path: root/arch/um/drivers/hostaudio_kern.c
2008-05-13uml: fix errno returnJohann Felix Soden
Error returns are negative. Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: arch/um/drivers formattingJeff Dike
Style fixes for the rest of the drivers. arch/um/drivers should be pretty CodingStyle-compliant now. Except for the ubd driver, which will have to be treated separately. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: rename os_{read_write}_file_k back to os_{read_write}_fileJeff Dike
Rename os_{read_write}_file_k back to os_{read_write}_file, delete the originals and their bogus infrastructure, and fix all the callers. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: start fixing os_read_file and os_write_fileJeff Dike
This patch starts the removal of a very old, very broken piece of code. This stems from the problem of passing a userspace buffer into read() or write() on the host. If that buffer had not yet been faulted in, read and write will return -EFAULT. To avoid this problem, the solution was to fault the buffer in before the system call by touching the pages that hold the buffer by doing a copy-user of a byte to each page. This is obviously bogus, but it does usually work, in tt mode, since the kernel and process are in the same address space and userspace addresses can be accessed directly in the kernel. In skas mode, where the kernel and process are in separate address spaces, it is completely bogus because the userspace address, which is invalid in the kernel, is passed into the system call instead of the corresponding physical address, which would be valid. Here, it appears that this code, on every host read() or write(), tries to fault in a random process page. This doesn't seem to cause any correctness problems, but there is a performance impact. This patch, and the ones following, result in a 10-15% performance gain on a kernel build. This code can't be immediately tossed out because when it is, you can't log in. Apparently, there is some code in the console driver which depends on this somehow. However, we can start removing it by switching the code which does I/O using kernel addresses to using plain read() and write(). This patch introduces os_read_file_k and os_write_file_k for use with kernel buffers and converts all call locations which use obvious kernel buffers to use them. These include I/O using buffers which are local variables which are on the stack or kmalloc-ed. Later patches will handle the less obvious cases, followed by a mass conversion back to the original interface. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: audio driver formattingJeff Dike
Whitespace and style fixes. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: audio driver lockingJeff Dike
Comment the lack of locking and make a couple of variables static. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-27[PATCH] uml: const more dataJeff Dike
Make lots of structures const in order to make it obvious that they need no locking. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] uml: sparse cleanupsAl Viro
misc sparse annotations Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] uml: update module interfaceDominik Hackl
This patch replaces the deprecated MODULE_PARM function by the new module_param function. Signed-off-by: Dominik Hackl <dominik@hackl.dhs.org> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
