Signed-off-by: Richard Weinberger <richard@nod.at>
Reintroduce uml_kmalloc for the benefit of UML libc code. The
previous tactic of declaring __kmalloc so it could be called directly
from the libc side of the house turned out to be getting too intimate
with slab, and it doesn't work with slob.
So, the uml_kmalloc wrapper is back. It calls kmalloc or whatever
that translates into, and libc code calls it.
kfree is left alone since that still works, leaving a somewhat
inconsistent API.
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Style fixes for the rest of the drivers. arch/um/drivers should be pretty
CodingStyle-compliant now.
Except for the ubd driver, which will have to be treated separately.
This does a lot of cleanup on the UML console system. This patch should be
entirely non-functional.
The tidying is as follows:
header cleanups - the includes should be closer to minimal and complete
all printks now have a severity
lots of style fixes
fd_close is restructured a little in order to reduce the nesting
some functions were calling the os_* wrappers when they can
call libc directly
port_accept had a unnecessary variable
it also tested a pid unecessarily before killing it
some functions were made static
xterm_free is gone, as it was identical to generic_free
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
UML had two wrapper procedures for kmalloc, um_kmalloc and um_kmalloc_atomic
because the flag constants weren't available in userspace code.
kern_constants.h had made kernel constants available for a long time, so there
is no need for these wrappers any more. Rather, userspace code calls kmalloc
directly with the userspace versions of the gfp flags.
kmalloc isn't a real procedure, so I had to essentially copy the inline
wrapper around __kmalloc.
vmalloc also had its own wrapper for no good reason. This is now gone.
user_util.h isn't needed any more, so delete it and remove all includes of it.
user.h is too generic a header name. I've split out allocation routines from
it.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Jeff Dike <jdike@addtoit.com>
Make lots of structures const in order to make it obvious that they need no
locking.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
The serial UML OS-abstraction layer patch (um/kernel dir).
This moves all systemcalls from user_util.c file under os-Linux dir
Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com>
We were using a long series of (stupid) wrappers which all call
generic_console_write(). Since the wrappers only change the 4th param, which
is unused by the called proc, remove them and call generic_console_write()
directly.
If needed at any time in the future to reintroduce this stuff, the member
could be moved to a generic struct, to avoid this duplicated handling.
Acked-by: Jeff Dike <jdike@addtoit.com>
infrastructure for it.
Let it rip!
