during the entire mondo send, otherwise our
cpu list and/or mondo block could get overwritten if we take
an interrupt and do a cpu mondo send on the current cpu.
4) Check for all possible error return types from the cpu_mondo_send()
hypervisor call. In particular:
HV_EOK) Our work is done, all cpus have received the mondo.
HV_CPUERROR) One or more of the cpus in the cpu list we passed
to the hypervisor are in error state. Use cpu_state()
calls over the entries in the cpu list to see which
ones. Record them in "error_mask" and report this
after we are done sending the mondo to cpus which are
not in error state.
HV_EWOULDBLOCK) We need to keep trying.
Any other error we consider fatal, we report the event and exit
immediately.
5) We only timeout if forward progress is not made. Forward progress
is defined as having at least one cpu get the mondo successfully
in a given cpu_mondo_send() call. Otherwise we bump a counter
and delay a little. If the counter hits a limit, we signal an
error and report the event.
Also, smp_call_function_mask() error handling reports the number
of cpus incorrectly.
1) We must flush the TLB, duh.
2) Even if the sw context was seen to be valid, the local cpu's
hw context can be out of date, so reload it unconditionally.
It's in "arg0" not "func".
The context allocation scheme we use depends upon there being a 1<-->1
mapping from cpu to physical TLB for correctness. Chips like Niagara
break this assumption.
So what we do is notify all cpus with a cross call when the context
version number changes, and if necessary this makes them allocate
a valid context for the address space they are running at the time.
Stress tested with make -j1024, make -j2048, and make -j4096 kernel
builds on a 32-strand, 8 core, T2000 with 16GB of ram.
Set, but never used.
We used to use this for dynamic IRQ retargetting, but that
code died a long time ago.
The sibling cpu bringup is extremely fragile. We can only
perform the most basic calls until we take over the trap
table from the firmware/hypervisor on the new cpu.
This means no accesses to %g4, %g5, %g6 since those can't be
TLB translated without our trap handlers.
In order to achieve this:
1) Change sun4v_init_mondo_queues() so that it can operate in
several modes.
It can allocate the queues, or install them in the current
processor, or both.
The boot cpu does both in it's call early on.
Later, the boot cpu allocates the sibling cpu queue, starts
the sibling cpu, then the sibling cpu loads them in.
2) init_cur_cpu_trap() is changed to take the current_thread_info()
as an argument instead of reading %g6 directly on the current
cpu.
3) Create a trampoline stack for the sibling cpus. We do our basic
kernel calls using this stack, which is locked into the kernel
image, then go to our proper thread stack after taking over the
trap table.
4) While we are in this delicate startup state, we put 0xdeadbeef
into %g4/%g5/%g6 in order to catch accidental accesses.
5) On the final prom_set_trap_table*() call, we put &init_thread_union
into %g6. This is a hack to make prom_world(0) work. All that
wants to do is restore the %asi register using
get_thread_current_ds().
Longer term we should just do the OBP calls to set the trap table by
hand just like we do for everything else. This would avoid that silly
prom_world(0) issue, then we can remove the init_thread_union hack.
Use prom_startcpu_cpuid() on SUN4V instead of prom_startcpu().
We should really test for "SUNW,start-cpu-by-cpuid" presence
and use it if present even on SUN4U.
That now gets done as a side effect of taking over the
trap table from OBP.
Writes by privileged code are not allowed.
We have to use bootmem during init_IRQ and page alloc
for sibling cpu calls.
Also, fix incorrect hypervisor call return value
checks in the hypervisor SMP cpu mondo send code.
We do this right after we take over the trap table from OBP.
Function goes in %o5, args go in %o0 --> %o5.
