path: root/arch/um/os-Linux/main.c
2011-07-25um: disable scan_elf_aux() on x86_64Richard Weinberger
Reusing the host's vDSO makes only sense on x86_32. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25um: remove SIGHUP handlerRichard Weinberger
The UML kernel ignores SIGHUP anyway. This handler is in vain. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25um: fix UML_LIB_PATHRichard Weinberger
UML_LIB_PATH is hardcoded to /usr/lib/uml/, on 64bit systems UML_LIB_PATH needs to be /usr/lib64/uml/. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: fix build when SLOB is enabledJeff Dike
Reintroduce uml_kmalloc for the benefit of UML libc code. The previous tactic of declaring __kmalloc so it could be called directly from the libc side of the house turned out to be getting too intimate with slab, and it doesn't work with slob. So, the uml_kmalloc wrapper is back. It calls kmalloc or whatever that translates into, and libc code calls it. kfree is left alone since that still works, leaving a somewhat inconsistent API. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: install panic notifier earlierJeff Dike
It turns out that if there's a panic early enough, UML will just sit there in the LED-blinking loop because the panic notifier hadn't been installed yet. This patch installs it earlier. It also fixes the problem which exposed the hang, namely that if you give UML a zero-sized initrd, it will ask alloc_bootmem for zero bytes, and that will cause the panic. While I was in initrd.c, I gave it a style makeover. Prompted by checkpatch, I moved a couple extern declarations of uml_exitcode to kern_util.h. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: code tidying under arch/um/os-LinuxWANG Cong
This patch contains varied fixes and improvements for some files under arch/um/os-Linux/, such as a typo fix in a perror message, a missing argument fix for a printf, some constifying for pointers and so on. [ jdike - made sigprocmask failure return -errno instead of -1 ] Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: eliminate SIGALRMJeff Dike
Now that ITIMER_REAL is no longer used, there is no need for any use of SIGALRM whatsoever. This patch removes all mention of it. In addition, real_alarm_handler took a signal argument which is now always SIGVTALRM. So, that is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: style fixes pass 3Jeff Dike
Formatting changes in the files which have been changed in the course of folding foo_skas functions into their callers. These include: copyright updates header file trimming style fixes adding severity to printks These changes should be entirely non-functional. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove code made redundant by CHOOSE_MODE removalJeff Dike
This patch makes a number of simplifications enabled by the removal of CHOOSE_MODE. There were lots of functions that looked like int foo(args){ foo_skas(args); } The bodies of foo_skas are now folded into foo, and their declarations (and sometimes entire header files) are deleted. In addition, the union uml_pt_regs, which was a union between the tt and skas register formats, is now a struct, with the tt-mode arm of the union being removed. It turns out that usr2_handler was unused, so it is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: throw out CHOOSE_MODEJeff Dike
The next stage after removing code which depends on CONFIG_MODE_TT is removing the CHOOSE_MODE abstraction, which provided both compile-time and run-time branching to either tt-mode or skas-mode code. This patch removes choose-mode.h and all inclusions of it, and replaces all CHOOSE_MODE invocations with the skas branch. This leaves a number of trivial functions which will be dealt with in a later patch. There are some changes in the uaccess and tls support which go somewhat beyond this and eliminate some of the now-redundant functions. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: throw out CONFIG_MODE_TTJeff Dike
This patchset throws out tt mode, which has been non-functional for a while. This is done in phases, interspersed with code cleanups on the affected files. The removal is done as follows: remove all code, config options, and files which depend on CONFIG_MODE_TT get rid of the CHOOSE_MODE macro, which decided whether to call tt-mode or skas-mode code, and replace invocations with their skas portions replace all now-trivial procedures with their skas equivalents There are now a bunch of now-redundant pieces of data structures, including mode-specific pieces of the thread structure, pt_regs, and mm_context. These are all replaced with their skas-specific contents. As part of the ongoing style compliance project, I made a style pass over all files that were changed. There are three such patches, one for each phase, covering the files affected by that phase but no later ones. I noticed that we weren't freeing the LDT state associated with a process when it exited, so that's fixed in one of the later patches. The last patch is a tidying patch which I've had for a while, but which caused inexplicable crashes under tt mode. Since that is no longer a problem, this can now go in. This patch: Start getting rid of tt mode support. This patch throws out CONFIG_MODE_TT and all config options, code, and files which depend on it. CONFIG_MODE_SKAS is gone and everything that depends on it is included unconditionally. The few changed lines are in re-written Kconfig help, lines which needed something skas-related removed from them, and a few more which weren't strictly deletions. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: stop using libc asm/page.hJeff Dike
Remove includes of asm/page.h from libc code. This header seems to be disappearing, and UML doesn't make much use of it anyway. The one use, PAGE_SHIFT in stub.h, is handled by copying the constant from the kernel side of the house in common_offsets.h. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16uml: Eliminate kernel allocator wrappersJeff Dike
UML had two wrapper procedures for kmalloc, um_kmalloc and um_kmalloc_atomic because the flag constants weren't available in userspace code. kern_constants.h had made kernel constants available for a long time, so there is no need for these wrappers any more. Rather, userspace code calls kmalloc directly with the userspace versions of the gfp flags. kmalloc isn't a real procedure, so I had to essentially copy the inline wrapper around __kmalloc. vmalloc also had its own wrapper for no good reason. This is now gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-16uml: remove PAGE_SIZE from libc codeJeff Dike
Distros seem to be removing PAGE_SIZE from asm/page.h. So, the libc side of UML should stop using it. I replace it with UM_KERN_PAGE_SIZE, which is defined to be the same as PAGE_SIZE on the kernel side of the house. I could also use getpagesize(), but it's more important that UML have the same value of PAGE_SIZE everywhere. It's conceivable that it could be built with a larger PAGE_SIZE, and use of getpagesize() would break that badly. PAGE_MASK got the same treatment, as it is closely tied to PAGE_SIZE. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: add missing __init declarationsJeff Dike
The build started finding calls from non-init to init functions. These are just cases of init functions not being properly marked, so this patch fixes that. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove user_util.hJeff Dike
user_util.h isn't needed any more, so delete it and remove all includes of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: create as-layout.hJeff Dike
This patch moves all the the symbols defined in um_arch.c, which are mostly boundaries between different parts of the UML kernel address space, to a new header, as-layout.h. There are also a few things here which aren't really related to address space layout, but which don't really have a better place to go. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: formatting fixesJeff Dike
Formatting fixes - style violations whitespace breakage emacs formatting comment removal Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: delete unused codeJeff Dike
Get rid of a bunch of unused stuff - cpu_feature had no users linux_prog is little-used, so its declaration is moved to the user for easy deletion when the whole file goes away a long-unused debugging aid in helper.c is gone Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] uml: split memory allocation prototypes out of user.hPaolo 'Blaisorblade' Giarrusso
user.h is too generic a header name. I've split out allocation routines from it. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Move signal handlers to arch codeJeff Dike
Have most signals go through an arch-provided handler which recovers the sigcontext and then calls a generic handler. This replaces the ARCH_GET_SIGCONTEXT macro, which was somewhat fragile. On x86_64, recovering %rdx (which holds the sigcontext pointer) must be the first thing that happens. sig_handler duly invokes that first, but there is no guarantee that I can see that instructions won't be reordered such that %rdx is used before that. Having the arch provide the handler seems much more robust. Some signals in some parts of UML require their own handlers - these places don't call set_handler any more. They call sigaction or signal themselves. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-05[PATCH] uml: fix a typo in do_uml_initcallsJeff Dike
From: Jeff Dike <jdike@addtoit.com> We had a spurious semicolon somehow. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] uml: search from uml_net in a more reasonable PATHMattia Dongili
Append /usr/lib/uml to the existing PATH environment variable to let execvp() search uml_net in FHS compliant locations. Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: implement soft interruptsJeff Dike
This patch implements soft interrupts. Interrupt enabling and disabling no longer map to sigprocmask. Rather, a flag is set indicating whether interrupts may be handled. If a signal comes in and interrupts are marked as OK, then it is handled normally. If interrupts are marked as off, then the signal handler simply returns after noting that a signal needs handling. When interrupts are enabled later on, this pending signals flag is checked, and the IRQ handlers are called at that point. The point of this is to reduce the cost of local_irq_save et al, since they are very much more common than the signals that they are enabling and disabling. Soft interrupts produce a speed-up of ~25% on a kernel build. Subtleties - UML uses sigsetjmp/siglongjmp to switch contexts. sigsetjmp has been wrapped in a save_flags-like macro which remembers the interrupt state at setjmp time, and restores it when it is longjmp-ed back to. The enable_signals function has to loop because the IRQ handler disables interrupts before returning. enable_signals has to return with signals enabled, and signals may come in between the disabling and the return to enable_signals. So, it loops for as long as there are pending signals, ensuring that signals are enabled when it finally returns, and that there are no pending signals that need to be dealt with. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: move libc-dependent time codeGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from time.c file under os-Linux dir and joins time.c and tine_kernel.c files Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] uml: move libc-dependent code from signal_user.cGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from signal_user.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] uml: separate libc-dependent early initializationJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from main.c file under os-Linux dir and joins mem.c and um_arch.c files. Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
