path: root/arch/tile/lib
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-12arch/tile: finish enabling support for TILE-Gx 64-bit chipChris Metcalf
This support was partially present in the existing code (look for "__tilegx__" ifdefs) but with this change you can build a working kernel using the TILE-Gx toolchain and ARCH=tilegx. Most of these files are new, generally adding a foo_64.c file where previously there was just a foo_32.c file. The ARCH=tilegx directive redirects to arch/tile, not arch/tilegx, using the existing SRCARCH mechanism in the top-level Makefile. Changes to existing files: - <asm/bitops.h> and <asm/bitops_32.h> changed to factor the include of <asm-generic/bitops/non-atomic.h> in the common header. - <asm/compat.h> and arch/tile/kernel/compat.c changed to remove the "const" markers I had put on compat_sys_execve() when trying to match some recent similar changes to the non-compat execve. It turns out the compat version wasn't "upgraded" to use const. - <asm/opcode-tile_64.h> and <asm/opcode_constants_64.h> were previously included accidentally, with the 32-bit contents. Now they have the proper 64-bit contents. Finally, I had to hack the existing hacky drivers/input/input-compat.h to add yet another "#ifdef" for INPUT_COMPAT_TEST (same as x86_64). Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> [drivers/input]
2011-05-04arch/tile: disable GX prefetcher during cache flushChris Metcalf
Otherwise, it's possible to end up with the prefetcher pulling data into cache that the code believes has been flushed. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-04arch/tile: allow nonatomic stores to interoperate with fast atomic syscallsChris Metcalf
This semantic was already true for atomic operations within the kernel, and this change makes it true for the fast atomic syscalls (__NR_cmpxchg and __NR_atomic_update) as well. Previously, user-space had to use the fast atomic syscalls exclusively to update memory, since raw stores could lose a race with the atomic update code even when the atomic update hadn't actually modified the value. With this change, we no longer write back the value to memory if it hasn't changed. This allows certain types of idioms in user space to work as expected, e.g. "atomic exchange" to acquire a spinlock, followed by a raw store of zero to release the lock. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-03-20arch/tile: fix futex sanitization definition/prototype mismatchChris Metcalf
Commit 8d7718aa082aaf30a0b4989e1f04858952f941bc changed "int" to "u32" in the prototypes but not the definition. I missed this when I saw the patch go by on LKML. We cast "u32 *" to "int *" since we are tying into the underlying atomics framework, and atomic_t uses int as its value type. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Reviewed-by: Michel Lespinasse <walken@google.com>
2011-03-10arch/tile: fix deadlock bugs in rwlock implementationChris Metcalf
The first issue fixed in this patch is that pending rwlock write locks could lock out new readers; this could cause a deadlock if a read lock was held on cpu 1, a write lock was then attempted on cpu 2 and was pending, and cpu 1 was interrupted and attempted to re-acquire a read lock. The write lock code was modified to not lock out new readers. The second issue fixed is that there was a narrow race window where a tns instruction had been issued (setting the lock value to "1") and the store instruction to reset the lock value correctly had not yet been issued. In this case, if an interrupt occurred and the same cpu then tried to manipulate the lock, it would find the lock value set to "1" and spin forever, assuming some other cpu was partway through updating it. The fix is to enforce an interrupt critical section around the tns/store pair. In addition, this change now arranges to always validate that after a readlock we have not wrapped around the count of readers, which is only eight bits. Since these changes make the rwlock "fast path" code heavier weight, I decided to move all the rwlock code all out of line, leaving only the conventional spinlock code with fastpath inlines. Since the read_lock and read_trylock implementations ended up very similar, I just expressed read_lock in terms of read_trylock. As part of this change I also eliminate support for the now-obsolete tns_atomic mode. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-03-10arch/tile: support 4KB page size as well as 64KBChris Metcalf
The Tilera architecture traditionally supports 64KB page sizes to improve TLB utilization and improve performance when the hardware is being used primarily to run a single application. For more generic server scenarios, it can be beneficial to run with 4KB page sizes, so this commit allows that to be specified (by modifying the arch/tile/include/hv/pagesize.h header). As part of this change, we also re-worked the PTE management slightly so that PTE writes all go through a __set_pte() function where we can do some additional validation. The set_pte_order() function was eliminated since the "order" argument wasn't being used. One bug uncovered was in the PCI DMA code, which wasn't properly flushing the specified range. This was benign with 64KB pages, but with 4KB pages we were getting some larger flushes wrong. The per-cpu memory reservation code also needed updating to conform with the newer percpu stuff; before it always chose 64KB, and that was always correct, but with 4KB granularity we now have to pay closer attention and reserve the amount of memory that will be requested when the percpu code starts allocating. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-03-10arch/tile: fix some comments and whitespaceChris Metcalf
This is a grab bag of changes with no actual change to generated code. This includes whitespace and comment typos, plus a couple of stale comments being removed. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-03-01arch/tile: export some additional module symbolsChris Metcalf
This adds a grab bag of symbols that have been missing for various modules. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-03-01arch/tile: enhance existing finv_buffer_remote() routineChris Metcalf
It now takes an additional argument so it can be used to flush-and-invalidate pages that are cached using hash-for-home as well those that are cached with coherence point on a single cpu. This allows it to be used more widely for changing the coherence point of arbitrary pages when necessary. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-03-01arch/tile: use extended assembly to inline __mb_incoherent()Chris Metcalf
This avoids having to maintain an additional separate assembly file, and of course the inline is slightly more efficient as well. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-03-01arch/tile: fix __ndelay etc to work betterChris Metcalf
The current implementations of __ndelay and __udelay call a hypervisor service to delay, but the hypervisor service isn't actually implemented very well, and the consensus is that Linux should handle figuring this out natively and not use a hypervisor service. By converting nanoseconds to cycles, and then spinning until the cycle counter reaches the desired cycle, we get several benefits: first, we are sensitive to the actual clock speed; second, we use less power by issuing a slow SPR read once every six cycles while we delay; and third, we properly handle the case of an interrupt by exiting at the target time rather than after some number of cycles. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-03-01arch/tile: catch up with section naming convention in 2.6.35Chris Metcalf
The convention changed to, e.g., ".data..page_aligned". This commit fixes the places in the tile architecture that were still using the old convention. One tile-specific section (.init.page) was dropped in favor of just using an "aligned" attribute. Sam Ravnborg <sam@ravnborg.org> pointed out __PAGE_ALIGNED_BSS, etc. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-11-24arch/tile: fix memchr() not to dereference memory for zero lengthChris Metcalf
This change fixes a bug that memchr() will read the first word of the source even if the length is zero. Ironically, the code was originally written with a test to avoid exactly this problem, but to make the code conform to Linux coding standards with all declarations preceding all statements, the first load from memory was moved up above that test as the initial value for a variable. The change just moves all the variable declarations to the top of the file, with no initializers, so that the test can also be at the top of the file. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-11-15arch/tile: fix rwlock so would-be write lockers don't block new readersChris Metcalf
This avoids a deadlock in the IGMP code where one core gets a read lock, another core starts trying to get a write lock (thus blocking new readers), and then the first core tries to recursively re-acquire the read lock. We still try to preserve some degree of balance by giving priority to additional write lockers that come along while the lock is held for write, so they can all complete quickly and return the lock to the readers. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-11-01arch/tile: complete migration to new kmap_atomic schemeChris Metcalf
This change makes KM_TYPE_NR independent of the actual deprecated list of km_type values, which are no longer used in tile code anywhere. For now we leave it set to 8, allowing that many nested mappings, and thus reserving 32MB of address space. A few remaining places using KM_* values were cleaned up as well. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-15arch/tile: minor whitespace/naming changes for string support filesChris Metcalf
Our internal process shares memcpy, memset, etc., with libc, and we did some minor tweaking as part of moving from uclibc to glibc, which is now reflected in the kernel versions of these files. There are no semantic changes in this commit, just whitespace (memcpy_32.S now properly uses tabs), naming (memmove.c instead of memmove_32.c, since TILE-Gx shares the file with TILEPro), and a couple of other minor tweaks. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-14arch/tile: properly export __mb_incoherent for modulesChris Metcalf
2010-10-05tile: replace some BUG_ON checks with BUILD_BUG_ON checksAkinobu Mita
Some BUG_ON checks can be detected at compile time rather than at runtime. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-08-13arch/tile: Various cleanups.Chris Metcalf
This change rolls up random cleanups not representing any actual bugs. - Remove a stale CONFIG_ value from the default tile_defconfig - Remove unused tns_atomic_xxx() family of methods from <asm/atomic.h> - Optimize get_order() using Tile's "clz" instruction - Fix a bad hypervisor upcall name (not currently used in Linux anyway) - Use __copy_in_user_inatomic() name for consistency, and export it - Export some additional hypervisor driver I/O upcalls and some homecache calls - Remove the obfuscating MEMCPY_TEST_WH64 support code - Other stray comment cleanups, #if 0 removal, etc. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-07-06arch/tile: Miscellaneous cleanup changes.Chris Metcalf
This commit is primarily changes caused by reviewing "sparse" and "checkpatch" output on our sources, so is somewhat noisy, since things like "printk() -> pr_err()" (or whatever) throughout the codebase tend to get tedious to read. Rather than trying to tease apart precisely which things changed due to which type of code review, this commit includes various cleanups in the code: - sparse: Add declarations in headers for globals. - sparse: Fix __user annotations. - sparse: Using gfp_t consistently instead of int. - sparse: removing functions not actually used. - checkpatch: Clean up printk() warnings by using pr_info(), etc.; also avoid partial-line printks except in bootup code. - checkpatch: Use exposed structs rather than typedefs. - checkpatch: Change some C99 comments to C89 comments. In addition, a couple of minor other changes are rolled in to this commit: - Add support for a "raise" instruction to cause SIGFPE, etc., to be raised. - Remove some compat code that is unnecessary when we fully eliminate some of the deprecated syscalls from the generic syscall ABI. - Update the tile_defconfig to reflect current config contents. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-07-06arch/tile: Split the icache flush code off to a generic <arch> header.Chris Metcalf
This code is used in other places in our system than in Linux, so to share it we now implement it as an inline function in our low-level <arch> headers, and instantiate it in one file in Linux's arch/tile/lib. The file is now cacheflush.c and is C code rather than the strangely-named and assembler-implemented __invalidate_icache.S. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-07-06arch/tile: Fix bug in support for atomic64_xx() ops.Chris Metcalf
This wasn't properly tested until the perf-event subsystem started to get brought up under the tile architecture. The bug caused bogus atomic64_cmpxchg() values to be returned, among other things. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-06-04arch/tile: core support for Tilera 32-bit chips.Chris Metcalf
This change is the core kernel support for TILEPro and TILE64 chips. No driver support (except the console driver) is included yet. This includes the relevant Linux headers in asm/; the low-level low-level "Tile architecture" headers in arch/, which are shared with the hypervisor, etc., and are build-system agnostic; and the relevant hypervisor headers in hv/. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Paul Mundt <lethal@linux-sh.org>
