path: root/arch/sparc64/prom/devops.c
2008-12-04sparc,sparc64: unify prom/Sam Ravnborg
- all files with identical names copied and renamed to *_64.c - the remaning files copied as is - added sparc64 specific files to sparc/prom/Makefile - teach sparc64 Makefile to look into sparc/prom/ - delete unused Makefile from sparc64/prom/ linking order was not kept for sparc64 with this change. It was not possible to keep linking order for both sparc and sparc64 and as sparc64 see more testing than sparc it was natural to break linking order on sparc64. Should it have any effect it would be detected sooner this way. printf_32.c and printf_64.c are obvious candidates to be merged but they are not 100% equal so that was left for later Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[SPARC64]: Rewrite bootup sequence.David S. Miller
Instead of all of this cpu-specific code to remap the kernel to the correct location, use portable firmware calls to do this instead. What we do now is the following in position independant assembler: chosen_node = prom_finddevice("/chosen"); prom_mmu_ihandle_cache = prom_getint(chosen_node, "mmu"); vaddr = 4MB_ALIGN(current_text_addr()); prom_translate(vaddr, &paddr_high, &paddr_low, &mode); prom_boot_mapping_mode = mode; prom_boot_mapping_phys_high = paddr_high; prom_boot_mapping_phys_low = paddr_low; prom_map(-1, 8 * 1024 * 1024, KERNBASE, paddr_low); and that replaces the massive amount of by-hand TLB probing and programming we used to do here. The new code should also handle properly the case where the kernel is mapped at the correct address already (think: future kexec support). Consequently, the bulk of remap_kernel() dies as does the entirety of arch/sparc64/prom/map.S We try to share some strings in the PROM library with the ones used at bootup, and while we're here mark input strings to oplib.h routines with "const" when appropriate. There are many more simplifications now possible. For one thing, we can consolidate the two copies we now have of a lot of cpu setup code sitting in head.S and trampoline.S. This is a significant step towards CONFIG_DEBUG_PAGEALLOC support. Signed-off-by: David S. Miller <davem@davemloft.net>
