path: root/arch/sparc64/kernel/traps.c
2008-12-04sparc,sparc64: unify kernel/Sam Ravnborg
o Move all files from sparc64/kernel/ to sparc/kernel - rename as appropriate o Update sparc/Makefile to the changes o Update sparc/kernel/Makefile to include the sparc64 files NOTE: This commit changes link order on sparc64! Link order had to change for either of sparc32 and sparc64. And assuming sparc64 see more testing than sparc32 change link order on sparc64 where issues will be caught faster. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc64: Make %pil level 15 a pseudo-NMI.David S. Miller
So that we can profile code even in a local_irq_disable() section, only write 14 (instead of 15) into the %pil register to disable IRQs. This allows PIL level 15 to serve as a pseudo NMI. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc64: Stop using memory barriers for atomics and locks.David S. Miller
The kernel always executes in the TSO memory model now, so none of this stuff is necessary any more. With helpful feedback from Nick Piggin. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: sound/core/memalloc.c
2008-09-16sparc64: Fix SMP bootup with CONFIG_STACK_DEBUG or ftrace.David S. Miller
Based upon a report by Meelis Roos. Any function call can try to access the current thread register via the _mcount hooks when the kernel is built with -pg (via ftrace or STACK_DEBUG). That can't be setup properly very early on during the bootup of other cpus for sun4u and some early sun4v systems. So add notrace markers to these specific functions, so that _mcount doesn't get invoked too early. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-11sparc64: Fix sparse warnings in pci.cDavid S. Miller
1) Declare pci_poke_* in pci_impl.h 2) of_create_pci_dev() should be static 3) ->setup_msi_irq() wants an unsigned int pointer not a plain int one 4) void value expression return in arch_teardown_msi_irq() Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-11sparc64: Fix sparse warnings in visemul.cDavid S. Miller
1) edge8 tables should be static 2) add vis_emul() extern decl. to asm/visasm.h Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-24sparc64: Allow chmc to be built as a module.David S. Miller
2008-08-24sparc64: Add generic interface for registering a dimm printing handler.David S. Miller
The way to do this varies by platform type and the exact memory controller the cpu uses. For Spitfire cpus we currently just use prom_getunumber() and hope that works. For Cheetah cpus we have a memory controller driver that can compute this information. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-12sparc64: Implement IRQ stacks.David S. Miller
2008-07-31sparc64: Kill __show_regs().David S. Miller
The story is that what we used to do when we actually used smp_report_regs() is that if you specifically only wanted to have the current cpu's registers dumped you would call "__show_regs()" otherwise you would call show_regs() which also invoked smp_report_regs(). Now that we killed off smp_report_regs() there is no longer any reason to have these two routines, just show_regs() is sufficient. Also kill off a stray declaration of show_regs() in sparc64_ksym.c Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-31sparc64: Kill smp_report_regs().David S. Miller
All the call sites are #if 0'd out and we have a much more useful global cpu dumping facility these days. smp_report_regs() is way too verbose to be usable. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22remove CONFIG_KMOD from sparc64Johannes Berg
One place is just a comment, the other a conditional, unused inclusion of linux/kmod.h. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-17sparc: Use new '%pS' infrastructure to print symbols.David S. Miller
2008-05-21sparc64: Fix stack tracing through trap frames.David S. Miller
The offset to the pt_regs area was wrong, so we weren't looking at the right location for the magic cookie. A trap frame is composed of a "struct sparc_stackf" then a "struct pt_regs", the code was using "struct reg_window" instead of "struct sparc_stackf". Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24[SPARC64]: Detect trap frames in stack backtraces.David S. Miller
Now that we have a magic cookie in the pt_regs, we can properly detect trap frames in stack bactraces. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[SPARC64]: Fix sparse errors in arch/sparc64/kernel/traps.cDavid S. Miller
Add 'UL' markers to DCU_* macros. Declare C functions called from assembler in entry.h Declare C functions called from within the sparc64 arch code in include/asm-sparc64/*.h headers as appropriate. Remove unused routines in traps.c Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-19[SPARC64]: Fix sparse warnings wrt. __show_regs().David S. Miller
arch/sparc64/kernel/process.c:219:6: warning: symbol '__show_regs' was not declared. Should it be static? Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-17[SPARC64]: Fix hypervisor TLB operation error reporting.David S. Miller
1) Trap level wasn't being passed down properly, we need to move it from %l4 into the correct outgoing arg register. 2) Although the TPC often provides the most direct clue, we have the caller PC so we should provide that as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-27[SPARC64]: __inline__ --> inlineDavid S. Miller
2007-10-19Use helpers to obtain task pid in printks (arch code)Alexey Dobriyan
One of the easiest things to isolate is the pid printed in kernel log. There was a patch, that made this for arch-independent code, this one makes so for arch/xxx files. It took some time to cross-compile it, but hopefully these are all the printks in arch code. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-13[SPARC64]: Access ivector_table[] using physical addresses.David S. Miller
2007-07-30[SPARC64]: Fix show_stack() when stack argument is NULL.David S. Miller
It didn't handle that case at all, and now dump_stack() can be implemented directly as show_stack(current, NULL) Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-17Report that kernel is tainted if there was an OOPSPavel Emelianov
If the kernel OOPSed or BUGed then it probably should be considered as tainted. Thus, all subsequent OOPSes and SysRq dumps will report the tainted kernel. This saves a lot of time explaining oddities in the calltraces. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Added parisc patch from Matthew Wilson -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-29[SPARC64]: Use machine description and OBP properly for cpu probing.David S. Miller
2007-05-09Remove hardcoding of hard_smp_processor_id on UP systemsFernando Luis Vazquez Cao
With the advent of kdump, the assumption that the boot CPU when booting an UP kernel is always the CPU with a particular hardware ID (often 0) (usually referred to as BSP on some architectures) is not valid anymore. The reason being that the dump capture kernel boots on the crashed CPU (the CPU that invoked crash_kexec), which may be or may not be that particular CPU. Move definition of hard_smp_processor_id for the UP case to architecture-specific code ("asm/smp.h") where it belongs, so that each architecture can provide its own implementation. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Acked-by: Andi Kleen <ak@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[SPARC64]: Run ctrl-alt-del action for sun4v powerdown request.David S. Miller
2006-12-10[SPARC64]: Call do_mathemu on illegal instruction traps too.David S. Miller
To add this logic, put the VIS instruction check at the vis_emul() call site instead of inside of vis_emul(). Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-30[SPARC64]: Add some missing print_symbol() calls.David S. Miller
2006-06-23[SPARC64]: Convert cpu_find_by_*() interface to in-kernel PROM device tree.David S. Miller
2006-06-20[SPARC64]: Send all device interrupts via one PIL.David S. Miller
This is the first in a series of cleanups that will hopefully allow a seamless attempt at using the generic IRQ handling infrastructure in the Linux kernel. Define PIL_DEVICE_IRQ and vector all device interrupts through there. Get rid of the ugly pil0_dummy_{bucket,desc}, instead vector the timer interrupt directly to a specific handler since the timer interrupt is the only event that will be signaled on PIL 14. The irq_worklist is now in the per-cpu trap_block[]. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-09[SPARC64]: Dump local cpu registers in sun4v_log_error()David S. Miller
This makes the debugging information more usable. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[SPARC64]: Print out return PC in cheetah_log_errors().David S. Miller
This makes debugging things a little bit easier. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[SPARC64]: Add a secondary TSB for hugepage mappings.David S. Miller
2006-03-20[SPARC64]: First cut at VIS simulator for Niagara.David S. Miller
Niagara does not implement some of the VIS instructions in hardware, so we have to emulate them. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Bulletproof hypervisor TLB flushing.David S. Miller
Check TLB flush hypervisor calls for errors and report them. Pass HV_MMU_ALL always for now, we can add back the optimization to avoid the I-TLB flush later. Always explicitly page align the virtual address arguments. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Typo in sun4v_data_access_exception log message.David S. Miller
Should be "Dax" not "Iax". Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Fix typo in dump_tl1_traplog()David S. Miller
Actually make use of the 'limit' we compute. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Disable smp_report_regs() for now.David S. Miller
It's extremely noisy and causes much grief on slow consoles with large numbers of cpus. We'll have to provide this some saner way in order to re-enable this. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Use KERN_EMERG in dump_tl1_traplog() and sun4v TLB errors.David S. Miller
We're about to seriously die in these cases so it is important that the messages make it to the console. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Fix some SUN4V TLB handling bugs.David S. Miller
1) Add error return checking for TLB load hypervisor calls. 2) Don't fallthru to dtlb tsb miss handler from itlb tsb miss handler, oops. 3) On window fixups, propagate fault information to fixup handler correctly. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Get SUN4V SMP working.David S. Miller
The sibling cpu bringup is extremely fragile. We can only perform the most basic calls until we take over the trap table from the firmware/hypervisor on the new cpu. This means no accesses to %g4, %g5, %g6 since those can't be TLB translated without our trap handlers. In order to achieve this: 1) Change sun4v_init_mondo_queues() so that it can operate in several modes. It can allocate the queues, or install them in the current processor, or both. The boot cpu does both in it's call early on. Later, the boot cpu allocates the sibling cpu queue, starts the sibling cpu, then the sibling cpu loads them in. 2) init_cur_cpu_trap() is changed to take the current_thread_info() as an argument instead of reading %g6 directly on the current cpu. 3) Create a trampoline stack for the sibling cpus. We do our basic kernel calls using this stack, which is locked into the kernel image, then go to our proper thread stack after taking over the trap table. 4) While we are in this delicate startup state, we put 0xdeadbeef into %g4/%g5/%g6 in order to catch accidental accesses. 5) On the final prom_set_trap_table*() call, we put &init_thread_union into %g6. This is a hack to make prom_world(0) work. All that wants to do is restore the %asi register using get_thread_current_ds(). Longer term we should just do the OBP calls to set the trap table by hand just like we do for everything else. This would avoid that silly prom_world(0) issue, then we can remove the init_thread_union hack. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Fix tl1 trap state capture/dump on SUN4V.David S. Miller
No trap levels above 2 in privileged mode on SUN4V. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Fix C-function name called by sun4v_mna trap code.David S. Miller
The trap code was calling itself :-) Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: SUN4V memory exception trap handlers.David S. Miller
2006-03-20[SPARC64]: Sun4v cross-call sending support.David S. Miller
Technically the hypervisor call supports sending in a list of all cpus to get the cross-call, but I only pass in one cpu at a time for now. The multi-cpu support is there, just ifdef'd out so it's easy to enable or delete it later. Signed-off-by: David S. Miller <davem@davemloft.net>
