Some time ago Jeff prepared 42daba316557 ("uml: stop saving process FP
state") for UML to stop saving the process FP state between task
switches. The assumption was that since with SKAS0 every guest process
runs inside a host process context the host OS will take care of keeping
the proper FP state.
Unfortunately this is not true for multi-threaded applications, where
all guest threads share a single host process context yet all may use
the FPU on their own. Although I haven't verified it I suspect things
to be even worse in SKAS3 mode where all guest processes run inside a
single host process.
The patch reintroduces the saving and restoring of the FP context
between task switches.
[richard@nod.at: Ingo posted this patch in 2009, sadly it was never applied
and got lost. Now in 2011 the problem was reported by Gunnar.]
Signed-off-by: Ingo van Lil <inguin@gmx.de>
Signed-off-by: Richard Weinberger <richard@nod.at>
Reported-by: <gunnarlindroth@hotmail.com>
Tested-by: <gunnarlindroth@hotmail.com>
Cc: Stanislav Meduna <stano@meduna.org>
Reusing the host's vDSO makes only sense on x86_32.
When creating the temp file there's a memory and file descriptor leak upon
error.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
Reviewed-by: Vitaliy Ivanov <vitalivanov@gmail.com>
Fix this warning:
arch/um/os-Linux/helper.c: In function `helper_child':
arch/um/os-Linux/helper.c:38:7: warning: ignoring return value of `write', declared with attribute warn_unused_result
[richard@nod.at: happens only with -D_FORTIFY_SOURCE=2]
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
When UML is compiled with _FORTIFY_SOURCE we have to export all _chk()
functions which are used in modules. For now it's only the case for
__sprintf_chk().
Tested-by: Florian Fainelli <florian@openwrt.org>
Reported-by: Florian Fainelli <florian@openwrt.org>
Acked-by: Vitaliy Ivanov <vitalivanov@gmail.com>
os_dump_core() emits SIGTERM to terminate all UML processes. Kernel
threads have to exit on SIGTERM instead of calling last_ditch_exit().
Multiple calls to last_ditch_exit() can cause a crash.
User Mode Linux can also benefit from earlyprintk. UML's earlyprintk
writes kernel messages directly to stdout.
The UML kernel ignores SIGHUP anyway. This handler is in vain.
UML_LIB_PATH is hardcoded to /usr/lib/uml/, on 64bit systems UML_LIB_PATH
needs to be /usr/lib64/uml/.
os_dump_core() uses abort() to terminate UML in case of an fatal error.
glibc's abort() calls raise(SIGABRT) which makes use of tgkill().
tgkill() has no effect within UML's kernel threads because they are not
pthreads. As fallback abort() executes an invalid instruction to
terminate the process. Therefore UML gets killed by SIGSEGV and leaves a
ugly log entry in the host's kernel ring buffer.
To get rid of this we use our own abort routine.
This fixes a issue which was introduced by fe2cc53e ("uml: track and make
up lost ticks").
timeval_to_ns() returns long long and not int. Due to that UML's timer
did not work properlt and caused timer freezes.
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: <stable@kernel.org>
The os-linux/mem.c file calls fchmod function, which is declared in sys/stat.h
header file, so include it. Fixes build breakage under FC13.
Signed-off-by: Liu Aleaxander <Aleaxander@gmail.com>
Acked-by: Boaz Harrosh <bharrosh@panasas.com>
We now have to to include linux/slab.h explicitly for kmalloc &
friends. Files that build against host headers already get their
prototypes via um_malloc.h, linux/slab.h may even be unavailable.
Signed-off-by: Jan Kiszka <jan.kiszka@web.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
fix the following 'make includecheck' warning:
arch/um/os-Linux/helper.c: linux/limits.h is included more than once.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Cc: jdike@addtoit.com
LKML-Reference: <1247064950.4382.45.camel@ht.satnam>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
These error messages are from check_sysemu(), not check_ptrace().
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Fix the following warning on x86_64:
LD vmlinux.o
MODPOST vmlinux.o
WARNING: vmlinux: 'memcpy' exported twice. Previous export was in vmlinux
For x86_64, this symbol is already exported from arch/um/sys-x86_64/ksyms.c.
Reported-by: Boaz Harrosh <bharrosh@panasas.com>
Tested-by: Boaz Harrosh <bharrosh@panasas.com>
Simply replace netdev->priv with netdev_priv().
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
we can get DEV_NULL defined for arch/um/drivers/null.c in less
convoluted ways, TYVM...
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Remove the dead CONFIG_TTY_LOG (no kconfig option).
Reported-by: Robert P. J. Day <rpjday@crashcourse.ca>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
- Make some variables and functions static, since they don't need to be
global.
- Remove an unused function - arch/um/kernel/time.c::sched_clock().
- Clean the style a bit as complained by checkpatch.pl.
Signed-off-by: WANG Cong <wangcong@zeuux.org>
Fedora broke PTRACE_SYSEMU again, and UML crashes as a result when it
doesn't need to. This patch makes the PTRACE_SYSEMU check fail gracefully
and makes UML fall back to PTRACE_SYSCALL.
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
I allowed an include of asm/user.h to sneak back in. This patch replaces
it with sys/user.h.
Include limits.h to get a definition of PATH_MAX.
We lost the marking of SIGWINCH as being OK to receive during stub
execution, causing a panic should that happen.
Cc: Benedict Verheyen <benedict.verheyen@gmail.com>
This patch makes os_get_task_size locate the bottom of the address space,
as well as the top. This is for systems which put a lower limit on mmap
addresses. It works by manually scanning pages from zero onwards until a
valid page is found.
Because the bottom of the address space may not be zero, it's not
sufficient to assume the top of the address space is the size of the
address space. The size is the difference between the top address and
bottom address.
[jdike@addtoit.com: changed the name to reflect that this function is
supposed to return the top of the process address space, not its size and
changed the return value to reflect that. Also some minor formatting
changes]
Signed-off-by: Tom Spink <tspink@gmail.com>
Protection against the host's time going backwards (eg, ntp activity on
the host) by keeping track of the time at the last tick and if it's
greater than the current time, keep time stopped until the host catches
up.
Cc: Nix <nix@esperi.org.uk>
We want sys/ptrace.h before any includes of linux/ptrace.h and
asm/user.h pulls the latter.
Acked-by: Jeff Dike <jdike@addtoit.com>
Alarm delivery could be noticably late in the !CONFIG_NOHZ case because lost
ticks weren't being taken into account. This is now treated more carefully,
with the time between ticks being calculated and the appropriate number of
ticks delivered to the timekeeping system.
The random driver would essentially hang if the host's /dev/random returned
-EAGAIN. There was a test of need_resched followed by a schedule inside the
loop, but that didn't help and it's the wrong way to work anyway.
The right way is to ask for an interrupt when there is input available from
the host and handle it then rather than polling.
Now, when the host's /dev/random returns -EAGAIN, the driver asks for a wakeup
when there's randomness available again and sleeps. The interrupt routine
just wakes up whatever processes are sleeping on host_read_wait.
There is an atomic_t, host_sleep_count, which counts the number of processes
waiting for randomness. When this reaches zero, the interrupt is disabled.
An added complication is that async I/O notification was only recently added
to /dev/random (by me), so essentially all hosts will lack it. So, we use the
sigio workaround here, which is to have a separate thread poll on the
descriptor and send an interrupt when there is input on it. This mechanism is
activated when a process gets -EAGAIN (activating this multiple times is
harmless, if a bit wasteful) and deactivated by the last process still
waiting.
The module name was changed from "random" to "hw_random" in order for udev to
recognize it.
The sigio workaround needed some changes. sigio_broken was added for cases
when we know that async notification doesn't work. This is now called from
maybe_sigio_broken, which deals with pts devices.
Reintroduce uml_kmalloc for the benefit of UML libc code. The
previous tactic of declaring __kmalloc so it could be called directly
from the libc side of the house turned out to be getting too intimate
with slab, and it doesn't work with slob.
So, the uml_kmalloc wrapper is back. It calls kmalloc or whatever
that translates into, and libc code calls it.
kfree is left alone since that still works, leaving a somewhat
inconsistent API.
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Tidy the ptrace interface code. Removed a bunch of unused macros.
Started converting register sets from arrays of longs to structures.
A few random style fixes.
Redo how host capabilities are recorded at startup and disabled on the
command line.
There are now explicit variables saying what's been disabled by the
command line rather than the implicitness of the have_* variable being
zero. The capability variables now start at zero and are set to one
as their capabilities are found to be present on the host.
Improve this code a bit: check sigaction's return value and remove a useless
fflush().
- lets ptrace_child become void
- adds checking for the return value of change_sig
- moves errors info into stderr instead of stdout.
fix:
arch/um/os-Linux/helper.c: In function 'run_helper':
arch/um/os-Linux/helper.c:73: error: 'PATH_MAX' undeclared (first use in this function)
Commit ee3d9bd4de1ed93d2a7ee41c331ed30a1c7b8acd ("uml: simplify SIGSEGV
handling"), while greatly simplifying the kernel SIGSEGV handler that
runs in the process address space, introduced a bug which corrupts FP
state in the process.
Previously, the SIGSEGV handler called the sigreturn system call by hand - it
couldn't return through the restorer provided to it because that could try to
call the libc restorer which likely wouldn't exist in the process address
space. So, it blocked off some signals, including SIGUSR1, on entry to the
SIGSEGV handler, queued a SIGUSR1 to itself, and invoked sigreturn. The
SIGUSR1 was delivered, and was visible to the UML kernel after sigreturn
finished.
The commit eliminated the signal masking and the call to sigreturn. The
handler simply hits itself with a SIGTRAP to let the UML kernel know that it
is finished. UML then restores the process registers, which effectively
longjmps the process out of the signal handler, skipping sigreturn's restoring
of register state and the signal mask.
The bug is that the host apparently sets used_fp to 0 when it saves the
process FP state in the sigcontext on the process signal stack. Thus, when
the process is longjmped out of the handler, its FP state is corrupt because
it wasn't saved on the context switch to the UML kernel.
This manifested itself as sleep hanging. For some reason, sleep uses floating
point in order to calculate the sleep interval. When a page fault corrupts
its FP state, it is faked into essentially sleeping forever.
This patch saves the FP state before entering the SIGSEGV handler and restores
it afterwards.
* arch/um/os-Linux/mem.c (make_tempfile): Don't deref NULL upon failed malloc.
* arch/um/os-Linux/mem.c (make_tempfile): Handle NULL tempdir.
Don't let a long tempdir (e.g., via TMPDIR) provoke heap corruption.
[ jdike - formatting cleanups, deleted obsolete comment ]
Signed-off-by: Jim Meyering <meyering@redhat.com>
Style changes under arch/um/os-Linux:
include trimming
CodingStyle fixes
some printks needed severity indicators
make_tempfile turns out not to be used outside of mem.c, so it is now static.
Its declaration in tempfile.h is no longer needed, and tempfile.h itself is no
longer needed.
create_tmp_file was also made static.
checkpatch moans about an EXPORT_SYMBOL in user_syms.c which is part of a
macro definition - this is copying a bit of kernel infrastructure into the
libc side of UML because the kernel headers can't be included there.
Calculate TASK_SIZE at run-time by figuring out the host's VMSPLIT - this is
needed on i386 if UML is to run on hosts with varying VMSPLITs without
recompilation.
TASK_SIZE is now defined in terms of a variable, task_size. This gets rid of
an include of pgtable.h from processor.h, which can cause include loops.
On i386, task_size is calculated early in boot by probing the address space in
a binary search to figure out where the boundary between usable and non-usable
memory is. This tries to make sure that a page that is considered to be in
userspace is, or can be made, read-write. I'm concerned about a system-global
VDSO page in kernel memory being hit and considered to be a userspace page.
On x86_64, task_size is just the old value of CONFIG_TOP_ADDR.
A bunch of config variable are gone now. CONFIG_TOP_ADDR is directly replaced
by TASK_SIZE. NEST_LEVEL is gone since the relocation of the stubs makes it
irrelevant. All the HOST_VMSPLIT stuff is gone. All references to these in
arch/um/Makefile are also gone.
I noticed and fixed a missing extern in os.h when adding os_get_task_size.
Note: This has been revised to fix the 32-bit UML on 64-bit host bug that
Miklos ran into.
Cc: Miklos Szeredi <miklos@szeredi.hu>
Calling init_registers inside the skas3 checking causes mysterious crashes if
it doesn't happen because the skas3 checking is bypassed. This patch moves it
to os_early_checks.
Some printks were missing newlines.
The .a flags in openflags never had an implementation.
init_irq_signals doesn't need to be called from the context of a new process.
It initializes handlers, which are useless in process context. With that call
gone, init_irq_signals has only one caller, so it can be inlined into
init_new_thread_signals.
This patch tidies the signal handling code slightly.
pending is renamed to signals_pending for symmetry with signals_enabled.
remove_sigstack was unused, so can be deleted.
The value of change_sig was never used, so it is now void and the
return value is not calculated any more.
sig_handler_common_skas needs significant modernization, starting with
its name and storage class.
There is no need to hide the true type of the sigcontext pointer, so
the void * dummy parameter can be replaced with a sigcontext *sc.
The array of uml_pt_regs structs used in the page fault case are gone,
replaced by a local variable. This is also used in the non-segfault
case instead of the copy in the task_struct. Since it's local, the
special handling of the is_user flag can go away.
There hasn't been any special treatment of SIGUSR1 in ages, so the
line that enables it can be deleted.
The special treatment of SIGSEGV similarly goes away, but to
compensate, SA_NODEFER is added to sa_mask when registering a signal
handler.
This patch moves sig_handler_common_skas from
arch/um/os-Linux/skas/trap.c to its only caller in
arch/um/os-Linux/signal.c. trap.c is now empty, so it can be removed.
This is code movement only - the significant cleanup needed here is
done in the next patch.
