Do not sign extend args using the sys32_ipc stub, that is
buggy and unnecessary.
Based upon an excellent report by Mikael Pettersson.
We must use the "a" (allocate) attribute every time we
emit an entry into the __ex_table section.
For consistency, use "a" instead of #alloc which is some
Solaris compat cruft GNU as provides on Sparc.
It's wrong and totally unneeded.
We were not calling kernel_mna_trap_fault() correctly.
Instead of being fancy, just return 0 vs. -EFAULT from
the assembler stubs, and handle that return value as
appropriate.
Create an "__retl_efault" stub for assembler exception
table entries and use it where possible.
The funny "range" exception table entries we had were only
used by the compat layer socketcall assembly, and it wasn't
even needed there.
For free we now get proper exception table sorting and fast
binary searching.
infrastructure for it.
Let it rip!
