path: root/arch/um/drivers/cow_sys.h
2007-07-16uml: Eliminate kernel allocator wrappersJeff Dike
UML had two wrapper procedures for kmalloc, um_kmalloc and um_kmalloc_atomic because the flag constants weren't available in userspace code. kern_constants.h had made kernel constants available for a long time, so there is no need for these wrappers any more. Rather, userspace code calls kmalloc directly with the userspace versions of the gfp flags. kmalloc isn't a real procedure, so I had to essentially copy the inline wrapper around __kmalloc. vmalloc also had its own wrapper for no good reason. This is now gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: rename os_{read_write}_file_k back to os_{read_write}_fileJeff Dike
Rename os_{read_write}_file_k back to os_{read_write}_file, delete the originals and their bogus infrastructure, and fix all the callers. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: formatting fixes around os_{read_write}_file callersJeff Dike
Formatting fixes ahead of renaming os_{read_write}_file_k to os_{read_write}_file and fixing all the callers. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: change remaining callers of os_{read_write}_fileJeff Dike
Convert all remaining os_{read_write}_file users to use the simple {read,write} wrappers, os_{read_write}_file_k. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove user_util.hJeff Dike
user_util.h isn't needed any more, so delete it and remove all includes of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] uml: split memory allocation prototypes out of user.hPaolo 'Blaisorblade' Giarrusso
user.h is too generic a header name. I've split out allocation routines from it. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] uml: avoid warnings for diffent names for an unsigned quadwordPaolo 'Blaisorblade' Giarrusso
Since on some 64-bit systems __u64 is rightfully defined to unsigned long and GCC recognizes anyway unsigned long and unsigned long long as different, fix some types back to being unsigned long long to avoid warnings and errors (for prototype mismatch) on those systems. Thanks to the report by Wesley Emeneker wesleyemeneker (at) google (dot) com Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] uml: tidying COW codePaolo 'Blaisorblade' Giarrusso
Improve (especially for coherence) some prototypes, and return code of init_cow_file in error case - for a short write return -EINVAL, otherwise return the error we got! Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] uml: correct error messages in COW driverPaolo 'Blaisorblade' Giarrusso
Improve some error messages in the COW driver, and say V3, not V2, when talking about V3 format. Also resync with our userspace code utility a bit more. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
