commit 4d2dc2cc766c3b51929658cacbc6e34fc8e242fb upstream.
Currently, we're capping the values too low in the F_GETLK64 case. The
fields in that structure are 64-bit values, so we shouldn't need to do
any sort of fixup there.
Make sure we check that assumption at build time in the future however
by ensuring that the sizes we're copying will fit.
With this, we no longer need COMPAT_LOFF_T_MAX either, so remove it.
Fixes: 94073ad77fff2 (fs/locks: don't mess with the address limit in compat_fcntl64)
Reported-by: Vitaly Lipatov <lav@etersoft.ru>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: David Howells <dhowells@redhat.com>
Pull arch/tile fixes from Chris Metcalf:
"Two one-line bug fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile: Implement ->set_state_oneshot_stopped()
tile: pass machine size to sparse
set_state_oneshot_stopped() is called by the clkevt core, when the
next event is required at an expiry time of 'KTIME_MAX'. This normally
happens with NO_HZ_{IDLE|FULL} in both LOWRES/HIGHRES modes.
This patch makes the clockevent device to stop on such an event, to
avoid spurious interrupts, as explained by: commit 8fff52fd5093
("clockevents: Introduce CLOCK_EVT_STATE_ONESHOT_STOPPED state").
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
Many user space API headers have licensing information, which is either
incomplete, badly formatted or just a shorthand for referring to the
license under which the file is supposed to be. This makes it hard for
compliance tools to determine the correct license.
Update these files with an SPDX license identifier. The identifier was
chosen based on the license information in the file.
GPL/LGPL licensed headers get the matching GPL/LGPL SPDX license
identifier with the added 'WITH Linux-syscall-note' exception, which is
the officially assigned exception identifier for the kernel syscall
exception:
NOTE! This copyright does *not* cover user programs that use kernel
services by normal system calls - this is merely considered normal use
of the kernel, and does *not* fall under the heading of "derived work".
This exception makes it possible to include GPL headers into non GPL
code, without confusing license compliance tools.
Headers which have either explicit dual licensing or are just licensed
under a non GPL license are updated with the corresponding SPDX
identifier and the GPLv2 with syscall exception identifier. The format
is:
((GPL-2.0 WITH Linux-syscall-note) OR SPDX-ID-OF-OTHER-LICENSE)
SPDX license identifiers are a legally binding shorthand, which can be
used instead of the full boiler plate text. The update does not remove
existing license information as this has to be done on a case by case
basis and the copyright holders might have to be consulted. This will
happen in a separate step.
Philippe Ombredanne. See the previous patch in this series for the
methodology of how this patch was researched.
license
Many user space API headers are missing licensing information, which
makes it hard for compliance tools to determine the correct license.
By default are files without license information under the default
license of the kernel, which is GPLV2. Marking them GPLV2 would exclude
them from being included in non GPLV2 code, which is obviously not
intended. The user space API headers fall under the syscall exception
which is in the kernels COPYING file:
otherwise syscall usage would not be possible.
Update the files which contain no license information with an SPDX
license identifier. The chosen identifier is 'GPL-2.0 WITH
Linux-syscall-note' which is the officially assigned identifier for the
Linux syscall exception. SPDX license identifiers are a legally binding
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
By default, sparse assumes a 64bit machine when compiled on x86-64
and 32bit when compiled on anything else.
This can of course create all sort of problems, like issuing false
warnings like: 'constant ... is so big it is unsigned long long'
or 'shift too big (32) for type unsigned long' when the architecture
is 64bit while sparse was compiled on a 32bit machine, or worse,
to not emit legitimate warnings in the reverse situation.
Fix this by passing to sparse the appropriate -m32/-m64 flag.
To: Chris Metcalf <cmetcalf@mellanox.com>
Signed-off-by: Luc Van Oostenryck <luc.vanoostenryck@gmail.com>
"These are a code cleanup and config cleanup, respectively"
tile: array underflow in setup_maxnodemem()
tile: defconfig: Cleanup from old Kconfig options
Pull dma-mapping updates from Christoph Hellwig:
- removal of the old dma_alloc_noncoherent interface
- remove unused flags to dma_declare_coherent_memory
- restrict OF DMA configuration to specific physical busses
- use the iommu mailing list for dma-mapping questions and patches
* tag 'dma-mapping-4.14' of git://git.infradead.org/users/hch/dma-mapping:
dma-coherent: fix dma_declare_coherent_memory() logic error
ARM: imx: mx31moboard: Remove unused 'dma' variable
dma-coherent: remove an unused variable
MAINTAINERS: use the iommu list for the dma-mapping subsystem
dma-coherent: remove the DMA_MEMORY_MAP and DMA_MEMORY_IO flags
dma-coherent: remove the DMA_MEMORY_INCLUDES_CHILDREN flag
of: restrict DMA configuration
dma-mapping: remove dma_alloc_noncoherent and dma_free_noncoherent
i825xx: switch to switch to dma_alloc_attrs
au1000_eth: switch to dma_alloc_attrs
sgiseeq: switch to dma_alloc_attrs
dma-mapping: reduce dma_mapping_error inline bloat
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace updates from Eric Biederman:
"Life has been busy and I have not gotten half as much done this round
as I would have liked. I delayed it so that a minor conflict
resolution with the mips tree could spend a little time in linux-next
before I sent this pull request.
This includes two long delayed user namespace changes from Kirill
Tkhai. It also includes a very useful change from Serge Hallyn that
allows the security capability attribute to be used inside of user
namespaces. The practical effect of this is people can now untar
tarballs and install rpms in user namespaces. It had been suggested to
generalize this and encode some of the namespace information
information in the xattr name. Upon close inspection that makes the
things that should be hard easy and the things that should be easy
more expensive.
Then there is my bugfix/cleanup for signal injection that removes the
magic encoding of the siginfo union member from the kernel internal
si_code. The mips folks reported the case where I had used FPE_FIXME
me is impossible so I have remove FPE_FIXME from mips, while at the
same time including a return statement in that case to keep gcc from
complaining about unitialized variables.
I almost finished the work to get make copy_siginfo_to_user a trivial
copy to user. The code is available at:
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace.git neuter-copy_siginfo_to_user-v3
But I did not have time/energy to get the code posted and reviewed
before the merge window opened.
I was able to see that the security excuse for just copying fields
that we know are initialized doesn't work in practice there are buggy
initializations that don't initialize the proper fields in siginfo. So
we still sometimes copy unitialized data to userspace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
Introduce v3 namespaced file capabilities
mips/signal: In force_fcr31_sig return in the impossible case
signal: Remove kernel interal si_code magic
fcntl: Don't use ambiguous SIG_POLL si_codes
prctl: Allow local CAP_SYS_ADMIN changing exe_file
security: Use user_namespace::level to avoid redundant iterations in cap_capable()
userns,pidns: Verify the userns for new pid namespaces
signal/testing: Don't look for __SI_FAULT in userspace
signal/mips: Document a conflict with SI_USER with SIGFPE
signal/sparc: Document a conflict with SI_USER with SIGFPE
signal/ia64: Document a conflict with SI_USER with SIGFPE
signal/alpha: Document a conflict with SI_USER for SIGTRAP
Merge more updates from Andrew Morton:
- most of the rest of MM
- a small number of misc things
- lib/ updates
- checkpatch
- autofs updates
- ipc/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (126 commits)
ipc: optimize semget/shmget/msgget for lots of keys
ipc/sem: play nicer with large nsops allocations
ipc/sem: drop sem_checkid helper
ipc: convert kern_ipc_perm.refcount from atomic_t to refcount_t
ipc: convert sem_undo_list.refcnt from atomic_t to refcount_t
ipc: convert ipc_namespace.count from atomic_t to refcount_t
kcov: support compat processes
sh: defconfig: cleanup from old Kconfig options
mn10300: defconfig: cleanup from old Kconfig options
m32r: defconfig: cleanup from old Kconfig options
drivers/pps: use surrounding "if PPS" to remove numerous dependency checks
drivers/pps: aesthetic tweaks to PPS-related content
cpumask: make cpumask_next() out-of-line
kmod: move #ifdef CONFIG_MODULES wrapper to Makefile
kmod: split off umh headers into its own file
MAINTAINERS: clarify kmod is just a kernel module loader
kmod: split out umh code into its own file
test_kmod: flip INT checks to be consistent
test_kmod: remove paranoid UINT_MAX check on uint range processing
vfat: deduplicate hex2bin()
First, number of CPUs can't be negative number.
Second, different signnnedness leads to suboptimal code in the following
cases:
1)
kmalloc(nr_cpu_ids * sizeof(X));
"int" has to be sign extended to size_t.
2)
while (loff_t *pos < nr_cpu_ids)
MOVSXD is 1 byte longed than the same MOV.
Other cases exist as well. Basically compiler is told that nr_cpu_ids
can't be negative which can't be deduced if it is "int".
Code savings on allyesconfig kernel: -3KB
add/remove: 0/0 grow/shrink: 25/264 up/down: 261/-3631 (-3370)
function old new delta
coretemp_cpu_online 450 512 +62
rcu_init_one 1234 1272 +38
pci_device_probe 374 399 +25
pgdat_reclaimable_pages 628 556 -72
select_fallback_rq 446 369 -77
task_numa_find_cpu 1923 1807 -116
Link: http://lkml.kernel.org/r/20170819114959.GA30580@avx2
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- add enhanced Downstream Port Containment support, which prints more
details about Root Port Programmed I/O errors (Dongdong Liu)
- add Layerscape ls1088a and ls2088a support (Hou Zhiqiang)
- add MediaTek MT2712 and MT7622 support (Ryder Lee)
- add MediaTek MT2712 and MT7622 MSI support (Honghui Zhang)
- add Qualcom IPQ8074 support (Varadarajan Narayanan)
- add R-Car r8a7743/5 device tree support (Biju Das)
- add Rockchip per-lane PHY support for better power management (Shawn
Lin)
- fix IRQ mapping for hot-added devices by replacing the
pci_fixup_irqs() boot-time design with a host bridge hook called at
probe-time (Lorenzo Pieralisi, Matthew Minter)
- fix race when enabling two devices that results in upstream bridge
not being enabled correctly (Srinath Mannam)
- fix pciehp power fault infinite loop (Keith Busch)
- fix SHPC bridge MSI hotplug events by enabling bus mastering
(Aleksandr Bezzubikov)
- fix a VFIO issue by correcting PCIe capability sizes (Alex
Williamson)
- fix an INTD issue on Xilinx and possibly other drivers by unifying
INTx IRQ domain support (Paul Burton)
- avoid IOMMU stalls by marking AMD Stoney GPU ATS as broken (Joerg
Roedel)
- allow APM X-Gene device assignment to guests by adding an ACS quirk
(Feng Kan)
- fix driver crashes by disabling Extended Tags on Broadcom HT2100
(Extended Tags support is required for PCIe Receivers but not
Requesters, and we now enable them by default when Requesters support
them) (Sinan Kaya)
- fix MSIs for devices that use phantom RIDs for DMA by assuming MSIs
use the real Requester ID (not a phantom RID) (Robin Murphy)
- prevent assignment of Intel VMD children to guests (which may be
supported eventually, but isn't yet) by not associating an IOMMU with
them (Jon Derrick)
- fix Intel VMD suspend/resume by releasing IRQs on suspend (Scott
Bauer)
- fix a Function-Level Reset issue with Intel 750 NVMe by waiting
longer (up to 60sec instead of 1sec) for device to become ready
(Sinan Kaya)
- fix a Function-Level Reset issue on iProc Stingray by working around
hardware defects in the CRS implementation (Oza Pawandeep)
- fix an issue with Intel NVMe P3700 after an iProc reset by adding a
delay during shutdown (Oza Pawandeep)
- fix a Microsoft Hyper-V lockdep issue by polling instead of blocking
in compose_msi_msg() (Stephen Hemminger)
- fix a wireless LAN driver timeout by clearing DesignWare MSI
interrupt status after it is handled, not before (Faiz Abbas)
- fix DesignWare ATU enable checking (Jisheng Zhang)
- reduce Layerscape dependencies on the bootloader by doing more
initialization in the driver (Hou Zhiqiang)
- improve Intel VMD performance allowing allocation of more IRQ vectors
than present CPUs (Keith Busch)
- improve endpoint framework support for initial DMA mask, different
BAR sizes, configurable page sizes, MSI, test driver, etc (Kishon
Vijay Abraham I, Stan Drozd)
- rework CRS support to add periodic messages while we poll during
enumeration and after Function-Level Reset and prepare for possible
other uses of CRS (Sinan Kaya)
- clean up Root Port AER handling by removing unnecessary code and
moving error handler methods to struct pcie_port_service_driver
(Christoph Hellwig)
- clean up error handling paths in various drivers (Bjorn Andersson,
Fabio Estevam, Gustavo A. R. Silva, Harunobu Kurokawa, Jeffy Chen,
Lorenzo Pieralisi, Sergei Shtylyov)
- clean up SR-IOV resource handling by disabling VF decoding before
updating the corresponding resource structs (Gavin Shan)
- clean up DesignWare-based drivers by unifying quirks to update Class
Code and Interrupt Pin and related handling of write-protected
registers (Hou Zhiqiang)
- clean up by adding empty generic pcibios_align_resource() and
pcibios_fixup_bus() and removing empty arch-specific implementations
(Palmer Dabbelt)
- request exclusive reset control for several drivers to allow cleanup
elsewhere (Philipp Zabel)
- constify various structures (Arvind Yadav, Bhumika Goyal)
- convert from full_name() to %pOF (Rob Herring)
- remove unused variables from iProc, HiSi, Altera, Keystone (Shawn
Lin)
* tag 'pci-v4.14-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (170 commits)
PCI: xgene: Clean up whitespace
PCI: xgene: Define XGENE_PCI_EXP_CAP and use generic PCI_EXP_RTCTL offset
PCI: xgene: Fix platform_get_irq() error handling
PCI: xilinx-nwl: Fix platform_get_irq() error handling
PCI: rockchip: Fix platform_get_irq() error handling
PCI: altera: Fix platform_get_irq() error handling
PCI: spear13xx: Fix platform_get_irq() error handling
PCI: artpec6: Fix platform_get_irq() error handling
PCI: armada8k: Fix platform_get_irq() error handling
PCI: dra7xx: Fix platform_get_irq() error handling
PCI: exynos: Fix platform_get_irq() error handling
PCI: iproc: Clean up whitespace
PCI: iproc: Rename PCI_EXP_CAP to IPROC_PCI_EXP_CAP
PCI: iproc: Add 500ms delay during device shutdown
PCI: Fix typos and whitespace errors
PCI: Remove unused "res" variable from pci_resource_io()
PCI: Correct kernel-doc of pci_vpd_srdt_size(), pci_vpd_srdt_tag()
PCI/AER: Reformat AER register definitions
iommu/vt-d: Prevent VMD child devices from being remapping targets
x86/PCI: Use is_vmd() rather than relying on the domain number
* pci/resource:
microblaze/PCI: Remove pcibios_setup_bus_{self/devices} dead code
ARC: Remove empty kernel/pcibios.c
PCI: Add a generic weak pcibios_align_resource()
PCI: Add a generic weak pcibios_fixup_bus()
Pull locking updates from Ingo Molnar:
- Add 'cross-release' support to lockdep, which allows APIs like
completions, where it's not the 'owner' who releases the lock, to be
tracked. It's all activated automatically under
CONFIG_PROVE_LOCKING=y.
- Clean up (restructure) the x86 atomics op implementation to be more
readable, in preparation of KASAN annotations. (Dmitry Vyukov)
- Fix static keys (Paolo Bonzini)
- Add killable versions of down_read() et al (Kirill Tkhai)
- Rework and fix jump_label locking (Marc Zyngier, Paolo Bonzini)
- Rework (and fix) tlb_flush_pending() barriers (Peter Zijlstra)
- Remove smp_mb__before_spinlock() and convert its usages, introduce
smp_mb__after_spinlock() (Peter Zijlstra)
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (56 commits)
locking/lockdep/selftests: Fix mixed read-write ABBA tests
sched/completion: Avoid unnecessary stack allocation for COMPLETION_INITIALIZER_ONSTACK()
acpi/nfit: Fix COMPLETION_INITIALIZER_ONSTACK() abuse
locking/pvqspinlock: Relax cmpxchg's to improve performance on some architectures
smp: Avoid using two cache lines for struct call_single_data
locking/lockdep: Untangle xhlock history save/restore from task independence
locking/refcounts, x86/asm: Disable CONFIG_ARCH_HAS_REFCOUNT for the time being
futex: Remove duplicated code and fix undefined behaviour
Documentation/locking/atomic: Finish the document...
locking/lockdep: Fix workqueue crossrelease annotation
workqueue/lockdep: 'Fix' flush_work() annotation
locking/lockdep/selftests: Add mixed read-write ABBA tests
mm, locking/barriers: Clarify tlb_flush_pending() barriers
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE and CONFIG_LOCKDEP_COMPLETIONS truly non-interactive
locking/lockdep: Explicitly initialize wq_barrier::done::map
locking/lockdep: Rename CONFIG_LOCKDEP_COMPLETE to CONFIG_LOCKDEP_COMPLETIONS
locking/lockdep: Reword title of LOCKDEP_CROSSRELEASE config
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE part of CONFIG_PROVE_LOCKING
locking/refcounts, x86/asm: Implement fast refcount overflow protection
locking/lockdep: Fix the rollback and overwrite detection logic in crossrelease
No users left, everyone switched to the _attrs versions.
There is code duplicated over all architecture's headers for
futex_atomic_op_inuser. Namely op decoding, access_ok check for uaddr,
and comparison of the result.
Remove this duplication and leave up to the arches only the needed
assembly which is now in arch_futex_atomic_op_inuser.
This effectively distributes the Will Deacon's arm64 fix for undefined
behaviour reported by UBSAN to all architectures. The fix was done in
commit 5f16a046f8e1 (arm64: futex: Fix undefined behaviour with
FUTEX_OP_OPARG_SHIFT usage). Look there for an example dump.
And as suggested by Thomas, check for negative oparg too, because it was
also reported to cause undefined behaviour report.
Note that s390 removed access_ok check in d12a29703 ("s390/uaccess:
remove pointless access_ok() checks") as access_ok there returns true.
We introduce it back to the helper for the sake of simplicity (it gets
optimized away anyway).
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [s390]
Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
Reviewed-by: Darren Hart (VMware) <dvhart@infradead.org>
Reviewed-by: Will Deacon <will.deacon@arm.com> [core/arm64]
Cc: linux-mips@linux-mips.org
Cc: Rich Felker <dalias@libc.org>
Cc: linux-ia64@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: peterz@infradead.org
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: sparclinux@vger.kernel.org
Cc: Jonas Bonn <jonas@southpole.se>
Cc: linux-s390@vger.kernel.org
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: linux-hexagon@vger.kernel.org
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Matt Turner <mattst88@gmail.com>
Cc: linux-snps-arc@lists.infradead.org
Cc: linux-xtensa@linux-xtensa.org
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: openrisc@lists.librecores.org
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Stafford Horne <shorne@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Chris Zankel <chris@zankel.net>
Cc: linux-parisc@vger.kernel.org
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: linux-alpha@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/20170824073105.3901-1-jslaby@suse.cz
There is no agreed-upon definition of spin_unlock_wait()'s semantics,
and it appears that all callers could do just as well with a lock/unlock
pair. This commit therefore removes the underlying arch-specific
arch_spin_unlock_wait() for all architectures providing them.
Cc: <linux-arch@vger.kernel.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Andrea Parri <parri.andrea@gmail.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Boqun Feng <boqun.feng@gmail.com>
Those architectures that have a special atomic_set implementation also
need a special atomic_set_release(), because for the very same reason
WRITE_ONCE() is broken for them, smp_store_release() is too.
The vast majority is architectures that have spinlock hash based atomic
implementation except hexagon which seems to have a hardware 'feature'.
The spinlock based atomics should be SC, that is, none of them appear to
place extra barriers in atomic_cmpxchg() or any of the other SC atomic
primitives and therefore seem to rely on their spinlock implementation
being SC (I did not fully validate all that).
Therefore, the normal atomic_set() is SC and can be used at
atomic_set_release().
Cc: Boqun Feng <boqun.feng@gmail.com>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: davem@davemloft.net
Cc: james.hogan@imgtec.com
Cc: jejb@parisc-linux.org
Cc: rkuo@codeaurora.org
Cc: vgupta@synopsys.com
Link: http://lkml.kernel.org/r/20170609110506.yod47flaav3wgoj5@hirez.programming.kicks-ass.net
The pci_fixup_irqs() function allocates IRQs for all PCI devices present in
a system; those PCI devices possibly belong to different PCI bus trees (and
possibly rooted at different host bridges) and may well be enabled (ie
probed and bound to a driver) by the time pci_fixup_irqs() is called when
probing a given host bridge driver.
Furthermore, current kernel code relying on pci_fixup_irqs() to assign
legacy PCI IRQs to devices does not work at all for hotplugged devices in
that the code carrying out the IRQ fixup is called at host bridge driver
probe time, which just cannot take into account devices hotplugged after
the system has booted.
The introduction of map/swizzle function hooks in struct pci_host_bridge
allows us to define per-bridge map/swizzle functions that can be used at
device probe time in PCI core code to allocate IRQs for a given device
(through pci_assign_irq()).
Convert PCI host bridge initialization code to the
pci_scan_root_bus_bridge() API (that allows to pass a struct
pci_host_bridge with initializedmap/swizzle pointers) and remove the
pci_fixup_irqs() call from arch code.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Multiple architectures define this as a trivial function, and I'm adding
another one as part of the RISC-V port. Add a __weak version of
pcibios_align_resource() and delete the now-obselete ones in a handful of
ports.
The only functional change should be that a handful of ports used to export
pcibios_fixup_bus(). Only some architectures export this, so I just
dropped it.
Signed-off-by: Palmer Dabbelt <palmer@dabbelt.com>
Multiple architectures define this as an empty function, and I'm adding
pcibios_fixup_bus() and delete the now-obselete ones in a handful of
ports.
The only functional change should be that microblaze used to export
pcibios_fixup_bus(). None of the other architectures exports this, so I
just dropped it.
struct siginfo is a union and the kernel since 2.4 has been hiding a union
tag in the high 16bits of si_code using the values:
__SI_KILL
__SI_TIMER
__SI_POLL
__SI_FAULT
__SI_CHLD
__SI_RT
__SI_MESGQ
__SI_SYS
While this looks plausible on the surface, in practice this situation has
not worked well.
- Injected positive signals are not copied to user space properly
unless they have these magic high bits set.
- Injected positive signals are not reported properly by signalfd
- These kernel internal values leaked to userspace via ptrace_peek_siginfo
- It was possible to inject these kernel internal values and cause the
the kernel to misbehave.
- Kernel developers got confused and expected these kernel internal values
in userspace in kernel self tests.
- Kernel developers got confused and set si_code to __SI_FAULT which
is SI_USER in userspace which causes userspace to think an ordinary user
sent the signal and that it was not kernel generated.
- The values make it impossible to reorganize the code to transform
siginfo_copy_to_user into a plain copy_to_user. As si_code must
be massaged before being passed to userspace.
So remove these kernel internal si codes and make the kernel code simpler
and more maintainable.
To replace these kernel internal magic si_codes introduce the helper
function siginfo_layout, that takes a signal number and an si_code and
computes which union member of siginfo is being used. Have
siginfo_layout return an enumeration so that gcc will have enough
information to warn if a switch statement does not handle all of union
members.
A couple of architectures have a messed up ABI that defines signal
specific duplications of SI_USER which causes more special cases in
siginfo_layout than I would like. The good news is only problem
architectures pay the cost.
Update all of the code that used the previous magic __SI_ values to
use the new SIL_ values and to call siginfo_layout to get those
values. Escept where not all of the cases are handled remove the
defaults in the switch statements so that if a new case is missed in
the future the lack will show up at compile time.
Modify the code that copies siginfo si_code to userspace to just copy
the value and not cast si_code to a short first. The high bits are no
longer used to hold a magic union member.
Fixup the siginfo header files to stop including the __SI_ values in
their constants and for the headers that were missing it to properly
update the number of si_codes for each signal type.
The fixes to copy_siginfo_from_user32 implementations has the
interesting property that several of them perviously should never have
worked as the __SI_ values they depended up where kernel internal.
With that dependency gone those implementations should work much
better.
The idea of not passing the __SI_ values out to userspace and then
not reinserting them has been tested with criu and criu worked without
changes.
Ref: 2.4.0-test1
My static checker correctly complains that we should have a lower bound
on "node" to prevent an array underflow.
Fixes: 867e359b97c9 ("arch/tile: core support for Tilera 32-bit chips.")
Remove old, dead Kconfig options (in order appearing in this commit):
- CRYPTO_ZLIB: commit 110492183c4b ("crypto: compress - remove unused
pcomp interface");
- IP_NF_TARGET_ULOG: commit d4da843e6fad ("netfilter: kill remnants of
ulog targets");
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Pull uacess-unaligned removal from Al Viro:
"That stuff had just one user, and an exotic one, at that - binfmt_flat
on arm and m68k"
* 'work.uaccess-unaligned' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
kill {__,}{get,put}_user_unaligned()
binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail
Pull arch/tile updates from Chris Metcalf:
"This adds support for an <arch/intreg.h> to help with removing
__need_xxx #defines from glibc, and removes some dead code in
arch/tile/mm/init.c"
mm, tile: drop arch_{add,remove}_memory
tile: prefer <arch/intreg.h> to __need_int_reg_t
Since commit fcc8487d477a ("uapi: export all headers under uapi
directories"), all (and only) headers under uapi directories are
exported, but asm-generic wrappers are still exceptions.
To complete de-coupling the uapi from kernel headers, move generic-y
of exported headers to uapi/asm/Kbuild.
With this change, "make headers_install" will just need to parse
uapi/asm/Kbuild to build up exported headers.
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kbuild thin archives updates from Masahiro Yamada:
"Thin archives migration by Nicholas Piggin.
THIN_ARCHIVES has been available for a while as an optional feature
only for PowerPC architecture, but we do not need two different
intermediate-artifact schemes.
Using thin archives instead of conventional incremental linking has
various advantages:
- save disk space for builds
- speed-up building a little
- fix some link issues (for example, allyesconfig on ARM) due to more
flexibility for the final linking
- work better with dead code elimination we are planning
As discussed before, this migration has been done unconditionally so
that any problems caused by this will show up with "git bisect".
With testing with 0-day and linux-next, some architectures actually
showed up problems, but they were trivial and all fixed now"
* tag 'kbuild-thinar-v4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
tile: remove unneeded extra-y in Makefile
kbuild: thin archives make default for all archs
x86/um: thin archives build fix
tile: thin archives fix linking
ia64: thin archives fix linking
sh: thin archives fix linking
kbuild: handle libs-y archives separately from built-in.o archives
kbuild: thin archives use P option to ar
kbuild: thin archives final link close --whole-archives option
ia64: remove unneeded extra-y in Makefile.gate
tile: fix dependency and .*.cmd inclusion for incremental build
sparc64: Use indirect calls in hamming weight stubs
Merge misc updates from Andrew Morton:
- a few hotfixes
- various misc updates
- ocfs2 updates
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (108 commits)
mm, memory_hotplug: move movable_node to the hotplug proper
mm, memory_hotplug: drop CONFIG_MOVABLE_NODE
mm, memory_hotplug: drop artificial restriction on online/offline
mm: memcontrol: account slab stats per lruvec
mm: memcontrol: per-lruvec stats infrastructure
mm: memcontrol: use generic mod_memcg_page_state for kmem pages
mm: memcontrol: use the node-native slab memory counters
mm: vmstat: move slab statistics from zone to node counters
mm/zswap.c: delete an error message for a failed memory allocation in zswap_dstmem_prepare()
mm/zswap.c: improve a size determination in zswap_frontswap_init()
mm/zswap.c: delete an error message for a failed memory allocation in zswap_pool_create()
mm/swapfile.c: sort swap entries before free
mm/oom_kill: count global and memory cgroup oom kills
mm: per-cgroup memory reclaim stats
mm: kmemleak: treat vm_struct as alternative reference to vmalloc'ed objects
mm: kmemleak: factor object reference updating out of scan_block()
mm: kmemleak: slightly reduce the size of some structures on 64-bit architectures
mm, mempolicy: don't check cpuset seqlock where it doesn't matter
mm, cpuset: always use seqlock when changing task's nodemask
mm, mempolicy: simplify rebinding mempolicies when updating cpusets
Pull user access str* updates from Al Viro:
"uaccess str...() dead code removal"
* 'uaccess.strlen' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
s390 keyboard.c: don't open-code strndup_user()
mips: get rid of unused __strnlen_user()
get rid of unused __strncpy_from_user() instances
kill strlen_user()
Pull dma-mapping infrastructure from Christoph Hellwig:
"This is the first pull request for the new dma-mapping subsystem
In this new subsystem we'll try to properly maintain all the generic
code related to dma-mapping, and will further consolidate arch code
into common helpers.
This pull request contains:
- removal of the DMA_ERROR_CODE macro, replacing it with calls to
->mapping_error so that the dma_map_ops instances are more self
contained and can be shared across architectures (me)
- removal of the ->set_dma_mask method, which duplicates the
->dma_capable one in terms of functionality, but requires more
duplicate code.
- various updates for the coherent dma pool and related arm code
(Vladimir)
- various smaller cleanups (me)"
* tag 'dma-mapping-4.13' of git://git.infradead.org/users/hch/dma-mapping: (56 commits)
ARM: dma-mapping: Remove traces of NOMMU code
ARM: NOMMU: Set ARM_DMA_MEM_BUFFERABLE for M-class cpus
ARM: NOMMU: Introduce dma operations for noMMU
drivers: dma-mapping: allow dma_common_mmap() for NOMMU
drivers: dma-coherent: Introduce default DMA pool
drivers: dma-coherent: Account dma_pfn_offset when used with device tree
dma: Take into account dma_pfn_offset
dma-mapping: replace dmam_alloc_noncoherent with dmam_alloc_attrs
dma-mapping: remove dmam_free_noncoherent
crypto: qat - avoid an uninitialized variable warning
au1100fb: remove a bogus dma_free_nonconsistent call
MAINTAINERS: add entry for dma mapping helpers
powerpc: merge __dma_set_mask into dma_set_mask
dma-mapping: remove the set_dma_mask method
powerpc/cell: use the dma_supported method for ops switching
powerpc/cell: clean up fixed mapping dma_ops initialization
tile: remove dma_supported and mapping_error methods
xen-swiotlb: remove xen_swiotlb_set_dma_mask
arm: implement ->dma_supported instead of ->set_dma_mask
mips/loongson64: implement ->dma_supported instead of ->set_dma_mask
A poisoned or migrated hugepage is stored as a swap entry in the page
tables. On architectures that support hugepages consisting of
contiguous page table entries (such as on arm64) this leads to ambiguity
in determining the page table entry to return in huge_pte_offset() when
a poisoned entry is encountered.
Let's remove the ambiguity by adding a size parameter to convey
additional information about the requested address. Also fixup the
definition/usage of huge_pte_offset() throughout the tree.
Link: http://lkml.kernel.org/r/20170522133604.11392-4-punit.agrawal@arm.com
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Acked-by: Steve Capper <steve.capper@arm.com>
Cc: James Hogan <james.hogan@imgtec.com> (odd fixer:METAG ARCHITECTURE)
Cc: Ralf Baechle <ralf@linux-mips.org> (supporter:MIPS)
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Add a default ioremap function which was not provided in all
circumstances. (Only when CONFIG_PCI and CONFIG_TILEGX was set).
I have designs to use them in scatterlist.c where they'd likely never be
called with this architecture, but it is needed to compile. Thus, if
the function is ever hit it returns NULL.
Link: http://lkml.kernel.org/r/1495726904-27380-1-git-send-email-logang@deltatee.com
Signed-off-by: Logan Gunthorpe <logang@deltatee.com>
Signed-off-by: Stephen Bates <sbates@raithlin.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Pull SMP hotplug updates from Thomas Gleixner:
"This update is primarily a cleanup of the CPU hotplug locking code.
The hotplug locking mechanism is an open coded RWSEM, which allows
recursive locking. The main problem with that is the recursive nature
as it evades the full lockdep coverage and hides potential deadlocks.
The rework replaces the open coded RWSEM with a percpu RWSEM and
establishes full lockdep coverage that way.
The bulk of the changes fix up recursive locking issues and address
the now fully reported potential deadlocks all over the place. Some of
these deadlocks have been observed in the RT tree, but on mainline the
probability was low enough to hide them away."
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (37 commits)
cpu/hotplug: Constify attribute_group structures
powerpc: Only obtain cpu_hotplug_lock if called by rtasd
ARM/hw_breakpoint: Fix possible recursive locking for arch_hw_breakpoint_init
cpu/hotplug: Remove unused check_for_tasks() function
perf/core: Don't release cred_guard_mutex if not taken
cpuhotplug: Link lock stacks for hotplug callbacks
acpi/processor: Prevent cpu hotplug deadlock
sched: Provide is_percpu_thread() helper
cpu/hotplug: Convert hotplug locking to percpu rwsem
s390: Prevent hotplug rwsem recursion
arm: Prevent hotplug rwsem recursion
arm64: Prevent cpu hotplug rwsem recursion
kprobes: Cure hotplug lock ordering issues
jump_label: Reorder hotplug lock and jump_label_lock
perf/tracing/cpuhotplug: Fix locking order
ACPI/processor: Use cpu_hotplug_disable() instead of get_online_cpus()
PCI: Replace the racy recursion prevention
PCI: Use cpu_hotplug_disable() instead of get_online_cpus()
perf/x86/intel: Drop get_online_cpus() in intel_snb_check_microcode()
x86/perf: Drop EXPORT of perf_check_microcode
no users left
"The main changes in this cycle were:
- Add CONFIG_REFCOUNT_FULL=y to allow the disabling of the 'full'
(robustness checked) refcount_t implementation with slightly lower
runtime overhead. (Kees Cook)
The lighter weight variant is the default. The two variants use the
same API. Having this variant was a precondition by some
maintainers to merge refcount_t cleanups.
- Add lockdep support for rtmutexes (Peter Zijlstra)
- liblockdep fixes and improvements (Sasha Levin, Ben Hutchings)
- ... misc fixes and improvements"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (30 commits)
locking/refcount: Remove the half-implemented refcount_sub() API
locking/refcount: Create unchecked atomic_t implementation
locking/rtmutex: Don't initialize lockdep when not required
locking/selftest: Add RT-mutex support
locking/selftest: Remove the bad unlock ordering test
rt_mutex: Add lockdep annotations
MAINTAINERS: Claim atomic*_t maintainership
locking/x86: Remove the unused atomic_inc_short() methd
tools/lib/lockdep: Remove private kernel headers
tools/lib/lockdep: Hide liblockdep output from test results
tools/lib/lockdep: Add dummy current_gfp_context()
tools/include: Add IS_ERR_OR_NULL to err.h
tools/lib/lockdep: Add empty __is_[module,kernel]_percpu_address
tools/lib/lockdep: Include err.h
tools/include: Add (mostly) empty include/linux/sched/mm.h
tools/lib/lockdep: Use LDFLAGS
tools/lib/lockdep: Remove double-quotes from soname
tools/lib/lockdep: Fix object file paths used in an out-of-tree build
tools/lib/lockdep: Fix compilation for 4.11
tools/lib/lockdep: Don't mix fd-based and stream IO
This extra-y is unneeded because vdso.lds is generated according to
the dependency.
The VDSO symbols can't be linked into built-in.o when building with
thin archives, so change this to linking a new object file that is
included into the built-in.o.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Build targets using if_changed(_rule) must depend on FORCE so that
they are evaluated every time.
In order to include .*.cmd files correctly, build targets added to
"targets" must not be prefixed with $(obj)/ because it is done by
scripts/Makefile.lib .
The only user of thread_saved_pc() in non-arch-specific code was removed
in commit 8243d5597793 ("sched/core: Remove pointless printout in
sched_show_task()"). Remove the implementations as well.
Some architectures use thread_saved_pc() in their arch-specific code.
Leave their thread_saved_pc() intact.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
These just duplicate the default behavior if no method is provided.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
It is completely unused and implemented only on x86.
Remove it.
Suggested-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Link: http://lkml.kernel.org/r/20170526172900.91058-1-dvyukov@google.com
The conversion of the hotplug locking to a percpu rwsem unearthed lock
ordering issues all over the place.
The jump_label code has two issues:
1) Nested get_online_cpus() invocations
2) Ordering problems vs. the cpus rwsem and the jump_label_mutex
To cure these, the following lock order has been established;
cpus_rwsem -> jump_label_lock -> text_mutex
Even if not all architectures need protection against CPU hotplug, taking
cpus_rwsem before jump_label_lock is now mandatory in code pathes which
actually modify code and therefor need text_mutex protection.
Move the get_online_cpus() invocations into the core jump label code and
establish the proper lock order where required.
Acked-by: Ingo Molnar <mingo@kernel.org>
Acked-by: "David S. Miller" <davem@davemloft.net>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Jason Baron <jbaron@akamai.com>
Link: http://lkml.kernel.org/r/20170524081549.025830817@linutronix.de
no callers, no consistent semantics, no sane way to use it...
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
This patch removes the need of subdir-y. Now all files/directories under
arch/<arch>/include/uapi/ are exported.
The only change for userland is the layout of the command 'make
headers_install_all': directories asm-<arch> are replaced by arch-<arch>/.
Those new directories contains all files/directories of the specified arch.
Note that only cris and tile have more directories than only asm:
- arch-v[10|32] for cris;
- arch for tile.
Regularly, when a new header is created in include/uapi/, the developer
forgets to add it in the corresponding Kbuild file. This error is usually
detected after the release is out.
In fact, all headers under uapi directories should be exported, thus it's
useless to have an exhaustive list.
After this patch, the following files, which were not exported, are now
exported (with make headers_install_all):
asm-arc/kvm_para.h
asm-arc/ucontext.h
asm-blackfin/shmparam.h
asm-blackfin/ucontext.h
asm-c6x/shmparam.h
asm-c6x/ucontext.h
asm-cris/kvm_para.h
asm-h8300/shmparam.h
asm-h8300/ucontext.h
asm-hexagon/shmparam.h
asm-m32r/kvm_para.h
asm-m68k/kvm_para.h
asm-m68k/shmparam.h
asm-metag/kvm_para.h
asm-metag/shmparam.h
asm-metag/ucontext.h
asm-mips/hwcap.h
asm-mips/reg.h
asm-mips/ucontext.h
asm-nios2/kvm_para.h
asm-nios2/ucontext.h
asm-openrisc/shmparam.h
asm-parisc/kvm_para.h
asm-powerpc/perf_regs.h
asm-sh/kvm_para.h
asm-sh/ucontext.h
asm-tile/shmparam.h
asm-unicore32/shmparam.h
asm-unicore32/ucontext.h
asm-x86/hwcap2.h
asm-xtensa/kvm_para.h
drm/armada_drm.h
drm/etnaviv_drm.h
drm/vgem_drm.h
linux/aspeed-lpc-ctrl.h
linux/auto_dev-ioctl.h
linux/bcache.h
linux/btrfs_tree.h
linux/can/vxcan.h
linux/cifs/cifs_mount.h
linux/coresight-stm.h
linux/cryptouser.h
linux/fsmap.h
linux/genwqe/genwqe_card.h
linux/hash_info.h
linux/kcm.h
linux/kcov.h
linux/kfd_ioctl.h
linux/lightnvm.h
linux/module.h
linux/nbd-netlink.h
linux/nilfs2_api.h
linux/nilfs2_ondisk.h
linux/nsfs.h
linux/pr.h
linux/qrtr.h
linux/rpmsg.h
linux/sched/types.h
linux/sed-opal.h
linux/smc.h
linux/smc_diag.h
linux/stm.h
linux/switchtec_ioctl.h
linux/vfio_ccw.h
linux/wil6210_uapi.h
rdma/bnxt_re-abi.h
Note that I have removed from this list the files which are generated in every
exported directories (like .install or .install.cmd).
Thanks to Julien Floret <julien.floret@6wind.com> for the tip to get all
subdirs with a pure makefile command.
For the record, note that exported files for asm directories are a mix of
files listed by:
- include/uapi/asm-generic/Kbuild.asm;
- arch/<arch>/include/uapi/asm/Kbuild;
- arch/<arch>/include/asm/Kbuild.
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Mark Salter <msalter@redhat.com>
