path: root/arch/tile
2011-12-03arch/tile: use new generic {enable,disable}_percpu_irq() routinesChris Metcalf
We provided very similar routines internally, but now we can hook into the generic framework by supplying our routines as function pointers in the irq_chip structure instead. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-12-03arch/tile: fix double-free bug in homecache_free_pages()Chris Metcalf
When freeing the page with this API, the page was "put" twice. This was only discovered bringing up an MPT fusion controller, which actually used the API; it hadn't been invoked previously, so the bug had gone unnoticed. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-12-03arch/tile: add a few #includes and an EXPORT to catch up with kernel changes.Chris Metcalf
The empty_zero_page[] export is required for ZERO_PAGE() module references. The #includes are due to changes in implicit inclusion, and should of course have been in the sources from the beginning. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-11-04Merge branch 'for-linus' of git://github.com/cmetcalf-tilera/linux-tileLinus Torvalds
* 'for-linus' of git://github.com/cmetcalf-tilera/linux-tile: arch/tile: factor out <arch/opcode.h> header arch/tile: add the <arch> headers to the set of installed kernel headers arch/tile: avoid exporting a symbol no longer used by gcc arch/tile: avoid ISO namespace pollution with <asm/sigcontext.h>
2011-11-03arch/tile: factor out <arch/opcode.h> headerChris Metcalf
The kernel code was using some <asm> headers that included a mix of hardware-specific information (typically found in Tilera <arch> headers) and structures, enums, and function declarations supporting the disassembly function of the tile-desc.c sources. This change refactors that code so that a hardware-specific, but OS- and application-agnostic header, is created: <arch/opcode.h>. This header is then exported to userspace along with the other <arch> headers and can be used to build userspace code; in particular, it is used by glibc as part of implementing the backtrace() function. The new header, together with a header that specifically describes the disassembly code (<asm/tile-desc.h> with _32 and _64 variants), replaces the old <asm/opcode-tile*.h> and <asm/opcode_constants*.h> headers. As part of this change, we are also renaming the 32-bit constants from TILE_xxx to TILEPRO_xxx to better reflect the fact that they are specific to the TILEPro architecture, and not to TILE-Gx and any successor "tile" architecture chips. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-11-03arch/tile: add the <arch> headers to the set of installed kernel headersChris Metcalf
These headers are similar to the <asm> headers that describe kernel APIs, but instead describe aspects of the actual hardware in an OS- and application-independent manner. We need to include them in the set of installed headers so that userspace tools (including glibc) can build purely from the provided kernel headers. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-11-03arch/tile: avoid exporting a symbol no longer used by gccChris Metcalf
An earlier Tilera compiler generated calls to an "__ll_mul" function for long long multiplication. Our libgcc supported that as an alias for the normal __muldi3 routine, so we made it available to kernel modules as well. However, for a while now the compiler has internally been generating only the standard __muldi3 symbol, and the version we are giving back to the community does not have the __ll_mul alias, so we are removing it from the kernel too. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-11-03arch/tile: avoid ISO namespace pollution with <asm/sigcontext.h>Chris Metcalf
<asm/sigcontext.h> is used by glibc's <bits/sigcontext.h> from <signal.h>, which means that it can't clutter the namespace with random symbols or #defines. However, we use <arch/abi.h> to get a suitable type to hold a machine register. This change makes <arch/abi.h> safe to use in this kind of context if __need_int_reg_t is defined prior to including the file; in that case, it only defines a few symbols that are safe in the ISO namespace (prefixed with double underscores). <asm/sigcontext.h> then uses the __uint_reg_t type instead of the normal uint_reg_t. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-10-26Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) time, s390: Get rid of compile warning dw_apb_timer: constify clocksource name time: Cleanup old CONFIG_GENERIC_TIME references that snuck in time: Change jiffies_to_clock_t() argument type to unsigned long alarmtimers: Fix error handling clocksource: Make watchdog reset lockless posix-cpu-timers: Cure SMP accounting oddities s390: Use direct ktime path for s390 clockevent device clockevents: Add direct ktime programming function clockevents: Make minimum delay adjustments configurable nohz: Remove "Switched to NOHz mode" debugging messages proc: Consider NO_HZ when printing idle and iowait times nohz: Make idle/iowait counter update conditional nohz: Fix update_ts_time_stat idle accounting cputime: Clean up cputime_to_usecs and usecs_to_cputime macros alarmtimers: Rework RTC device selection using class interface alarmtimers: Add try_to_cancel functionality alarmtimers: Add more refined alarm state tracking alarmtimers: Remove period from alarm structure alarmtimers: Remove interval cap limit hack ...
2011-10-13tile: revert change from <asm/atomic.h> to <linux/atomic.h> in asm filesChris Metcalf
The 32-bit TILEPro support uses some #defines in <asm/atomic_32.h> for atomic support routines in assembly. To make this more explicit, I've turned those includes into includes of <asm/atomic_32.h>, which should hopefully make it clear that they shouldn't be bombed into <linux/atomic.h> in any cleanups. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-10-04time: Cleanup old CONFIG_GENERIC_TIME references that snuck inJohn Stultz
Awhile back I removed all the CONFIG_GENERIC_TIME referecnes as the last of the non-GENERIC_TIME arches were converted. However, due to the functionality being important and around for awhile, there apparently were some out of tree hardware enablement patches that used it and have since been merged. This patch removes the remaining instances of GENERIC_TIME. Singed-off-by: John Stultz <john.stultz@linaro.org>
2011-08-03Merge branch 'apei-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'apei-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI, APEI, EINJ Param support is disabled by default APEI GHES: 32-bit buildfix ACPI: APEI build fix ACPI, APEI, GHES: Add hardware memory error recovery support HWPoison: add memory_failure_queue() ACPI, APEI, GHES, Error records content based throttle ACPI, APEI, GHES, printk support for recoverable error via NMI lib, Make gen_pool memory allocator lockless lib, Add lock-less NULL terminated single list Add Kconfig option ARCH_HAVE_NMI_SAFE_CMPXCHG ACPI, APEI, Add WHEA _OSC support ACPI, APEI, Add APEI bit support in generic _OSC call ACPI, APEI, GHES, Support disable GHES at boot time ACPI, APEI, GHES, Prevent GHES to be built as module ACPI, APEI, Use apei_exec_run_optional in APEI EINJ and ERST ACPI, APEI, Add apei_exec_run_optional ACPI, APEI, GHES, Do not ratelimit fatal error printk before panic ACPI, APEI, ERST, Fix erst-dbg long record reading issue ACPI, APEI, ERST, Prevent erst_dbg from loading if ERST is disabled
2011-08-03Merge branch 'apei' into apei-releaseLen Brown
Some trivial conflicts due to other various merges adding to the end of common lists sooner than this one. arch/ia64/Kconfig arch/powerpc/Kconfig arch/x86/Kconfig lib/Kconfig lib/Makefile Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-03Add Kconfig option ARCH_HAVE_NMI_SAFE_CMPXCHGHuang Ying
cmpxchg() is widely used by lockless code, including NMI-safe lockless code. But on some architectures, the cmpxchg() implementation is not NMI-safe, on these architectures the lockless code may need a spin_trylock_irqsave() based implementation. This patch adds a Kconfig option: ARCH_HAVE_NMI_SAFE_CMPXCHG, so that NMI-safe lockless code can depend on it or provide different implementation according to it. On many architectures, cmpxchg is only NMI-safe for several specific operand sizes. So, ARCH_HAVE_NMI_SAFE_CMPXCHG define in this patch only guarantees cmpxchg is NMI-safe for sizeof(unsigned long). Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Richard Henderson <rth@twiddle.net> CC: Mikael Starvik <starvik@axis.com> Acked-by: David Howells <dhowells@redhat.com> CC: Yoshinori Sato <ysato@users.sourceforge.jp> CC: Tony Luck <tony.luck@intel.com> CC: Hirokazu Takata <takata@linux-m32r.org> CC: Geert Uytterhoeven <geert@linux-m68k.org> CC: Michal Simek <monstr@monstr.eu> Acked-by: Ralf Baechle <ralf@linux-mips.org> CC: Kyle McMartin <kyle@mcmartin.ca> CC: Martin Schwidefsky <schwidefsky@de.ibm.com> CC: Chen Liqin <liqin.chen@sunplusct.com> CC: "David S. Miller" <davem@davemloft.net> CC: Ingo Molnar <mingo@redhat.com> CC: Chris Zankel <chris@zankel.net> Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile/mm/init.c: trivial: use BUG_ON arch/tile: remove useless set_fixmap_nocache() macro arch/tile: add hypervisor-based character driver for SPI flash ROM ioctl-number.txt: add the tile hardwall ioctl range tile: use generic-y format for one-line asm-generic headers clocksource: tile: convert to use clocksource_register_hz
2011-08-02arch/tile/mm/init.c: trivial: use BUG_ONJulia Lawall
Use BUG_ON(x) rather than if(x) BUG(); The semantic patch that fixes this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier x; @@ -if (x) BUG(); +BUG_ON(x); @@ identifier x; @@ -if (!x) BUG(); +BUG_ON(!x); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-08-02Merge tag 'v3.0' of ↵Chris Metcalf
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic: add another generic ext2 atomic bitopsAkinobu Mita
The majority of architectures implement ext2 atomic bitops as test_and_{set,clear}_bit() without spinlock. This adds this type of generic implementation in ext2-atomic-setbit.h and use it wherever possible. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Suggested-by: Andreas Dilger <adilger@dilger.ca> Suggested-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-3.1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.1' of git://linux-nfs.org/~bfields/linux: nfsd: don't break lease on CLAIM_DELEGATE_CUR locks: rename lock-manager ops nfsd4: update nfsv4.1 implementation notes nfsd: turn on reply cache for NFSv4 nfsd4: call nfsd4_release_compoundargs from pc_release nfsd41: Deny new lock before RECLAIM_COMPLETE done fs: locks: remove init_once nfsd41: check the size of request nfsd41: error out when client sets maxreq_sz or maxresp_sz too small nfsd4: fix file leak on open_downgrade nfsd4: remember to put RW access on stateid destruction NFSD: Added TEST_STATEID operation NFSD: added FREE_STATEID operation svcrpc: fix list-corrupting race on nfsd shutdown rpc: allow autoloading of gss mechanisms svcauth_unix.c: quiet sparse noise svcsock.c: include sunrpc.h to quiet sparse noise nfsd: Remove deprecated nfsctl system call and related code. NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-23virtio: expose for non-virtualization users tooOhad Ben-Cohen
virtio has been so far used only in the context of virtualization, and the virtio Kconfig was sourced directly by the relevant arch Kconfigs when VIRTUALIZATION was selected. Now that we start using virtio for inter-processor communications, we need to source the virtio Kconfig outside of the virtualization scope too. Moreover, some architectures might use virtio for both virtualization and inter-processor communications, so directly sourcing virtio might yield unexpected results due to conflicting selections. The simple solution offered by this patch is to always source virtio's Kconfig in drivers/Kconfig, and remove it from the appropriate arch Kconfigs. Additionally, a virtio menu entry has been added so virtio drivers don't show up in the general drivers menu. This way anyone can use virtio, though it's arguably less accessible (and neat!) for virtualization users now. Note: some architectures (mips and sh) seem to have a VIRTUALIZATION menu merely for sourcing virtio's Kconfig, so that menu is removed too. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-15nfsd: Remove deprecated nfsctl system call and related code.NeilBrown
As promised in feature-removal-schedule.txt it is time to remove the nfsctl system call. Userspace has perferred to not use this call throughout 2.6 and it has been excluded in the default configuration since 2.6.36 (9 months ago). So this patch removes all the code that was being compiled out. There are still references to sys_nfsctl in various arch systemcall tables and related code. These should be cleaned out too, probably in the next merge window. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-06-27Fix node_start/end_pfn() definition for mm/page_cgroup.cKAMEZAWA Hiroyuki
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end of nodes. But, it's not defined in linux/mmzone.h but defined in /arch/???/include/mmzone.h which is included only under CONFIG_NEED_MULTIPLE_NODES=y. Then, we see mm/page_cgroup.c: In function 'page_cgroup_init': mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn' mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn' So, fixiing page_cgroup.c is an idea... But node_start_pfn()/node_end_pfn() is a very generic macro and should be implemented in the same manner for all archs. (m32r has different implementation...) This patch removes definitions of node_start/end_pfn() in each archs and defines a unified one in linux/mmzone.h. It's not under CONFIG_NEED_MULTIPLE_NODES, now. A result of macro expansion is here (mm/page_cgroup.c) for !NUMA start_pfn = ((&contig_page_data)->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); for NUMA (x86-64) start_pfn = ((node_data[nid])->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); Changelog: - fixed to avoid using "nid" twice in node_end_pfn() macro. Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-and-tested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15arch/tile: remove useless set_fixmap_nocache() macroChris Metcalf
TILE doesn't support PAGE_KERNEL_NOCACHE so the macro isn't useful; it's a copy-and-paste from the first version of this header in 2007. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-06-10arch/tile: add hypervisor-based character driver for SPI flash ROMChris Metcalf
The first version of this patch proposed an arch/tile/drivers/ directory, but the consensus was that this was probably a poor choice for a place to group Tilera-specific drivers, and that in any case grouping by platform was discouraged, and grouping by function was preferred. This version of the patch addresses various issues raised in the community, primarily the absence of sysfs integration. The sysfs integration now handles passing information on sector size, page size, and total partition size to userspace as well. In addition, we now use a single "struct cdev" to manage all the partition minor devices, and dynamically discover the correct number of partitions from the hypervisor rather than using a module_param with a default value. This driver has no particular "peer" drivers it can be grouped with. It is sort of like an MTD driver for SPI ROM, but it doesn't group well with the other MTD devices since it relies on hypervisor virtualization to handle many of the irritating aspects of flash ROM management: sector awareness, background read for sub-sector writes, bit examination to determine whether a sector erase needs to be issued, etc. It is in fact more like an EEPROM driver, but the hypervisor virtualization does require a "flush" command if you wish to commit a sector write prior to writing to a different sector, and this is sufficiently different from generic I2C/SPI EEPROMs that as a result it doesn't group well with them either. The simple character device is already in use by a range of Tilera SPI ROM management tools, as well as by customers. In addition, using the simple character device actually simplifies the userspace tools, since they don't need to manage sector erase, background read, etc. This both simplifies the code (since we can uniformly manage plain files and the SPI ROM) as well as makes the user code portable to non-Linux platforms that don't offer the same MTD ioctls. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-03tile: use generic-y format for one-line asm-generic headersChris Metcalf
This lets us remove a lot of one-line wrapper header files. See commit d8ecc5cd8e227bc318513b5306ae88a474b8886d for context. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-06-03clocksource: tile: convert to use clocksource_register_hzJohn Stultz
Convert tile to use clocksource_register_hz. CC: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: more /proc and /sys file support
2011-05-27arch/tile: more /proc and /sys file supportChris Metcalf
This change introduces a few of the less controversial /proc and /proc/sys interfaces for tile, along with sysfs attributes for various things that were originally proposed as /proc/tile files. It also adjusts the "hardwall" proc API. Arnd Bergmann reviewed the initial arch/tile submission, which included a complete set of all the /proc/tile and /proc/sys/tile knobs that we had added in a somewhat ad hoc way during initial development, and provided feedback on where most of them should go. One knob turned out to be similar enough to the existing /proc/sys/debug/exception-trace that it was re-implemented to use that model instead. Another knob was /proc/tile/grid, which reported the "grid" dimensions of a tile chip (e.g. 8x8 processors = 64-core chip). Arnd suggested looking at sysfs for that, so this change moves that information to a pair of sysfs attributes (chip_width and chip_height) in the /sys/devices/system/cpu directory. We also put the "chip_serial" and "chip_revision" information from our old /proc/tile/board file as attributes in /sys/devices/system/cpu. Other information collected via hypervisor APIs is now placed in /sys/hypervisor. We create a /sys/hypervisor/type file (holding the constant string "tilera") to be parallel with the Xen use of /sys/hypervisor/type holding "xen". We create three top-level files, "version" (the hypervisor's own version), "config_version" (the version of the configuration file), and "hvconfig" (the contents of the configuration file). The remaining information from our old /proc/tile/board and /proc/tile/switch files becomes an attribute group appearing under /sys/hypervisor/board/. Finally, after some feedback from Arnd Bergmann for the previous version of this patch, the /proc/tile/hardwall file is split up into two conceptual parts. First, a directory /proc/tile/hardwall/ which contains one file per active hardwall, each file named after the hardwall's ID and holding a cpulist that says which cpus are enclosed by the hardwall. Second, a /proc/PID file "hardwall" that is either empty (for non-hardwall-using processes) or contains the hardwall ID. Finally, this change pushes the /proc/sys/tile/unaligned_fixup/ directory, with knobs controlling the kernel code for handling the fixup of unaligned exceptions. Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits) arch/tile: prefer "tilepro" as the name of the 32-bit architecture compat: include aio_abi.h for aio_context_t arch/tile: cleanups for tilegx compat mode arch/tile: allocate PCI IRQs later in boot arch/tile: support signal "exception-trace" hook arch/tile: use better definitions of xchg() and cmpxchg() include/linux/compat.h: coding-style fixes tile: add an RTC driver for the Tilera hypervisor arch/tile: finish enabling support for TILE-Gx 64-bit chip compat: fixes to allow working with tile arch arch/tile: update defconfig file to something more useful tile: do_hardwall_trap: do not play with task->sighand tile: replace mm->cpu_vm_mask with mm_cpumask() tile,mn10300: add device parameter to dma_cache_sync() audit: support the "standard" <asm-generic/unistd.h> arch/tile: clarify flush_buffer()/finv_buffer() function names arch/tile: kernel-related cleanups from removing static page size arch/tile: various header improvements for building drivers arch/tile: disable GX prefetcher during cache flush arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD ...
2011-05-25arch/tile: prefer "tilepro" as the name of the 32-bit architectureChris Metcalf
With this change, you can (and should) build with ARCH=tilepro for the current 32-bit chips. Building with ARCH=tile continues to work, but we've renamed the defconfig file to tilepro_defconfig for consistency. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-25lib: consolidate DEBUG_STACK_USAGE optionStephen Boyd
Most arches define CONFIG_DEBUG_STACK_USAGE exactly the same way. Move it to lib/Kconfig.debug so each arch doesn't have to define it. This obviously makes the option generic, but that's fine because the config is already used in generic code. It's not obvious to me that sysrq-P actually does anything caution by keeping the most inclusive wording. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
2011-05-24Merge branch 'fixes-2.6.39' into for-2.6.40Tejun Heo
2011-05-19arch/tile: cleanups for tilegx compat modeChris Metcalf
These changes make the syscall table line up correctly for tilegx compat mode, and remove the stale sys32_fadvise64() function, which isn't actually used by any syscall table. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-19arch/tile: allocate PCI IRQs later in bootChris Metcalf
This change became required due to some recent reworking in the platform-independent IRQ code. It is required for 2.6.38 and later. Cc: stable@kernel.org Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-19arch/tile: support signal "exception-trace" hookChris Metcalf
This change adds support for /proc/sys/debug/exception-trace to tile. Like x86 and sparc, by default it is set to "1", generating a one-line printk whenever a user process crashes. By setting it to "2", we get a much more complete userspace diagnostic at crash time, including a user-space backtrace, register dump, and memory dump around the address of the crash. Some vestiges of the Tilera-internal version of this support are removed with this patch (the show_crashinfo variable and the arch_coredump_signal function). We retain a "crashinfo" boot parameter which allows you to set the boot-time value of exception-trace. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-19arch/tile: use better definitions of xchg() and cmpxchg()Chris Metcalf
These definitions use a ({}) construct to avoid some cases where we were getting warnings about unused return values. We also promote the definition to the common <asm/atomic.h>, since it applies to both the 32- and 64-bit atomics. In addition, define __HAVE_ARCH_CMPXCHG for TILE-Gx since it has efficient direct atomic instructions. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-17tile: add an RTC driver for the Tilera hypervisorChris Metcalf
This is a simple RTC driver that lets Tilera hardware boot up and set the clock correctly. Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
