path: root/arch/um/kernel/ksyms.c
2005-11-07[PATCH] uml: separate libc-dependent helper codeJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from helper.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] uml: inline mk_pte and various friendsPaolo 'Blaisorblade' Giarrusso
Turns out that, for UML, a *lot* of VM-related trivial functions are not inlined but rather normal functions. In other sections of UML code, this is justified by having files which interact with the host and cannot therefore include kernel headers, but in this case there's no such justification. I've had to turn many of them to macros because of missing declarations. While doing this, I've decided to reuse some already existing macros. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: remove duplicated exportsJeff Dike
Al Viro <viro@parcelfarce.linux.theplanet.co.uk> spotted a bunch of duplicated exports - this removes them. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20[PATCH] uml: Export clear_user_*Jeff Dike
From: Oleg Drokin: This patch is needed to support kernel modules that want to use clear_user() (that is exported symbol on all other architectures). Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: s390 preparation, delay moved to archBodo Stroesser
s390 has fast read access to realtime clock (nanosecond resolution). So it makes sense to have an arch-specific implementation not only of __delay, but __udelay also. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
