path: root/arch/um/os-Linux/skas/process.c
2008-07-24UML: make several more things staticWANG Cong
- Make some variables and functions static, since they don't need to be global. - Remove an unused function - arch/um/kernel/time.c::sched_clock(). - Clean the style a bit as complained by checkpatch.pl. Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: WANG Cong <wangcong@zeuux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06uml: stub needs to tolerate SIGWINCHJeff Dike
We lost the marking of SIGWINCH as being OK to receive during stub execution, causing a panic should that happen. Cc: Benedict Verheyen <benedict.verheyen@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: style fixesJeff Dike
A few random style fixes. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23uml: fix FP register corruptionJeff Dike
Commit ee3d9bd4de1ed93d2a7ee41c331ed30a1c7b8acd ("uml: simplify SIGSEGV handling"), while greatly simplifying the kernel SIGSEGV handler that runs in the process address space, introduced a bug which corrupts FP state in the process. Previously, the SIGSEGV handler called the sigreturn system call by hand - it couldn't return through the restorer provided to it because that could try to call the libc restorer which likely wouldn't exist in the process address space. So, it blocked off some signals, including SIGUSR1, on entry to the SIGSEGV handler, queued a SIGUSR1 to itself, and invoked sigreturn. The SIGUSR1 was delivered, and was visible to the UML kernel after sigreturn finished. The commit eliminated the signal masking and the call to sigreturn. The handler simply hits itself with a SIGTRAP to let the UML kernel know that it is finished. UML then restores the process registers, which effectively longjmps the process out of the signal handler, skipping sigreturn's restoring of register state and the signal mask. The bug is that the host apparently sets used_fp to 0 when it saves the process FP state in the sigcontext on the process signal stack. Thus, when the process is longjmped out of the handler, its FP state is corrupt because it wasn't saved on the context switch to the UML kernel. This manifested itself as sleep hanging. For some reason, sleep uses floating point in order to calculate the sleep interval. When a page fault corrupts its FP state, it is faked into essentially sleeping forever. This patch saves the FP state before entering the SIGSEGV handler and restores it afterwards. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08uml: style fixes in arch/um/os-LinuxJeff Dike
Style changes under arch/um/os-Linux: include trimming CodingStyle fixes some printks needed severity indicators make_tempfile turns out not to be used outside of mem.c, so it is now static. Its declaration in tempfile.h is no longer needed, and tempfile.h itself is no longer needed. create_tmp_file was also made static. checkpatch moans about an EXPORT_SYMBOL in user_syms.c which is part of a macro definition - this is copying a bit of kernel infrastructure into the libc side of UML because the kernel headers can't be included there. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: add newlines to printksJeff Dike
Some printks were missing newlines. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: don't allow processes to call into stubJeff Dike
Kill a process that tries to branch into a stub and execute a system call. There are no security implications here - a system call in a stub is treated the same as a system call anywhere else. But if a process is trying to branch into a stub, either it is trying something nasty or it has gone haywire, so it's a good idea to get rid of it in either case. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: kill processes instead of panicing kernelJeff Dike
UML was panicing in the case of failures of libc calls which shouldn't happen. This is an overreaction since a failure from libc doesn't normally mean that kernel data structures are in an unknown state. Instead, the current process should just be killed if there is no way to recover. The case that prompted this was a failure of PTRACE_SETREGS restoring the same state that was read by PTRACE_GETREGS. It appears that when a process tries to load a bogus value into a segment register, it segfaults (as expected) and the value is actually loaded and is seen by PTRACE_GETREGS (not expected). This case is fixed by forcing a fatal SIGSEGV on the process so that it immediately dies. fatal_sigsegv was added for this purpose. It was declared as noreturn, so in order to pursuade gcc that it actually does not return, I added a call to os_dump_core (and declared it noreturn) so that I get a core file if somehow the process survives. All other calls in arch/um/os-Linux/skas/process.c got the same treatment, with failures causing the process to die instead of a kernel panic, with some exceptions. userspace_tramp exits with status 1 if anything goes wrong there. That will cause start_userspace to return an error. copy_context_skas0 and map_stub_pages also now return errors instead of panicing. Callers of thes functions were changed to check for errors and do something appropriate. Usually that's to return an error to their callers. check_skas3_ptrace_faultinfo just exits since that's too early to do anything else. save_registers, restore_registers, and init_registers now return status instead of panicing on failure, with their callers doing something appropriate. There were also duplicate declarations of save_registers and restore_registers in os.h - these are gone. I noticed and fixed up some whitespace damage. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: use ptrace directly in libc codeJeff Dike
Some register accessor cleanups - userspace() was calling restore_registers and save_registers for no reason, since userspace() is on the libc side of the house, and these add no value over calling ptrace directly init_thread_registers and get_safe_registers were the same thing, so init_thread_registers is gone Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: simplify SIGSEGV handlingJeff Dike
Simplify the page fault stub by not masking signals while it is running. This allows it to signal that it is done by executing an instruction which will generate a SIGTRAP (int3 on x86) rather than running sigreturn by hand after queueing a blocked SIGUSR1. userspace_tramp now no longer puts anything in the SIGSEGV sa_mask, but it does add SA_NODEFER to sa_flags so that SIGSEGV is still enabled after the signal handler fails to run sigreturn. SIGWINCH is just blocked so that we don't have to deal with it and the signal masks used by wait_stub_done are updated to reflect the smaller number of signals that it has to worry about. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: tidy kern_util.hJeff Dike
Tidy kern_util.h. It turns out that most of the function declarations aren't used, so they can go away. os.h no longer includes kern_util.h, so files which got it through os.h now need to include it directly. A number of other files never needed it, so these includes are deleted. The structure which was used to pass signal handlers from the kernel side to the userspace side is gone. Instead, the handlers are declared here, and used directly from libc code. This allows arch/um/os-Linux/trap.c to be deleted, with its remnants being moved to arch/um/os-Linux/skas/trap.c. arch/um/os-Linux/tty.c had its inclusions changed, and it needed some style attention, so it got tidied. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17uml: stop gdb from deleting breakpoints when running UMLStanislaw Gruszka
Sometimes when UML is debugged gdb miss breakpoints. When process traced by gdb do fork, debugger remove breakpoints from child address space. There is possibility to trace more than one fork, but this not work with UML, I guess (only guess) there is a deadlock - gdb waits for UML and UML waits for gdb. When clone() is called with SIGCHLD and CLONE_VM flags, gdb see this as PTRACE_EVENT_FORK not as PTRACE_EVENT_CLONE and remove breakpoints from child and at the same time from traced process, because either have the same address space. Maybe it is possible to do fix in gdb, but I'm not sure if there is easy way to find out if traced and child processes share memory. So I do fix for UML, it simply do not call clone() with both SIGCHLD and CLONE_VM flags together. Additionally __WALL flag is used for waitpid() to assure not miss clone and normal process events. [ jdike - checkpatch fixes ] Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: definitively kill subprocesses on panicLepton Wu
In a stock 2.6.22.6 kernel, poweroff a user mode linux guest (2.6.22.6 running in skas0 mode) will halt the host linux. I think the reason is the kernel thread abort because of a bug. Then the sys_reboot in process of user mode linux guest is not trapped by the user mode linux kernel and is executed by host. I think it is better to make sure all of our children process to quit when user mode linux kernel abort. [ jdike - the kernel process needs to ignore SIGTERM, plus the waitpid/kill loop is needed to make sure that all of our children are dead before the kernel exits ] Signed-off-by: Lepton Wu <ytht.net@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: fix stub address calculationsJeff Dike
The calculation of CONFIG_STUB_CODE and CONFIG_STUB_DATA didn't take into account anything but 3G/1G and 2G/2G, leaving the other vmsplits out in the cold. I'd rather not duplicate the four known host vmsplit cases for each of these symbols. I'd also like to calculate them based on the highest userspace address. The Kconfig language seems not to allow calculation of hex constants, so I moved this to as-layout.h. CONFIG_STUB_CODE, CONFIG_STUB_DATA, and CONFIG_STUB_START are now gone. In their place are STUB_CODE, STUB_DATA, and STUB_START in as-layout.h. i386 and x86_64 seem to differ as to whether an unadorned constant is an int or a long, so I cast them to unsigned long so they can be printed consistently. However, they are also used in stub.S, where C types don't work so well. So, there are ASM_ versions of these constants for use in stub.S. I also ifdef-ed the non-asm-friendly portion of as-layout.h. With this in place, most of the rest of this patch is changing CONFIG_STUB_* to STUB_*, except in stub.S, where they are changed to ASM_STUB_*. defconfig has the old symbols deleted. I also print these addresses out in case there is any problem mapping them on the host. The two stub.S files had some trailing whitespace, so that is cleaned up here. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: use *SEC_PER_*SEC constantsJeff Dike
There are various uses of powers of 1000, plus the odd BILLION constant in the time code. However, there are perfectly good definitions of *SEC_PER_*SEC in linux/time.h which can be used instaed. These are replaced directly in kernel code. Userspace code imports those constants as UM_*SEC_PER_*SEC and uses these. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: eliminate SIGALRMJeff Dike
Now that ITIMER_REAL is no longer used, there is no need for any use of SIGALRM whatsoever. This patch removes all mention of it. In addition, real_alarm_handler took a signal argument which is now always SIGVTALRM. So, that is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: tickless supportJeff Dike
Enable tickless support. CONFIG_TICK_ONESHOT and CONFIG_NO_HZ are enabled. itimer_clockevent gets CLOCK_EVT_FEAT_ONESHOT and an implementation of .set_next_event. CONFIG_UML_REAL_TIME_CLOCK goes away because it only makes sense when there is a clock ticking away all the time. timer_handler now just calls do_IRQ once without trying to figure out how many ticks to emulate. The idle loop now needs to turn ticking on and off. Userspace ticks keep happening as usual. However, the userspace loop keep track of when the next wakeup should happen and suppresses process ticks until that happens. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: simplify interval settingJeff Dike
set_interval took a timer type as an argument, but it always specified a virtual timer. So, it is not needed, and it is gone, and set_interval is simplified appropriately. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: eliminate hz()Jeff Dike
Eliminate hz() since its only purpose was to provide a kernel-space constant to userspace code. This can be done instead by providing the constant directly through kernel_constants.h. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: userspace files should call libc directlyJeff Dike
A number of files that were changed in the recent removal of tt mode are userspace files which call the os_* wrappers instead of calling libc directly. A few other files were affected by this, through This patch makes these call glibc directly. There are also style fixes in the affected areas. os_print_error has no remaining callers, so it is deleted. There is a interface change to os_set_exec_close, eliminating a parameter which was always the same. The callers are fixed as well. os_process_pc got its error path cleaned up. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: rename pt_regs general-purpose register fileJeff Dike
Before the removal of tt mode, access to a register on the skas-mode side of a pt_regs struct looked like pt_regs.regs.skas.regs.regs[FOO]. This was bad enough, but it became pt_regs.regs.regs.regs[FOO] with the removal of the union from the middle. To get rid of the run of three "regs", the last field is renamed to "gp". Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove __u64 usage from physical memory subsystemJeff Dike
Eliminate some uses of __u64 in the physical memory support. It's hard to get a definition of __u64 in both kernel and userspace code on x86_64, so this changes them to unsigned long long. There are also a copyright update and formatting comment removal from the affected header. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: style fixes pass 3Jeff Dike
Formatting changes in the files which have been changed in the course of folding foo_skas functions into their callers. These include: copyright updates header file trimming style fixes adding severity to printks These changes should be entirely non-functional. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove code made redundant by CHOOSE_MODE removalJeff Dike
This patch makes a number of simplifications enabled by the removal of CHOOSE_MODE. There were lots of functions that looked like int foo(args){ foo_skas(args); } The bodies of foo_skas are now folded into foo, and their declarations (and sometimes entire header files) are deleted. In addition, the union uml_pt_regs, which was a union between the tt and skas register formats, is now a struct, with the tt-mode arm of the union being removed. It turns out that usr2_handler was unused, so it is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: stop saving process FP stateJeff Dike
Throw out a lot of code dealing with saving and restoring floating-point state. In skas mode, where processes run in a restoring floating-point state on kernel entry and exit is pointless. This eliminates most of arch/um/os-Linux/sys-{i386,x86_64}/registers.c. Most of what remained is now arch-indpendent, and can be moved up to arch/um/os-Linux/registers.c. Both arches need the jmp_buf accessor get_thread_reg, and i386 needs {save,restore}_fp_regs because it cheats during sigreturn by getting the fp state using ptrace rather than copying it out of the process sigcontext. After this, it turns out that arch/um/include/skas/mode-skas.h is almost completely unneeded. The declarations in it are variables which either don't exist or which don't have global scope. The one exception is kill_off_processes_skas. If that's removed, this header can be deleted. This uncovered a bug in user.h, which wasn't correctly making sure that a size_t definition was available to both userspace and kernelspace files. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16uml: SIGIO support cleanupJeff Dike
Cleanup of the SIGWINCH support. Some code and comment reformatting. The stack used for SIGWINCH threads was leaked. This is now fixed by storing it with the pid and other information, and freeing it when the thread is killed. If something goes wrong with a WIGWINCH thread, and this is discovered in the interrupt handler, the winch record would leak. It is now freed, except that the IRQ isn't freed. This is hard to do from interrupt context. This has the side-effect that the IRQ system maintains a reference to the freed structure, but that shouldn't cause a problem since the descriptor is disabled. register_winch_irq is now much better about cleaning up after an initialization failure. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-16uml: remove PAGE_SIZE from libc codeJeff Dike
Distros seem to be removing PAGE_SIZE from asm/page.h. So, the libc side of UML should stop using it. I replace it with UM_KERN_PAGE_SIZE, which is defined to be the same as PAGE_SIZE on the kernel side of the house. I could also use getpagesize(), but it's more important that UML have the same value of PAGE_SIZE everywhere. It's conceivable that it could be built with a larger PAGE_SIZE, and use of getpagesize() would break that badly. PAGE_MASK got the same treatment, as it is closely tied to PAGE_SIZE. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11uml: tidy IRQ codeJeff Dike
Some tidying of the irq code before introducing irq stacks. Mostly style fixes, but the timer handler calls the timer code directly rather than going through the generic sig_handler_common_skas. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11uml: use UM_THREAD_SIZE in userspace codeJeff Dike
Now that we have UM_THREAD_SIZE, we can replace the calculations in user-space code (an earlier patch took care of the kernel side of the house). Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09uml: turn build warnings into commentsMiklos Szeredi
These haven't been fixed for ages. Just make comments out of them. arch/um/kernel/skas/process.c:181:2: warning: #warning Need to look up +userspace_pid by cpu arch/um/kernel/skas/process.c:187:2: warning: #warning Need to look up +userspace_pid by cpu arch/um/kernel/skas/process.c:194:2: warning: #warning need to loop over +userspace_pids in kill_off_processes_skas Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: more page fault path trimmingJeff Dike
More trimming of the page fault path. Permissions are passed around in a single int rather than one bit per int. The permission values are copied from libc so that they can be passed to mmap and mprotect without any further conversion. The register sets used by do_syscall_stub and copy_context_skas0 are initialized once, at boot time, rather than once per call. wait_stub_done checks whether it is getting the signals it expects by comparing the wait status to a mask containing bits for the signals of interest rather than comparing individually to the signal numbers. It also has one check for a wait failure instead of two. The caller is expected to do the initial continue of the stub. This gets rid of an argument and some logic. The fname argument is gone, as that can be had from a stack trace. user_signal() is collapsed into userspace() as it is basically one or two lines of code afterwards. The physical memory remapping stuff is gone, as it is unused. flush_tlb_page is inlined. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: don't try to handle signals on initial process stackJeff Dike
Code running on the initial UML stack can't receive or process signals since current must be valid when IRQs are handled, and there is no current for this stack. So, instead of using UML_LONGJMP and UML_SETJMP, which are careful to save and restore signal state, and, as a side-effect, handle any deferred signals, start_idle_thread must use the bare equivalents, which don't do anything with signals. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: convert libc layer to call read and writeJeff Dike
This patch converts calls in the os layer to os_{read,write}_file to calls directly to libc read() and write() where it is clear that the I/O buffer is in the kernel. We can do that here instead of calling os_{read,write}_file_k since we are in libc code and can call libc directly. With the change in the calls, error handling needs to be changed to refer to errno directly rather than the return value of the call. CATCH_EINTR wrappers were also added where needed. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: tidy libc codeJeff Dike
This patch lays some groundwork for the next one, which converts calls to os_{read,write}_file into {read,write}, by doing some tidying in the affected areas. do_not_aio gets restructured to make the final result a bit cleaner. There are also whitespace and other formatting fixes, fixes in error messages, and a typo fix. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: dump registers on ptrace or wait failureJeff Dike
Provide a register dump if handle_trap fails. Abstract out ptrace_dump_regs since it now has two callers. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove page_size()Jeff Dike
userspace code used to have to call the kernelspace function page_size() in order to determine the value of the kernel's PAGE_SIZE. Since this is now available directly from kern_constants.h as UM_KERN_PAGE_SIZE, page_size() can be deleted and calls changed to use the constant. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove user_util.hJeff Dike
user_util.h isn't needed any more, so delete it and remove all includes of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-27[PATCH] uml: use correct register file size everywhereJeff Dike
This patch uses MAX_REG_NR consistently to refer to the register file size. FRAME_SIZE isn't sufficient because on x86_64, it is smaller than the ptrace register file size. MAX_REG_NR was introduced as a consistent way to get the number of registers, but wasn't used everywhere it should be. When this causes a problem, it makes PTRACE_SETREGS fail on x86_64 because of a corrupted segment register value in the known-good register file. The patch also adds a register dump at that point in case there are any future problems here. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06[PATCH] uml: add a debugging messageJeff Dike
Add a debugging message in the case that mapping a stub fails. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-03[PATCH] uml: include tidyingJeff Dike
In order to get the __NR_* constants, we need sys/syscall.h. linux/unistd.h works as well since it includes syscall.h, however syscall.h is more parsimonious. We were inconsistent in this, and this patch adds syscall.h includes where necessary and removes linux/unistd.h includes where they are not needed. asm/unistd.h also includes the __NR_* constants, but these are not the glibc-sanctioned ones, so this also removes one such inclusion. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: thread creation tidyingJeff Dike
fork on UML has always somewhat subtle. The underlying cause has been the need to initialize a stack for the new process. The only portable way to initialize a new stack is to set it as the alternate signal stack and take a signal. The signal handler does whatever initialization is needed and jumps back to the original stack, where the fork processing is finished. The basic context switching mechanism is a jmp_buf for each process. You switch to a new process by longjmping to its jmp_buf. Now that UML has its own implementation of setjmp and longjmp, and I can poke around inside a jmp_buf without fear that libc will change the structure, a much simpler mechanism is possible. The jmpbuf can simply be initialized by hand. This eliminates - the need to set up and remove the alternate signal stack sending and handling a signal the signal blocking needed around the stack switching, since there is no stack switching setting up the jmp_buf needed to jump back to the original stack after the new one is set up In addition, since jmp_buf is now defined by UML, and not by libc, it can be embedded in the thread struct. This makes it unnecessary to have it exist on the stack, where it used to be. It also simplifies interfaces, since the switch jmp_buf used to be a void * inside the thread struct, and functions which took it as an argument needed to define a jmp_buf variable and assign it from the void *. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: timer cleanupsJeff Dike
set_interval returns an error instead of panicing if setitimer fails. Some of its callers now check the return. enable_timer is largely tt-mode-specific, so it is marked as such, and the only skas-mode caller is made to call set-interval instead. user_time_init was a no-value-added wrapper around set_interval, so it is gone. Since set_interval is now called from kernel code, callers no longer pass ITIMER_* to it. Instead, they pass a flag which is converted into ITIMER_REAL or ITIMER_VIRTUAL. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Move signal handlers to arch codeJeff Dike
Have most signals go through an arch-provided handler which recovers the sigcontext and then calls a generic handler. This replaces the ARCH_GET_SIGCONTEXT macro, which was somewhat fragile. On x86_64, recovering %rdx (which holds the sigcontext pointer) must be the first thing that happens. sig_handler duly invokes that first, but there is no guarantee that I can see that instructions won't be reordered such that %rdx is used before that. Having the arch provide the handler seems much more robust. Some signals in some parts of UML require their own handlers - these places don't call set_handler any more. They call sigaction or signal themselves. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Use klibc setjmp/longjmpJeff Dike
This patch adds an implementation of setjmp and longjmp to UML, allowing access to the inside of a jmpbuf without needing the access macros formerly provided by libc. The implementation is stolen from klibc. I copy the relevant files into arch/um. I have another patch which avoids the copying, but requires klibc be in the tree. setjmp and longjmp users required some tweaking. Includes of <setjmp.h> were removed and includes of the UML longjmp.h were added where necessary. There are also replacements of siglongjmp with UML_LONGJMP which I somehow missed earlier. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] uml: tidy longjmp macroJeff Dike
The UML_SETJMP macro was requiring its users to pass in a argument which it could supply itself, since it wasn't used outside that invocation of the macro. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: signal initialization cleanupJeff Dike
It turns out that init_new_thread_signals is always called with altstack == 1, so we can eliminate the parameter. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] uml: error handling fixesJeff Dike
Blairsorblade noticed some confusion between our use of a system call's return value and errno. This patch fixes a number of related bugs - using errno instead of a return value using a return value instead of errno forgetting to negate a error return to get a positive error code Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] uml: change sigjmp_buf to jmp_bufJeff Dike
Clean up the jmpbuf code. Since softints, we no longer use sig_setjmp, so the UML_SIGSETJMP wrapper now has a misleading name. Also, I forgot to change the buffers from sigjmp_buf to jmp_buf. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] uml: fix format errorsPaolo 'Blaisorblade' Giarrusso
Now that GCC warns about format errors, fix them. Nothing able to cause a crash, however. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] uml: initialize process FP registers properlyJeff Dike
We weren't making sure that we initialized the FP registers of new processes to sane values. This patch also moves some defines in the affected area closer to where they are used. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
