path: root/arch/um/drivers/line.c
2008-05-08uml: fix inconsistence due to tty_operation changeWANG Cong
'put_char' of 'struct tty_operations' has changed from 'void' into 'int'. This can also shut up compiler warnings. Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: WANG Cong <wangcong@zeuux.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28uml: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: DEBUG_SHIRQ fixesJeff Dike
A couple more DEBUG_SHIRQ fixes. The previous mconsole blocking fix exposed the lack of O_NONBLOCK on the mconsole socket. Also, winch_interrupt started crashing because it is called at irq free time and it tries to dereference tty->driver_data, which has already been set to NULL. I added some error cleanup in mconsole_init while I was there. Cc: "Karol Swietlicki" <magotari@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: tidy kern_util.hJeff Dike
Tidy kern_util.h. It turns out that most of the function declarations aren't used, so they can go away. os.h no longer includes kern_util.h, so files which got it through os.h now need to include it directly. A number of other files never needed it, so these includes are deleted. The structure which was used to pass signal handlers from the kernel side to the userspace side is gone. Instead, the handlers are declared here, and used directly from libc code. This allows arch/um/os-Linux/trap.c to be deleted, with its remnants being moved to arch/um/os-Linux/skas/trap.c. arch/um/os-Linux/tty.c had its inclusions changed, and it needed some style attention, so it got tidied. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: console driver cleanupsJeff Dike
Console driver cleanups - Changed an instance of foo = bar + foo to foo += bar Removed checks of tty->stopped - I don't think the low-level driver has any business looking at that Removed an annoying warning Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20spelling fixes: arch/um/Simon Arlott
Spelling fixes in arch/um/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16uml: console tidyingJeff Dike
Tidy line.c: The includes are more minimal Lots of style fixes All the printks have severities Removed some commented-out code Deleted a useless printk when ioctl is called Fixed some whitespace damage Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: fix console writing bugsJeff Dike
The previous console cleanup patch switched generic_read and generic_write from calling os_{read,write}_file to calling read and write directly. Because the calling convention is different, they now need to get any error from errno rather than the return value. I did this for generic_read, but forgot about generic_write. While chasing some output corruption, I noticed that line_write was unnecessarily calling flush_buffer, and deleted it. I don't understand why, but the corruption disappeared. This is unneeded because there already is a perfectly good mechanism for finding out when the host output device has some room to write data - there is an interrupt that comes in when writes can happen again. line_write calling flush_buffer seemed to just be an attempt to opportunistically get some data out to the host. I also made write_chan short-circuit calling into the host-level code for zero-length writes. Calling libc write with a length of zero conflated write not being able to write anything with asking it not to write anything. Better to just cut it off as soon as possible. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16uml: SIGIO support cleanupJeff Dike
Cleanup of the SIGWINCH support. Some code and comment reformatting. The stack used for SIGWINCH threads was leaked. This is now fixed by storing it with the pid and other information, and freeing it when the thread is killed. If something goes wrong with a WIGWINCH thread, and this is discovered in the interrupt handler, the winch record would leak. It is now freed, except that the IRQ isn't freed. This is hard to do from interrupt context. This has the side-effect that the IRQ system maintains a reference to the freed structure, but that shouldn't cause a problem since the descriptor is disabled. register_winch_irq is now much better about cleaning up after an initialization failure. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16uml: handle errors on opening host side of consolesJeff Dike
If the host side of a console can't be opened, this will now produce visible error messages. enable_chan now returns a status and this is passed up to con_open and ssl_open, which will complain if anything went wrong. The default host device for the serial line driver is now a pts device rather than a pty device since lots of hosts have LEGACY_PTYS disabled. This had always been failing on such hosts, but silently. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08uml: get declaration of simple_strtoulJeff Dike
Include linux/kernel.h wherever simple_strtoul is used. This kills a compile warning in stderr_console.c and potential ones in the other files. This also fixes a bunch of style violations in exitcode.c. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove user_util.hJeff Dike
user_util.h isn't needed any more, so delete it and remove all includes of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] um: fix confusion irq early reenablingPaolo 'Blaisorblade' Giarrusso
Fix confusion about call context - comments and code are inconsistent and plain wrong, my fault. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] tty: update the tty layer to work with struct pidEric W. Biederman
Of kernel subsystems that work with pids the tty layer is probably the largest consumer. But it has the nice virtue that the assiation with a session only lasts until the session leader exits. Which means that no reference counting is required. So using struct pid winds up being a simple optimization to avoid hash table lookups. In the long term the use of pid_nr also ensures that when we have multiple pid spaces mixed everything will work correctly. Signed-off-by: Eric W. Biederman <eric@maxwell.lnxi.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: fix previous console lockingJeff Dike
Eliminate the open_mutex after complaints from Blaisorblade. It turns out that the tty count provides the information needed to tell whether we are the first opener or last closer. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: console locking commentary and code cleanupJeff Dike
Remove the last vestiges of devfs from console registration. Change the name of the function, plus remove a couple of unused fields from the line_driver structure. struct lines is no longer needed, all traces of it are gone. The only way that I can see to mark a structure as being almost-const is to individually const the fields. This is the case for the line_driver structure, which has only one modifiable field - a list_head in a sub-structure. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: return hotplug errors to hostJeff Dike
I noticed that errors happening while hotplugging devices from the host were never returned back to the mconsole client. In some cases, success was returned instead of even an information-free error. This patch cleans that up by having the low-level configuration code pass back an error string along with an error code. At the top level, which knows whether it is early boot time or responding to an mconsole request, the string is printk'd or returned to the mconsole client. There are also whitespace and trivial code cleanups in the surrounding code. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: console locking fixesJeff Dike
Clean up the console driver locking. There are various problems here, including sleeping under a spinlock and spinlock recursion, some of which are fixed here. This patch deals with the locking involved with opens and closes. The problem is that an mconsole request to change a console's configuration can race with an open. Changing a configuration should only be done when a console isn't opened. Also, an open must be looking at a stable configuration. In addition, a get configuration request must observe the same locking since it must also see a stable configuration. With the old locking, it was possible for this to hang indefinitely in some cases because open would block for a long time waiting for a connection from the host while holding the lock needed by the mconsole request. As explained in the long comment, this is fixed by adding a spinlock for the use count and configuration and a mutex for the actual open and close. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] uml: workqueue build fixAndrew Morton
arch/um/drivers/chan_kern.c:643: error: conflicting types for 'chan_interrupt' arch/um/include/chan_kern.h:31: error: previous declaration of 'chan_interrupt' Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-08[PATCH] uml pt_regs fixesAl Viro
Real fix for UML pt_regs stuff. Note set_irq_regs() logics in there... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Attack of "the the"s in archMatt LaPlante
The patch below corrects multiple occurances of "the the" typos across several files, both in source comments and KConfig files. There is no actual code changed, only text. Note this only affects the /arch directory, and I believe I could find many more elsewhere. :) Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: const more dataJeff Dike
Make lots of structures const in order to make it obvious that they need no locking. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: UM: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Remove the line_driver devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the devfs_fs_kernel.h file from the treeGreg Kroah-Hartman
Also fixes up all files that #include it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-01[PATCH] uml: some harmless sparse warning fixesPaolo 'Blaisorblade' Giarrusso
Fix some simple sparse warnings - a lot more staticness and a misplaced __user. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: SIGWINCH handling cleanupJeff Dike
Code cleanup - unregister_winch and winch_cleanup had some duplicate code. This is now abstracted out into free_winch. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: umid cleanupJeff Dike
This patch cleans up the umid code: - The only_if_set argument to get_umid is gone. - get_umid returns an empty string rather than NULL if there is no umid. - umid_is_random is gone since its users went away. - Some printfs were turned into printks because the code runs late enough that printk is working. - Error paths were cleaned up. - Some functions now return an error and let the caller print the error message rather than printing it themselves. This eliminates the practice of passing a pointer to printf or printk in, depending on where in the boot process we are. - Major tidying of not_dead_yet - mostly error path cleanup, plus a comment explaining why it doesn't react to errors the way you might expect. - Calls to os_* interfaces that were moved under os are changed back to their native libc forms. - snprintf, strlcpy, and their bounds-checking friends are used more often, replacing by-hand bounds checking in some places. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: Add throttling to console driverJeff Dike
This patch adds support for throttling and unthrottling input when the tty driver can't handle it. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: Simplify console opening/closing and irq registrationJeff Dike
This patch simplifies the opening and closing of host console devices and the registration and deregistration of IRQs. The intent is to make it obvious that an IRQ can't exist without an open file descriptor. chan_enable will now open the channel, and when both opening and IRQ registration are desired, this should be used. Opening only is done for the initial console, so that interface still needs to exist. The free_irqs_later interface is now gone. It was intended to avoid freeing an IRQ while it was being processed. It did this, but it didn't eliminate the possiblity of free_irq being called from an interrupt, which is bad. In its place is a list of irqs to be freed, which is processed by the signal handler just before exiting. close_one_chan now disables irqs. When a host device disappears, it is just closed, and that disables IRQs. The device id registered with the IRQ is now the chan structure, not the tty. This is because the interrupt arrives on a descriptor associated with the channel. This caused equivalent changes in the arguments to line_timer_cb. line_disable is gone since it is not used any more. The count field in the line structure is gone. tty->count is used instead. The complicated logic in sigio_handler with freeing IRQs when necessary and making sure its idea of the next irq is correct is now much simpler. The irq list can't be rearranged underneath it, so it is now a simple list walk. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: move console configurationJeff Dike
This patch changes when console devices are configured in order to prepare the ground for the next patch. parse_chan_pair is now done earlier, when initcalls are run, rather than when the device is opened. When a host device disappears, the channel list is closed, but not freed. This is required by the previous change. line_config now takes the options structure as an argument, and line_open doesn't. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: line_setup interface changeJeff Dike
line_setup is changed to return the device which it set up, rather than just success or failure. This will be important in the line-config patch. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: Add static initializations and declarationsJeff Dike
Some structure fields were being dynamically initialized when they could be initialized at compile-time instead. This also makes some declarations static (in the C sense). Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: Move mconsole support out of generic codeJeff Dike
A bit of restructuring which eliminates the all_allowed argument (which is mconsole-specific) to line_setup. That logic is moved to the mconsole callback. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: Remove unneeded structure fieldJeff Dike
This removes a structure field which turned out to be pointless, and references to it. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: Formatting changesJeff Dike
This patch makes a bunch of non-functional changes - return(foo); becomes return foo; some statements are broken across lines for readability some trailing whitespace is cleaned up open_one_chan took four arguments, three of which could be deduced from the first. Accordingly, they were eliminated. some examples of "} else {" had a newline added some whitespace cleanup in the indentation lines_init got some control flow cleanup some long lines were broken removed another emacs-specific C formatting comment Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: use kstrdupJeff Dike
There were a bunch of calls to uml_strdup dating from before kstrdup was introduced. This changes those calls. It doesn't eliminate the definition since there is still a couple of calls in userspace code (which should probably call the libc strdup). Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] uml: remove winch semPaolo 'Blaisorblade' Giarrusso
Replace a semaphore (winch_handler_sem) used in atomic code with a spinlock, and reduces as needed the amount of protected code to the bare minimum (for instance no kmalloc calls are needed). This fixes the last problems with spinlocking (in UP mode with DEBUG options); the semaphore, taken inside spinlocks, caused a "spin_lock was already locked" warning, without this patch. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] uml: hot-unplug code cleanupJeff Dike
Clean up the hot-unplugging code. There is now an id procedure which is called to figure out what device we're talking to. The error messages from that are now done from mconsole_remove instead of the driver. remove is now called with the device number, after it has been checked, so doesn't need to do sanity checking on it. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] uml: complete hw_controller_type->release conversionPaolo 'Blaisorblade' Giarrusso
This occurrence of free_irq_by_irq_and_dev() was missed when converting UML to the use of hw_controller_type->release. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] uml: add and use generic hw_controller_type->releasePaolo 'Blaisorblade' Giarrusso
With Chris Wedgwood <cw@f00f.org> Currently UML must explicitly call the UML-specific free_irq_by_irq_and_dev() for each free_irq call it's done. This is needed because ->shutdown and/or ->disable are only called when the last "action" for that irq is removed. Instead, for UML shared IRQs (UML IRQs are very often, if not always, shared), for each dev_id some setup is done, which must be cleared on the release of that fd. For instance, for each open console a new instance (i.e. new dev_id) of the same IRQ is requested(). Exactly, a fd is stored in an array (pollfds), which is after read by a host thread and passed to poll(). Each event registered by poll() triggers an interrupt. So, for each free_irq() we must remove the corresponding host fd from the table, which we do via this -release() method. In this patch we add an appropriate hook for this, and remove all uses of it by pointing the hook to the said procedure; this is safe to do since the said procedure. Also some cosmetic improvements are included. This is heavily based on some work by Chris Wedgwood, which however didn't get the patch merged for something I'd call a "misunderstanding" (the need for this patch wasn't cleanly explained, thus adding the generic hook was felt as undesirable). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> CC: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: Fix SIGWINCH relayingJeff Dike
This makes SIGWINCH work again, and fixes a couple of SIGWINCH-associated crashes. First, the sigio thread disables SIGWINCH because all hell breaks loose if it ever gets one and tries to call the signal handling code. Second, there was a problem with deferencing tty structs after they were freed. The SIGWINCH support for a tty wasn't being turned off or freed after the tty went away. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] uml: redo console lockingPaolo 'Blaisorblade' Giarrusso
Fix some console locking problems (including scheduling in atomic) and various reorderings and cleanup in that code. Not yet ready for 2.6.12 probably. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
