path: root/arch/sparc64/kernel/sys32.S
2008-12-04sparc,sparc64: unify kernel/Sam Ravnborg
o Move all files from sparc64/kernel/ to sparc/kernel - rename as appropriate o Update sparc/Makefile to the changes o Update sparc/kernel/Makefile to include the sparc64 files NOTE: This commit changes link order on sparc64! Link order had to change for either of sparc32 and sparc64. And assuming sparc64 see more testing than sparc32 change link order on sparc64 where issues will be caught faster. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19sparc64: wire up accept4()David Miller
This adds the sparc syscall hookups. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-13[SPARC64]: Fix arg passing to compat_sys_ipc().David S. Miller
Do not sign extend args using the sys32_ipc stub, that is buggy and unnecessary. Based upon an excellent report by Mikael Pettersson. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[SPARC]: Hook up vmsplice into syscall tables.David S. Miller
2006-04-14[SPARC]: Hook up sys_tee() into syscall tables.David S. Miller
2006-03-31[SPARC]: Wire up sys_sync_file_range() into syscall tables.David S. Miller
2006-03-31[SPARC]: Wire up sys_splice() into the syscall tables.David S. Miller
2006-03-04[SPARC64]: Mark __ex_table section correctly.David S. Miller
We must use the "a" (allocate) attribute every time we emit an entry into the __ex_table section. For consistency, use "a" instead of #alloc which is some Solaris compat cruft GNU as provides on Sparc. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-30[SPARC64]: Kill compat_sys_clock_settime sign extension stub.David S. Miller
It's wrong and totally unneeded. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[SPARC64]: Fix fault handling in unaligned trap handler.David S. Miller
We were not calling kernel_mna_trap_fault() correctly. Instead of being fancy, just return 0 vs. -EFAULT from the assembler stubs, and handle that return value as appropriate. Create an "__retl_efault" stub for assembler exception table entries and use it where possible. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[SPARC64]: Convert to use generic exception table support.David S. Miller
The funny "range" exception table entries we had were only used by the compat layer socketcall assembly, and it wasn't even needed there. For free we now get proper exception table sorting and fast binary searching. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-10[SPARC]: Add ioprio system call support.David S. Miller
