path: root/arch/um/drivers/ubd_kern.c
2008-06-06uml: remove a duplicate includeHuang Weiyi
Removed duplicated include file "kern_util.h" in arch/um/drivers/ubd_kern.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: use DIV_ROUND_UPJiri Olsa
I just saw similar patches in the janitor kernel's list, and spotted place it fits. Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28uml: clean up arch/um/drivers/ubd_kern.cWANG Cong
Make some global functions and variables static. And remove some useless declarations for local functions, since we just need to move their definitions ahead. [jdike@addtoit.com: checkpatch cleanups] Signed-off-by: WANG Cong <wangcong@zeuux.org> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: remove fakehdJeff Dike
The fakehd switch lost its implementation at some point. Since no one is screaming for it, we might as well remove it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: reconst a parameterJeff Dike
The previous const-ing patch consted a string which shouldn't have been, and I didn't notice the gcc warning. ubd_setup can't take a const char * because its address is assigned to something which expects a char *arg. Many setups modify the string they are given, they can't be const. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: tidy kern_util.hJeff Dike
Tidy kern_util.h. It turns out that most of the function declarations aren't used, so they can go away. os.h no longer includes kern_util.h, so files which got it through os.h now need to include it directly. A number of other files never needed it, so these includes are deleted. The structure which was used to pass signal handlers from the kernel side to the userspace side is gone. Instead, the handlers are declared here, and used directly from libc code. This allows arch/um/os-Linux/trap.c to be deleted, with its remnants being moved to arch/um/os-Linux/skas/trap.c. arch/um/os-Linux/tty.c had its inclusions changed, and it needed some style attention, so it got tidied. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: const and other tidyingWANG Cong
This patch also does some improvements for uml code. Improvements include dropping unnecessary cast, killing some unnecessary code and still some constifying for pointers etc.. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: document new ubd flagJeff Dike
The ubd help message didn't document the 'c' flag. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28blk_end_request: changing um (take 4)Kiyoshi Ueda
This patch converts um to use blk_end_request interfaces. Related 'uptodate' arguments are converted to 'error'. As a result, the interface of internal function, ubd_end_request(), is changed. Cc: Jeff Dike <jdike@karaya.com> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-11-29leak in do_ubd_requestMiklos Szeredi
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-05uml: fix incompatible types warning in previous SG fixWANG Cong
Fix an incompatible-pointer warning. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-24arch/um/drivers/ubd_kern.c: fix a building errorWANG Cong
Fix this uml building error: arch/um/drivers/ubd_kern.c: In function 'do_ubd_request': arch/um/drivers/ubd_kern.c:1118: error: implicit declaration of function 'sg_page' arch/um/drivers/ubd_kern.c:1118: warning: passing argument 6 of 'prepare_request' makes pointer from integer without a cast make[1]: *** [arch/um/drivers/ubd_kern.o] Error 1 make: *** [arch/um/drivers] Error 2 Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Add sg_init_table() call as well. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-16uml: remove unneeded void * castJesper Juhl
vmalloc() returns a void pointer, so casting to (void *) is pretty pointless. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22uml: fix previous request size limit fixJeff Dike
The previous patch which limited the number of sectors in a single request to a COWed device was correct in concept, but the limit was implemented in the wrong place. By putting it in ubd_add, it covered the cases where the COWing was specified on the command line. However, when the command line only has the COW file specified, the fact that it's a COW file isn't known until it's opened, so the limit is missed in these cases. This patch moves the sector limit from ubd_add to ubd_open_dev. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-16uml: limit request size on COWed devicesJeff Dike
COWed devices can't handle more than 32 (64 on x86_64) sectors in one request due to the size of the bitmap being carried around in the io_thread_req. Enforce that by telling the block layer not to put too many sectors in requests to COWed devices. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16uml: fix request->sector updateJeff Dike
It is theoretically possible for a request to finish and be freed between writing it to the I/O thread and updating the sector count. In this case, the update will dereference a freed pointer. To avoid this, I delay the update until processing the next sg segment, when the request pointer is known to be good. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08uml: get declaration of simple_strtoulJeff Dike
Include linux/kernel.h wherever simple_strtoul is used. This kills a compile warning in stderr_console.c and potential ones in the other files. This also fixes a bunch of style violations in exitcode.c. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: rename os_{read_write}_file_k back to os_{read_write}_fileJeff Dike
Rename os_{read_write}_file_k back to os_{read_write}_file, delete the originals and their bogus infrastructure, and fix all the callers. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: formatting fixes around os_{read_write}_file callersJeff Dike
Formatting fixes ahead of renaming os_{read_write}_file_k to os_{read_write}_file and fixing all the callers. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: change remaining callers of os_{read_write}_fileJeff Dike
Convert all remaining os_{read_write}_file users to use the simple {read,write} wrappers, os_{read_write}_file_k. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: fixup allocation in the ubd driverPeter Zijlstra
Sanitise gfp flags; it actually is an atomic context, so drop the GFP_KERNEL part. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: send pointers instead of structures to I/O threadJeff Dike
Instead of writing entire structures between UML and the I/O thread, we send pointers. This cuts down on the amount of data being copied and possibly allows more requests to be pending between the two. This requires that the requests be kmalloced and freed instead of living on the stack. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: batch I/O requestsJeff Dike
Send as many I/O requests to the I/O thread as possible, even though it will still only handle one at a time. This provides an opportunity to reduce latency by starting one request before the previous one has been finished in the driver. Request handling is somewhat modernized by requesting sg pieces of a request and handling them separately, finishing off the entire request after all the pieces are done. When a request queue stalls, normally because its pipe to the I/O thread is full, it is put on the restart list. This list is processed by starting up the queues on it whenever there is some indication that progress might be possible again. Currently, this happens in the driver interrupt routine. Some requests have been finished, so there is likely to be room in the pipe again. This almost doubles throughput when copying data between devices, but made no noticable difference on anything else I tried. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: start fixing os_read_file and os_write_fileJeff Dike
This patch starts the removal of a very old, very broken piece of code. This stems from the problem of passing a userspace buffer into read() or write() on the host. If that buffer had not yet been faulted in, read and write will return -EFAULT. To avoid this problem, the solution was to fault the buffer in before the system call by touching the pages that hold the buffer by doing a copy-user of a byte to each page. This is obviously bogus, but it does usually work, in tt mode, since the kernel and process are in the same address space and userspace addresses can be accessed directly in the kernel. In skas mode, where the kernel and process are in separate address spaces, it is completely bogus because the userspace address, which is invalid in the kernel, is passed into the system call instead of the corresponding physical address, which would be valid. Here, it appears that this code, on every host read() or write(), tries to fault in a random process page. This doesn't seem to cause any correctness problems, but there is a performance impact. This patch, and the ones following, result in a 10-15% performance gain on a kernel build. This code can't be immediately tossed out because when it is, you can't log in. Apparently, there is some code in the console driver which depends on this somehow. However, we can start removing it by switching the code which does I/O using kernel addresses to using plain read() and write(). This patch introduces os_read_file_k and os_write_file_k for use with kernel buffers and converts all call locations which use obvious kernel buffers to use them. These include I/O using buffers which are local variables which are on the stack or kmalloc-ed. Later patches will handle the less obvious cases, followed by a mass conversion back to the original interface. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: drivers get release methodsJeff Dike
Define release methods for the ubd and net drivers. They contain as much of the remove methods as make sense. All error checking must have already been done as well as anything else that might be holding a reference on the device kobject. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove user_util.hJeff Dike
user_util.h isn't needed any more, so delete it and remove all includes of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: handle block device hotplug errorsJeff Dike
If a disk fails to open, i.e. its host file doesn't exist, it won't be removable because the hot-unplug code checks the existence of its gendisk. This won't exist because it is only allocated for successfully opened disks. Thus, a typo on the command line can result in a unusable and unfixable disk. This is fixed by freeing the gendisk if it's there, but not letting that affect the removal. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-29[PATCH] uml: fix I/O hang when multiple devices are in useJeff Dike
Commit 62f96cb01e8de7a5daee472e540f726db2801499 introduced per-devices queues and locks, which was fine as far as it went, but left in place a global which controlled access to submitting requests to the host. This should have been made per-device as well, since it causes I/O hangs when multiple block devices are in use. This patch fixes that by replacing the global with an activity flag in the device structure in order to tell whether the queue is currently being run. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] proc: remove useless (and buggy) ->nlink settingsAlexey Dobriyan
Bug: pnx8550 code creates directory but resets ->nlink to 1. create_proc_entry() et al will correctly set ->nlink for you. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Corey Minyard <minyard@acm.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: locking fixes in the ubd driverJeff Dike
Some small locking and formatting fixes in the ubd driver. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: add per-device queues and locks to ubd driverJeff Dike
Replace global queue and lock with per-device queues and locks. Mostly a straightforward replacement of ubd_io_lock with dev->lock and ubd_queue with dev->queue. Complications - There was no way to get a request struct (and queue) from the structure sent to the io_thread, so a pointer to the request was added. This is needed in ubd_handler in order to kick do_ubd_request to process another request. Queue initialization is moved from ubd_init to ubd_add. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: mconsole lockingJeff Dike
Locking fixes. Locking was totally lacking for the mconsole_devices, which got a spin lock, and the unplugged pages data, which got a mutex. The locking of the mconsole console output code was confused. Now, the console_lock (renamed to client_lock) protects the clients list. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: return hotplug errors to hostJeff Dike
I noticed that errors happening while hotplugging devices from the host were never returned back to the mconsole client. In some cases, success was returned instead of even an information-free error. This patch cleans that up by having the low-level configuration code pass back an error string along with an error code. At the top level, which knows whether it is early boot time or responding to an mconsole request, the string is printk'd or returned to the mconsole client. There are also whitespace and trivial code cleanups in the surrounding code. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-31[PATCH] uml ubd driver: various little changesPaolo 'Blaisorblade' Giarrusso
Fix a small memory leak in ubd_config, and clearify the confusion which lead to it. Then, some little changes not affecting operations - * move init functions together, * add a comment about a potential problem in case of some evolution in the block layer, * mark all initcalls as static __init functions * mark an used once little function as inline * document that mconsole methods are all called in process context (was triggered when checking ubd mconsole methods). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] uml ubd driver: do not store error codes as ->fdPaolo 'Blaisorblade' Giarrusso
To simplify error handling, make sure fd is saved into ubd_dev->fd only when we are sure it is an fd and not an error code. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] uml ubd driver: use bitfields where possiblePaolo 'Blaisorblade' Giarrusso
Use bitfields for boolean fields in ubd data structure. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] uml ubd driver: reformat ubd_configPaolo 'Blaisorblade' Giarrusso
Pure whitespace and style fixes split out from subsequent patch. Some changes (err -> ret) don't make sense now, only later, but I split them out anyway since they cluttered the patch. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] uml ubd driver: convert do_ubd to a boolean variablePaolo 'Blaisorblade' Giarrusso
do_ubd is actually just a boolean variable - the way it is used currently is a leftover from the old 2.4 block layer, but it is still used; its use is suspicious, but removing it would be too intrusive for now and needs more thinking. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] uml ubd driver: ubd_io_lock usage fixupPaolo 'Blaisorblade' Giarrusso
Add some comments about requirements for ubd_io_lock and expand its use. When an irq signals that the "controller" (i.e. another thread on the host, which does the actual requests and is the only one blocked on I/O on the host) has done some work, we call again the request function ourselves (do_ubd_request). We now do that with ubd_io_lock held - that's useful to protect against concurrent calls to elv_next_request and so on. XXX: Maybe we shouldn't call at all the request function. Input needed on this. Are we supposed to plug and unplug the queue? That code "indirectly" does that by setting a flag, called do_ubd, which makes the request function return (it's a residual of 2.4 block layer interface). Meanwhile, however, merge this patch, which improves things. Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] uml ubd driver: change ubd_lock to be a mutexPaolo 'Blaisorblade' Giarrusso
This lock protects ubd setup and teardown, so is only used in process context; beyond that, during such setup memory allocations must be performed and some generic functions which can sleep must be called (such as add_disk()). So the only correct solution is to make it a mutex instead of a spin_lock. No other change is done - this lock must be acquired in different places but it's done afterwards. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] uml ubd driver: give better names to some functions.Paolo 'Blaisorblade' Giarrusso
To rethink locking, I needed to understand well what each function does. While doing this I renamed some: * ubd_close -> ubd_close_dev (since it pairs with ubd_open_dev) * ubd_new_disk -> ubd_disk_register (it handles registration with the block layer - one hopes this makes clearer the difference with ubd_add()) Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] uml ubd driver: var renamesPaolo 'Blaisorblade' Giarrusso
Rename the ubd_dev array to ubd_devs and then call any "struct ubd" ubd_dev instead of dev, which doesn't make clear what we're treating (and no, it's not hungarian notation - not any more than calling all vm_area_struct vma or all inodes inode). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] uml ubd driver: document some struct fieldsPaolo 'Blaisorblade' Giarrusso
Add documentation about some fields in struct ubd, whose meaning is non-obvious due to struct names (should change names altogether, I agree). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] uml ubd driver: allow using up to 16 UBD devicesPaolo 'Blaisorblade' Giarrusso
With 256 minors and 16 minors used per each UBD device, we can allow the use of up to 16 UBD devices per UML. Also chnage parse_unit and leave to the caller (which already do it) the check for excess numbers, since this is just supposed to do raw parsing. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-08[PATCH] uml pt_regs fixesAl Viro
Real fix for UML pt_regs stuff. Note set_irq_regs() logics in there... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-30[PATCH] Remove ->rq_status from struct requestJens Axboe
After Christophs SCSI change, the only usage left is RQ_ACTIVE and RQ_INACTIVE. The block layer sets RQ_INACTIVE right before freeing the request, so any check for RQ_INACTIVE in a driver is a bug and indicates use-after-free. So kill/clean the remaining users, straight forward. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-29[PATCH] uml: close file descriptor leaksJeff Dike
Close two file descriptor leaks, one in the ubd driver and one to /proc/mounts. The ubd driver bug also leaked some vmalloc space. The /proc/mounts leak was a descriptor that was just never closed. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
