In preparation for the removal of 'driverfs_dev' from 'struct gendisk'
use a local variable to track the parented vs un-parented case in
ubd_disk_register().
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Bart Van Assche <bart.vanassche@sandisk.com>
This adds a REQ_OP_FLUSH operation that is sent to request_fn
based drivers by the block layer's flush code, instead of
sending requests with the request->cmd_flags REQ_FLUSH bit set.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
This decreases the number of syscalls per read/write by half.
Signed-off-by: Anton Ivanov <aivanov@brocade.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
Starting with Linux 3.12 processes get stuck in D state forever in
UserModeLinux under sync heavy workloads. This bug was introduced by
commit 805f11a0d5 (um: ubd: Add REQ_FLUSH suppport).
Fix bug by adding a check if FLUSH request was successfully submitted to
the I/O thread and keeping the FLUSH request on the request queue on
submission failures.
Fixes: 805f11a0d5 (um: ubd: Add REQ_FLUSH suppport)
Signed-off-by: Thorsten Knabe <linux@thorsten-knabe.de>
Cc: stable@kernel.org # >= 3.12
Richard reported that some UML processes survive if the UML
main process receives a SIGTERM.
This issue was caused by a wrongly placed signal(SIGTERM, SIG_DFL)
in init_new_thread_signals().
It disabled the UML exit handler accidently for some processes.
The correct solution is to disable the fatal handler for all
UML helper threads/processes.
Such that last_ditch_exit() does not get called multiple times
and all processes can exit due to SIGTERM.
Reported-and-tested-by: Richard W.M. Jones <rjones@redhat.com>
Just a clean-up patch to remove the open coded
variants and to ensure that all requests are submitted the
same way.
UML's block device driver does not support write barriers,
to support this this patch adds REQ_FLUSH suppport.
Every time the block layer sends a REQ_FLUSH we fsync() now
our backing file to guarantee data consistency.
The value passed is 0 in all but "it can never happen" cases (and those
only in a couple of drivers) *and* it would've been lost on the way
out anyway, even if something tried to pass something meaningful.
Just don't bother.
Made ubd_file_size not request write access. Fixes use of read-only images.
Signed-off-by: Martin Pärtel <martin.partel@gmail.com>
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled],
We run all interrupt handlers with interrupts disabled
and we even check and yell when an interrupt handler
returns with interrupts enabled (see commit [b738a50a:
genirq: Warn when handler enables interrupts]).
So now this flag is a NOOP and can be removed.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
ubd_file_size() cannot use ubd_dev->cow.file because at this time
ubd_dev->cow.file is not initialized.
Therefore, ubd_file_size() will always report a wrong disk size when
COW files are used.
Reading from /dev/ubd* would crash the kernel.
We have to read the correct disk size from the COW file's backing
file.
CC: stable@kernel.org
... nothing declared there exists
SPIN_LOCK_UNLOCK is deprecated. Use the lockdep capable variant
instead.
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
BKL: introduce CONFIG_BKL.
dabusb: remove the BKL
sunrpc: remove the big kernel lock
init/main.c: remove BKL notations
blktrace: remove the big kernel lock
rtmutex-tester: make it build without BKL
dvb-core: kill the big kernel lock
dvb/bt8xx: kill the big kernel lock
tlclk: remove big kernel lock
fix rawctl compat ioctls breakage on amd64 and itanic
uml: kill big kernel lock
parisc: remove big kernel lock
cris: autoconvert trivial BKL users
alpha: kill big kernel lock
isapnp: BKL removal
s390/block: kill the big kernel lock
hpet: kill BKL, add compat_ioctl
Three uml device drivers still use the big kernel lock,
but all of them can be safely converted to using
a per-driver mutex instead. Most likely this is not
even necessary, so after further review these can
and should be removed as well.
The exec system call no longer requires the BKL either,
so remove it from there, too.
Cc: user-mode-linux-devel@lists.sourceforge.net
Commit f81f2f7c (ubd: drop unnecessary rq->sector manipulation)
dropped request->sector manipulation in preparation for global request
handling cleanup; unfortunately, it incorrectly assumed that the
updated sector wasn't being used.
ubd tries to issue as many requests as possible to io_thread. When
issuing fails due to memory pressure or other reasons, the device is
put on the restart list and issuing stops. On IO completion, devices
on the restart list are scanned and IO issuing is restarted.
ubd issues IOs sg-by-sg and issuing can be stopped in the middle of a
request, so each device on the restart queue needs to remember where
to restart in its current request. ubd needs to keep track of the
issue position itself because,
* blk_rq_pos(req) is now updated by the block layer to keep track of
_completion_ position.
* Multiple io_req's for the current request may be in flight, so it's
difficult to tell where blk_rq_pos(req) currently is.
Add ubd->rq_pos to keep track of the issue position and use it to
correctly restart io_req issue.
Reported-by: Richard Weinberger <richard@nod.at>
Tested-by: Richard Weinberger <richard@nod.at>
Tested-by: Chris Frey <cdfrey@foursquare.net>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
The open and release block_device_operations are currently
called with the BKL held. In order to change that, we must
first make sure that all drivers that currently rely
on this have no regressions.
This blindly pushes the BKL into all .open and .release
operations for all block drivers to prepare for the
next step. The drivers can subsequently replace the BKL
with their own locks or remove it completely when it can
be shown that it is not needed.
The functions blkdev_get and blkdev_put are the only
remaining users of the big kernel lock in the block
layer, besides a few uses in the ioctl code, none
of which need to serialize with blkdev_{get,put}.
Most of these two functions is also under the protection
of bdev->bd_mutex, including the actual calls to
->open and ->release, and the common code does not
access any global data structures that need the BKL.
Acked-by: Christoph Hellwig <hch@infradead.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Except for SCSI no device drivers distinguish between physical and
hardware segment limits. Consolidate the two into a single segment
limit.
The block layer calling convention is blk_queue_<limit name>.
blk_queue_max_sectors predates this practice, leading to some confusion.
Rename the function to appropriately reflect that its intended use is to
set max_hw_sectors.
Also introduce a temporary wrapper for backwards compability. This can
be removed after the merge window is closed.
Convert code away from ->read_proc/->write_proc interfaces. Switch to
proc_create()/proc_create_data() which make addition of proc entries
reliable wrt NULL ->proc_fops, NULL ->data and so on.
Problem with ->read_proc et al is described here commit
786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in
/proc entries"
In the near future, the driver core is going to not allow direct access
to the driver_data pointer in struct device. Instead, the functions
dev_get_drvdata() and dev_set_drvdata() should be used. These functions
have been around since the beginning, so are backwards compatible with
all older kernel versions.
Till now block layer allowed two separate modes of request execution.
A request is always acquired from the request queue via
elv_next_request(). After that, drivers are free to either dequeue it
or process it without dequeueing. Dequeue allows elv_next_request()
to return the next request so that multiple requests can be in flight.
Executing requests without dequeueing has its merits mostly in
allowing drivers for simpler devices which can't do sg to deal with
segments only without considering request boundary. However, the
benefit this brings is dubious and declining while the cost of the API
ambiguity is increasing. Segment based drivers are usually for very
old or limited devices and as converting to dequeueing model isn't
difficult, it doesn't justify the API overhead it puts on block layer
and its more modern users.
Previous patches converted all block low level drivers to dequeueing
model. This patch completes the API transition by...
* renaming elv_next_request() to blk_peek_request()
* renaming blkdev_dequeue_request() to blk_start_request()
* adding blk_fetch_request() which is combination of peek and start
* disallowing completion of queued (not started) requests
* applying new API to all LLDs
Renamings are for consistency and to break out of tree code so that
it's apparent that out of tree drivers need updating.
[ Impact: block request issue API cleanup, no functional change ]
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Mike Miller <mike.miller@hp.com>
Cc: unsik Kim <donari75@gmail.com>
Cc: Paul Clements <paul.clements@steeleye.com>
Cc: Tim Waugh <tim@cyberelk.net>
Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Cc: Laurent Vivier <Laurent@lvivier.info>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Borislav Petkov <petkovbb@googlemail.com>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Cc: Alex Dubov <oakad@yahoo.com>
Cc: Pierre Ossman <drzeus@drzeus.cx>
Cc: Markus Lidel <Markus.Lidel@shadowconnect.com>
Cc: Stefan Weinhuber <wein@de.ibm.com>
Cc: Pete Zaitcev <zaitcev@redhat.com>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
With recent cleanups, there is no place where low level driver
directly manipulates request fields. This means that the 'hard'
request fields always equal the !hard fields. Convert all
rq->sectors, nr_sectors and current_nr_sectors references to
accessors.
While at it, drop superflous blk_rq_pos() < 0 test in swim.c.
[ Impact: use pos and nr_sectors accessors ]
Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Tested-by: Grant Likely <grant.likely@secretlab.ca>
Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk>
Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk>
Acked-by: Mike Miller <mike.miller@hp.com>
Cc: Eric Moore <Eric.Moore@lsi.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Dario Ballabio <ballabio_dario@emc.com>
ubd curiously updates rq->sector while issuing the request in multiple
pieces. Don't do it and simply use local copy of sector.
[ Impact: cleanup ]
Cc: Jeff Dike <jdike@linux.intel.com>
ubd had its own block request partial completion mechanism, which is
unnecessary as block layer already does it. Kill ubd_end_request()
and ubd_finish() and replace them with direct call to
blk_end_request().
[ Impact: cleanup ]
* Change ubd_id in ubd_ioctl() from 'struct hd_driveid *id'
to 'u16 *id' and update driver accordingly.
* Include <linux/ata.h> directly instead of through <linux/hdreg.h>.
There should be no functional changes caused by this patch.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
MAJOR_NR isn't needed anymore since very early 2.5 kernels.
ubd_ioctl() doesn't need BKL, so unlocked_ioctl() it becomes...
To keep the size of changesets sane we split the switch by drivers;
to keep the damn thing bisectable we do the following:
1) rename the affected methods, add ones with correct
prototypes, make (few) callers handle both. That's this changeset.
2) for each driver convert to new methods. *ALL* drivers
are converted in this series.
3) kill the old (renamed) methods.
Note that it _is_ a flagday; all in-tree drivers are converted and by the
end of this series no trace of old methods remain. The only reason why
we do that this way is to keep the damn thing bisectable and allow per-driver
debugging if anything goes wrong.
New methods:
open(bdev, mode)
release(disk, mode)
ioctl(bdev, mode, cmd, arg) /* Called without BKL */
compat_ioctl(bdev, mode, cmd, arg)
locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */
Removed duplicated include file "kern_util.h" in
arch/um/drivers/ubd_kern.c.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
I just saw similar patches in the janitor kernel's list, and spotted place it
fits.
Signed-off-by: Jiri Olsa <olsajiri@gmail.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Make some global functions and variables static.
And remove some useless declarations for local functions, since we just need
to move their definitions ahead.
[jdike@addtoit.com: checkpatch cleanups]
Signed-off-by: WANG Cong <wangcong@zeuux.org>
Signed-off-by: Jeff Dike <jdike@addtoit.com>
The fakehd switch lost its implementation at some point. Since no one is
screaming for it, we might as well remove it.
The previous const-ing patch consted a string which shouldn't have
been, and I didn't notice the gcc warning.
ubd_setup can't take a const char * because its address is assigned to
something which expects a char *arg. Many setups modify the string
they are given, they can't be const.
Tidy kern_util.h. It turns out that most of the function declarations
aren't used, so they can go away. os.h no longer includes
kern_util.h, so files which got it through os.h now need to include it
directly. A number of other files never needed it, so these includes
are deleted.
The structure which was used to pass signal handlers from the kernel
side to the userspace side is gone. Instead, the handlers are
declared here, and used directly from libc code. This allows
arch/um/os-Linux/trap.c to be deleted, with its remnants being moved
to arch/um/os-Linux/skas/trap.c.
arch/um/os-Linux/tty.c had its inclusions changed, and it needed some
style attention, so it got tidied.
This patch also does some improvements for uml code. Improvements include
dropping unnecessary cast, killing some unnecessary code and still some
constifying for pointers etc..
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
The ubd help message didn't document the 'c' flag.
This patch converts um to use blk_end_request interfaces.
Related 'uptodate' arguments are converted to 'error'.
As a result, the interface of internal function, ubd_end_request(),
is changed.
Cc: Jeff Dike <jdike@karaya.com>
Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Fix an incompatible-pointer warning.
Cc: Jens Axboe <jens.axboe@oracle.com>
Fix this uml building error:
arch/um/drivers/ubd_kern.c: In function 'do_ubd_request':
arch/um/drivers/ubd_kern.c:1118: error: implicit declaration of function
'sg_page'
arch/um/drivers/ubd_kern.c:1118: warning: passing argument 6 of
'prepare_request' makes pointer from integer without a cast
make[1]: *** [arch/um/drivers/ubd_kern.o] Error 1
make: *** [arch/um/drivers] Error 2
Add sg_init_table() call as well.
vmalloc() returns a void pointer, so casting to (void *) is pretty pointless.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
The previous patch which limited the number of sectors in a single request
to a COWed device was correct in concept, but the limit was implemented in
the wrong place.
By putting it in ubd_add, it covered the cases where the COWing was
specified on the command line. However, when the command line only has the
COW file specified, the fact that it's a COW file isn't known until it's
opened, so the limit is missed in these cases.
This patch moves the sector limit from ubd_add to ubd_open_dev.
Cc: <stable@kernel.org>
