path: root/arch/um/kernel/skas/mmu.c
2016-03-17mm: cleanup *pte_alloc* interfacesKirill A. Shutemov
There are few things about *pte_alloc*() helpers worth cleaning up: - 'vma' argument is unused, let's drop it; - most __pte_alloc() callers do speculative check for pmd_none(), before taking ptl: let's introduce pte_alloc() macro which does the check. The only direct user of __pte_alloc left is userfaultfd, which has different expectation about atomicity wrt pmd. - pte_alloc_map() and pte_alloc_map_lock() are redefined using pte_alloc(). [sudeep.holla@arm.com: fix build for arm64 hugetlbpage] [sfr@canb.auug.org.au: fix arch/arm/mm/mmu.c some more] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06um: Switch clocksource to hrtimersAnton Ivanov
UML is using an obsolete itimer call for all timers and "polls" for kernel space timer firing in its userspace portion resulting in a long list of bugs and incorrect behaviour(s). It also uses ITIMER_VIRTUAL for its timer which results in the timer being dependent on it running and the cpu load. This patch fixes this by moving to posix high resolution timers firing off CLOCK_MONOTONIC and relaying the timer correctly to the UML userspace. Fixes: - crashes when hosts suspends/resumes - broken userspace timers - effecive ~40Hz instead of what they should be. Note - this modifies skas behavior by no longer setting an itimer per clone(). Timer events are relayed instead. - kernel network packet scheduling disciplines - tcp behaviour especially under load - various timer related corner cases Finally, overall responsiveness of userspace is better. Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Anton Ivanov <aivanov@brocade.com> [rw: massaged commit message] Signed-off-by: Richard Weinberger <richard@nod.at>
2015-05-31um: Use char[] for linker script address declarationsNicolas Iooss
The linker script defines some variables which are declared either with type char[] in include/asm-generic/sections.h or with a meaningless integer type in arch/um/include/asm/sections.h. Fix this inconsistency by declaring every variable char[]. Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Signed-off-by: Richard Weinberger <richard@nod.at>
2015-05-31um: Create asm/sections.hNicolas Iooss
arch/um/kernel/dyn.lds.S and arch/um/kernel/uml.lds.S define some UML-specific symbols. These symbols are used in the kernel part of UML with extern declarations. Move these declarations to a new header, asm/sections.h, like other architectures do. Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Signed-off-by: Richard Weinberger <richard@nod.at>
2015-04-13um: Remove SKAS3/4 supportRichard Weinberger
Before we had SKAS0 UML had two modes of operation TT (tracing thread) and SKAS3/4 (separated kernel address space). TT was known to be insecure and got removed a long time ago. SKAS3/4 required a few (3 or 4) patches on the host side which never went mainline. The last host patch is 10 years old. With SKAS0 mode (separated kernel address space using 0 host patches), default since 2005, SKAS3/4 is obsolete and can be removed. Signed-off-by: Richard Weinberger <richard@nod.at>
2013-07-19um: Mark stub pages mapping with VM_PFNMAPRichard Weinberger
Ensure that a process cannot destroy his stub pages with using MADV_DONTNEED and friends. Reported-by: toralf.foerster@gmx.de Signed-off-by: Richard Weinberger <richard@nod.at>
2012-10-09um: get rid of pointless include "..." where include <...> will doAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2012-04-10um: uml_setup_stubs': warning: unused variable 'pages'Boaz Harrosh
Fix the following gcc complain arch/um/kernel/skas/mmu.c: In function 'uml_setup_stubs': arch/um/kernel/skas/mmu.c:106:16: warning: unused variable 'pages' [-Wunused-variable] Signed-Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Richard Weinberger <richard@nod.at>
2012-03-20um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() ↵Al Viro
doesn't hold it ... while calling uml_dup_mmap() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20um: embed ->stub_pages[] into mmu_contextAl Viro
seriously, kmalloc() for two-element array of pointers? Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-13thp: pte alloc trans splittingAndrea Arcangeli
pte alloc routines must wait for split_huge_page if the pmd is not present and not null (i.e. pmd_trans_splitting). The additional branches are optimized away at compile time by pmd_trans_splitting if the config option is off. However we must pass the vma down in order to know the anon_vma lock to wait for. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-22uml: fix order of pud and pmd_free()Roel Kluin
If pmd_alloc() fails we should only free the prior allocated pud, if pte_alloc_map() fails, we should free pmd as well. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08uml: fix mm_context memory leakJeff Dike
[ Spotted by Miklos ] Fix a memory leak in init_new_context. The struct page ** buffer allocated for install_special_mapping was never recorded, and thus leaked when the mm_struct was freed. Fix it by saving the pointer in mm_context_t and freeing it in arch_exit_mmap. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: don't kill pid 0Jeff Dike
A bit of defensive programming - during development, it ocassionally happens that a call to init_new_context is missed, resulting in context holding a host pid of zero. When that address space is torn down, destroy_context does a kill(0), which instantly kills the whole UML without any errors whatsoever. This patch add a check for pids less than 2, to also catch 1 and negative pids. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: cover stubs with a VMAJeff Dike
Give the stubs a VMA. This allows the removal of a truly nasty kludge to make sure that mm->nr_ptes was correct in exit_mmap. The underlying problem was always that the stubs, which have ptes, and thus allocated a page table, weren't covered by a VMA. This patch fixes that by using install_special_mapping in arch_dup_mmap and activate_context to create the VMA. The stubs have to be moved, since shift_arg_pages seems to assume that the stack is the only VMA present at that point during exec, and uses vma_adjust to fiddle its VMA. However, that extends the stub VMA by the amount removed from the stack VMA. To avoid this problem, the stubs were moved to a different fixed location at the start of the address space. The init_stub_pte calls were moved from init_new_context to arch_dup_mmap because I was occasionally seeing arch_dup_mmap not being called, causing exit_mmap to die. Rather than figure out what was really happening, I decided it was cleaner to just move the calls so that there's no doubt that both the pte and VMA creation happen, no matter what. arch_exit_mmap is used to clear the stub ptes at exit time. The STUB_* constants in as-layout.h no longer depend on UM_TASK_SIZE, that that definition is removed, along with the comments complaining about gcc. Because the stubs are no longer at the top of the address space, some care is needed while flushing TLBs. update_pte_range checks for addresses in the stub range and skips them. flush_thread now issues two unmaps, one for the range before STUB_START and one for the range after STUB_END. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: kill processes instead of panicing kernelJeff Dike
UML was panicing in the case of failures of libc calls which shouldn't happen. This is an overreaction since a failure from libc doesn't normally mean that kernel data structures are in an unknown state. Instead, the current process should just be killed if there is no way to recover. The case that prompted this was a failure of PTRACE_SETREGS restoring the same state that was read by PTRACE_GETREGS. It appears that when a process tries to load a bogus value into a segment register, it segfaults (as expected) and the value is actually loaded and is seen by PTRACE_GETREGS (not expected). This case is fixed by forcing a fatal SIGSEGV on the process so that it immediately dies. fatal_sigsegv was added for this purpose. It was declared as noreturn, so in order to pursuade gcc that it actually does not return, I added a call to os_dump_core (and declared it noreturn) so that I get a core file if somehow the process survives. All other calls in arch/um/os-Linux/skas/process.c got the same treatment, with failures causing the process to die instead of a kernel panic, with some exceptions. userspace_tramp exits with status 1 if anything goes wrong there. That will cause start_userspace to return an error. copy_context_skas0 and map_stub_pages also now return errors instead of panicing. Callers of thes functions were changed to check for errors and do something appropriate. Usually that's to return an error to their callers. check_skas3_ptrace_faultinfo just exits since that's too early to do anything else. save_registers, restore_registers, and init_registers now return status instead of panicing on failure, with their callers doing something appropriate. There were also duplicate declarations of save_registers and restore_registers in os.h - these are gone. I noticed and fixed up some whitespace damage. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05add mm argument to pte/pmd/pud/pgd_freeBenjamin Herrenschmidt
(with Martin Schwidefsky <schwidefsky@de.ibm.com>) The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as first argument. The free functions do not get the mm_struct argument. This is 1) asymmetrical and 2) to do mm related page table allocations the mm argument is needed on the free function as well. [kamalesh@linux.vnet.ibm.com: i386 fix] [akpm@linux-foundation.org: coding-syle fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: fix stub address calculationsJeff Dike
The calculation of CONFIG_STUB_CODE and CONFIG_STUB_DATA didn't take into account anything but 3G/1G and 2G/2G, leaving the other vmsplits out in the cold. I'd rather not duplicate the four known host vmsplit cases for each of these symbols. I'd also like to calculate them based on the highest userspace address. The Kconfig language seems not to allow calculation of hex constants, so I moved this to as-layout.h. CONFIG_STUB_CODE, CONFIG_STUB_DATA, and CONFIG_STUB_START are now gone. In their place are STUB_CODE, STUB_DATA, and STUB_START in as-layout.h. i386 and x86_64 seem to differ as to whether an unadorned constant is an int or a long, so I cast them to unsigned long so they can be printed consistently. However, they are also used in stub.S, where C types don't work so well. So, there are ASM_ versions of these constants for use in stub.S. I also ifdef-ed the non-asm-friendly portion of as-layout.h. With this in place, most of the rest of this patch is changing CONFIG_STUB_* to STUB_*, except in stub.S, where they are changed to ASM_STUB_*. defconfig has the old symbols deleted. I also print these addresses out in case there is any problem mapping them on the host. The two stub.S files had some trailing whitespace, so that is cleaned up here. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: free LDT state on process exitJeff Dike
The space allocated for a process LDT wasn't being freed when the process exited. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: fold mmu_context_skas into mm_contextJeff Dike
This patch folds mmu_context_skas into struct mm_context, changing all users of these structures as needed. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: style fixes pass 3Jeff Dike
Formatting changes in the files which have been changed in the course of folding foo_skas functions into their callers. These include: copyright updates header file trimming style fixes adding severity to printks These changes should be entirely non-functional. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove code made redundant by CHOOSE_MODE removalJeff Dike
This patch makes a number of simplifications enabled by the removal of CHOOSE_MODE. There were lots of functions that looked like int foo(args){ foo_skas(args); } The bodies of foo_skas are now folded into foo, and their declarations (and sometimes entire header files) are deleted. In addition, the union uml_pt_regs, which was a union between the tt and skas register formats, is now a struct, with the tt-mode arm of the union being removed. It turns out that usr2_handler was unused, so it is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-11[PATCH] uml: correct removal of pte_mkexecPaolo 'Blaisorblade' Giarrusso
Correct commit 5906e4171ad61ce68de95e51b773146707671f80 - this makes more sense: we turn pte_mkexec + pte_wrprotect to pte_mkread. However, due to a bug in pte_mkread, it does the exact same thing as pte_mkwrite, so this patch improves the code but does not change anything in practice. The pte_mkread bug is fixed separately, as it may have big impact. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-29[PATCH] uml: remove pte_mkexecJeff Dike
Andi is making pte_mkexec go away, and UML had one of the last uses. This removes the use and the definition. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] Standardize pxx_page macrosDave McCracken
One of the changes necessary for shared page tables is to standardize the pxx_page macros. pte_page and pmd_page have always returned the struct page associated with their entry, while pte_page_kernel and pmd_page_kernel have returned the kernel virtual address. pud_page and pgd_page, on the other hand, return the kernel virtual address. Shared page tables needs pud_page and pgd_page to return the actual page structures. There are very few actual users of these functions, so it is simple to standardize their usage. Since this is basic cleanup, I am submitting these changes as a standalone patch. Per Hugh Dickins' comments about it, I am also changing the pxx_page_kernel macros to pxx_page_vaddr to clarify their meaning. Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: conversion of nr_pagetables to per zone counterChristoph Lameter
Conversion of nr_page_table_pages to a per zone counter [akpm@osdl.org: bugfix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: move LDT creationBodo Stroesser
s390 doesn't have a LDT. So MM_COPY_SEGMENTS will not be supported on s390. The only user of MM_COPY_SEGMENTS is new_mm(), but that's no longer useful, as arch/sys-i386/ldt.c defines init_new_ldt(), which is called immediately after new_mm(). So we should copy host's LDT in init_new_ldt(), if /proc/mm is available, to have this subarch specific call in subarch code. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] uml: maintain own LDT entriesBodo Stroesser
Patch imlements full LDT handling in SKAS: * UML holds it's own LDT table, used to deliver data on modify_ldt(READ) * UML disables the default_ldt, inherited from the host (SKAS3) or resets LDT entries, set by host's clib and inherited in SKAS0 * A new global variable skas_needs_stub is inserted, that can be used to decide, whether stub-pages must be supported or not. * Uses the syscall-stub to replace missing PTRACE_LDT (therefore, write_ldt_entry needs to be modified) Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: split page table lockHugh Dickins
Christoph Lameter demonstrated very poor scalability on the SGI 512-way, with a many-threaded application which concurrently initializes different parts of a large anonymous area. This patch corrects that, by using a separate spinlock per page table page, to guard the page table entries in that page, instead of using the mm's single page_table_lock. (But even then, page_table_lock is still used to guard page table allocation, and anon_vma allocation.) In this implementation, the spinlock is tucked inside the struct page of the page table page: with a BUILD_BUG_ON in case it overflows - which it would in the case of 32-bit PA-RISC with spinlock debugging enabled. Splitting the lock is not quite for free: another cacheline access. Ideally, I suppose we would use split ptlock only for multi-threaded processes on multi-cpu machines; but deciding that dynamically would have its own costs. So for now enable it by config, at some number of cpus - since the Kconfig language doesn't support inequalities, let preprocessor compare that with NR_CPUS. But I don't think it's worth being user-configurable: for good testing of both split and unsplit configs, split now at 4 cpus, and perhaps change that to 8 later. There is a benefit even for singly threaded processes: kswapd can be attacking one part of the mm while another part is busy faulting. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: arches skip ptlockHugh Dickins
Convert those few architectures which are calling pud_alloc, pmd_alloc, pte_alloc_map on a user mm, not to take the page_table_lock first, nor drop it after. Each of these can continue to use pte_alloc_map, no need to change over to pte_alloc_map_lock, they're neither racy nor swappable. In the sparc64 io_remap_pfn_range, flush_tlb_range then falls outside of the page_table_lock: that's okay, on sparc64 it's like flush_tlb_mm, and that has always been called from outside of page_table_lock in dup_mmap. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: fix x86_64 page leakJeff Dike
We were leaking pmd pages when 3_LEVEL_PGTABLES was enabled. This fixes that. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: increase granularity of host capability checkingBodo Stroesser
This change enables SKAS0/SKAS3 to work with all combinations of /proc/mm and PTRACE_FAULTINFO being available or not. Also it changes the initialization of proc_mm and ptrace_faultinfo slightly, to ease forcing SKAS0 on a patched host. Forcing UML to run without /proc/mm or PTRACE_FAULTINFO by cmdline parameter can be implemented with a setup resetting the related variable. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] uml: Proper clone support for skas0Bodo Stroesser
This patch implements the clone-stub mechanism, which allows skas0 to run with proc_mm==0, even if the clib in UML uses modify_ldt. Note: There is a bug in skas3.v7 host patch, that avoids UML-skas from running properly on a SMP-box. In full skas3, I never really saw problems, but in skas0 they showed up. More commentary by jdike - What this patch does is makes sure that the host parent of each new host process matches the UML parent of the corresponding UML process. This ensures that any changed LDTs are inherited. This is done by having clone actually called by the UML process from its stub, rather than by the kernel. We have special syscall stubs that are loaded onto the stub code page because that code must be completely self-contained. These stubs are given C interfaces, and used like normal C functions, but there are subtleties. Principally, we have to be careful about stack variables in stub_clone_handler after the clone. The code is written so that there aren't any - everything boils down to a fixed address. If there were any locals, references to them after the clone would be wrong because the stack just changed. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] uml: skas0 - separate kernel address space on stock hostsJeff Dike
UML has had two modes of operation - an insecure, slow mode (tt mode) in which the kernel is mapped into every process address space which requires no host kernel modifications, and a secure, faster mode (skas mode) in which the UML kernel is in a separate host address space, which requires a patch to the host kernel. This patch implements something very close to skas mode for hosts which don't support skas - I'm calling this skas0. It provides the security of the skas host patch, and some of the performance gains. The two main things that are provided by the skas patch, /proc/mm and PTRACE_FAULTINFO, are implemented in a way that require no host patch. For the remote address space changing stuff (mmap, munmap, and mprotect), we set aside two pages in the process above its stack, one of which contains a little bit of code which can call mmap et al. To update the address space, the system call information (system call number and arguments) are written to the stub page above the code. The %esp is set to the beginning of the data, the %eip is set the the start of the stub, and it repeatedly pops the information into its registers and makes the system call until it sees a system call number of zero. This is to amortize the cost of the context switch across multiple address space updates. When the updates are done, it SIGSTOPs itself, and the kernel process continues what it was doing. For a PTRACE_FAULTINFO replacement, we set up a SIGSEGV handler in the child, and let it handle segfaults rather than nullifying them. The handler is in the same page as the mmap stub. The second page is used as the stack. The handler reads cr2 and err from the sigcontext, sticks them at the base of the stack in a faultinfo struct, and SIGSTOPs itself. The kernel then reads the faultinfo and handles the fault. A complication on x86_64 is that this involves resetting the registers to the segfault values when the process is inside the kill system call. This breaks on x86_64 because %rcx will contain %rip because you tell SYSRET where to return to by putting the value in %rcx. So, this corrupts $rcx on return from the segfault. To work around this, I added an arch_finish_segv, which on x86 does nothing, but which on x86_64 ptraces the child back through the sigreturn. This causes %rcx to be restored by sigreturn and avoids the corruption. Ultimately, I think I will replace this with the trick of having it send itself a blocked signal which will be unblocked by the sigreturn. This will allow it to be stopped just after the sigreturn, and PTRACE_SYSCALLed without all the back-and-forth of PTRACE_SYSCALLing it through sigreturn. This runs on a stock host, so theoretically (and hopefully), tt mode isn't needed any more. We need to make sure that this is better in every way than tt mode, though. I'm concerned about the speed of address space updates and page fault handling, since they involve extra round-trips to the child. We can amortize the round-trip cost for large address space updates by writing all of the operations to the data page and having the child execute them all at the same time. This will help fork and exec, but not page faults, since they involve only one page. I can't think of any way to help page faults, except to add something like PTRACE_FAULTINFO to the host. There is PTRACE_SIGINFO, but UML doesn't use siginfo for SIGSEGV (or anything else) because there isn't enough information in the siginfo struct to handle page faults (the faulting operation type is missing). Adding that would make PTRACE_SIGINFO a usable equivalent to PTRACE_FAULTINFO. As for the code itself: - The system call stub is in arch/um/kernel/sys-$(SUBARCH)/stub.S. It is put in its own section of the binary along with stub_segv_handler in arch/um/kernel/skas/process.c. This is manipulated with run_syscall_stub in arch/um/kernel/skas/mem_user.c. syscall_stub will execute any system call at all, but it's only used for mmap, munmap, and mprotect. - The x86_64 stub calls sigreturn by hand rather than allowing the normal sigreturn to happen, because the normal sigreturn is a SA_RESTORER in UML's address space provided by libc. Needless to say, this is not available in the child's address space. Also, it does a couple of odd pops before that which restore the stack to the state it was in at the time the signal handler was called. - There is a new field in the arch mmu_context, which is now a union. This is the pid to be manipulated rather than the /proc/mm file descriptor. Code which deals with this now checks proc_mm to see whether it should use the usual skas code or the new code. - userspace_tramp is now used to create a new host process for every UML process, rather than one per UML processor. It checks proc_mm and ptrace_faultinfo to decide whether to map in the pages above its stack. - start_userspace now makes CLONE_VM conditional on proc_mm since we need separate address spaces now. - switch_mm_skas now just sets userspace_pid[0] to the new pid rather than PTRACE_SWITCH_MM. There is an addition to userspace which updates its idea of the pid being manipulated each time around the loop. This is important on exec, when the pid will change underneath userspace(). - The stub page has a pte, but it can't be mapped in using tlb_flush because it is part of tlb_flush. This is why it's required for it to be mapped in by userspace_tramp. Other random things: - The stub section in uml.lds.S is page aligned. This page is written out to the backing vm file in setup_physmem because it is mapped from there into user processes. - There's some confusion with TASK_SIZE now that there are a couple of extra pages that the process can't use. TASK_SIZE is considered by the elf code to be the usable process memory, which is reasonable, so it is decreased by two pages. This confuses the definition of USER_PGDS_IN_LAST_PML4, making it too small because of the rounding down of the uneven division. So we round it to the nearest PGDIR_SIZE rather than the lower one. - I added a missing PT_SYSCALL_ARG6_OFFSET macro. - um_mmu.h was made into a userspace-usable file. - proc_mm and ptrace_faultinfo are globals which say whether the host supports these features. - There is a bad interaction between the mm.nr_ptes check at the end of exit_mmap, stack randomization, and skas0. exit_mmap will stop freeing pages at the PGDIR_SIZE boundary after the last vma. If the stack isn't on the last page table page, the last pte page won't be freed, as it should be since the stub ptes are there, and exit_mmap will BUG because there is an unfreed page. To get around this, TASK_SIZE is set to the next lowest PGDIR_SIZE boundary and mm->nr_ptes is decremented after the calls to init_stub_pte. This ensures that we know the process stack (and all other process mappings) will be below the top page table page, and thus we know that mm->nr_ptes will be one too many, and can be decremented. Things that need fixing: - We may need better assurrences that the stub code is PIC. - The stub pte is set up in init_new_context_skas. - alloc_pgdir is probably the right place. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
