path: root/arch/um/drivers/pcap_user.c
2008-05-21missed kmalloc() in pcap_user.cAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: network driver MTU cleanupsJeff Dike
A bunch of MTU-related cleanups in the network code. First, there is the addition of the notion of a maximally-sized packet, which is the MTU plus headers. This is used to size the skb that will receive a packet. This allows ether_adjust_skb to go away, as it was used to resize the skb after it was allocated. Since the skb passed into the low-level read routine is no longer resized, and possibly reallocated, there, they (and the write routines) don't need to get an sk_buff **. They just need the sk_buff * now. The callers of ether_adjust_skb still need to do the skb_put, so that's now inlined. The MAX_PACKET definitions in most of the drivers are gone. The set_mtu methods were all the same and did nothing, so they can be removed. The ethertap driver had a typo which doubled the size of the packet rather than adding two bytes to it. It also wasn't defining its setup_size, causing a zero-byte kmalloc and crash when the invalid pointer returned from kmalloc was dereferenced. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: network formattingJeff Dike
Style and other non-functional changes in the UML networking code, including include tidying style violations copyright updates printks getting severities userspace code calling libc directly rather than using the os_* wrappers There's also a exit path cleanup in the pcap driver. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17um_kmalloc() remnantsAl Viro
2007-05-08uml: network and pcap cleanupJeff Dike
Some network device cleanup. When setup_etheraddr found a globally valid MAC being assigned to an interface, it went ahead and used it rather than assigning a random MAC like the other cases do. This isn't really an error like the others, but it seems consistent to make it behave the same. We were getting some duplicate kfree() in the error case in eth_configure because platform_device_unregister frees buffers that the error cases following tried to free again. The pcap initialization routine wasn't doing the proper printk of its information, causing a printk of the first part of that line to be unterminated by a newline. The pcap code had a bunch of style violations, which are now fixed. pcap_setup wasn't returning false when it detected an unrecognized option. The printks in pcap_user all got UM_KERN_BLAH prepended to their format strings. pcap_remove now checks for a non-NULL pcap structure before it calls pcap_close. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Acked-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: network interface hotplug error handlingJeff Dike
This fixes a number of problems associated with network interface hotplug. The userspace initialization function can fail in some cases, but the failure was never passed back to eth_configure, which proceeded with the configuration. This results in a zombie device that is present, but can't work. This is fixed by allowing the initialization routines to return an error, which is checked, and the configuration aborted on failure. eth_configure failed to check for many failures. Even when it did check, it didn't undo whatever initializations has already happened, so a present, but partially initialized and non-working device could result. It now checks everything that can fail, and bails out, undoing whatever had been done. The return value of eth_configure was always ignored, so it is now just void. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: driver formatting fixesJeff Dike
Fix a bunch of formatting violations in the drivers: return(n) -> return n whitespace fixes emacs formatting comment removal breaking if(foo) return(n) into two lines There are also a couple of errno use bugs: using errno in a printk when the failure put errno into a local variable saving errno after a printk, which can change it Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] uml: split memory allocation prototypes out of user.hPaolo 'Blaisorblade' Giarrusso
user.h is too generic a header name. I've split out allocation routines from it. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: const more dataJeff Dike
Make lots of structures const in order to make it obvious that they need no locking. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
